    Unable to install dependencies, NPM install not working
    66 Posts 19 Posters 127.8k Views 16 Watching
      jamlid @geeflaxx
      @geeflaxx I’ve tried it on a fresh install of Jessie, but you’re right, I don’t have rpi-update either. Come to think of it, I did install Jessie Lite rather than the full verison. Not sure what exactly is stripped out of the Lite version and if it’s enough to make a difference to this?
      • Y
        yawns Moderator
        Did you try sudo apt-get install rpi-update to install rpi-updat before running it?
        • G
          geeflaxx
          http://www.bilder-upload.eu/show.php?file=df2e81-1477496516.png
          http://www.bilder-upload.eu/show.php?file=64ba61-1477496550.png
          it doesn’t work anything any other ideas ? :/
          • Y
            yawns Moderator
            In your first screenshot the command install is missing
              cpramhofer
              hi guys,
              i have actually the same problem.
              i started with a fresh version of jessie with pixel and followed the setup tutorial mentioned above.
              with update upgrade a new kernel was installed.
              i also recognized that there have been a few lines telling me that “electron” has now a new name…maybe this could be some reason?
              electron-quick-start is also not working!!
              • G
                geeflaxx
                oh i wanted to use ‘sudo rpi update’
                look on my second command i wanted to install it
                i forget remove the apt-get …
                but ‘sudo rpi update’ is still not working
                electron is the problem
                • G
                  geeflaxx
                  BRO I GOT IT !!!
                  sudo apt-get upgrade
                  and than npm install npm install
                  I LOVE YOU ALL !
                    cpramhofer
                    where exactly did you run npm install?
                      PaulB
                      Guys, thanks for your great help!
                      I fixed this problem, now. Well, after fixing this problem I got several problem more :D
                      J 1 Reply Last reply
                      • G
                        geeflaxx
                          jamlid @PaulB
                          @PaulB How did you fix the problem?
                            PaulB
                            @cpramhofer I did everything from the scratch :-D
                            1. Reformation the SD Card
                            2. Copying the Software to the SD Card.
                            3. Installing everything
                            4. Installing the MM2 Software via the link on Michaels website
                            –> Conclusion: No no problem more :D
                            • G
                              geeflaxx
                              i want to say that via ssh it comes the problem
                              • K
                                kiefersmith
                                Reinstalled the OS (Raspbian 8.0) and followed @KirAsh4 's install posts. Still fail at the electron install. Has anyone found a solution?
                                  jamlid
                                  Could one of the advanced pro users here try a fresh install and see if they hit the same problems most are experiencing here?
                                  I’ve been trying to install Node from the tarball but the make install was running for hours and still verbosely outputting as though it was doing things…
                                  • K
                                    KirAsh4 Moderator
                                    I will try this weekend. Haven’t had much free time lately.
                                    Reply Quote 2
                                    • cowboysdudeC
                                      cowboysdude Module Developer @KirAsh4
                                      @KirAsh4 said in Unable to install dependencies, NPM install not working:
                                      WHAT? Free time… what’s this ‘free time’ thing of which you speak? Hahahahahaha
                                        cpramhofer
                                        here is what i meant bevor:
                                        this warning comes during the exectution of the install script.
                                        npm WARN deprecated electron-prebuilt@1.3.8: electron-prebuilt has been renamed to electron. For more details, see http://electron.atom.io/blog/2016/08/16/npm-install-electron
                                        my process:
                                        • blank sd card
                                        • copy image of RASPBIAN JESSIE LITE 2016-09-23
                                        • setup the Pi with Wlan/Ip
                                        • update/upgrade
                                        but as far as i can see this is an electron issue as some others also face this problems.
                                          cpramhofer
                                          1 verbose cli [ ‘/usr/bin/nodejs’, ‘/usr/bin/npm’, ‘start’ ]
                                          2 info using npm@3.10.8
                                          3 info using node@v6.9.1
                                          4 verbose run-script [ ‘prestart’, ‘start’, ‘poststart’ ]
                                          5 info lifecycle magicmirror@2.0.0~prestart: magicmirror@2.0.0
                                          6 silly lifecycle magicmirror@2.0.0~prestart: no script for prestart, continuing
                                          7 info lifecycle magicmirror@2.0.0~start: magicmirror@2.0.0
                                          8 verbose lifecycle magicmirror@2.0.0~start: unsafe-perm in lifecycle true
                                          9 verbose lifecycle magicmirror@2.0.0~start: PATH: /usr/lib/node_modules/npm/bin/node-gyp-bin:/home/pi/MagicMirror/node_modules/.bin:/usr/local/sbin:/usr/local/bin:$
                                          10 verbose lifecycle magicmirror@2.0.0~start: CWD: /home/pi/MagicMirror
                                          11 silly lifecycle magicmirror@2.0.0~start: Args: [ ‘-c’, ‘electron js/electron.js’ ]
                                          12 silly lifecycle magicmirror@2.0.0~start: Returned: code: 1 signal: null
                                          13 info lifecycle magicmirror@2.0.0~start: Failed to exec start script
                                          14 verbose stack Error: magicmirror@2.0.0 start: electron js/electron.js
                                          14 verbose stack Exit status 1
                                          14 verbose stack at EventEmitter. (/usr/lib/node_modules/npm/lib/utils/lifecycle.js:255:16)
                                          14 verbose stack at emitTwo (events.js:106:13)
                                          14 verbose stack at EventEmitter.emit (events.js:191:7)
                                          14 verbose stack at ChildProcess. (/usr/lib/node_modules/npm/lib/utils/spawn.js:40:14)
                                          14 verbose stack at ChildProcess.emit (events.js:191:7)
                                          14 verbose stack at maybeClose (internal/child_process.js:877:16)
                                          14 verbose stack at Process.ChildProcess._handle.onexit (internal/child_process.js:226:5)
                                          15 verbose pkgid magicmirror@2.0.0
                                          16 verbose cwd /home/pi/MagicMirror
                                          17 error Linux 4.4.21-v7+
                                          18 error argv “/usr/bin/nodejs” “/usr/bin/npm” “start”
                                          19 error node v6.9.1
                                          20 error npm v3.10.8
                                          21 error code ELIFECYCLE
                                          22 error magicmirror@2.0.0 start: electron js/electron.js
                                          22 error Exit status 1
                                          23 error Failed at the magicmirror@2.0.0 start script ‘electron js/electron.js’.
                                          23 error Make sure you have the latest version of node.js and npm installed.
                                          23 error If you do, this is most likely a problem with the magicmirror package,
                                          23 error not with npm itself.
