    328 Posts 27 Posters 740.6k Views 24 Watching
      sdetweil @swvalenti
      @swvalenti said in new update/upgrade script, ready for testing:
      |server | Error: bind EADDRNOTAVAIL 10.30.1.223:1905
      looks like the omxplayer task is hung, holding onto ports… reboot time…
      • StoffbeuteluweS
        Stoffbeuteluwe Project Sponsor @sdetweil
        @sdetweil Hi, do have to install the script in the MM Folder?
          sdetweil @Stoffbeuteluwe
          @Stoffbeuteluwe no… run the script from the web.
          the update will now install the new scripts in the installers folder, for the future
          StoffbeuteluweS Mykle1M 2 Replies Last reply Reply Quote 0
          • StoffbeuteluweS
            @sdetweil thanks Sam :folded_hands_medium-light_skin_tone:
            • Mykle1M
              Reporting upgrade script results as of January 2, 2020 4:00 PM Eastern time, US
              Successful upgrade from MM 2.9.0 to 2.10.0
              Ubuntu 16.04 LTS
              No errors reported.
              • T
                trividar
                Can someone write a how to instruction for mac? Thanks a lot…
                • Mykle1M
                  Mykle1 Project Sponsor Module Developer @trividar
                  @trividar said in new update/upgrade script, ready for testing:
                  How to run the update/upgrade script? :-/
                  • T
                    trividar @Mykle1
                    @Mykle1 sorry for the noob question! I tried it and I got just errors…
                    • Mykle1M
                      No worries. :thumbsup:
                      When did you run it? I’ve just done it minutes ago and it works fine. @sdetweil has been working on it but I believe he has ironed out most, if not all of the kinks.
                      1. So, when did you run it?
                      2. Errors during the upgrade or after the upgrade?
                      3. What were the errors?
                      • T
                        trividar @Mykle1
                        @Mykle1 I will send it tomorrow and also what I have done! Thanks for your time
                        • Mykle1M
                          @trividar
                          Well, I would think you have nothing to lose by running the upgrade script again. Simply open a new terminal and copy and paste the script into the terminal and press enter.
                          • T
                            trividar
                            this is what I get:
                            > cd - >/dev/null
                            > date +"Upgrade ended - %a %b %e %H:%M:%S %Z %Y" >>$logfile
                            > else
                            > echo It appears MagicMirror has not been installed on this system
                            > echo please run the installer, "raspberry.sh" first
                            > fi
                            Can it be because my path has the same folder name twice? /Users/s****/MagicMirror/MagicMirror
                            Mykle1M S 2 Replies Last reply Reply Quote 0
                            • Mykle1M
                              @trividar
                              Hmm, perhaps. The installer may be looking for the MM installation inside /Users/s****/MagicMirror. Can you move the MagicMirror folder with the installation OUT of the containing MagicMirror folder. Rename the containing MagicMirror folder to something else and put the MagicMirror folder containing the MM installation here /Users/s****/MagicMirror and try again?
                                sdetweil @trividar
                                @trividar yeh, he assumes MagicMirror is THE folder where things are installed…
                                • G
                                  gonzonia
                                  Test runs fine…This is the result when I try to apply the log will be ```
                                  code_text
                                  No LSB modules are available.
                                  doing test run = false
                                  saving custom.css
                                  upgrading from version 2.9.0 to 2.10.0
                                  fetching latest revisions
                                  there were merge errors
                                  error: The following untracked working tree files would be overwritten by merge: 	installers/dumpactivemodules.js Please move or remove them before you merge. Aborting Updating 500147e..b595cdd
                                  you should examine and resolve them
                                  using the command git log --oneline --decorate
                                  500147e (grafted, HEAD -> master, tag: v2.9.0) Merge pull request #1776 from MichMich/develop
                                  restoring custom.css
                                    sdetweil @gonzonia
                                    @gonzonia yes, the upgrade script from the master github site has a bug,
                                    please erase that one file
                                    ~/MagicMirror/installers/dumpactivemodules.js
                                    and then use the link to the script from this topic page1
                                    https://forum.magicmirror.builders/topic/10859/new-update-upgrade-script-ready-for-testing?page=1
                                    evroomE G 2 Replies Last reply Reply Quote 0
                                    • evroomE
                                      evroom @sdetweil
                                      Hi Sam, updating MM to 2.10.0 using your script. At the end the test run says:
                                      any *-lock.json files do not need to be saved
                                      do you want to save these files for later   (Y/n)?Y
                                      git: 'git_user_name' is not a git command. See 'git --help'.
                                      no modules found needing npm refresh
                                      test run, restoring files stashed
                                      The upgrade.log file does not give a clue as to what exact command was used.
                                      I am not into git, so cannot give you anything more than the git version
                                      pi@MagicPi:~ $ git --version
                                      git version 2.11.0
                                      Any ideas ?
                                      Best regards,
                                      E.J.
                                      MagicMirror version: 2.37.0
                                        sdetweil @evroom
                                        @evroom great find!..
                                        give it another try please…
                                        git wants all operations to be tagged with the users email address and name.
                                        but if you haven’t provided one, I use a temporary approach…
                                        • evroomE
                                          evroom
                                          Latest run:
                                          here are 1 local files that are different than the master repo
                                             css/custom.css
                                          error: Your local changes to the following files would be overwritten by merge:
                                          	css/custom.css
                                          Please commit your changes or stash them before you merge.
                                          Aborting
                                          I can of course save and restore during the apply, but I do not know if this is what you want /expect.
                                            sdetweil @evroom
                                            @evroom said in new update/upgrade script, ready for testing:
                                            css/custom.css
                                            hmm… custom.css was taken out of distribution on the 2.9 release…
                                            let me examine… hang on 30 mins
                                            • 10
                                            • 11
                                            • 16
                                            • 17
                                            • 9 / 17
