    328 Posts 27 Posters 706.4k Views 24 Watching
      I have submitted this script as part of pull request 1789
      • swvalentiS Offline
        swvalenti Project Sponsor
        @sdetweil Idk why or if this is even the case but I updated MMM-EventHorizon and now I get a black screen and server shows errored below…any ideas how to fix?
        pi@raspberrypi:~ $ pm2 restart mm
        [PM2] Applying action restartProcessId on app [mm](ids: 1)
        [PM2] [mm](1) ✓
        │ Name        │ id │ mode │ status │ ↺       │ cpu │ memory │
        │ mm          │ 1  │ N/A  │ fork   │ online  │ 5   │ 0%     │ 2.5 MB   │
        │ omx_stream1 │ 2  │ N/A  │ fork   │ online  │ 28  │ 0%     │ 2.8 MB   │
        │ omx_stream2 │ 3  │ N/A  │ fork   │ online  │ 28  │ 0%     │ 2.7 MB   │
        │ omx_stream3 │ 4  │ N/A  │ fork   │ online  │ 28  │ 0%     │ 2.7 MB   │
        │ server      │ 0  │ N/A  │ fork   │ errored │ 0   │ 0%     │ 0 B      │
        swvalentiS Mykle1M 2 Replies Last reply Reply Quote 0
          swvalenti Project Sponsor @swvalenti
          @sdetweil Actually idk what the issue is…black screen even though all show online. Odd
            @sdetweil I fixed the server issue and it shows online. But still get a black screen when start MM. So frustrating
              @sdetweil I stand corrected I did not fix server issue…
                  pi@raspberrypi:~ $ pm2 logs
                  /home/pi/.pm2/pm2.log last 15 lines:
                  PM2        | 2019-12-07T15:03:42: PM2 log: App [omx_stream1:2] exited with code [1] via signal [SIGINT]
                  PM2        | 2019-12-07T15:03:42: PM2 log: App [omx_stream1:2] starting in -fork mode-
                  PM2        | 2019-12-07T15:03:42: PM2 log: App [omx_stream1:2] online
                  PM2        | 2019-12-07T15:03:42: PM2 log: App [omx_stream2:3] exited with code [1] via signal [SIGINT]
                  PM2        | 2019-12-07T15:03:42: PM2 log: App [omx_stream2:3] starting in -fork mode-
                  PM2        | 2019-12-07T15:03:42: PM2 log: App [omx_stream2:3] online
                  PM2        | 2019-12-07T15:04:13: PM2 log: App [omx_stream3:4] exited with code [1] via signal [SIGINT]
                  PM2        | 2019-12-07T15:04:13: PM2 log: App [omx_stream3:4] starting in -fork mode-
                  PM2        | 2019-12-07T15:04:13: PM2 log: App [omx_stream3:4] online
                  PM2        | 2019-12-07T15:04:14: PM2 log: App [omx_stream1:2] exited with code [1] via signal [SIGINT]
                  PM2        | 2019-12-07T15:04:14: PM2 log: App [omx_stream1:2] starting in -fork mode-
                  PM2        | 2019-12-07T15:04:14: PM2 log: App [omx_stream1:2] online
                  PM2        | 2019-12-07T15:04:14: PM2 log: App [omx_stream2:3] exited with code [1] via signal [SIGINT]
                  PM2        | 2019-12-07T15:04:14: PM2 log: App [omx_stream2:3] starting in -fork mode-
                  PM2        | 2019-12-07T15:04:14: PM2 log: App [omx_stream2:3] online
                  /home/pi/.pm2/logs/omx-stream2-error.log last 15 lines:
                  /home/pi/.pm2/logs/omx-stream3-error.log last 15 lines:
                  /home/pi/.pm2/logs/omx-stream1-error.log last 15 lines:
                  2|omx_stre |
                  2|omx_stre | #
                  2|omx_stre | # Fatal process OOM in heap setup
                  2|omx_stre | #
                  2|omx_stre |
                  2|omx_stre | /usr/bin/env: error while loading shared libraries: /usr/lib/arm-linux-gnueabihf/libarmmem.so: cannot make segment writable for relocation: Cannot allocate memory
                  2|omx_stre | /usr/bin/omxplayer: xmalloc: .././subst.c:3868: cannot allocate 131 bytes (159744 bytes allocated)
                  2|omx_stre | /usr/bin/omxplayer: line 67:  5417 Aborted                 (core dumped) LD_LIBRARY_PATH="$OMXPLAYER_LIBS${LD_LIBRARY_PATH:+:$LD_LIBRARY_PATH}" $OMXPLAYER_BIN "$@"
                  2|omx_stre | /usr/bin/omxplayer.bin: error while loading shared libraries: libmpg123.so.0: failed to map segment from shared object