                                          23 error Tell the author that this fails on your system:
                                          23 error electron js/electron.js
                                          23 error You can get information on how to open an issue for this project with:
                                          23 error npm bugs magicmirror
                                          23 error Or if that isn’t available, you can get their info via:
                                          23 error npm owner ls magicmirror
                                          23 error There is likely additional logging output above.
                                          24 verbose exit [ 1, true ]
                                            cpramhofer
                                            next try…
                                            1., installed NOOBS
                                            2., installed JESSIE LITE
                                            3., Setup WLAN, IP, Internalisation, Update, Upgrade
                                            4., Setup MM2:
                                            pi@MM:~ $ curl -sL https://raw.githubusercontent.com/MichMich/MagicMirror/master/installers/raspberry.sh | bash
                                            $$$\ $$$ | _| $$$\ $$$ |_| $$ $$
                                            $$$$\ $$$$ | $$$$$$\ $$$$$$\ $$\ $$$$$$$\ $$$$\ $$$$ |$$\ $$$$$$\ $$$$$$\ $$$$$$\ $$$$$$\ _/ $$ |
                                            $$$$$$ $$ | _
                                            $$ $$$ $$ | $$$$$$$ |$$ / $$ |$$ |$$ / $$ $$$ $$ |$$ |$$ | _|$$ | _|$$ / $$ |$$ | _|$$ /
                                            $$ |$ /$$ |$$ __$$ |$$ | $$ |$$ |$$ | $$ |$ /$$ |$$ |$$ | $$ | $$ | $$ |$$ | $$ |
                                            $$ | _/ $$ |$$$$$$$ |$$$$$$$ |$$ |$$$$$$$\ $$ | _/ $$ |$$ |$$ | $$ | $$$$$$ |$$ | $$$$$$$$
                                            _
                                            | _
                                            | _
                                            | _
                                            $$ |_| _
                                            |_| _|_|_| __| _
                                            / _| _______|
                                            _
                                            ____/
                                            Installing helper tools …
                                            Paketlisten werden gelesen… Fertig
                                            Abhängigkeitsbaum wird aufgebaut.
                                            Statusinformationen werden eingelesen… Fertig
                                            build-essential ist schon die neueste Version.
                                            curl ist schon die neueste Version.
                                            unzip ist schon die neueste Version.
                                            wget ist schon die neueste Version.
                                            Vorgeschlagene Pakete:
                                            gettext-base git-daemon-run git-daemon-sysvinit git-doc git-el git-email
                                            git-gui gitk gitweb git-arch git-cvs git-mediawiki git-svn
                                            Die folgenden NEUEN Pakete werden installiert:
                                            git git-man libcurl3-gnutls liberror-perl rsync
                                            0 aktualisiert, 5 neu installiert, 0 zu entfernen und 0 nicht aktualisiert.
                                            Es müssen 4.613 kB an Archiven heruntergeladen werden.
                                            Nach dieser Operation werden 21,5 MB Plattenplatz zusätzlich benutzt.
                                            Holen: 1 http://mirrordirector.raspbian.org/raspbian/ jessie/main libcurl3-gnutls armhf 7.38.0-4+deb8u4 [225 kB]
                                            Holen: 2 http://mirrordirector.raspbian.org/raspbian/ jessie/main liberror-perl all 0.17-1.1 [22,4 kB]
                                            Holen: 3 http://mirrordirector.raspbian.org/raspbian/ jessie/main git-man all 1:2.1.4-2.1+deb8u2 [1.267 kB]
                                            Holen: 4 http://mirrordirector.raspbian.org/raspbian/ jessie/main git armhf 1:2.1.4-2.1+deb8u2 [2.725 kB]
                                            Holen: 5 http://mirrordirector.raspbian.org/raspbian/ jessie/main rsync armhf 3.1.1-3 [373 kB]
                                            Es wurden 4.613 kB in 2 s geholt (1.577 kB/s).
                                            Vormals nicht ausgewähltes Paket libcurl3-gnutls:armhf wird gewählt.
                                            (Lese Datenbank … 31227 Dateien und Verzeichnisse sind derzeit installiert.)
                                            Vorbereitung zum Entpacken von …/libcurl3-gnutls_7.38.0-4+deb8u4_armhf.deb …
                                            Entpacken von libcurl3-gnutls:armhf (7.38.0-4+deb8u4) …
                                            Vormals nicht ausgewähltes Paket liberror-perl wird gewählt.
                                            Vorbereitung zum Entpacken von …/liberror-perl_0.17-1.1_all.deb …
                                            Entpacken von liberror-perl (0.17-1.1) …
                                            Vormals nicht ausgewähltes Paket git-man wird gewählt.
                                            Vorbereitung zum Entpacken von …/git-man_1%3a2.1.4-2.1+deb8u2_all.deb …
                                            Entpacken von git-man (1:2.1.4-2.1+deb8u2) …
                                            Vormals nicht ausgewähltes Paket git wird gewählt.
                                            Vorbereitung zum Entpacken von …/git_1%3a2.1.4-2.1+deb8u2_armhf.deb …
                                            Entpacken von git (1:2.1.4-2.1+deb8u2) …
                                            Vormals nicht ausgewähltes Paket rsync wird gewählt.
                                            Vorbereitung zum Entpacken von …/rsync_3.1.1-3_armhf.deb …
                                            Entpacken von rsync (3.1.1-3) …
                                            Trigger für man-db (2.7.0.2-5) werden verarbeitet …
                                            Trigger für systemd (215-17+deb8u5) werden verarbeitet …
                                            libcurl3-gnutls:armhf (7.38.0-4+deb8u4) wird eingerichtet …
                                            liberror-perl (0.17-1.1) wird eingerichtet …
                                            git-man (1:2.1.4-2.1+deb8u2) wird eingerichtet …
                                            git (1:2.1.4-2.1+deb8u2) wird eingerichtet …
                                            rsync (3.1.1-3) wird eingerichtet …
                                            Trigger für libc-bin (2.19-18+deb8u6) werden verarbeitet …
                                            Check current Node installation …
                                            Node.js is not installed.
