    328 Posts 27 Posters 740.6k Views 24 Watching
      sdetweil @Stoffbeuteluwe
      @Stoffbeuteluwe no… run the script from the web.
      the update will now install the new scripts in the installers folder, for the future
      StoffbeuteluweS Mykle1M 2 Replies Last reply Reply Quote 0
      • StoffbeuteluweS
        Stoffbeuteluwe Project Sponsor @sdetweil
        @sdetweil thanks Sam :folded_hands_medium-light_skin_tone:
        • Mykle1M
          Reporting upgrade script results as of January 2, 2020 4:00 PM Eastern time, US
          Successful upgrade from MM 2.9.0 to 2.10.0
          Ubuntu 16.04 LTS
          No errors reported.
          • T
            trividar
            Can someone write a how to instruction for mac? Thanks a lot…
            • Mykle1M
              Mykle1 Project Sponsor Module Developer @trividar
              @trividar said in new update/upgrade script, ready for testing:
              How to run the update/upgrade script? :-/
              • T
                trividar @Mykle1
                @Mykle1 sorry for the noob question! I tried it and I got just errors…
                • Mykle1M
                  No worries. :thumbsup:
                  When did you run it? I’ve just done it minutes ago and it works fine. @sdetweil has been working on it but I believe he has ironed out most, if not all of the kinks.
                  1. So, when did you run it?
                  2. Errors during the upgrade or after the upgrade?
                  3. What were the errors?
                  • T
                    trividar @Mykle1
                    @Mykle1 I will send it tomorrow and also what I have done! Thanks for your time
                    • Mykle1M
                      @trividar
                      Well, I would think you have nothing to lose by running the upgrade script again. Simply open a new terminal and copy and paste the script into the terminal and press enter.
                      • T
                        trividar
                        this is what I get:
                        > cd - >/dev/null
                        > date +"Upgrade ended - %a %b %e %H:%M:%S %Z %Y" >>$logfile
                        > else
                        > echo It appears MagicMirror has not been installed on this system
                        > echo please run the installer, "raspberry.sh" first
                        > fi
                        Can it be because my path has the same folder name twice? /Users/s****/MagicMirror/MagicMirror
                        Mykle1M S 2 Replies Last reply Reply Quote 0
                        • Mykle1M
                          @trividar
                          Hmm, perhaps. The installer may be looking for the MM installation inside /Users/s****/MagicMirror. Can you move the MagicMirror folder with the installation OUT of the containing MagicMirror folder. Rename the containing MagicMirror folder to something else and put the MagicMirror folder containing the MM installation here /Users/s****/MagicMirror and try again?
                            sdetweil @trividar
                            @trividar yeh, he assumes MagicMirror is THE folder where things are installed…
                            • G
                              gonzonia
                              Test runs fine…This is the result when I try to apply the log will be ```
                              code_text
                              No LSB modules are available.
                              doing test run = false
                              saving custom.css
                              upgrading from version 2.9.0 to 2.10.0
                              fetching latest revisions
                              there were merge errors
                              error: The following untracked working tree files would be overwritten by merge: 	installers/dumpactivemodules.js Please move or remove them before you merge. Aborting Updating 500147e..b595cdd
                              you should examine and resolve them
                              using the command git log --oneline --decorate
                              500147e (grafted, HEAD -> master, tag: v2.9.0) Merge pull request #1776 from MichMich/develop
                              restoring custom.css
                                sdetweil @gonzonia
                                @gonzonia yes, the upgrade script from the master github site has a bug,
                                please erase that one file
                                ~/MagicMirror/installers/dumpactivemodules.js
                                and then use the link to the script from this topic page1
                                https://forum.magicmirror.builders/topic/10859/new-update-upgrade-script-ready-for-testing?page=1
                                evroomE G 2 Replies Last reply Reply Quote 0
                                • evroomE
                                  evroom @sdetweil
                                  Hi Sam, updating MM to 2.10.0 using your script. At the end the test run says:
                                  any *-lock.json files do not need to be saved
                                  do you want to save these files for later   (Y/n)?Y
                                  git: 'git_user_name' is not a git command. See 'git --help'.
                                  no modules found needing npm refresh
                                  test run, restoring files stashed
                                  The upgrade.log file does not give a clue as to what exact command was used.
                                  I am not into git, so cannot give you anything more than the git version
                                  pi@MagicPi:~ $ git --version
                                  git version 2.11.0
                                  Any ideas ?
                                  Best regards,
                                  E.J.
                                  MagicMirror version: 2.37.0
                                    sdetweil @evroom
                                    @evroom great find!..
                                    give it another try please…
                                    git wants all operations to be tagged with the users email address and name.
                                    but if you haven’t provided one, I use a temporary approach…
                                    • evroomE
                                      evroom
                                      Latest run:
                                      here are 1 local files that are different than the master repo
                                         css/custom.css
                                      error: Your local changes to the following files would be overwritten by merge:
                                      	css/custom.css
                                      Please commit your changes or stash them before you merge.
                                      Aborting
                                      I can of course save and restore during the apply, but I do not know if this is what you want /expect.
                                        sdetweil @evroom
                                        @evroom said in new update/upgrade script, ready for testing:
                                        css/custom.css
                                        hmm… custom.css was taken out of distribution on the 2.9 release…
                                        let me examine… hang on 30 mins
                                          @sdetweil can u tell me what MM version you are running?
                                          grep version ~/MagicMirror/package.json
                                          thanks
                                          • evroomE
                                            evroom
                                            @sdetweil said in new update/upgrade script, ready for testing:
                                            This MM install has
                                            pi@MagicPi:~ $ grep version ~/MagicMirror/package.json
                                              "version": "2.8.0",
                                            Apparently I did not upgrade to 2.9.0. :-)
                                            In parallel I am upgrading an 2.9.0 install (using the ‘old’ apply script). I got the same git: 'git_user_name' is not a git command.error there, but decided to do the apply anyway.
                                            Currently Downloading tmp-27972-0-electron-v3.1.13-linux-armv7l.zip which takes forever for some reason (approx. 700 B/s).
                                            Btw, I know it can be solved by other means, but I would like you to be able to tweak your script.
                                            • 10
                                            • 11
                                            • 16
                                            • 17
                                            • 9 / 17