                  2|omx_stre | /usr/bin/omxplayer: line 67:  9527 Aborted                 (core dumped) LD_LIBRARY_PATH="$OMXPLAYER_LIBS${LD_LIBRARY_PATH:+:$LD_LIBRARY_PATH}" $OMXPLAYER_BIN "$@"
                  2|omx_stre | /usr/bin/omxplayer: line 67: 10115 Killed                  LD_LIBRARY_PATH="$OMXPLAYER_LIBS${LD_LIBRARY_PATH:+:$LD_LIBRARY_PATH}" $OMXPLAYER_BIN "$@"
                  2|omx_stre | /usr/bin/omxplayer: line 67: 13967 Killed                  LD_LIBRARY_PATH="$OMXPLAYER_LIBS${LD_LIBRARY_PATH:+:$LD_LIBRARY_PATH}" $OMXPLAYER_BIN "$@"
                  2|omx_stre | process 25324: arguments to dbus_message_new_method_call() were incorrect, assertion "destination == NULL || _dbus_check_is_valid_bus_name (destination)" failed in file ../../../dbus/dbus-message.c line 1370.
                  2|omx_stre | This is normally a bug in some application using the D-Bus library.
                  /home/pi/.pm2/logs/server-error.log last 15 lines:
                  0|server   |     at _handle.lookup (dgram.js:266:18)
                  0|server   |     at args.(anonymous function) (/usr/lib/node_modules/pm2/node_modules/event-loop-inspector/index.js:138:29)
                  0|server   |     at process._tickCallback (internal/process/next_tick.js:178:19)
                  0|server   | Error: bind EADDRNOTAVAIL 10.30.1.223:1905
                  0|server   |     at state.handle.lookup (dgram.js:242:18)
                  0|server   |     at process._tickCallback (internal/process/next_tick.js:63:19)
                  /home/pi/.pm2/logs/server-out.log last 15 lines:
                  0|server   |         { roomName: 'TV Room', volume: 15 } ],
                  0|server   |      playMode: { shuffle: true, repeat: 'all', crossfade: false },
                  0|server   |      pauseOthers: false } }
                  0|server   | 2019-12-07T19:32:42.519Z INFO http server listening on 0.0.0.0 port 5005
                  0|server   | 2019-12-07T19:37:02.420Z INFO Could not find file /home/pi/node-sonos-http-api/settings.json
                  0|server   | 2019-12-07T19:37:03.086Z INFO Presets loaded: { example:
                  0|server   |    { players:
                  0|server   |       [ { roomName: 'Bathroom', volume: 10 },
                  0|server   |         { roomName: 'Kitchen', volume: 10 },
                  0|server   |         { roomName: 'Office', volume: 10 },
                  0|server   |         { roomName: 'Bedroom', volume: 10 },
                  0|server   | 2019-12-07T19:37:07.083Z INFO http server listening on 0.0.0.0 port 5005
                  1|mm       |     at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-RTSPStream/node_helper.js:563:3)
                  1|mm       |     at Module._compile (internal/modules/cjs/loader.js:711:30)
                  1|mm       |     at Object.Module._extensions..js (internal/modules/cjs/loader.js:722:10)
                  1|mm       |     at Module.load (internal/modules/cjs/loader.js:620:32)
                  1|mm       | { Error: Cannot find module 'node_helper'
                  1|mm       |     at Module._resolveFilename (internal/modules/cjs/loader.js:602:15)
                  1|mm       |     at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/electron/dist/resources/electron.asar/common/reset-search-paths.js:35:12)
                  1|mm       |     at Function.Module._load (internal/modules/cjs/loader.js:528:25)
                  1|mm       |     at Module.require (internal/modules/cjs/loader.js:658:17)
                  1|mm       |     at require (internal/modules/cjs/helpers.js:20:18)
                  1|mm       |     at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-RTSPStream/node_helper.js:9:18)
                  1|mm       |     at Module.load (internal/modules/cjs/loader.js:620:32) code: 'MODULE_NOT_FOUND' }
                  1|mm       | If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                  1|mm       | Launching application.