                                            Installing Node.js …
                                            Installing the NodeSource Node.js v6.x repo…
                                            Populating apt-get cache…
                                            • apt-get update
                                              OK http://archive.raspberrypi.org jessie InRelease
                                              OK http://mirrordirector.raspbian.org jessie InRelease
                                              OK http://mirrordirector.raspbian.org jessie/main armhf Packages
                                              OK http://mirrordirector.raspbian.org jessie/contrib armhf Packages
                                              OK http://mirrordirector.raspbian.org jessie/non-free armhf Packages
                                              OK http://mirrordirector.raspbian.org jessie/rpi armhf Packages
                                              Ign http://mirrordirector.raspbian.org jessie/contrib Translation-de_AT
                                              Ign http://mirrordirector.raspbian.org jessie/contrib Translation-en
                                              Ign http://mirrordirector.raspbian.org jessie/main Translation-de_AT
                                              Ign http://mirrordirector.raspbian.org jessie/main Translation-en
                                              Ign http://mirrordirector.raspbian.org jessie/non-free Translation-de_AT
                                              Ign http://mirrordirector.raspbian.org jessie/non-free Translation-en
                                              Ign http://mirrordirector.raspbian.org jessie/rpi Translation-de_AT
                                              Ign http://mirrordirector.raspbian.org jessie/rpi Translation-en
                                              OK http://archive.raspberrypi.org jessie/main armhf Packages
                                              OK http://archive.raspberrypi.org jessie/ui armhf Packages
                                              Ign http://archive.raspberrypi.org jessie/main Translation-de_AT
                                              Ign http://archive.raspberrypi.org jessie/main Translation-en
                                              Ign http://archive.raspberrypi.org jessie/ui Translation-de_AT
                                              Ign http://archive.raspberrypi.org jessie/ui Translation-en
                                            Installing packages required for setup: apt-transport-https…
                                            • apt-get install -y apt-transport-https > /dev/null 2>&1
                                            Confirming “jessie” is supported…
                                            • curl -sLf -o /dev/null ‘https://deb.nodesource.com/node_6.x/dists/jessie/Release’
                                            Adding the NodeSource signing key to your keyring…
                                            • curl -s https://deb.nodesource.com/gpgkey/nodesource.gpg.key | apt-key add -
                                              OK
                                            Creating apt sources list file for the NodeSource Node.js v6.x repo…
                                            • echo ‘deb https://deb.nodesource.com/node_6.x jessie main’ > /etc/apt/sources.list.d/nodesource.list
                                            • echo ‘deb-src https://deb.nodesource.com/node_6.x jessie main’ >> /etc/apt/sources.list.d/nodesource.list
                                            Running apt-get update for you…
                                            • apt-get update
                                              Holen: 1 https://deb.nodesource.com jessie InRelease [3.914 B]
                                              Holen: 2 https://deb.nodesource.com jessie/main Sources [760 B]
                                              Holen: 3 https://deb.nodesource.com jessie/main armhf Packages [962 B]
                                              Holen: 4 https://deb.nodesource.com jessie/main Translation-de_AT [162 B]
                                              Holen: 5 https://deb.nodesource.com jessie/main Translation-de [162 B]
                                              Holen: 6 https://deb.nodesource.com jessie/main Translation-en [162 B]
                                              Holen: 7 https://deb.nodesource.com jessie/main Translation-de_AT [162 B]
                                              Holen: 8 https://deb.nodesource.com jessie/main Translation-de [162 B]
                                              Holen: 9 https://deb.nodesource.com jessie/main Translation-en [162 B]
                                              Holen: 10 https://deb.nodesource.com jessie/main Translation-de_AT [162 B]
                                              Holen: 11 https://deb.nodesource.com jessie/main Translation-de [162 B]
                                              Holen: 12 https://deb.nodesource.com jessie/main Translation-en [162 B]
                                              Holen: 13 https://deb.nodesource.com jessie/main Translation-de_AT [162 B]
                                              Holen: 14 https://deb.nodesource.com jessie/main Translation-de [162 B]
                                              Holen: 15 https://deb.nodesource.com jessie/main Translation-en [162 B]
                                              Holen: 16 https://deb.nodesource.com jessie/main Translation-de_AT [162 B]
                                              Ign https://deb.nodesource.com jessie/main Translation-de_AT
                                              Holen: 17 https://deb.nodesource.com jessie/main Translation-de [162 B]
                                              Holen: 18 https://deb.nodesource.com jessie/main Translation-en [162 B]
                                              Ign https://deb.nodesource.com jessie/main Translation-en
                                              Es wurden 5.636 B in 8 s geholt (688 B/s).
                                            Run apt-get install nodejs (as root) to install Node.js v6.x and npm
                                            nodejs
                                            0 aktualisiert, 1 neu installiert, 0 zu entfernen und 0 nicht aktualisiert.
                                            Es müssen 8.932 kB an Archiven heruntergeladen werden.
                                            Nach dieser Operation werden 45,5 MB Plattenplatz zusätzlich benutzt.
                                            Holen: 1 https://deb.nodesource.com/node_6.x/ jessie/main nodejs armhf 6.9.1-1nodesource1~jessie1 [8.932 kB]
                                            Es wurden 8.932 kB in 6 s geholt (1.367 kB/s).
                                            Vormals nicht ausgewähltes Paket nodejs wird gewählt.
                                            (Lese Datenbank … 32046 Dateien und Verzeichnisse sind derzeit installiert.)
                                            Vorbereitung zum Entpacken von …/nodejs_6.9.1-1nodesource1~jessie1_armhf.deb …
                                            Entpacken von nodejs (6.9.1-1nodesource1~jessie1) …
                                            nodejs (6.9.1-1nodesource1~jessie1) wird eingerichtet …
                                            Node.js installation Done!
                                            Cloning MagicMirror …
                                            Klone nach ‘MagicMirror’…
                                            remote: Counting objects: 4363, done.
                                            remote: Compressing objects: 100% (5/5), done.
                                            remote: Total 4363 (delta 0), reused 0 (delta 0), pack-reused 4358
                                            Empfange Objekte: 100% (4363/4363), 10.43 MiB | 920.00 KiB/s, Fertig.
                                            Löse Unterschiede auf: 100% (2288/2288), Fertig.
                                            Prüfe Konnektivität… Fertig.
                                            Cloning MagicMirror Done!
