    Automatic Installation doesn't work.
    installationmagicmirror2raspberry pi 3
    25 Posts 5 Posters 12.0k Views 5 Watching
      doyoun0913
      I’m using Raspberry Pi 3 B+, and when I copy and paste the code for automatic installation (bash -c "$(curl -sL https://raw.githubusercontent.com/MichMich/MagicMirror/master/installers/raspberry.sh)"), 0_1578179235039_9f710d81-9df0-46ba-a352-43396628d1bf-image.png
      This is what I get. It doesn’t show me any progress, and no matter how long I wait, there isn’t really anything happening. The terminal won’t show me anything and will sit there like that forever. To resolve this issue, I force exited the installation (of course, this will lock the administration directory and others) and killed the process, but nothing seems to work. In fact, I think the problem much worse as you can see in the image that Magic Mirror Logo is already broken. Maybe this is related to the commands I used ( sudo rm /var/lib/dpkg/lock, sudo dpkg --configure -a, sudo killall apt-get, and sudo --fix-broken install)
      But regardless, I couldn’t see any progress in the beginning anyways. What might be the problem for this?
      The OS for Raspberry Pi is, according to uname -a, Linux raspberrypi 4.19.66-v7+ #1253 SMP Thu Aug 15 11:49:46 BST 2019 armv7l GNU/Linux.
      If you need any more information, I will attach it.
        sdetweil @doyoun0913
        @doyoun0913 yes, the official.installer has a bug, use the development version
        see
        https://forum.magicmirror.builders/topic/10171/updated-installer-script-available-for-testing
          doyoun0913 @sdetweil
          @sdetweil Oh really? Since when did it had a bug?
            @doyoun0913 from the 1st moment… it hangs at the apt-get upgade on some systems
            (because the darned thing prompts, but I have saved stdin and stdout, so u never see the prompt)
            the updater also has a bug… so much fun
              @sdetweil So I ran the command that you had for the developer version and realized that I still have the old, dangling installation I did previously (the official installer that I had to force-stop). So I got this error message as expected: 0_1578181123576_9e1f00ba-9393-41c1-bb9c-25394de216ca-image.png
              Now, can I just remove the lock which is traditionally not recommended with sudo rm /var/lib/apt/lists/lock?
                doyoun0913 @doyoun0913
                @doyoun0913 Actually, nevermind. I did type these: sudo rm /var/cache/apt/archives/lock, sudo rm /var/lib/dpkg/lock, followed by sudo dpkg --configure -a and sudo apt install -f.
                The thing is after I launched your script, I get struck by another error message looks like this:
                What is the problem?
                  @doyoun0913 the dpkg stuff got left in a mess.
                  See here
                  https://unix.stackexchange.com/questions/78004/error-while-using-apt-get-install-for-any-package
                  I think it’s dpkg --configure - a
                    @sdetweil This leads to another problem…
                    I already have searched this issue in the past; I think something is wrong with Google itself possibly. This is the source: Setting up aiy-python-wheels: protobuf not supported on armv6.1 #526
                      @doyoun0913 sorry. I have no idea
                        @sdetweil All good! I forgot to post that I figured it out. Thank you for your help :)
                        S Mykle1M 2 Replies Last reply Reply Quote 0
                          @doyoun0913 what did u end up doing? and then did u redo the script install?
                            Mykle1 Project Sponsor Module Developer @doyoun0913
                            @doyoun0913 said in Automatic Installation doesn't work.:
                            Yes, please post your solution for the benefit of other users that may encounter the same issue. :thumbsup:
                            • K Offline
                              krishnaanivilla @Mykle1
                              @Mykle1 Hello bro the same problem im facing but i stuck with first step unable to move forward please help me
                                sdetweil @krishnaanivilla
                                @krishnaanivilla what have you done so far?
                                did u use the update script from the MM readme page?
                                have u tried the updated version?
                                see here
                                https://forum.magicmirror.builders/topic/10859/new-update-upgrade-script-ready-for-testing?page=1
                                • K Offline
                                  krishnaanivilla
                                  i have run this
                                  bash -c “$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)” apply
                                  after this
                                  bash -c “$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/raspberry.sh)”
                                  but still it is showing updating packages and not moving forward
                                    @krishnaanivilla send me the ~/MagicMirror/installers/upgrade.log file… same userid as here, at gmail
                                    • K Offline
                                      krishnaanivilla @sdetweil
                                      @sdetweil pi@raspberrypi:~ $ bash -c “$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)”
                                      the log will be /home/pi/MagicMirror/installers/upgrade.log
                                      No LSB modules are available.
