    Unable to install dependencies, NPM install not working
    66 Posts 19 Posters 127.4k Views 16 Watching
      joey12725
      I think the issue is from that first unable to install dependencies issue. Maybe the electron-v1.3.8-linux-arm.zip is in /.electron folder was in the dependencies that were not installed causing npm install to have issues
        jamlid
        I can’t find .electron/ within the MagicMirror folder. Am I supposed to clone electron separately and install that first?
        • MichMichM
          MichMich
          @jamlid Your Node version is extremely old. Just use the installer as noted in the documentation.
            jamlid
            @MichMich I’m running a Pi 1 so the installer isn’t compatible. I ran through the manual instructions and used apt-get for my Node. (Bear with me as I’m not too hot on Linux. I worked on CentOS servers for a while a few years ago but that’s about it)
            • G
              geeflaxx
              maybe us pi firmware is old ?
              cause i can’t use ‘sudo rpi update’
              command not found
                jamlid @geeflaxx
                @geeflaxx I’ve tried it on a fresh install of Jessie, but you’re right, I don’t have rpi-update either. Come to think of it, I did install Jessie Lite rather than the full verison. Not sure what exactly is stripped out of the Lite version and if it’s enough to make a difference to this?
                • Y
                  yawns Moderator
                  Did you try sudo apt-get install rpi-update to install rpi-updat before running it?
                  • G
                    geeflaxx
                    http://www.bilder-upload.eu/show.php?file=df2e81-1477496516.png
                    http://www.bilder-upload.eu/show.php?file=64ba61-1477496550.png
                    it doesn’t work anything any other ideas ? :/
                    • Y
                      yawns Moderator
                      In your first screenshot the command install is missing
                        cpramhofer
                        hi guys,
                        i have actually the same problem.
                        i started with a fresh version of jessie with pixel and followed the setup tutorial mentioned above.
                        with update upgrade a new kernel was installed.
                        i also recognized that there have been a few lines telling me that “electron” has now a new name…maybe this could be some reason?
                        electron-quick-start is also not working!!
                        • G
                          geeflaxx
                          oh i wanted to use ‘sudo rpi update’
                          look on my second command i wanted to install it
                          i forget remove the apt-get …
                          but ‘sudo rpi update’ is still not working
                          electron is the problem
                          • G
                            geeflaxx
                            BRO I GOT IT !!!
                            sudo apt-get upgrade
                            and than npm install npm install
                            I LOVE YOU ALL !
                              cpramhofer
                              where exactly did you run npm install?
                                PaulB
                                Guys, thanks for your great help!
                                I fixed this problem, now. Well, after fixing this problem I got several problem more :D
                                • G
                                  geeflaxx
                                    jamlid @PaulB
                                    @PaulB How did you fix the problem?
                                      PaulB
                                      @cpramhofer I did everything from the scratch :-D
                                      1. Reformation the SD Card
                                      2. Copying the Software to the SD Card.
                                      3. Installing everything
                                      4. Installing the MM2 Software via the link on Michaels website
                                      –> Conclusion: No no problem more :D
                                      • G
                                        geeflaxx
                                        i want to say that via ssh it comes the problem
                                        • K
                                          kiefersmith
                                          Reinstalled the OS (Raspbian 8.0) and followed @KirAsh4 's install posts. Still fail at the electron install. Has anyone found a solution?
                                            jamlid
                                            Could one of the advanced pro users here try a fresh install and see if they hit the same problems most are experiencing here?
                                            I’ve been trying to install Node from the tarball but the make install was running for hours and still verbosely outputting as though it was doing things…
                                            • 2 / 4