                                            Installing dependencies …
                                            npm WARN prefer global coffee-script@1.10.0 should be installed with -g
                                            npm WARN prefer global colorguard@1.2.0 should be installed with -g
                                            npm WARN prefer global jsonlint@1.6.2 should be installed with -g
                                            electron-prebuilt@1.3.8 postinstall /home/pi/MagicMirror/node_modules/electron-prebuilt
                                            node install.js
                                            Downloading SHASUMS256.txt
                                            [============================================>] 100.0% of 2.77 kB (2.77 kB/s)
                                            magicmirror@2.0.0 prepublish /home/pi/MagicMirror
                                            npm run snyk-protect
                                            magicmirror@2.0.0 snyk-protect /home/pi/MagicMirror
                                            snyk protect
                                            Successfully applied Snyk patches
                                            magicmirror@2.0.0 /home/pi/MagicMirror
                                            ├─┬ electron-prebuilt@1.3.8
                                            │ ├─┬ electron-download@3.0.1
                                            │ │ ├─┬ fs-extra@0.30.0
                                            │ │ │ ├── jsonfile@2.4.0
                                            │ │ │ ├── klaw@1.3.1
                                            │ │ │ └── rimraf@2.5.4
                                            │ │ ├── home-path@1.0.3
                                            │ │ ├── minimist@1.2.0
                                            │ │ ├─┬ nugget@2.0.1
                                            │ │ │ ├── pretty-bytes@1.0.4
                                            │ │ │ ├─┬ progress-stream@1.2.0
                                            │ │ │ │ ├── speedometer@0.1.4
                                            │ │ │ │ └─┬ through2@0.2.3
                                            │ │ │ │ └─┬ xtend@2.1.2
                                            │ │ │ │ └── object-keys@0.4.0
                                            │ │ │ ├── single-line-log@1.1.2
                                            │ │ │ └── throttleit@0.0.2
                                            │ │ ├── path-exists@2.1.0
                                            │ │ ├─┬ rc@1.1.6
                                            │ │ │ ├── deep-extend@0.4.1
                                            │ │ │ └── ini@1.3.4
                                            │ │ └── sumchecker@1.2.0
                                            │ └─┬ extract-zip@1.5.0
                                            │ ├─┬ concat-stream@1.5.0
                                            │ │ ├─┬ readable-stream@2.0.6
                                            │ │ │ ├── core-util-is@1.0.2
                                            │ │ │ ├── isarray@1.0.0
                                            │ │ │ ├── process-nextick-args@1.0.7
                                            │ │ │ ├── string_decoder@0.10.31
                                            │ │ │ └── util-deprecate@1.0.2
                                            │ │ └── typedarray@0.0.6
                                            │ ├── debug@0.7.4
                                            │ ├─┬ mkdirp@0.5.0
                                            │ │ └── minimist@0.0.8
                                            │ └─┬ yauzl@2.4.1
                                            │ └─┬ fd-slicer@1.0.1
                                            │ └── pend@1.2.0
                                            ├─┬ express@4.14.0
                                            │ ├─┬ accepts@1.3.3
                                            │ │ └── negotiator@0.6.1
                                            │ ├── array-flatten@1.1.1
                                            │ ├── content-disposition@0.5.1
                                            │ ├── content-type@1.0.2
                                            │ ├── cookie@0.3.1
                                            │ ├── cookie-signature@1.0.6
                                            │ ├─┬ debug@2.2.0
                                            │ │ └── ms@0.7.1
                                            │ ├── depd@1.1.0
                                            │ ├── encodeurl@1.0.1
                                            │ ├── escape-html@1.0.3
                                            │ ├── etag@1.7.0
                                            │ ├─┬ finalhandler@0.5.0
                                            │ │ ├── statuses@1.3.0
                                            │ │ └── unpipe@1.0.0
                                            │ ├── fresh@0.3.0
                                            │ ├── merge-descriptors@1.0.1
                                            │ ├── methods@1.1.2
                                            │ ├─┬ on-finished@2.3.0
                                            │ │ └── ee-first@1.1.1
                                            │ ├── parseurl@1.3.1
                                            │ ├── path-to-regexp@0.1.7
                                            │ ├─┬ proxy-addr@1.1.2
                                            │ │ ├── forwarded@0.1.0
                                            │ │ └── ipaddr.js@1.1.1
                                            │ ├── qs@6.2.0
                                            │ ├── range-parser@1.2.0
                                            │ ├─┬ send@0.14.1
                                            │ │ ├── destroy@1.0.4
                                            │ │ ├─┬ http-errors@1.5.0
                                            │ │ │ ├── inherits@2.0.1
                                            │ │ │ └── setprototypeof@1.0.1
                                            │ │ └── mime@1.3.4
                                            │ ├── serve-static@1.11.1
                                            │ ├─┬ type-is@1.6.13
                                            │ │ └── media-typer@0.3.0
                                            │ ├── utils-merge@1.0.0
                                            │ └── vary@1.1.0
                                            ├─┬ feedme@0.3.2
                                            │ ├── clarinet@0.11.0
                                            │ ├── eventyoshi@0.1.6
                                            │ └── sax@1.2.1
                                            ├─┬ UNMET PEER DEPENDENCY grunt@1.0.1
                                            │ ├── coffee-script@1.10.0
                                            │ ├─┬ dateformat@1.0.12
                                            │ │ ├── get-stdin@4.0.1
                                            │ │ └─┬ meow@3.7.0
                                            │ │ ├─┬ camelcase-keys@2.1.0
                                            │ │ │ └── camelcase@2.1.1
                                            │ │ ├── decamelize@1.2.0
                                            │ │ ├─┬ loud-rejection@1.6.0
                                            │ │ │ ├─┬ currently-unhandled@0.4.1
                                            │ │ │ │ └── array-find-index@1.0.2
                                            │ │ │ └── signal-exit@3.0.1
                                            │ │ ├── map-obj@1.0.1
                                            │ │ ├─┬ normalize-package-data@2.3.5
                                            │ │ │ ├─┬ is-builtin-module@1.0.0
                                            │ │ │ │ └── builtin-modules@1.1.1
                                            │ │ │ └─┬ validate-npm-package-license@3.0.1
                                            │ │ │ ├─┬ spdx-correct@1.0.2
                                            │ │ │ │ └── spdx-license-ids@1.2.2
                                            │ │ │ └── spdx-expression-parse@1.0.4
                                            │ │ ├─┬ read-pkg-up@1.0.1
                                            │ │ │ ├── find-up@1.1.2
                                            │ │ │ └─┬ read-pkg@1.1.0
                                            │ │ │ ├─┬ load-json-file@1.1.0
                                            │ │ │ │ └─┬ strip-bom@2.0.0
