    328 Posts 27 Posters 740.6k Views 24 Watching
    • evroomE
      evroom
      Latest run:
      here are 1 local files that are different than the master repo
         css/custom.css
      do you want to save these files for later   (Y/n)?Y
      restoring custom.css
      test run, restoring files stashed
      error: Your local changes to the following files would be overwritten by merge:
      	css/custom.css
      Please commit your changes or stash them before you merge.
      Aborting
      I can of course save and restore during the apply, but I do not know if this is what you want /expect.
      MagicMirror version: 2.37.0
        sdetweil @evroom
        @evroom said in new update/upgrade script, ready for testing:
        css/custom.css
        hmm… custom.css was taken out of distribution on the 2.9 release…
        let me examine… hang on 30 mins
          @sdetweil can u tell me what MM version you are running?
          grep version ~/MagicMirror/package.json
          thanks
          • evroomE
            evroom
            @sdetweil said in new update/upgrade script, ready for testing:
            This MM install has
            pi@MagicPi:~ $ grep version ~/MagicMirror/package.json
              "version": "2.8.0",
            Apparently I did not upgrade to 2.9.0. :-)
            In parallel I am upgrading an 2.9.0 install (using the ‘old’ apply script). I got the same git: 'git_user_name' is not a git command.error there, but decided to do the apply anyway.
            Currently Downloading tmp-27972-0-electron-v3.1.13-linux-armv7l.zip which takes forever for some reason (approx. 700 B/s).
            Btw, I know it can be solved by other means, but I would like you to be able to tweak your script.
            • G
              gonzonia @sdetweil
              @sdetweil Thanks! I thought I’d tried that as well. Guess not. All good now!
                sdetweil @evroom
                @evroom >In parallel I am upgrading an 2.9.0 install (using the ‘old’ apply script).
                old? I updated the dropbox file so, it should have been fixed…
                the install script is now part of the base.
                “version”: “2.8.0”,
                actually the upgrade log should have said, upgrading from 2.8 to 2.10,
                also shown on the screen
                the upgrade.log is located in the MagicMirror/installers folder
                • evroomE
                  evroom
                  I mean before you said “give it another try please…”.
                  Old is always relative :-)
                  The upgrade log did say```
                  upgrading from version 2.8.0 to 2.10.0
                  The upgrade that I still running says```
                  upgrading from version 2.9.0 to 2.10.0
                  The test run on the 2.8.0 install currently outputs this:
                  pi@MagicPi:~ $ date; bash -c  "$(curl -sL https://www.dropbox.com/s/lxzwyzohg61sppu/upgrade-script.sh?dl=0)"
                  Fri Jan  3 15:34:42 CET 2020
                  the log will be /home/pi/MagicMirror/installers/upgrade.log
                  No LSB modules are available.
                  doing test run = true
                  saving custom.css
                  fetching latest revisions
                  there are 1 local files that are different than the master repo
                     css/custom.css
                  processing for module MMM-PublicTransportHafas please wait
                  skipped processing for MMM-PublicTransportHafas, doing test run
                  processing complete for module MMM-PublicTransportHafas
                  processing for module MMM-soccer please wait
                  skipped processing for MMM-soccer, doing test run
                  processing complete for module MMM-soccer
                  	css/custom.css
                  Aborting
                    sdetweil @evroom
                    @evroom yeh, thats because of the test run against 2.8
                    on apply this will be fixed…
                      surger13 Project Sponsor
                      i have tried the script now to upgrade MM to the new version. but nothing changes in the version.
                      in upgrade.log are the following errors:
                      test merge result rc='' , if empty, no conflicts
                      executing merge, apply specified
                      merge result rc= 1
                       error: Ihre lokalen Änderungen in den folgenden Dateien würden durch den Merge überschrieben werden: 	css/custom.css 	package-lock.json 	vendor/package-lock.json Bitte committen oder stashen Sie Ihre Änderungen, bevor sie mergen. Abbruch Aktualisiere b508a62..b595cdd
                      there were merge errors
                      you should examine and resolve them
                        sdetweil @surger13
                        @surger13 did u save the changed files when prompted?
                        what version are u on? 2.8?
                        do
                          surger13 Project Sponsor @sdetweil
                          pi@MagicMirrorPi:~/MagicMirror $ grep version ~/MagicMirror/package.json
                            "version": "2.7.1",
                            sdetweil @surger13
                            can u show me the log , ~/MagicMirror/installers/upgrade.log
                            thx
                              there was no request to save the files?!
                              I will send you the logfile by mail.
                              • evroomE
                                evroom
                                Sam, the 2.9.0 threw an error on the electron update, but then continued.
                                I am apparently on 2.10.0 now, but probably I am not running the latest electron version.
                                pi@raspberrypi:~ $ grep version ~/MagicMirror/package.json
                                  "version": "2.10.0",
                                This was the part where the error occured:
                                > electron@3.1.13 postinstall /home/pi/MagicMirror/node_modules/electron
                                > node install.js
                                Error: read ECONNRESET
                                /home/pi/MagicMirror/node_modules/electron/install.js:49
                                  throw err
                                    at TLSWrap.onStreamRead (internal/stream_base_commons.js:111:27)
                                What would be the correct command to update electron and from which directory?
                                  sdetweil @evroom
                                  yeh, the website with the file broke the download…
                                  u can try
                                  npm install electron@3.0.13
                                    sdetweil @surger13
                                    @surger13 thanks for the log…
                                    can u do
                                    echo $LC_ALL
                                    and
                                    locale | grep LANGUAGE
                                    thx
                                      both empty.
                                      pi@MagicMirrorPi:~/MagicMirror $ echo $LC_ALL
                                      pi@MagicMirrorPi:~/MagicMirror $ locale | grep LANGUAGE
                                      LANGUAGE=
                                        sdetweil @surger13
                                        @surger13 weird, but the system is in german… so the message I was looking for the output of
                                        git status, with the content of ‘modified’ in english
                                        how about the output of
                                        alias
                                          yes the language is german.
                                          pi@MagicMirrorPi:~/MagicMirror $ alias
                                          alias egrep='egrep --color=auto'
                                          alias fgrep='fgrep --color=auto'
                                          alias grep='grep --color=auto'
                                          alias ls='ls --color=auto'
                                            sdetweil @surger13
                                            @surger13 ok, how about output of
                                            locale
                                            thx…
                                            • 10
                                            • 11
                                            • 12
                                            • 16
                                            • 17
                                            • 10 / 17
