    Unable to install dependencies, NPM install not working
    66 Posts 19 Posters 128.1k Views 16 Watching
    • cowboysdudeC
      After I get back from my 5 day vacation :)
      KirAsh4K 1 Reply Last reply
      • KirAsh4K
        KirAsh4 Moderator @cowboysdude
        @cowboysdude, I don’t know who gave you permission to take a vacation, but they need to be fired. First thing you will need to do when you return.
          joey12725
          I re-installed magic mirror and got this above the unable to install dependencies error
          npm WARN deprecated electron-prebuilt@1.4.3: electron-prebuilt has been renamed to electron. For more details, see http://electron.atom.io/blog/2016/08/16/npm-install-electron
          npm ERR! Linux 4.1.19-v7+
          npm ERR! argv “/usr/local/bin/node” “/usr/local/bin/npm” “install”
          npm ERR! node v4.0.0
          npm ERR! npm v3.10.8
          npm ERR! file /home/pi/.npm/extract-zip/1.5.0/package/package.json
          npm ERR! code EJSONPARSE
          npm ERR! Failed to parse json
          npm ERR! No data, empty input at 1:1
          npm ERR!
          npm ERR! ^
          npm ERR! File: /home/pi/.npm/extract-zip/1.5.0/package/package.json
          npm ERR! Failed to parse package.json data.
          npm ERR! package.json must be actual JSON, not just JavaScript.
          npm ERR!
          npm ERR! This is not a bug in npm.
          npm ERR! Tell the package author to fix their package.json file. JSON.parse
          npm ERR! /home/pi/MagicMirror/npm-debug.log
          Unable to install dependencies!
            joey12725
            Could that be related to the npm install issue?
              jamlid
              It looks like I’m having the same problem. Trying to manually install on a Pi 1…
              33914 error electron-prebuilt@1.4.3 postinstall: node install.js
              33914 error Exit status 1
              33915 error Failed at the electron-prebuilt@1.4.3 postinstall script.
              33915 error This is most likely a problem with the electron-prebuilt package,
              33915 error not with npm itself.
              33915 error Tell the author that this fails on your system:
              33915 error node install.js
              33915 error You can get their info via:
              33915 error npm owner ls electron-prebuilt
              33915 error There is likely additional logging output above.
              33916 error System Linux 4.4.21+
              33917 error command “/usr/bin/nodejs” “/usr/bin/npm” “install”
              33918 error cwd /home/pi/MagicMirror
              33919 error node -v v0.10.29
              33920 error npm -v 1.4.21
              33921 error code ELIFECYCLE
                joey12725
                Im on a pi 2 B
                • F
                  FlorianRD
                  Yesterday i perform a install for MM². I get step by step from a user who made an InstallGuide.
                  And finaly the same error as shown below. I’ve buy the complete Hardware for the Mirror. The frame are handmade an looks fine. But the Software goes wrong. There should be a project for the incomming autumn here in Germany. I hope that any can fix this problem and tell us.
                  I used a RaspberryPi 3 with Jessie
                  Greetings from North of Germany
                  • strawberry 3.141S
                    strawberry 3.141 Project Sponsor Module Developer @FlorianRD
                    @FlorianRD did you use this tutorial? https://forum.magicmirror.builders/topic/236/complete-setup-tutorial
                    you forgot to append your errors
                    • F
                      FlorianRD
                      Yes i am use this tutorial.
                      Here the errors:
                      magicmirror@2.0.0 start /home/pi/MagicMirror
                      electron js/electron.js
                      npm ERR! Linux 4.4.23-v7+
                      npm ERR! argv “/usr/bin/nodejs” “/usr/bin/npm” “start”
                      npm ERR! node v6.9.0
                      npm ERR! code ELIFECYCLE
                      npm ERR! magicmirror@2.0.0 start: electron js/electron.js
                      npm ERR! Exit status 1
                      npm ERR!
                      npm ERR! Failed at the magicmirror@2.0.0 start script ‘electron js/electron.js’.
                      npm ERR! If you do, this is most likely a problem with the magicmirror package,
                      npm ERR! not with npm itself.
                      npm ERR! electron js/electron.js
                      npm ERR! npm bugs magicmirror
                      npm ERR! Or if that isn’t available, you can get their info via:
                      npm ERR! npm owner ls magicmirror
                      • MichMichM
                        MichMich
                        @FlorianRD, did you run npm install from within the MagicMirror folder?
                        • K
                          kiefersmith @MichMich
                          @MichMich I seem to be having the same problem as folks above. Whenever I try npm install from inside the MM folder, the electron installation either stalls or fails.
                          • F
                            FlorianRD
                            @MichMich, yes i did run npm install. I’ve just finished a new installation of this project.
                            Step by step by the tutorial. And, same problem.
                            electron-v1.3.8-linux-arm.zip is in /.electron folder
                            • MichMichM
                              MichMich
                              Did the npm install finish without issues?
                                Patrick
                                Sounds strange but did set a system time?
                                Sometimes it’s messing around without.
                                  MarkAlisch
                                  I have the same error with a newly installed system
                                  • G
                                    geeflaxx
                                    same, i thought its because the electron doesn’t work look http://www.bilder-upload.eu/show.php?file=967e7b-1477258720.png
                                    why it’s red?
                                    and i haven’t in the folder electron any data … maybe by you too ?
                                    http://www.bilder-upload.eu/show.php?file=58e559-1477259579.png
                                      PaulB
                                      Hello guys, I have the same problem.
                                      Here is the code:
                                      Cloning MagigMirror Done!
                                      Installing dependencies …
                                      bash: line 109: nom: command not found
                                      Do you an idea on how to solve this Problem?
                                      Thanks a lot and many greetings from Germany :)
                                        PaulB
                                        Hello guys,
                                        I tried to overwrite everything. Well, I installed NPM with:
                                        sudo apt-get install nodejs npm node-semver
                                        After that, I renamed the initial Magic Mirror folder. Then I tried to installed the MM2 again.
                                        Conlusion:
                                        I have the same problem as @joey12725 .
                                        Any suggestions?
                                          jamlid
                                          Yep, same issues as everyone else.
                                          @MichMich : Need any specific output or logs, etc. to help? I’m desperate to get my mirror up and running again and happy to help.
                                          Interesting to note though, is since formatting my Pi to do a fresh install and it failing, I’ve really missed my Magic Mirror. I hadn’t realised how much a part of my daily routine it had become, using it!
                                          • MichMichM
                                            MichMich
                                            @jamlid My wife and I noticed the same when our Mirror was off a few weeks ago. Can’t live without it. ;)
                                            About solving the issue:
                                            • What steps did you try to install it?
                                            • And what did you try to fix it?
                                            • How do you try start your mirror?
                                            • Does this repository work on your pi? https://github.com/electron/electron-quick-start
                                            If the last repository doesn’t work for you, please open an issue in that repo, since it is a issue with electron.
                                            • 1 / 4