                                            │ │ │ │ └── is-utf8@0.2.1
                                            │ │ │ └── path-type@1.1.0
                                            │ │ ├─┬ redent@1.0.0
                                            │ │ │ ├─┬ indent-string@2.1.0
                                            │ │ │ │ └── repeating@2.0.1
                                            │ │ │ └── strip-indent@1.0.1
                                            │ │ └── trim-newlines@1.0.0
                                            │ ├── eventemitter2@0.4.14
                                            │ ├── exit@0.1.2
                                            │ ├─┬ findup-sync@0.3.0
                                            │ │ └── glob@5.0.15
                                            │ ├─┬ glob@7.0.6
                                            │ │ ├── fs.realpath@1.0.0
                                            │ │ ├─┬ inflight@1.0.6
                                            │ │ │ └── wrappy@1.0.2
                                            │ │ ├── inherits@2.0.3
                                            │ │ └── once@1.4.0
                                            │ ├─┬ grunt-cli@1.2.0
                                            │ │ └── resolve@1.1.7
                                            │ ├── grunt-known-options@1.1.0
                                            │ ├─┬ grunt-legacy-log@1.0.0
                                            │ │ ├── colors@1.1.2
                                            │ │ ├─┬ grunt-legacy-log-utils@1.0.0
                                            │ │ │ └── lodash@4.3.0
                                            │ │ ├── lodash@3.10.1
                                            │ │ └── underscore.string@3.2.3
                                            │ ├─┬ grunt-legacy-util@1.0.0
                                            │ │ ├── async@1.5.2
                                            │ │ ├── getobject@0.1.0
                                            │ │ ├── lodash@4.3.0
                                            │ │ └─┬ which@1.2.11
                                            │ │ └── isexe@1.1.2
                                            │ ├─┬ js-yaml@3.5.5
                                            │ │ ├─┬ argparse@1.0.9
                                            │ │ │ └── sprintf-js@1.0.3
                                            │ │ └── esprima@2.7.3
                                            │ ├─┬ minimatch@3.0.3
                                            │ │ └─┬ brace-expansion@1.1.6
                                            │ │ └── concat-map@0.0.1
                                            │ ├── nopt@3.0.6
                                            │ ├── path-is-absolute@1.0.1
                                            │ └── rimraf@2.2.8
                                            ├─┬ grunt-eslint@19.0.0
                                            │ ├─┬ chalk@1.1.3
                                            │ │ ├── ansi-styles@2.2.1
                                            │ │ ├── escape-string-regexp@1.0.5
                                            │ │ ├─┬ has-ansi@2.0.0
                                            │ │ │ └── ansi-regex@2.0.0
                                            │ │ ├── strip-ansi@3.0.1
                                            │ │ └── supports-color@2.0.0
                                            │ └─┬ eslint@3.9.0
                                            │ ├─┬ babel-code-frame@6.16.0
                                            │ │ └── js-tokens@2.0.0
                                            │ ├─┬ doctrine@1.5.0
                                            │ │ └── isarray@1.0.0
                                            │ ├─┬ escope@3.6.0
                                            │ │ ├─┬ es6-map@0.1.4
                                            │ │ │ ├── d@0.1.1
                                            │ │ │ ├── es5-ext@0.10.12
                                            │ │ │ ├── es6-iterator@2.0.0
                                            │ │ │ ├── es6-set@0.1.4
                                            │ │ │ ├── es6-symbol@3.1.0
                                            │ │ │ └── event-emitter@0.3.4
                                            │ │ ├── es6-weak-map@2.0.1
                                            │ │ └─┬ esrecurse@4.1.0
                                            │ │ └── estraverse@4.1.1
                                            │ ├─┬ espree@3.3.2
                                            │ │ ├── acorn@4.0.3
                                            │ │ └─┬ acorn-jsx@3.0.1
                                            │ │ └── acorn@3.3.0
                                            │ ├── estraverse@4.2.0
                                            │ ├── esutils@2.0.2
                                            │ ├─┬ file-entry-cache@2.0.0
                                            │ │ └─┬ flat-cache@1.2.1
                                            │ │ ├── circular-json@0.3.1
                                            │ │ ├─┬ del@2.2.2
                                            │ │ │ ├── globby@5.0.0
                                            │ │ │ ├── is-path-cwd@1.0.0
                                            │ │ │ └─┬ is-path-in-cwd@1.0.0
                                            │ │ │ └── is-path-inside@1.0.0
                                            │ │ └─┬ write@0.2.1
                                            │ │ └─┬ mkdirp@0.5.1
                                            │ ├── glob@7.1.1
                                            │ ├── globals@9.12.0
                                            │ ├── ignore@3.2.0
                                            │ ├── imurmurhash@0.1.4
                                            │ ├─┬ inquirer@0.12.0
                                            │ │ ├─┬ readline2@1.0.1
                                            │ │ │ └── mute-stream@0.0.5
                                            │ │ ├── run-async@0.1.0
                                            │ │ └── rx-lite@3.1.2
                                            │ ├─┬ is-my-json-valid@2.15.0
                                            │ │ ├── generate-function@2.0.0
                                            │ │ ├─┬ generate-object-property@1.2.0
                                            │ │ │ └── is-property@1.0.2
                                            │ │ ├── jsonpointer@4.0.0
                                            │ │ └── xtend@4.0.1
                                            │ ├─┬ is-resolvable@1.0.0
                                            │ │ └── tryit@1.0.3
                                            │ ├─┬ json-stable-stringify@1.0.1
                                            │ │ └── jsonify@0.0.0
                                            │ ├─┬ levn@0.3.0
                                            │ │ ├── prelude-ls@1.1.2
                                            │ │ └── type-check@0.3.2
                                            │ ├── lodash@4.16.4
                                            │ ├── natural-compare@1.4.0
                                            │ ├─┬ optionator@0.8.2
                                            │ │ ├── deep-is@0.1.3
                                            │ │ ├── fast-levenshtein@2.0.5
                                            │ │ └── wordwrap@1.0.0
                                            │ ├── path-is-inside@1.0.2
                                            │ ├── pluralize@1.2.1
                                            │ ├── progress@1.1.8
                                            │ ├─┬ require-uncached@1.0.2
                                            │ │ ├─┬ caller-path@0.1.0
                                            │ │ │ └── callsites@0.2.0
                                            │ │ └── resolve-from@1.0.1
                                            │ ├─┬ shelljs@0.7.5
                                            │ │ ├── interpret@1.0.1
                                            │ │ └── rechoir@0.6.2
                                            │ ├── strip-bom@3.0.0
                                            │ ├── strip-json-comments@1.0.4
                                            │ ├─┬ table@3.8.3
                                            │ │ ├─┬ ajv@4.8.2
                                            │ │ │ └── co@4.6.0
                                            │ │ ├── ajv-keywords@1.1.1
