    328 Posts 27 Posters 740.6k Views 24 Watching
    • evroomE
      evroom @sdetweil
      Hi Sam, updating MM to 2.10.0 using your script. At the end the test run says:
      any *-lock.json files do not need to be saved
      do you want to save these files for later   (Y/n)?Y
      git: 'git_user_name' is not a git command. See 'git --help'.
      no modules found needing npm refresh
      restoring custom.css
      test run, restoring files stashed
      The upgrade.log file does not give a clue as to what exact command was used.
      I am not into git, so cannot give you anything more than the git version
      pi@MagicPi:~ $ git --version
      git version 2.11.0
      Any ideas ?
      Best regards,
      E.J.
      MagicMirror version: 2.37.0
        sdetweil @evroom
        @evroom great find!..
        give it another try please…
        git wants all operations to be tagged with the users email address and name.
        but if you haven’t provided one, I use a temporary approach…
        • evroomE
          evroom
          Latest run:
          here are 1 local files that are different than the master repo
             css/custom.css
          error: Your local changes to the following files would be overwritten by merge:
          	css/custom.css
          Please commit your changes or stash them before you merge.
          Aborting
          I can of course save and restore during the apply, but I do not know if this is what you want /expect.
            sdetweil @evroom
            @evroom said in new update/upgrade script, ready for testing:
            css/custom.css
            hmm… custom.css was taken out of distribution on the 2.9 release…
            let me examine… hang on 30 mins
              @sdetweil can u tell me what MM version you are running?
              grep version ~/MagicMirror/package.json
              thanks
              • evroomE
                evroom
                @sdetweil said in new update/upgrade script, ready for testing:
                This MM install has
                pi@MagicPi:~ $ grep version ~/MagicMirror/package.json
                  "version": "2.8.0",
                Apparently I did not upgrade to 2.9.0. :-)
                In parallel I am upgrading an 2.9.0 install (using the ‘old’ apply script). I got the same git: 'git_user_name' is not a git command.error there, but decided to do the apply anyway.
                Currently Downloading tmp-27972-0-electron-v3.1.13-linux-armv7l.zip which takes forever for some reason (approx. 700 B/s).
                Btw, I know it can be solved by other means, but I would like you to be able to tweak your script.
                • G
                  gonzonia @sdetweil
                  @sdetweil Thanks! I thought I’d tried that as well. Guess not. All good now!
                    sdetweil @evroom
                    @evroom >In parallel I am upgrading an 2.9.0 install (using the ‘old’ apply script).
                    old? I updated the dropbox file so, it should have been fixed…
                    the install script is now part of the base.
                    “version”: “2.8.0”,
                    actually the upgrade log should have said, upgrading from 2.8 to 2.10,
                    also shown on the screen
                    the upgrade.log is located in the MagicMirror/installers folder
                    • evroomE
                      evroom
                      I mean before you said “give it another try please…”.
                      Old is always relative :-)
                      The upgrade log did say```
                      upgrading from version 2.8.0 to 2.10.0
                      The upgrade that I still running says```
                      upgrading from version 2.9.0 to 2.10.0
                      The test run on the 2.8.0 install currently outputs this:
                      pi@MagicPi:~ $ date; bash -c  "$(curl -sL https://www.dropbox.com/s/lxzwyzohg61sppu/upgrade-script.sh?dl=0)"
                      Fri Jan  3 15:34:42 CET 2020
                      the log will be /home/pi/MagicMirror/installers/upgrade.log
                      No LSB modules are available.
                      doing test run = true
                      saving custom.css
                      fetching latest revisions
                      there are 1 local files that are different than the master repo
                         css/custom.css
                      processing for module MMM-PublicTransportHafas please wait
                      skipped processing for MMM-PublicTransportHafas, doing test run
                      processing complete for module MMM-PublicTransportHafas
                      processing for module MMM-soccer please wait
                      skipped processing for MMM-soccer, doing test run
                      processing complete for module MMM-soccer
                      	css/custom.css
                      Aborting
                        sdetweil @evroom
                        @evroom yeh, thats because of the test run against 2.8
                        on apply this will be fixed…
                          surger13 Project Sponsor
                          i have tried the script now to upgrade MM to the new version. but nothing changes in the version.
                          in upgrade.log are the following errors:
                          test merge result rc='' , if empty, no conflicts
                          executing merge, apply specified
                          merge result rc= 1
                           error: Ihre lokalen Änderungen in den folgenden Dateien würden durch den Merge überschrieben werden: 	css/custom.css 	package-lock.json 	vendor/package-lock.json Bitte committen oder stashen Sie Ihre Änderungen, bevor sie mergen. Abbruch Aktualisiere b508a62..b595cdd
                          there were merge errors
                          you should examine and resolve them
                            sdetweil @surger13
                            @surger13 did u save the changed files when prompted?
                            what version are u on? 2.8?
                            do
                              surger13 Project Sponsor @sdetweil
                              pi@MagicMirrorPi:~/MagicMirror $ grep version ~/MagicMirror/package.json
                                "version": "2.7.1",
                                sdetweil @surger13
                                can u show me the log , ~/MagicMirror/installers/upgrade.log
                                thx
                                  there was no request to save the files?!
                                  I will send you the logfile by mail.
                                  • evroomE
                                    evroom
                                    Sam, the 2.9.0 threw an error on the electron update, but then continued.
                                    I am apparently on 2.10.0 now, but probably I am not running the latest electron version.
                                    pi@raspberrypi:~ $ grep version ~/MagicMirror/package.json
                                      "version": "2.10.0",
                                    This was the part where the error occured:
                                    > electron@3.1.13 postinstall /home/pi/MagicMirror/node_modules/electron
                                    > node install.js
                                    Error: read ECONNRESET
                                    /home/pi/MagicMirror/node_modules/electron/install.js:49
                                      throw err
                                        at TLSWrap.onStreamRead (internal/stream_base_commons.js:111:27)
                                    What would be the correct command to update electron and from which directory?
                                      sdetweil @evroom
                                      yeh, the website with the file broke the download…
                                      u can try
                                      npm install electron@3.0.13
                                        sdetweil @surger13
                                        @surger13 thanks for the log…
                                        can u do
                                        echo $LC_ALL
                                        and
                                        locale | grep LANGUAGE
                                        thx
                                          both empty.
                                          pi@MagicMirrorPi:~/MagicMirror $ echo $LC_ALL
                                          pi@MagicMirrorPi:~/MagicMirror $ locale | grep LANGUAGE
                                          LANGUAGE=
                                            sdetweil @surger13
                                            @surger13 weird, but the system is in german… so the message I was looking for the output of
                                            git status, with the content of ‘modified’ in english
                                            how about the output of
                                            alias
                                            • 10
                                            • 11
                                            • 12
                                            • 16
                                            • 17
                                            • 10 / 17
