    328 Posts 27 Posters 740.6k Views 24 Watching
    • swvalentiS
      swvalenti Project Sponsor
      @sdetweil I fixed the server issue and it shows online. But still get a black screen when start MM. So frustrating
      • swvalentiS
        @sdetweil I stand corrected I did not fix server issue…
        • swvalentiS
          • swvalentiS
            pi@raspberrypi:~ $ pm2 logs
            /home/pi/.pm2/pm2.log last 15 lines:
            PM2        | 2019-12-07T15:03:42: PM2 log: App [omx_stream1:2] exited with code [1] via signal [SIGINT]
            PM2        | 2019-12-07T15:03:42: PM2 log: App [omx_stream1:2] starting in -fork mode-
            PM2        | 2019-12-07T15:03:42: PM2 log: App [omx_stream1:2] online
            PM2        | 2019-12-07T15:03:42: PM2 log: App [omx_stream2:3] exited with code [1] via signal [SIGINT]
            PM2        | 2019-12-07T15:03:42: PM2 log: App [omx_stream2:3] starting in -fork mode-
            PM2        | 2019-12-07T15:03:42: PM2 log: App [omx_stream2:3] online
            PM2        | 2019-12-07T15:04:13: PM2 log: App [omx_stream3:4] exited with code [1] via signal [SIGINT]
            PM2        | 2019-12-07T15:04:13: PM2 log: App [omx_stream3:4] starting in -fork mode-
            PM2        | 2019-12-07T15:04:13: PM2 log: App [omx_stream3:4] online
            PM2        | 2019-12-07T15:04:14: PM2 log: App [omx_stream1:2] exited with code [1] via signal [SIGINT]
            PM2        | 2019-12-07T15:04:14: PM2 log: App [omx_stream1:2] starting in -fork mode-
            PM2        | 2019-12-07T15:04:14: PM2 log: App [omx_stream1:2] online
            PM2        | 2019-12-07T15:04:14: PM2 log: App [omx_stream2:3] exited with code [1] via signal [SIGINT]
            PM2        | 2019-12-07T15:04:14: PM2 log: App [omx_stream2:3] starting in -fork mode-
            PM2        | 2019-12-07T15:04:14: PM2 log: App [omx_stream2:3] online
            /home/pi/.pm2/logs/omx-stream2-error.log last 15 lines:
            /home/pi/.pm2/logs/omx-stream3-error.log last 15 lines:
            /home/pi/.pm2/logs/omx-stream1-error.log last 15 lines:
            2|omx_stre |
            2|omx_stre | #
            2|omx_stre | # Fatal process OOM in heap setup
            2|omx_stre | #
            2|omx_stre |
            2|omx_stre | /usr/bin/env: error while loading shared libraries: /usr/lib/arm-linux-gnueabihf/libarmmem.so: cannot make segment writable for relocation: Cannot allocate memory
            2|omx_stre | /usr/bin/omxplayer: xmalloc: .././subst.c:3868: cannot allocate 131 bytes (159744 bytes allocated)
            2|omx_stre | /usr/bin/omxplayer: line 67:  5417 Aborted                 (core dumped) LD_LIBRARY_PATH="$OMXPLAYER_LIBS${LD_LIBRARY_PATH:+:$LD_LIBRARY_PATH}" $OMXPLAYER_BIN "$@"
            2|omx_stre | /usr/bin/omxplayer.bin: error while loading shared libraries: libmpg123.so.0: failed to map segment from shared object
            2|omx_stre | /usr/bin/omxplayer: line 67:  9527 Aborted                 (core dumped) LD_LIBRARY_PATH="$OMXPLAYER_LIBS${LD_LIBRARY_PATH:+:$LD_LIBRARY_PATH}" $OMXPLAYER_BIN "$@"
            2|omx_stre | /usr/bin/omxplayer: line 67: 10115 Killed                  LD_LIBRARY_PATH="$OMXPLAYER_LIBS${LD_LIBRARY_PATH:+:$LD_LIBRARY_PATH}" $OMXPLAYER_BIN "$@"
            2|omx_stre | /usr/bin/omxplayer: line 67: 13967 Killed                  LD_LIBRARY_PATH="$OMXPLAYER_LIBS${LD_LIBRARY_PATH:+:$LD_LIBRARY_PATH}" $OMXPLAYER_BIN "$@"
            2|omx_stre | process 25324: arguments to dbus_message_new_method_call() were incorrect, assertion "destination == NULL || _dbus_check_is_valid_bus_name (destination)" failed in file ../../../dbus/dbus-message.c line 1370.