                                            │ │ ├── slice-ansi@0.0.4
                                            │ │ └─┬ string-width@2.0.0
                                            │ │ └── is-fullwidth-code-point@2.0.0
                                            │ └─┬ user-home@2.0.0
                                            │ └── os-homedir@1.0.2
                                            ├─┬ grunt-jsonlint@1.1.0
                                            │ ├─┬ jsonlint@1.6.2
                                            │ │ ├── JSV@4.0.2
                                            │ │ └─┬ nomnom@1.8.1
                                            │ │ ├─┬ chalk@0.4.0
                                            │ │ │ ├── ansi-styles@1.0.0
                                            │ │ │ ├── has-color@0.1.7
                                            │ │ │ └── strip-ansi@0.1.1
                                            │ │ └── underscore@1.6.0
                                            │ └── strip-json-comments@2.0.1
                                            ├─┬ grunt-markdownlint@1.0.9
                                            │ └─┬ markdownlint@0.2.0
                                            │ └─┬ markdown-it@7.0.1
                                            │ ├── entities@1.1.1
                                            │ ├── linkify-it@2.0.2
                                            │ ├── mdurl@1.0.1
                                            │ └── uc.micro@1.0.3
                                            ├─┬ grunt-stylelint@0.6.0
                                            │ └─┬ stylelint@7.5.0
                                            │ ├─┬ autoprefixer@6.5.1
                                            │ │ ├── browserslist@1.4.0
                                            │ │ ├── caniuse-db@1.0.30000570
                                            │ │ ├── normalize-range@0.1.2
                                            │ │ └── num2fraction@1.2.2
                                            │ ├── balanced-match@0.4.2
                                            │ ├─┬ colorguard@1.2.0
                                            │ │ ├── color-diff@0.1.7
                                            │ │ ├─┬ pipetteur@2.0.3
                                            │ │ │ ├── onecolor@3.0.4
                                            │ │ │ └─┬ synesthesia@1.0.1
                                            │ │ │ └── css-color-names@0.0.3
                                            │ │ ├─┬ plur@2.1.2
                                            │ │ │ └── irregular-plurals@1.2.0
                                            │ │ └── yargs@1.3.3
                                            │ ├─┬ cosmiconfig@2.1.0
                                            │ │ ├─┬ parse-json@2.2.0
                                            │ │ │ └─┬ error-ex@1.3.0
                                            │ │ │ └── is-arrayish@0.2.1
                                            │ │ └── require-from-string@1.2.1
                                            │ ├─┬ doiuse@2.5.0
                                            │ │ ├─┬ css-rule-stream@1.1.0
                                            │ │ │ ├── css-tokenize@1.0.1
                                            │ │ │ ├── duplexer2@0.0.2
                                            │ │ │ └─┬ through2@0.6.5
                                            │ │ │ ├── readable-stream@1.0.34
                                            │ │ │ └── xtend@4.0.1
                                            │ │ ├─┬ duplexer2@0.0.2
                                            │ │ │ └── readable-stream@1.1.14
                                            │ │ ├─┬ jsonfilter@1.1.2
                                            │ │ │ ├─┬ JSONStream@0.8.4
                                            │ │ │ │ └── jsonparse@0.0.5
                                            │ │ │ ├─┬ stream-combiner@0.2.2
                                            │ │ │ │ └── duplexer@0.1.1
                                            │ │ ├─┬ ldjson-stream@1.2.1
                                            │ │ │ ├─┬ split2@0.2.1
                                            │ │ │ │ └─┬ through2@0.6.5
                                            │ │ │ │ ├── readable-stream@1.0.34
                                            │ │ │ │ └── xtend@4.0.1
                                            │ │ ├─┬ source-map@0.4.4
                                            │ │ │ └── amdefine@1.0.0
                                            │ │ ├─┬ through2@0.6.5
                                            │ │ └─┬ yargs@3.15.0
                                            │ │ ├── camelcase@1.2.1
                                            │ │ ├─┬ cliui@2.1.0
                                            │ │ │ ├─┬ center-align@0.1.3
                                            │ │ │ │ ├─┬ align-text@0.1.4
                                            │ │ │ │ │ ├─┬ kind-of@3.0.4
                                            │ │ │ │ │ │ └── is-buffer@1.1.4
                                            │ │ │ │ │ ├── longest@1.0.1
                                            │ │ │ │ │ └── repeat-string@1.6.1
                                            │ │ │ │ └── lazy-cache@1.0.4
                                            │ │ │ ├── right-align@0.1.3
                                            │ │ │ └── wordwrap@0.0.2
                                            │ │ └── window-size@0.1.4
                                            │ ├─┬ execall@1.0.0
                                            │ │ └─┬ clone-regexp@1.0.0
                                            │ │ ├── is-regexp@1.0.0
                                            │ │ └── is-supported-regexp-flag@1.0.0
                                            │ ├── get-stdin@5.0.1
                                            │ ├─┬ globby@6.0.0
                                            │ │ └── pify@2.3.0
                                            │ ├── globjoin@0.1.4
                                            │ ├── html-tags@1.1.1
                                            │ ├── known-css-properties@0.0.5
                                            │ ├── log-symbols@1.0.2
                                            │ ├─┬ multimatch@2.1.0
                                            │ │ ├── array-differ@1.0.0
                                            │ │ ├─┬ array-union@1.0.2
                                            │ │ │ └── array-uniq@1.0.3
                                            │ │ └── arrify@1.0.1
                                            │ ├── normalize-selector@0.2.0
                                            │ ├─┬ postcss@5.2.5
                                            │ │ ├── js-base64@2.1.9
                                            │ │ ├── source-map@0.5.6
                                            │ │ └─┬ supports-color@3.1.2
                                            │ │ └── has-flag@1.0.0
                                            │ ├── postcss-less@0.14.0
                                            │ ├── postcss-media-query-parser@0.2.3
                                            │ ├── postcss-reporter@1.4.1
                                            │ ├── postcss-resolve-nested-selector@0.1.1
                                            │ ├── postcss-scss@0.3.1
                                            │ ├─┬ postcss-selector-parser@2.2.1
                                            │ │ ├── flatten@1.0.2
                                            │ │ ├── indexes-of@1.0.1
                                            │ │ └── uniq@1.0.1
                                            │ ├── postcss-value-parser@3.3.0
                                            │ ├── resolve-from@2.0.0
                                            │ ├── specificity@0.3.0
                                            │ ├─┬ string-width@2.0.0
                                            │ ├── style-search@0.1.0
                                            │ ├─┬ stylehacks@2.3.1
                                            │ │ ├─┬ read-file-stdin@0.2.1
                                            │ │ │ └── gather-stream@1.0.0
                                            │ │ └── write-file-stdout@0.0.2
                                            │ ├── sugarss@0.2.0
                                            │ └── svg-tags@1.0.0
                                            ├─┬ grunt-yamllint@0.2.0
                                            │ ├── async@0.9.2