                  1|mm       | Shutting down server...
                  1|mm       |
                  1|mm       | > magicmirror@2.8.0 start /home/pi/MagicMirror
                  1|mm       | > sh run-start.sh
                  1|mm       |
                  1|mm       | Starting MagicMirror: v2.8.0
                  1|mm       | Loading config ...
                  1|mm       | Loading module helpers ...
                  1|mm       | Whoops! There was an uncaught exception...
                  1|mm       | MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                    Mykle1 Project Sponsor Module Developer @swvalenti
                    @swvalenti
                    I updated MMM-EventHorizon and now I get a black screen and server shows errored . . .
                    If MMM-EventHorizon is the cause simply disable it.
                    We can troubleshoot in another topic instead of hijacking this one.
                      sdetweil @swvalenti
                      @swvalenti said in new update/upgrade script, ready for testing:
                      looks like the omxplayer task is hung, holding onto ports… reboot time…
                      • StoffbeuteluweS Offline
                        Stoffbeuteluwe Project Sponsor @sdetweil
                        @sdetweil Hi, do have to install the script in the MM Folder?
                          sdetweil @Stoffbeuteluwe
                          @Stoffbeuteluwe no… run the script from the web.
                          the update will now install the new scripts in the installers folder, for the future
                          StoffbeuteluweS Mykle1M 2 Replies Last reply Reply Quote 0
                            @sdetweil thanks Sam :folded_hands_medium-light_skin_tone:
                              Reporting upgrade script results as of January 2, 2020 4:00 PM Eastern time, US
                              Successful upgrade from MM 2.9.0 to 2.10.0
                              Ubuntu 16.04 LTS
                              No errors reported.
                              • T Offline
                                trividar
                                Can someone write a how to instruction for mac? Thanks a lot…
                                  Mykle1 Project Sponsor Module Developer @trividar
                                  @trividar said in new update/upgrade script, ready for testing:
                                  How to run the update/upgrade script? :-/
                                  • T Offline
                                    trividar @Mykle1
                                    @Mykle1 sorry for the noob question! I tried it and I got just errors…
                                      No worries. :thumbsup:
                                      When did you run it? I’ve just done it minutes ago and it works fine. @sdetweil has been working on it but I believe he has ironed out most, if not all of the kinks.
                                      1. So, when did you run it?
                                      2. Errors during the upgrade or after the upgrade?
                                      3. What were the errors?
                                      • T Offline
                                        trividar @Mykle1
                                        @Mykle1 I will send it tomorrow and also what I have done! Thanks for your time
                                          @trividar
                                          Well, I would think you have nothing to lose by running the upgrade script again. Simply open a new terminal and copy and paste the script into the terminal and press enter.
                                          • T Offline
                                            trividar
                                            this is what I get:
                                            > cd - >/dev/null
                                            > date +"Upgrade ended - %a %b %e %H:%M:%S %Z %Y" >>$logfile
                                            > else
                                            > echo It appears MagicMirror has not been installed on this system
                                            > echo please run the installer, "raspberry.sh" first
                                            > fi
                                            Can it be because my path has the same folder name twice? /Users/s****/MagicMirror/MagicMirror
                                            Mykle1M S 2 Replies Last reply Reply Quote 0
                                            • 10
                                            • 11
                                            • 16
                                            • 17
                                            • 9 / 17
