    328 Posts 27 Posters 716.6k Views 24 Watching
    • T Offline
      trividar
      this is what I get:
      > cd - >/dev/null
      > date +"Upgrade ended - %a %b %e %H:%M:%S %Z %Y" >>$logfile
      > else
      > echo It appears MagicMirror has not been installed on this system
      > echo please run the installer, "raspberry.sh" first
      > fi
      Can it be because my path has the same folder name twice? /Users/s****/MagicMirror/MagicMirror
      Mykle1M S 2 Replies Last reply Reply Quote 0
        Mykle1 Project Sponsor Module Developer @trividar
        @trividar
        Hmm, perhaps. The installer may be looking for the MM installation inside /Users/s****/MagicMirror. Can you move the MagicMirror folder with the installation OUT of the containing MagicMirror folder. Rename the containing MagicMirror folder to something else and put the MagicMirror folder containing the MM installation here /Users/s****/MagicMirror and try again?
          sdetweil @trividar
          @trividar yeh, he assumes MagicMirror is THE folder where things are installed…
          • G Offline
            gonzonia
            Test runs fine…This is the result when I try to apply the log will be ```
            code_text
            No LSB modules are available.
            doing test run = false
            saving custom.css
            upgrading from version 2.9.0 to 2.10.0
            fetching latest revisions
            there were merge errors
            error: The following untracked working tree files would be overwritten by merge: 	installers/dumpactivemodules.js Please move or remove them before you merge. Aborting Updating 500147e..b595cdd
            you should examine and resolve them
            using the command git log --oneline --decorate
            500147e (grafted, HEAD -> master, tag: v2.9.0) Merge pull request #1776 from MichMich/develop
            restoring custom.css
              sdetweil @gonzonia
              @gonzonia yes, the upgrade script from the master github site has a bug,
              please erase that one file
              ~/MagicMirror/installers/dumpactivemodules.js
              and then use the link to the script from this topic page1
              https://forum.magicmirror.builders/topic/10859/new-update-upgrade-script-ready-for-testing?page=1
              evroomE G 2 Replies Last reply Reply Quote 0
              • evroomE Offline
                evroom @sdetweil
                Hi Sam, updating MM to 2.10.0 using your script. At the end the test run says:
                any *-lock.json files do not need to be saved
                do you want to save these files for later   (Y/n)?Y
                git: 'git_user_name' is not a git command. See 'git --help'.
                no modules found needing npm refresh
                test run, restoring files stashed
                The upgrade.log file does not give a clue as to what exact command was used.
                I am not into git, so cannot give you anything more than the git version
                pi@MagicPi:~ $ git --version
                git version 2.11.0
                Any ideas ?
                Best regards,
                E.J.
                MagicMirror version: 2.37.0
                  sdetweil @evroom
                  @evroom great find!..
                  give it another try please…
                  git wants all operations to be tagged with the users email address and name.
                  but if you haven’t provided one, I use a temporary approach…
                  • evroomE Offline
                    evroom
                    Latest run:
                    here are 1 local files that are different than the master repo
                       css/custom.css
                    error: Your local changes to the following files would be overwritten by merge:
                    	css/custom.css
                    Please commit your changes or stash them before you merge.
                    Aborting
                    I can of course save and restore during the apply, but I do not know if this is what you want /expect.
                      sdetweil @evroom
                      @evroom said in new update/upgrade script, ready for testing:
                      css/custom.css
                      hmm… custom.css was taken out of distribution on the 2.9 release…
                      let me examine… hang on 30 mins
                        @sdetweil can u tell me what MM version you are running?
                        grep version ~/MagicMirror/package.json
                        thanks
                        • evroomE Offline
                          evroom
                          @sdetweil said in new update/upgrade script, ready for testing:
                          This MM install has
                          pi@MagicPi:~ $ grep version ~/MagicMirror/package.json
                            "version": "2.8.0",
                          Apparently I did not upgrade to 2.9.0. :-)
                          In parallel I am upgrading an 2.9.0 install (using the ‘old’ apply script). I got the same git: 'git_user_name' is not a git command.error there, but decided to do the apply anyway.
                          Currently Downloading tmp-27972-0-electron-v3.1.13-linux-armv7l.zip which takes forever for some reason (approx. 700 B/s).
                          Btw, I know it can be solved by other means, but I would like you to be able to tweak your script.
                          • G Offline
                            gonzonia @sdetweil
                            @sdetweil Thanks! I thought I’d tried that as well. Guess not. All good now!
                              sdetweil @evroom
                              @evroom >In parallel I am upgrading an 2.9.0 install (using the ‘old’ apply script).
                              old? I updated the dropbox file so, it should have been fixed…
                              the install script is now part of the base.
                              “version”: “2.8.0”,
                              actually the upgrade log should have said, upgrading from 2.8 to 2.10,
                              also shown on the screen
                              the upgrade.log is located in the MagicMirror/installers folder
                              • evroomE Offline
                                evroom
                                I mean before you said “give it another try please…”.
                                Old is always relative :-)
                                The upgrade log did say```
                                upgrading from version 2.8.0 to 2.10.0
                                The upgrade that I still running says```
                                The test run on the 2.8.0 install currently outputs this:
                                pi@MagicPi:~ $ date; bash -c  "$(curl -sL https://www.dropbox.com/s/lxzwyzohg61sppu/upgrade-script.sh?dl=0)"
                                Fri Jan  3 15:34:42 CET 2020
                                the log will be /home/pi/MagicMirror/installers/upgrade.log
                                doing test run = true
                                saving custom.css
                                there are 1 local files that are different than the master repo
                                   css/custom.css
                                processing for module MMM-PublicTransportHafas please wait
                                skipped processing for MMM-PublicTransportHafas, doing test run
                                processing complete for module MMM-PublicTransportHafas
                                processing for module MMM-soccer please wait
                                skipped processing for MMM-soccer, doing test run
                                processing complete for module MMM-soccer
                                	css/custom.css
                                Aborting
                                  sdetweil @evroom
                                  @evroom yeh, thats because of the test run against 2.8
                                  on apply this will be fixed…
                                    surger13 Project Sponsor
                                    i have tried the script now to upgrade MM to the new version. but nothing changes in the version.
                                    in upgrade.log are the following errors:
                                    test merge result rc='' , if empty, no conflicts
                                    executing merge, apply specified
                                    merge result rc= 1
                                     error: Ihre lokalen Änderungen in den folgenden Dateien würden durch den Merge überschrieben werden: 	css/custom.css 	package-lock.json 	vendor/package-lock.json Bitte committen oder stashen Sie Ihre Änderungen, bevor sie mergen. Abbruch Aktualisiere b508a62..b595cdd
                                      sdetweil @surger13
                                      @surger13 did u save the changed files when prompted?
                                      what version are u on? 2.8?
                                      do
                                        surger13 Project Sponsor @sdetweil
                                        pi@MagicMirrorPi:~/MagicMirror $ grep version ~/MagicMirror/package.json
                                          "version": "2.7.1",
                                          sdetweil @surger13
                                          can u show me the log , ~/MagicMirror/installers/upgrade.log
                                          thx
                                            there was no request to save the files?!
                                            I will send you the logfile by mail.
                                            • 10
                                            • 11
                                            • 12
                                            • 16
                                            • 17
                                            • 10 / 17