                                            │ ├─┬ chalk@0.5.1
                                            │ │ ├── ansi-styles@1.1.0
                                            │ │ ├─┬ has-ansi@0.1.0
                                            │ │ │ └── ansi-regex@0.2.1
                                            │ │ ├── strip-ansi@0.3.0
                                            │ │ └── supports-color@0.2.0
                                            │ └── js-yaml@3.6.1
                                            ├── iconv-lite@0.4.13
                                            ├── moment@2.15.2
                                            ├─┬ request@2.76.0
                                            │ ├── aws-sign2@0.6.0
                                            │ ├── aws4@1.5.0
                                            │ ├── caseless@0.11.0
                                            │ ├─┬ combined-stream@1.0.5
                                            │ │ └── delayed-stream@1.0.0
                                            │ ├── extend@3.0.0
                                            │ ├── forever-agent@0.6.1
                                            │ ├─┬ form-data@2.1.1
                                            │ │ └── asynckit@0.4.0
                                            │ ├─┬ har-validator@2.0.6
                                            │ │ ├─┬ commander@2.9.0
                                            │ │ │ └── graceful-readlink@1.0.1
                                            │ │ └─┬ pinkie-promise@2.0.1
                                            │ │ └── pinkie@2.0.4
                                            │ ├─┬ hawk@3.1.3
                                            │ │ ├── boom@2.10.1
                                            │ │ ├── cryptiles@2.0.5
                                            │ │ ├── hoek@2.16.3
                                            │ │ └── sntp@1.0.9
                                            │ ├─┬ http-signature@1.1.1
                                            │ │ ├── assert-plus@0.2.0
                                            │ │ ├─┬ jsprim@1.3.1
                                            │ │ │ ├── extsprintf@1.0.2
                                            │ │ │ ├── json-schema@0.2.3
                                            │ │ │ └── verror@1.3.6
                                            │ │ └─┬ sshpk@1.10.1
                                            │ │ ├── asn1@0.2.3
                                            │ │ ├── assert-plus@1.0.0
                                            │ │ ├── bcrypt-pbkdf@1.0.0
                                            │ │ ├─┬ dashdash@1.14.0
                                            │ │ │ └── assert-plus@1.0.0
                                            │ │ ├── ecc-jsbn@0.1.1
                                            │ │ ├─┬ getpass@0.1.6
                                            │ │ ├── jodid25519@1.0.2
                                            │ │ ├── jsbn@0.1.0
                                            │ │ └── tweetnacl@0.14.3
                                            │ ├── is-typedarray@1.0.0
                                            │ ├── isstream@0.1.2
                                            │ ├── json-stringify-safe@5.0.1
                                            │ ├─┬ mime-types@2.1.12
                                            │ │ └── mime-db@1.24.0
                                            │ ├── node-uuid@1.4.7
                                            │ ├── oauth-sign@0.8.2
                                            │ ├── qs@6.3.0
                                            │ ├── stringstream@0.0.5
                                            │ ├─┬ tough-cookie@2.3.2
                                            │ │ └── punycode@1.4.1
                                            │ └── tunnel-agent@0.4.3
                                            ├── rrule@2.1.0
                                            ├─┬ snyk@1.19.1
                                            │ ├── abbrev@1.0.9
                                            │ ├── ansi-escapes@1.4.0
                                            │ ├─┬ configstore@1.4.0
                                            │ │ ├── graceful-fs@4.1.9
                                            │ │ ├── object-assign@4.1.0
                                            │ │ ├── os-tmpdir@1.0.2
                                            │ │ ├── osenv@0.1.3
                                            │ │ ├── uuid@2.0.3
                                            │ │ ├─┬ write-file-atomic@1.2.0
                                            │ │ │ └── slide@1.1.6
                                            │ │ └── xdg-basedir@2.0.0
                                            │ ├── es6-promise@3.3.1
                                            │ ├── hasbin@1.2.3
                                            │ ├─┬ inquirer@1.0.3
                                            │ │ ├─┬ cli-cursor@1.0.2
                                            │ │ │ └─┬ restore-cursor@1.0.1
                                            │ │ │ ├── exit-hook@1.1.1
                                            │ │ │ └── onetime@1.1.0
                                            │ │ ├── cli-width@2.1.0
                                            │ │ ├── mute-stream@0.0.6
                                            │ │ ├─┬ run-async@2.2.0
                                            │ │ │ └── is-promise@2.1.0
                                            │ │ ├── rx@4.1.0
                                            │ │ ├─┬ string-width@1.0.2
                                            │ │ │ ├── code-point-at@1.0.1
                                            │ │ │ └── is-fullwidth-code-point@1.0.0
                                            │ │ └── through@2.3.8
                                            │ ├── open@0.0.5
                                            │ ├─┬ os-name@1.0.3
                                            │ │ ├── osx-release@1.1.0
                                            │ │ └── win-release@1.1.1
                                            │ ├── semver@5.3.0
                                            │ ├─┬ snyk-config@1.0.1
                                            │ │ └─┬ nconf@0.7.2
                                            │ │ └── async@0.9.2
                                            │ ├─┬ snyk-module@1.7.0
                                            │ │ ├── hosted-git-info@2.1.5
                                            │ │ └─┬ validate-npm-package-name@2.2.2
                                            │ │ └── builtins@0.0.7
                                            │ ├─┬ snyk-policy@1.5.2
                                            │ │ └── lodash.clonedeep@4.5.0
                                            │ ├─┬ snyk-recursive-readdir@2.0.0
                                            │ │ └── minimatch@3.0.2
                                            │ ├── snyk-resolve@1.0.0
                                            │ ├─┬ snyk-resolve-deps@1.7.0
                                            │ │ ├── ansicolors@0.3.2
                                            │ │ ├─┬ clite@0.3.0
                                            │ │ │ ├── lodash.defaults@4.2.0
                                            │ │ │ ├── lodash.defaultsdeep@4.6.0
                                            │ │ │ ├── lodash.mergewith@4.6.0
                                            │ │ │ ├─┬ update-notifier@0.6.3
                                            │ │ │ │ ├─┬ boxen@0.3.1
                                            │ │ │ │ │ ├── filled-array@1.1.0
                                            │ │ │ │ │ └── widest-line@1.0.0
                                            │ │ │ │ ├─┬ configstore@2.1.0
                                            │ │ │ │ │ └─┬ dot-prop@3.0.0
                                            │ │ │ │ │ └── is-obj@1.0.1
                                            │ │ │ │ └─┬ latest-version@2.0.0
                                            │ │ │ │ └─┬ package-json@2.4.0
                                            │ │ │ │ ├─┬ got@5.6.0
                                            │ │ │ │ │ ├─┬ create-error-class@3.0.2
                                            │ │ │ │ │ │ └── capture-stack-trace@1.0.0
                                            │ │ │ │ │ ├─┬ duplexer2@0.1.4
                                            │ │ │ │ │ │ └─┬ readable-stream@2.1.5
