Unsolved Unable to install dependencies, NPM install not working
Did the
npm install
finish without issues? -
Sounds strange but did set a system time?
Sometimes it’s messing around without. -
I have the same error with a newly installed system
same, i thought its because the electron doesn’t work look http://www.bilder-upload.eu/show.php?file=967e7b-1477258720.png
why it’s red?
and i haven’t in the folder electron any data … maybe by you too ?
http://www.bilder-upload.eu/show.php?file=58e559-1477259579.png -
Hello guys, I have the same problem.
Here is the code:
Cloning MagigMirror Done!
Installing dependencies …
bash: line 109: nom: command not found
Unable to install dependencies!Do you an idea on how to solve this Problem?
Thanks a lot and many greetings from Germany :)
Hello guys,
I tried to overwrite everything. Well, I installed NPM with:
sudo apt-get install nodejs npm node-semver
After that, I renamed the initial Magic Mirror folder. Then I tried to installed the MM2 again.
Conlusion:
I have the same problem as @joey12725 .
Any suggestions?
Yep, same issues as everyone else.
@MichMich : Need any specific output or logs, etc. to help? I’m desperate to get my mirror up and running again and happy to help.
Interesting to note though, is since formatting my Pi to do a fresh install and it failing, I’ve really missed my Magic Mirror. I hadn’t realised how much a part of my daily routine it had become, using it!
@jamlid My wife and I noticed the same when our Mirror was off a few weeks ago. Can’t live without it. ;)
About solving the issue:
- What steps did you try to install it?
- And what did you try to fix it?
- How do you try start your mirror?
- Does this repository work on your pi? https://github.com/electron/electron-quick-start
If the last repository doesn’t work for you, please open an issue in that repo, since it is a issue with electron.
@MichMich For some reason I can’t seem to post my full post, saying it’s been flagged as spam. I’m doing everything as per the manual process on github. My node/npm versions show as:
pi@raspberrypi:~/MagicMirror $ dpkg -s node | grep Version
Version: 0.3.2-7.4
pi@raspberrypi:~/MagicMirror $ dpkg -s npm | grep Version
Version: 1.4.21+ds-2And here’s what I think is the important bit of my npm install output:
npm WARN deprecated electron-prebuilt@1.3.8: electron-prebuilt has been renamed to electron. For more details, see http://electron.atom.io/blog/2016/08/16/npm-install-electron npm WARN engine grunt-jsonlint@1.1.0: wanted: {"node":">=4.0"} (current: {"node":"0.10.29","npm":"1.4.21"}) npm WARN engine grunt-eslint@19.0.0: wanted: {"node":">=4"} (current: {"node":"0.10.29","npm":"1.4.21"}) npm WARN engine eslint@3.8.1: wanted: {"node":">=4"} (current: {"node":"0.10.29","npm":"1.4.21"}) npm WARN engine stylelint@7.5.0: wanted: {"node":">=4.2.1"} (current: {"node":"0.10.29","npm":"1.4.21"}) npm WARN engine stylelint@7.5.0: wanted: {"node":">=4.2.1"} (current: {"node":"0.10.29","npm":"1.4.21"}) npm WARN engine deep-extend@0.4.1: wanted: {"node":">=0.12.0","iojs":">=1.0.0"} (current: {"node":"0.10.29","npm":"1.4.21"}) npm WARN engine form-data@2.1.1: wanted: {"node":">= 0.12"} (current: {"node":"0.10.29","npm":"1.4.21"}) npm WARN engine hawk@3.1.3: wanted: {"node":">=0.10.32"} (current: {"node":"0.10.29","npm":"1.4.21"}) npm WARN engine hoek@2.16.3: wanted: {"node":">=0.10.40"} (current: {"node":"0.10.29","npm":"1.4.21"}) npm WARN engine boom@2.10.1: wanted: {"node":">=0.10.40"} (current: {"node":"0.10.29","npm":"1.4.21"}) npm WARN engine cryptiles@2.0.5: wanted: {"node":">=0.10.40"} (current: {"node":"0.10.29","npm":"1.4.21"})
I think the issue is from that first unable to install dependencies issue. Maybe the electron-v1.3.8-linux-arm.zip is in /.electron folder was in the dependencies that were not installed causing npm install to have issues