            2|omx_stre | This is normally a bug in some application using the D-Bus library.
            /home/pi/.pm2/logs/server-error.log last 15 lines:
            0|server   |     at _handle.lookup (dgram.js:266:18)
            0|server   |     at args.(anonymous function) (/usr/lib/node_modules/pm2/node_modules/event-loop-inspector/index.js:138:29)
            0|server   |     at process._tickCallback (internal/process/next_tick.js:178:19)
            0|server   | Error: bind EADDRNOTAVAIL 10.30.1.223:1905
            0|server   |     at state.handle.lookup (dgram.js:242:18)
            0|server   |     at process._tickCallback (internal/process/next_tick.js:63:19)
            /home/pi/.pm2/logs/server-out.log last 15 lines:
            0|server   |         { roomName: 'TV Room', volume: 15 } ],
            0|server   |      playMode: { shuffle: true, repeat: 'all', crossfade: false },
            0|server   |      pauseOthers: false } }
            0|server   | 2019-12-07T19:32:42.519Z INFO http server listening on 0.0.0.0 port 5005
            0|server   | 2019-12-07T19:37:02.420Z INFO Could not find file /home/pi/node-sonos-http-api/settings.json
            0|server   | 2019-12-07T19:37:03.086Z INFO Presets loaded: { example:
            0|server   |    { players:
            0|server   |       [ { roomName: 'Bathroom', volume: 10 },
            0|server   |         { roomName: 'Kitchen', volume: 10 },
            0|server   |         { roomName: 'Office', volume: 10 },
            0|server   |         { roomName: 'Bedroom', volume: 10 },
            0|server   | 2019-12-07T19:37:07.083Z INFO http server listening on 0.0.0.0 port 5005
            1|mm       |     at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-RTSPStream/node_helper.js:563:3)
            1|mm       |     at Module._compile (internal/modules/cjs/loader.js:711:30)
            1|mm       |     at Object.Module._extensions..js (internal/modules/cjs/loader.js:722:10)
            1|mm       |     at Module.load (internal/modules/cjs/loader.js:620:32)
            1|mm       | { Error: Cannot find module 'node_helper'
            1|mm       |     at Module._resolveFilename (internal/modules/cjs/loader.js:602:15)
            1|mm       |     at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/electron/dist/resources/electron.asar/common/reset-search-paths.js:35:12)
            1|mm       |     at Function.Module._load (internal/modules/cjs/loader.js:528:25)
            1|mm       |     at Module.require (internal/modules/cjs/loader.js:658:17)
            1|mm       |     at require (internal/modules/cjs/helpers.js:20:18)
            1|mm       |     at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-RTSPStream/node_helper.js:9:18)
            1|mm       |     at Module.load (internal/modules/cjs/loader.js:620:32) code: 'MODULE_NOT_FOUND' }
            1|mm       | If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
            1|mm       | Launching application.
            1|mm       | Shutting down server...
            1|mm       |
            1|mm       | > magicmirror@2.8.0 start /home/pi/MagicMirror
            1|mm       | > sh run-start.sh
            1|mm       |
            1|mm       | Starting MagicMirror: v2.8.0
            1|mm       | Loading config ...
            1|mm       | Loading module helpers ...
            1|mm       | Whoops! There was an uncaught exception...
            1|mm       | MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
            • Mykle1M
              Mykle1 Project Sponsor Module Developer @swvalenti
              @swvalenti
              I updated MMM-EventHorizon and now I get a black screen and server shows errored . . .