                                            │ │ │ │ │ │ └── isarray@1.0.0
                                            │ │ │ │ │ ├── is-plain-obj@1.1.0
                                            │ │ │ │ │ ├── is-retry-allowed@1.1.0
                                            │ │ │ │ │ ├── node-status-codes@1.0.0
                                            │ │ │ │ │ ├─┬ readable-stream@2.1.5
                                            │ │ │ │ │ ├── unzip-response@1.0.1
                                            │ │ │ │ │ └── url-parse-lax@1.0.0
                                            │ │ │ │ └── registry-auth-token@3.1.0
                                            │ │ │ └─┬ yargs@4.8.1
                                            │ │ │ ├─┬ cliui@3.2.0
                                            │ │ │ │ └── wrap-ansi@2.0.0
                                            │ │ │ ├── get-caller-file@1.0.2
                                            │ │ │ ├── lodash.assign@4.2.0
                                            │ │ │ ├─┬ os-locale@1.4.0
                                            │ │ │ │ └─┬ lcid@1.0.0
                                            │ │ │ │ └── invert-kv@1.0.0
                                            │ │ │ ├── require-directory@2.1.1
                                            │ │ │ ├── require-main-filename@1.0.1
                                            │ │ │ ├── set-blocking@2.0.0
                                            │ │ │ ├── which-module@1.0.0
                                            │ │ │ ├── window-size@0.2.0
                                            │ │ │ ├── y18n@3.2.1
                                            │ │ │ └─┬ yargs-parser@2.4.1
                                            │ │ │ └── camelcase@3.0.0
                                            │ │ └─┬ lru-cache@4.0.1
                                            │ │ ├── pseudomap@1.0.2
                                            │ │ └── yallist@2.0.0
                                            │ ├─┬ snyk-tree@1.0.0
                                            │ │ └── archy@1.0.0
                                            │ ├── snyk-try-require@1.1.1
                                            │ ├── tempfile@1.1.1
                                            │ ├─┬ then-fs@2.0.0
                                            │ │ └─┬ promise@7.1.1
                                            │ │ └── asap@2.0.5
                                            │ ├── undefsafe@0.0.3
                                            │ ├─┬ update-notifier@0.5.0
                                            │ │ ├── is-npm@1.0.0
                                            │ │ ├─┬ latest-version@1.0.1
                                            │ │ │ └─┬ package-json@1.2.0
                                            │ │ │ ├─┬ got@3.3.1
                                            │ │ │ │ ├─┬ duplexify@3.5.0
                                            │ │ │ │ │ ├─┬ end-of-stream@1.0.0
                                            │ │ │ │ │ │ └── once@1.3.3
                                            │ │ │ │ │ │ ├── buffer-shims@1.0.0
                                            │ │ │ │ │ └── stream-shift@1.0.0
                                            │ │ │ │ ├── infinity-agent@2.0.3
                                            │ │ │ │ ├── is-redirect@1.0.0
                                            │ │ │ │ ├── is-stream@1.1.0
                                            │ │ │ │ ├── lowercase-keys@1.0.0
                                            │ │ │ │ ├── nested-error-stacks@1.0.2
                                            │ │ │ │ ├── object-assign@3.0.0
                                            │ │ │ │ ├── prepend-http@1.0.4
                                            │ │ │ │ ├─┬ read-all-stream@3.1.0
                                            │ │ │ │ └── timed-out@2.0.0
                                            │ │ │ └── registry-url@3.1.0
                                            │ │ ├── repeating@1.1.3
                                            │ │ ├── semver-diff@2.1.0
                                            │ │ └── string-length@1.0.1
                                            │ └─┬ url@0.11.0
                                            │ ├── punycode@1.3.2
                                            │ └── querystring@0.2.0
                                            ├─┬ socket.io@1.5.1
                                            │ ├─┬ engine.io@1.7.2
                                            │ │ ├── base64id@0.1.0
                                            │ │ ├─┬ engine.io-parser@1.3.1
                                            │ │ │ ├── after@0.8.1
                                            │ │ │ ├── arraybuffer.slice@0.0.6
                                            │ │ │ ├── base64-arraybuffer@0.1.5
                                            │ │ │ ├── blob@0.0.4
                                            │ │ │ ├── has-binary@0.1.6
                                            │ │ │ └── wtf-8@1.0.0
                                            │ │ └─┬ ws@1.1.1
                                            │ │ ├── options@0.0.6
                                            │ │ └── ultron@1.0.2
                                            │ ├─┬ has-binary@0.1.7
                                            │ │ └── isarray@0.0.1
                                            │ ├─┬ socket.io-adapter@0.4.0
                                            │ │ └─┬ socket.io-parser@2.2.2
                                            │ │ ├── benchmark@1.0.0
                                            │ │ ├── debug@0.7.4
                                            │ │ └── json3@3.2.6
                                            │ ├─┬ socket.io-client@1.5.1
                                            │ │ ├── backo2@1.0.2
                                            │ │ ├── component-bind@1.0.0
                                            │ │ ├── component-emitter@1.2.0
                                            │ │ ├─┬ engine.io-client@1.7.2
                                            │ │ │ ├── component-inherit@0.0.3
                                            │ │ │ ├── has-cors@1.1.0
                                            │ │ │ ├── parsejson@0.0.1
                                            │ │ │ ├── parseqs@0.0.2
                                            │ │ │ ├── xmlhttprequest-ssl@1.5.1
                                            │ │ │ └── yeast@0.1.2
                                            │ │ ├── indexof@0.0.1
                                            │ │ ├── object-component@0.0.3
                                            │ │ ├─┬ parseuri@0.0.4
                                            │ │ │ └─┬ better-assert@1.0.2
                                            │ │ │ └── callsite@1.0.0
                                            │ │ └── to-array@0.1.4
                                            │ └─┬ socket.io-parser@2.3.1
                                            │ ├── component-emitter@1.1.2
                                            │ └── json3@3.3.2
                                            ├── stylelint-config-standard@14.0.0
                                            ├─┬ time-grunt@1.4.0
                                            │ ├─┬ date-time@1.1.0
                                            │ │ └── time-zone@0.1.0
                                            │ ├── figures@1.7.0
                                            │ ├── hooker@0.2.3
                                            │ ├── number-is-nan@1.0.1
                                            │ ├─┬ pretty-ms@2.1.0
                                            │ │ ├── is-finite@1.0.2
                                            │ │ ├── parse-ms@1.0.1
                                            │ │ └── plur@1.0.0
                                            │ └── text-table@0.2.0
                                            ├── valid-url@1.0.9
                                            └─┬ walk@2.3.9
                                            └── foreachasync@3.0.0
                                            npm WARN grunt-yamllint@0.2.0 requires a peer of grunt@~0.4.0 but none was installed.
                                            Dependencies installation Done!
                                            We’re ready! Run DISPLAY=:0 npm start from the ~/MagicMirror directory to start your MagicMirror.
                                            pi@MM:~ $
                                            • 3 / 4
