Unsolved Unable to install dependencies, NPM install not working
Guys, thanks for your great help!
I fixed this problem, now. Well, after fixing this problem I got several problem more :D
@PaulB How did you fix the problem?
@cpramhofer I did everything from the scratch :-D
- Reformation the SD Card
- Copying the Software to the SD Card.
- Installing everything
- Installing the MM2 Software via the link on Michaels website
–> Conclusion: No no problem more :D
i want to say that via ssh it comes the problem
Reinstalled the OS (Raspbian 8.0) and followed @KirAsh4 's install posts. Still fail at the electron install. Has anyone found a solution?
Could one of the advanced pro users here try a fresh install and see if they hit the same problems most are experiencing here?
I’ve been trying to install Node from the tarball but the make install was running for hours and still verbosely outputting as though it was doing things…
I will try this weekend. Haven’t had much free time lately.
@KirAsh4 said in Unable to install dependencies, NPM install not working:
WHAT? Free time… what’s this ‘free time’ thing of which you speak? Hahahahahaha
here is what i meant bevor:
this warning comes during the exectution of the install script.
npm WARN deprecated electron-prebuilt@1.3.8: electron-prebuilt has been renamed to electron. For more details, see http://electron.atom.io/blog/2016/08/16/npm-install-electron
my process:
- blank sd card
- copy image of RASPBIAN JESSIE LITE 2016-09-23
- setup the Pi with Wlan/Ip
- update/upgrade
but as far as i can see this is an electron issue as some others also face this problems.
