    Automatic Installation doesn't work.
    installationmagicmirror2raspberry pi 3
    25 Posts 5 Posters 9.6k Views 5 Watching
      sdetweil @doyoun0913
      @doyoun0913 from the 1st moment… it hangs at the apt-get upgade on some systems
      (because the darned thing prompts, but I have saved stdin and stdout, so u never see the prompt)
      the updater also has a bug… so much fun
        doyoun0913 @sdetweil
        @sdetweil So I ran the command that you had for the developer version and realized that I still have the old, dangling installation I did previously (the official installer that I had to force-stop). So I got this error message as expected: 0_1578181123576_9e1f00ba-9393-41c1-bb9c-25394de216ca-image.png
        Now, can I just remove the lock which is traditionally not recommended with sudo rm /var/lib/apt/lists/lock?
          doyoun0913 @doyoun0913
          @doyoun0913 Actually, nevermind. I did type these: sudo rm /var/cache/apt/archives/lock, sudo rm /var/lib/dpkg/lock, followed by sudo dpkg --configure -a and sudo apt install -f.
          The thing is after I launched your script, I get struck by another error message looks like this:
          What is the problem?
            @doyoun0913 the dpkg stuff got left in a mess.
            See here
            https://unix.stackexchange.com/questions/78004/error-while-using-apt-get-install-for-any-package
            I think it’s dpkg --configure - a
              @sdetweil This leads to another problem…
              I already have searched this issue in the past; I think something is wrong with Google itself possibly. This is the source: Setting up aiy-python-wheels: protobuf not supported on armv6.1 #526
                @doyoun0913 sorry. I have no idea
                  @sdetweil All good! I forgot to post that I figured it out. Thank you for your help :)
                  S Mykle1M 2 Replies Last reply Reply Quote 0
                    @doyoun0913 what did u end up doing? and then did u redo the script install?
                      Mykle1 Project Sponsor Module Developer @doyoun0913
                      @doyoun0913 said in Automatic Installation doesn't work.:
                      Yes, please post your solution for the benefit of other users that may encounter the same issue. :thumbsup:
                      • K Offline
                        krishnaanivilla @Mykle1
                        @Mykle1 Hello bro the same problem im facing but i stuck with first step unable to move forward please help me