                                      doing test run = true
                                      saving custom.css
                                      cp: cannot stat ‘custom.css’: No such file or directory
                                      upgrading from version 2.10.0 to 2.10.0
                                      fetching latest revisions
                                      there are 1 local files that are different than the master repo
                                      package-lock.json
                                      any *-lock.json files do not need to be saved
                                      do you want to save these files for later (Y/n)?y
                                      *** Please tell me who you are.
                                      Run
                                      git config --global user.email “you@example.com”
                                      git config --global user.name “Your Name”
                                      to set your account’s default identity.
                                      Omit --global to set the identity only in this repository.
                                      fatal: unable to auto-detect email address (got ‘pi@raspberrypi.(none)’)
                                      Cannot save the current index state
                                      no modules found needing npm refresh
                                      restoring custom.css
                                      cp: cannot stat ‘save_custom.css’: No such file or directory
                                      rm: cannot remove ‘save_custom.css’: No such file or directory
                                      bash: line 339: unalias: git: not found
                                      test run, restoring files stashed
                                      No stash entries found.
                                      saving custom.css
                                      package-lock.json
                                      do you want to save these files for later (Y/n)?n
                                      skipping restore for package-lock.json, doing test run
                                      saving custom.css
                                      package-lock.json
                                      Run
                                      pi@raspberrypi:~ $ bash -c “$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/raspberry.sh)”
                                      $$$\ $$$ | _| $$$\ $$$ |_| $$ $$
                                      $$$$\ $$$$ | $$$$$$\ $$$$$$\ $$\ $$$$$$$\ $$$$\ $$$$ |$$\ $$$$$$\ $$$$$$\ $$$$$$\ $$$$$$\ _/ $$ |
                                      $$$$$$ $$ | _
                                      $$ $$$ $$ | $$$$$$$ |$$ / $$ |$$ |$$ / $$ $$$ $$ |$$ |$$ | _|$$ | _|$$ / $$ |$$ | _|$$ /
                                      $$ |$ /$$ |$$ __$$ |$$ | $$ |$$ |$$ | $$ |$ /$$ |$$ |$$ | $$ | $$ | $$ |$$ | $$ |
                                      $$ | _/ $$ |$$$$$$$ |$$$$$$$ |$$ |$$$$$$$\ $$ | _/ $$ |$$ |$$ | $$ | $$$$$$ |$$ | $$$$$$$$
                                      _
                                      | _
                                      | _
                                      | _
                                      $$ |_| _
                                      |_| _|_|_| __| _
                                      / _| _______|
                                      _
                                      ____/
                                      install log being saved to /home/pi/install.log
                                      Updating packages …
                                        working on this in chat
                                        • K Offline
                                          krishnaanivilla
                                          • K Offline
                                            @sdetweil Initializing MagicMirror.
                                            translator.js:202 Loading core translation file: translations/en.json
                                            translator.js:225 Loading core translation fallback file: translations/en.json
                                            loader.js:179 Load script: modules/aiclient//aiclient.js
                                            module.js:476 Module registered: aiclient
                                            loader.js:150 Bootstrapping module: aiclient
                                            loader.js:155 Scripts loaded for: aiclient
                                            loader.js:194 Load stylesheet: vendor/node_modules/weathericons/css/weather-icons.css
                                            loader.js:194 Load stylesheet: modules/aiclient/currentweather.css
                                            loader.js:157 Styles loaded for: aiclient
                                            loader.js:159 Translations loaded for: aiclient
                                            loader.js:179 Load script: modules/aiclientdebugger//aiclientdebugger.js
                                            module.js:476 Module registered: aiclientdebugger
                                            loader.js:150 Bootstrapping module: aiclientdebugger
                                            loader.js:155 Scripts loaded for: aiclientdebugger
                                            loader.js:157 Styles loaded for: aiclientdebugger
                                            loader.js:159 Translations loaded for: aiclientdebugger
                                            loader.js:194 Load stylesheet: css/custom.css
                                            :8080/modules/aiclient//aiclient.js:39 Starting module: aiclient
                                            aiclientdebugger.js:20 Starting module: aiclientdebugger
                                            main.js:473 All modules started!
                                            module.js:156 aiclient received a system notification: ALL_MODULES_STARTED
                                            module.js:156 aiclientdebugger received a system notification: ALL_MODULES_STARTED
                                            module.js:156 aiclient received a system notification: MODULE_DOM_CREATED
                                            module.js:156 aiclientdebugger received a system notification: MODULE_DOM_CREATED
                                            module.js:156 aiclient received a system notification: DOM_OBJECTS_CREATED
                                            module.js:156 aiclientdebugger received a system notification: DOM_OBJECTS_CREATED
