    Unable to install dependencies, NPM install not working
    66 Posts 19 Posters 126.3k Views 16 Watching
    • F Offline
      FlorianRD
      Yes i am use this tutorial.
      Here the errors:
      magicmirror@2.0.0 start /home/pi/MagicMirror
      electron js/electron.js
      npm ERR! Linux 4.4.23-v7+
      npm ERR! argv “/usr/bin/nodejs” “/usr/bin/npm” “start”
      npm ERR! node v6.9.0
      npm ERR! npm v3.10.8
      npm ERR! code ELIFECYCLE
      npm ERR! magicmirror@2.0.0 start: electron js/electron.js
      npm ERR! Exit status 1
      npm ERR!
      npm ERR! Failed at the magicmirror@2.0.0 start script ‘electron js/electron.js’.
      npm ERR! If you do, this is most likely a problem with the magicmirror package,
      npm ERR! not with npm itself.
      npm ERR! electron js/electron.js
      npm ERR! npm bugs magicmirror
      npm ERR! Or if that isn’t available, you can get their info via:
      npm ERR! npm owner ls magicmirror
      npm ERR! /home/pi/MagicMirror/npm-debug.log
      • MichMichM Offline
        MichMich
        @FlorianRD, did you run npm install from within the MagicMirror folder?
        • K Offline
          kiefersmith @MichMich
          @MichMich I seem to be having the same problem as folks above. Whenever I try npm install from inside the MM folder, the electron installation either stalls or fails.
          • F Offline
            FlorianRD
            @MichMich, yes i did run npm install. I’ve just finished a new installation of this project.
            Step by step by the tutorial. And, same problem.
            electron-v1.3.8-linux-arm.zip is in /.electron folder
            • MichMichM Offline
              MichMich
              Did the npm install finish without issues?
                Patrick
                Sounds strange but did set a system time?
                Sometimes it’s messing around without.
                  MarkAlisch
                  I have the same error with a newly installed system
                  • G Offline
                    geeflaxx
                    same, i thought its because the electron doesn’t work look http://www.bilder-upload.eu/show.php?file=967e7b-1477258720.png
                    why it’s red?
                    and i haven’t in the folder electron any data … maybe by you too ?
                    http://www.bilder-upload.eu/show.php?file=58e559-1477259579.png
                      PaulB
                      Hello guys, I have the same problem.
                      Here is the code:
                      Cloning MagigMirror Done!
                      Installing dependencies …
                      bash: line 109: nom: command not found
                      Unable to install dependencies!
                      Do you an idea on how to solve this Problem?
                      Thanks a lot and many greetings from Germany :)
                        PaulB
                        Hello guys,
                        I tried to overwrite everything. Well, I installed NPM with:
                        sudo apt-get install nodejs npm node-semver
                        After that, I renamed the initial Magic Mirror folder. Then I tried to installed the MM2 again.
                        Conlusion:
                        I have the same problem as @joey12725 .
                        Any suggestions?
                          jamlid
                          Yep, same issues as everyone else.
                          @MichMich : Need any specific output or logs, etc. to help? I’m desperate to get my mirror up and running again and happy to help.
                          Interesting to note though, is since formatting my Pi to do a fresh install and it failing, I’ve really missed my Magic Mirror. I hadn’t realised how much a part of my daily routine it had become, using it!
                          • MichMichM Offline
                            MichMich
                            @jamlid My wife and I noticed the same when our Mirror was off a few weeks ago. Can’t live without it. ;)
                            About solving the issue:
                            • What steps did you try to install it?
                            • And what did you try to fix it?
                            • How do you try start your mirror?
                            • Does this repository work on your pi? https://github.com/electron/electron-quick-start
                            If the last repository doesn’t work for you, please open an issue in that repo, since it is a issue with electron.
                              jamlid
                              @MichMich For some reason I can’t seem to post my full post, saying it’s been flagged as spam. I’m doing everything as per the manual process on github. My node/npm versions show as:
                              pi@raspberrypi:~/MagicMirror $ dpkg -s node | grep Version
                              Version: 0.3.2-7.4
                              pi@raspberrypi:~/MagicMirror $ dpkg -s npm | grep Version
                              Version: 1.4.21+ds-2
                              And here’s what I think is the important bit of my npm install output:
                              npm WARN deprecated electron-prebuilt@1.3.8: electron-prebuilt has been renamed to electron. For more details, see http://electron.atom.io/blog/2016/08/16/npm-install-electron
                              npm WARN engine grunt-jsonlint@1.1.0: wanted: {"node":">=4.0"} (current: {"node":"0.10.29","npm":"1.4.21"})
                              npm WARN engine grunt-eslint@19.0.0: wanted: {"node":">=4"} (current: {"node":"0.10.29","npm":"1.4.21"})
                              npm WARN engine eslint@3.8.1: wanted: {"node":">=4"} (current: {"node":"0.10.29","npm":"1.4.21"})
                              npm WARN engine stylelint@7.5.0: wanted: {"node":">=4.2.1"} (current: {"node":"0.10.29","npm":"1.4.21"})
                              npm WARN engine deep-extend@0.4.1: wanted: {"node":">=0.12.0","iojs":">=1.0.0"} (current: {"node":"0.10.29","npm":"1.4.21"})
                              npm WARN engine form-data@2.1.1: wanted: {"node":">= 0.12"} (current: {"node":"0.10.29","npm":"1.4.21"})
                              npm WARN engine hawk@3.1.3: wanted: {"node":">=0.10.32"} (current: {"node":"0.10.29","npm":"1.4.21"})
                              npm WARN engine hoek@2.16.3: wanted: {"node":">=0.10.40"} (current: {"node":"0.10.29","npm":"1.4.21"})
                              npm WARN engine boom@2.10.1: wanted: {"node":">=0.10.40"} (current: {"node":"0.10.29","npm":"1.4.21"})
                              npm WARN engine cryptiles@2.0.5: wanted: {"node":">=0.10.40"} (current: {"node":"0.10.29","npm":"1.4.21"})
                                joey12725
                                I think the issue is from that first unable to install dependencies issue. Maybe the electron-v1.3.8-linux-arm.zip is in /.electron folder was in the dependencies that were not installed causing npm install to have issues
                                  jamlid
                                  I can’t find .electron/ within the MagicMirror folder. Am I supposed to clone electron separately and install that first?
                                  • MichMichM Offline
                                    MichMich
                                    @jamlid Your Node version is extremely old. Just use the installer as noted in the documentation.
                                      jamlid
                                      @MichMich I’m running a Pi 1 so the installer isn’t compatible. I ran through the manual instructions and used apt-get for my Node. (Bear with me as I’m not too hot on Linux. I worked on CentOS servers for a while a few years ago but that’s about it)
                                      • G Offline
                                        geeflaxx
                                        maybe us pi firmware is old ?
                                        cause i can’t use ‘sudo rpi update’
                                        command not found
                                          jamlid @geeflaxx
                                          @geeflaxx I’ve tried it on a fresh install of Jessie, but you’re right, I don’t have rpi-update either. Come to think of it, I did install Jessie Lite rather than the full verison. Not sure what exactly is stripped out of the Lite version and if it’s enough to make a difference to this?
                                          • Y Offline
                                            yawns Moderator
                                            Did you try sudo apt-get install rpi-update to install rpi-updat before running it?
                                            • 2 / 4
