    Automatic Installation doesn't work.
    installationmagicmirror2raspberry pi 3
    25 Posts 5 Posters 9.4k Views 5 Watching
      doyoun0913 @doyoun0913
      @doyoun0913 Actually, nevermind. I did type these: sudo rm /var/cache/apt/archives/lock, sudo rm /var/lib/dpkg/lock, followed by sudo dpkg --configure -a and sudo apt install -f.
      The thing is after I launched your script, I get struck by another error message looks like this:
      What is the problem?
        sdetweil @doyoun0913
        @doyoun0913 the dpkg stuff got left in a mess.
        See here
        https://unix.stackexchange.com/questions/78004/error-while-using-apt-get-install-for-any-package
        I think it’s dpkg --configure - a
          doyoun0913 @sdetweil
          @sdetweil This leads to another problem…
          I already have searched this issue in the past; I think something is wrong with Google itself possibly. This is the source: Setting up aiy-python-wheels: protobuf not supported on armv6.1 #526
            @doyoun0913 sorry. I have no idea
              @sdetweil All good! I forgot to post that I figured it out. Thank you for your help :)
              S Mykle1M 2 Replies Last reply Reply Quote 0
                @doyoun0913 what did u end up doing? and then did u redo the script install?
                  Mykle1 Project Sponsor Module Developer @doyoun0913
                  @doyoun0913 said in Automatic Installation doesn't work.:
                  Yes, please post your solution for the benefit of other users that may encounter the same issue. :thumbsup:
                  • K Offline
                    krishnaanivilla @Mykle1
                    @Mykle1 Hello bro the same problem im facing but i stuck with first step unable to move forward please help me
                      sdetweil @krishnaanivilla
                      @krishnaanivilla what have you done so far?
                      did u use the update script from the MM readme page?
                      have u tried the updated version?
                      see here
                      https://forum.magicmirror.builders/topic/10859/new-update-upgrade-script-ready-for-testing?page=1
                      • K Offline
                        krishnaanivilla
                        i have run this
                        bash -c “$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)” apply
                        after this
                        bash -c “$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/raspberry.sh)”
                        but still it is showing updating packages and not moving forward
