    Automatic Installation doesn't work.
    installationmagicmirror2raspberry pi 3
    25 Posts 5 Posters 9.2k Views 5 Watching
      doyoun0913
      I’m using Raspberry Pi 3 B+, and when I copy and paste the code for automatic installation (bash -c "$(curl -sL https://raw.githubusercontent.com/MichMich/MagicMirror/master/installers/raspberry.sh)"), 0_1578179235039_9f710d81-9df0-46ba-a352-43396628d1bf-image.png
      This is what I get. It doesn’t show me any progress, and no matter how long I wait, there isn’t really anything happening. The terminal won’t show me anything and will sit there like that forever. To resolve this issue, I force exited the installation (of course, this will lock the administration directory and others) and killed the process, but nothing seems to work. In fact, I think the problem much worse as you can see in the image that Magic Mirror Logo is already broken. Maybe this is related to the commands I used ( sudo rm /var/lib/dpkg/lock, sudo dpkg --configure -a, sudo killall apt-get, and sudo --fix-broken install)
      But regardless, I couldn’t see any progress in the beginning anyways. What might be the problem for this?
      The OS for Raspberry Pi is, according to uname -a, Linux raspberrypi 4.19.66-v7+ #1253 SMP Thu Aug 15 11:49:46 BST 2019 armv7l GNU/Linux.
      If you need any more information, I will attach it.
        sdetweil @doyoun0913
        @doyoun0913 yes, the official.installer has a bug, use the development version
        see
        https://forum.magicmirror.builders/topic/10171/updated-installer-script-available-for-testing
          doyoun0913 @sdetweil
          @sdetweil Oh really? Since when did it had a bug?
            @doyoun0913 from the 1st moment… it hangs at the apt-get upgade on some systems
            (because the darned thing prompts, but I have saved stdin and stdout, so u never see the prompt)
            the updater also has a bug… so much fun
              @sdetweil So I ran the command that you had for the developer version and realized that I still have the old, dangling installation I did previously (the official installer that I had to force-stop). So I got this error message as expected: 0_1578181123576_9e1f00ba-9393-41c1-bb9c-25394de216ca-image.png
              Now, can I just remove the lock which is traditionally not recommended with sudo rm /var/lib/apt/lists/lock?
                doyoun0913 @doyoun0913
                @doyoun0913 Actually, nevermind. I did type these: sudo rm /var/cache/apt/archives/lock, sudo rm /var/lib/dpkg/lock, followed by sudo dpkg --configure -a and sudo apt install -f.
                The thing is after I launched your script, I get struck by another error message looks like this:
                What is the problem?
                  @doyoun0913 the dpkg stuff got left in a mess.
                  See here
                  https://unix.stackexchange.com/questions/78004/error-while-using-apt-get-install-for-any-package
                  I think it’s dpkg --configure - a
                    @sdetweil This leads to another problem…
                    I already have searched this issue in the past; I think something is wrong with Google itself possibly. This is the source: Setting up aiy-python-wheels: protobuf not supported on armv6.1 #526
                      @doyoun0913 sorry. I have no idea
                        @sdetweil All good! I forgot to post that I figured it out. Thank you for your help :)
                        S Mykle1M 2 Replies Last reply Reply Quote 0