              If MMM-EventHorizon is the cause simply disable it.
              We can troubleshoot in another topic instead of hijacking this one.
                sdetweil @swvalenti
                @swvalenti said in new update/upgrade script, ready for testing:
                looks like the omxplayer task is hung, holding onto ports… reboot time…
                StoffbeuteluweS 1 Reply Last reply
                • StoffbeuteluweS
                  Stoffbeuteluwe Project Sponsor @sdetweil
                  @sdetweil Hi, do have to install the script in the MM Folder?
                    sdetweil @Stoffbeuteluwe
                    @Stoffbeuteluwe no… run the script from the web.
                    the update will now install the new scripts in the installers folder, for the future
                    StoffbeuteluweS Mykle1M 2 Replies Last reply
                    • StoffbeuteluweS
                      @sdetweil thanks Sam :folded_hands_medium-light_skin_tone:
                      • Mykle1M
                        Reporting upgrade script results as of January 2, 2020 4:00 PM Eastern time, US
                        Successful upgrade from MM 2.9.0 to 2.10.0
                        Ubuntu 16.04 LTS
                        No errors reported.
                        • T
                          trividar
                          Can someone write a how to instruction for mac? Thanks a lot…
                          Mykle1M 1 Reply Last reply
                          • Mykle1M
                            Mykle1 Project Sponsor Module Developer @trividar
                            @trividar said in new update/upgrade script, ready for testing:
                            How to run the update/upgrade script? :-/
                            T 1 Reply Last reply
                            • T
                              trividar @Mykle1
                              @Mykle1 sorry for the noob question! I tried it and I got just errors…
                              • Mykle1M
                                No worries. :thumbsup:
                                When did you run it? I’ve just done it minutes ago and it works fine. @sdetweil has been working on it but I believe he has ironed out most, if not all of the kinks.
                                1. So, when did you run it?
                                2. Errors during the upgrade or after the upgrade?
                                3. What were the errors?
                                • T
                                  trividar @Mykle1
                                  @Mykle1 I will send it tomorrow and also what I have done! Thanks for your time
                                  • Mykle1M
                                    @trividar
                                    Well, I would think you have nothing to lose by running the upgrade script again. Simply open a new terminal and copy and paste the script into the terminal and press enter.
                                    • T
                                      trividar
                                      this is what I get:
                                      > cd - >/dev/null
                                      > date +"Upgrade ended - %a %b %e %H:%M:%S %Z %Y" >>$logfile
                                      > else
                                      > echo It appears MagicMirror has not been installed on this system
                                      > echo please run the installer, "raspberry.sh" first
                                      > fi
                                      Can it be because my path has the same folder name twice? /Users/s****/MagicMirror/MagicMirror
                                      Mykle1M S 2 Replies Last reply
                                      • Mykle1M
                                        @trividar
                                        Hmm, perhaps. The installer may be looking for the MM installation inside /Users/s****/MagicMirror. Can you move the MagicMirror folder with the installation OUT of the containing MagicMirror folder. Rename the containing MagicMirror folder to something else and put the MagicMirror folder containing the MM installation here /Users/s****/MagicMirror and try again?
                                          sdetweil @trividar
                                          @trividar yeh, he assumes MagicMirror is THE folder where things are installed…
                                          • G
                                            gonzonia
                                            Test runs fine…This is the result when I try to apply the log will be ```
                                            code_text
                                            No LSB modules are available.
                                            doing test run = false
                                            saving custom.css
                                            upgrading from version 2.9.0 to 2.10.0
                                            fetching latest revisions
                                            there were merge errors
                                            error: The following untracked working tree files would be overwritten by merge: 	installers/dumpactivemodules.js Please move or remove them before you merge. Aborting Updating 500147e..b595cdd
                                            you should examine and resolve them
                                            using the command git log --oneline --decorate
                                            500147e (grafted, HEAD -> master, tag: v2.9.0) Merge pull request #1776 from MichMich/develop
                                            restoring custom.css
                                            • 10
                                            • 11
                                            • 16
                                            • 17
                                            • 9 / 17
