    328 Posts 27 Posters 727.0k Views 24 Watching
    • T Offline
      trividar @Mykle1
      @Mykle1 I will send it tomorrow and also what I have done! Thanks for your time
        Mykle1 Project Sponsor Module Developer @trividar
        @trividar
        Well, I would think you have nothing to lose by running the upgrade script again. Simply open a new terminal and copy and paste the script into the terminal and press enter.
        • T Offline
          trividar
          this is what I get:
          > cd - >/dev/null
          > date +"Upgrade ended - %a %b %e %H:%M:%S %Z %Y" >>$logfile
          > else
          > echo It appears MagicMirror has not been installed on this system
          > echo please run the installer, "raspberry.sh" first
          > fi
          Can it be because my path has the same folder name twice? /Users/s****/MagicMirror/MagicMirror
          Mykle1M S 2 Replies Last reply Reply Quote 0
            @trividar
            Hmm, perhaps. The installer may be looking for the MM installation inside /Users/s****/MagicMirror. Can you move the MagicMirror folder with the installation OUT of the containing MagicMirror folder. Rename the containing MagicMirror folder to something else and put the MagicMirror folder containing the MM installation here /Users/s****/MagicMirror and try again?
              sdetweil @trividar
              @trividar yeh, he assumes MagicMirror is THE folder where things are installed…
              • G Offline
                gonzonia
                Test runs fine…This is the result when I try to apply the log will be ```
                code_text
                No LSB modules are available.
                doing test run = false
                saving custom.css
                upgrading from version 2.9.0 to 2.10.0
                fetching latest revisions
                there were merge errors
                error: The following untracked working tree files would be overwritten by merge: 	installers/dumpactivemodules.js Please move or remove them before you merge. Aborting Updating 500147e..b595cdd
                you should examine and resolve them
                using the command git log --oneline --decorate
                500147e (grafted, HEAD -> master, tag: v2.9.0) Merge pull request #1776 from MichMich/develop
                restoring custom.css
                  sdetweil @gonzonia
                  @gonzonia yes, the upgrade script from the master github site has a bug,
                  please erase that one file
                  ~/MagicMirror/installers/dumpactivemodules.js
                  and then use the link to the script from this topic page1
                  https://forum.magicmirror.builders/topic/10859/new-update-upgrade-script-ready-for-testing?page=1
                  evroomE G 2 Replies Last reply Reply Quote 0
                  • evroomE Offline
                    evroom @sdetweil
                    Hi Sam, updating MM to 2.10.0 using your script. At the end the test run says:
                    any *-lock.json files do not need to be saved
                    do you want to save these files for later   (Y/n)?Y
                    git: 'git_user_name' is not a git command. See 'git --help'.
                    no modules found needing npm refresh
                    test run, restoring files stashed
                    The upgrade.log file does not give a clue as to what exact command was used.
                    I am not into git, so cannot give you anything more than the git version
                    pi@MagicPi:~ $ git --version
                    git version 2.11.0
                    Any ideas ?
                    Best regards,
                    E.J.
                    MagicMirror version: 2.37.0
                      sdetweil @evroom
                      @evroom great find!..
                      give it another try please…
                      git wants all operations to be tagged with the users email address and name.
                      but if you haven’t provided one, I use a temporary approach…
                      • evroomE Offline
                        evroom
                        Latest run:
                        here are 1 local files that are different than the master repo
                           css/custom.css
                        error: Your local changes to the following files would be overwritten by merge:
                        	css/custom.css
                        Please commit your changes or stash them before you merge.
                        Aborting
                        I can of course save and restore during the apply, but I do not know if this is what you want /expect.
                          sdetweil @evroom
                          @evroom said in new update/upgrade script, ready for testing:
                          css/custom.css
                          hmm… custom.css was taken out of distribution on the 2.9 release…
                          let me examine… hang on 30 mins
                            @sdetweil can u tell me what MM version you are running?
                            grep version ~/MagicMirror/package.json
                            thanks
                            • evroomE Offline
                              evroom
                              @sdetweil said in new update/upgrade script, ready for testing:
                              This MM install has
                              pi@MagicPi:~ $ grep version ~/MagicMirror/package.json
                                "version": "2.8.0",
                              Apparently I did not upgrade to 2.9.0. :-)
                              In parallel I am upgrading an 2.9.0 install (using the ‘old’ apply script). I got the same git: 'git_user_name' is not a git command.error there, but decided to do the apply anyway.
                              Currently Downloading tmp-27972-0-electron-v3.1.13-linux-armv7l.zip which takes forever for some reason (approx. 700 B/s).
                              Btw, I know it can be solved by other means, but I would like you to be able to tweak your script.
                              • G Offline
                                gonzonia @sdetweil
                                @sdetweil Thanks! I thought I’d tried that as well. Guess not. All good now!
                                  sdetweil @evroom
                                  @evroom >In parallel I am upgrading an 2.9.0 install (using the ‘old’ apply script).
                                  old? I updated the dropbox file so, it should have been fixed…
                                  the install script is now part of the base.
                                  “version”: “2.8.0”,
                                  actually the upgrade log should have said, upgrading from 2.8 to 2.10,
                                  also shown on the screen
                                  the upgrade.log is located in the MagicMirror/installers folder
                                  • evroomE Offline
                                    evroom
                                    I mean before you said “give it another try please…”.
                                    Old is always relative :-)
                                    The upgrade log did say```
                                    upgrading from version 2.8.0 to 2.10.0
                                    The upgrade that I still running says```
                                    The test run on the 2.8.0 install currently outputs this:
                                    pi@MagicPi:~ $ date; bash -c  "$(curl -sL https://www.dropbox.com/s/lxzwyzohg61sppu/upgrade-script.sh?dl=0)"
                                    Fri Jan  3 15:34:42 CET 2020
                                    the log will be /home/pi/MagicMirror/installers/upgrade.log
                                    doing test run = true
                                    saving custom.css
                                    there are 1 local files that are different than the master repo
                                       css/custom.css
                                    processing for module MMM-PublicTransportHafas please wait
                                    skipped processing for MMM-PublicTransportHafas, doing test run
                                    processing complete for module MMM-PublicTransportHafas
                                    processing for module MMM-soccer please wait
                                    skipped processing for MMM-soccer, doing test run
                                    processing complete for module MMM-soccer
                                    	css/custom.css
                                    Aborting
                                      sdetweil @evroom
                                      @evroom yeh, thats because of the test run against 2.8
                                      on apply this will be fixed…
                                        surger13 Project Sponsor
                                        i have tried the script now to upgrade MM to the new version. but nothing changes in the version.
                                        in upgrade.log are the following errors:
                                        test merge result rc='' , if empty, no conflicts
                                        executing merge, apply specified
                                        merge result rc= 1
                                         error: Ihre lokalen Änderungen in den folgenden Dateien würden durch den Merge überschrieben werden: 	css/custom.css 	package-lock.json 	vendor/package-lock.json Bitte committen oder stashen Sie Ihre Änderungen, bevor sie mergen. Abbruch Aktualisiere b508a62..b595cdd
                                          sdetweil @surger13
                                          @surger13 did u save the changed files when prompted?
                                          what version are u on? 2.8?
                                          do
                                            surger13 Project Sponsor @sdetweil
                                            pi@MagicMirrorPi:~/MagicMirror $ grep version ~/MagicMirror/package.json
                                              "version": "2.7.1",
                                            • 10
                                            • 11
                                            • 12
                                            • 16
                                            • 17
                                            • 10 / 17
