    Unable to install dependencies, NPM install not working
    66 Posts 19 Posters 126.3k Views 16 Watching
    • K Offline
      KirAsh4 Moderator @cowboysdude
      @cowboysdude, I don’t know who gave you permission to take a vacation, but they need to be fired. First thing you will need to do when you return.
        joey12725
        I re-installed magic mirror and got this above the unable to install dependencies error
        npm WARN deprecated electron-prebuilt@1.4.3: electron-prebuilt has been renamed to electron. For more details, see http://electron.atom.io/blog/2016/08/16/npm-install-electron
        npm ERR! Linux 4.1.19-v7+
        npm ERR! argv “/usr/local/bin/node” “/usr/local/bin/npm” “install”
        npm ERR! node v4.0.0
        npm ERR! npm v3.10.8
        npm ERR! file /home/pi/.npm/extract-zip/1.5.0/package/package.json
        npm ERR! code EJSONPARSE
        npm ERR! Failed to parse json
        npm ERR! No data, empty input at 1:1
        npm ERR!
        npm ERR! ^
        npm ERR! File: /home/pi/.npm/extract-zip/1.5.0/package/package.json
        npm ERR! Failed to parse package.json data.
        npm ERR! package.json must be actual JSON, not just JavaScript.
        npm ERR!
        npm ERR! This is not a bug in npm.
        npm ERR! Tell the package author to fix their package.json file. JSON.parse
        npm ERR! /home/pi/MagicMirror/npm-debug.log
        Unable to install dependencies!
          joey12725
          Could that be related to the npm install issue?
            jamlid
            It looks like I’m having the same problem. Trying to manually install on a Pi 1…
            33914 error electron-prebuilt@1.4.3 postinstall: node install.js
            33914 error Exit status 1
            33915 error Failed at the electron-prebuilt@1.4.3 postinstall script.
            33915 error This is most likely a problem with the electron-prebuilt package,
            33915 error not with npm itself.
            33915 error Tell the author that this fails on your system:
            33915 error node install.js
            33915 error You can get their info via:
            33915 error npm owner ls electron-prebuilt
            33915 error There is likely additional logging output above.
            33916 error System Linux 4.4.21+
            33917 error command “/usr/bin/nodejs” “/usr/bin/npm” “install”
            33918 error cwd /home/pi/MagicMirror
            33919 error node -v v0.10.29
            33920 error npm -v 1.4.21
            33921 error code ELIFECYCLE
              joey12725
              Im on a pi 2 B
              • F Offline
                FlorianRD
                Yesterday i perform a install for MM². I get step by step from a user who made an InstallGuide.
                And finaly the same error as shown below. I’ve buy the complete Hardware for the Mirror. The frame are handmade an looks fine. But the Software goes wrong. There should be a project for the incomming autumn here in Germany. I hope that any can fix this problem and tell us.
                I used a RaspberryPi 3 with Jessie
                Greetings from North of Germany
                • strawberry 3.141S Offline
                  strawberry 3.141 Project Sponsor Module Developer @FlorianRD
                  @FlorianRD did you use this tutorial? https://forum.magicmirror.builders/topic/236/complete-setup-tutorial
                  you forgot to append your errors
                  • F Offline
                    FlorianRD
                    Yes i am use this tutorial.
                    Here the errors:
                    magicmirror@2.0.0 start /home/pi/MagicMirror
                    electron js/electron.js
                    npm ERR! Linux 4.4.23-v7+
                    npm ERR! argv “/usr/bin/nodejs” “/usr/bin/npm” “start”
                    npm ERR! node v6.9.0
                    npm ERR! code ELIFECYCLE
                    npm ERR! magicmirror@2.0.0 start: electron js/electron.js
                    npm ERR! Exit status 1
                    npm ERR!
                    npm ERR! Failed at the magicmirror@2.0.0 start script ‘electron js/electron.js’.
                    npm ERR! If you do, this is most likely a problem with the magicmirror package,
                    npm ERR! not with npm itself.
                    npm ERR! electron js/electron.js
                    npm ERR! npm bugs magicmirror
                    npm ERR! Or if that isn’t available, you can get their info via:
                    npm ERR! npm owner ls magicmirror
                    • MichMichM Offline
                      MichMich
                      @FlorianRD, did you run npm install from within the MagicMirror folder?
                      • K Offline
                        kiefersmith @MichMich
                        @MichMich I seem to be having the same problem as folks above. Whenever I try npm install from inside the MM folder, the electron installation either stalls or fails.
                        • F Offline
                          FlorianRD
                          @MichMich, yes i did run npm install. I’ve just finished a new installation of this project.
                          Step by step by the tutorial. And, same problem.
                          electron-v1.3.8-linux-arm.zip is in /.electron folder
                          • MichMichM Offline
                            MichMich
                            Did the npm install finish without issues?
                              Patrick
                              Sounds strange but did set a system time?
                              Sometimes it’s messing around without.
                                MarkAlisch
                                I have the same error with a newly installed system
                                • G Offline
                                  geeflaxx
                                  same, i thought its because the electron doesn’t work look http://www.bilder-upload.eu/show.php?file=967e7b-1477258720.png
                                  why it’s red?
                                  and i haven’t in the folder electron any data … maybe by you too ?
                                  http://www.bilder-upload.eu/show.php?file=58e559-1477259579.png
                                    PaulB
                                    Hello guys, I have the same problem.
                                    Here is the code:
                                    Cloning MagigMirror Done!
                                    Installing dependencies …
                                    bash: line 109: nom: command not found
                                    Do you an idea on how to solve this Problem?
                                    Thanks a lot and many greetings from Germany :)
                                      PaulB
                                      Hello guys,
                                      I tried to overwrite everything. Well, I installed NPM with:
                                      sudo apt-get install nodejs npm node-semver
                                      After that, I renamed the initial Magic Mirror folder. Then I tried to installed the MM2 again.
                                      Conlusion:
                                      I have the same problem as @joey12725 .
                                      Any suggestions?
                                        jamlid
                                        Yep, same issues as everyone else.
                                        @MichMich : Need any specific output or logs, etc. to help? I’m desperate to get my mirror up and running again and happy to help.
                                        Interesting to note though, is since formatting my Pi to do a fresh install and it failing, I’ve really missed my Magic Mirror. I hadn’t realised how much a part of my daily routine it had become, using it!
                                        • MichMichM Offline
                                          MichMich
                                          @jamlid My wife and I noticed the same when our Mirror was off a few weeks ago. Can’t live without it. ;)
                                          About solving the issue:
                                          • What steps did you try to install it?
                                          • And what did you try to fix it?
                                          • How do you try start your mirror?
                                          • Does this repository work on your pi? https://github.com/electron/electron-quick-start
                                          If the last repository doesn’t work for you, please open an issue in that repo, since it is a issue with electron.
                                            jamlid
                                            @MichMich For some reason I can’t seem to post my full post, saying it’s been flagged as spam. I’m doing everything as per the manual process on github. My node/npm versions show as:
                                            pi@raspberrypi:~/MagicMirror $ dpkg -s node | grep Version
                                            Version: 0.3.2-7.4
                                            pi@raspberrypi:~/MagicMirror $ dpkg -s npm | grep Version
                                            Version: 1.4.21+ds-2
                                            And here’s what I think is the important bit of my npm install output:
                                            npm WARN deprecated electron-prebuilt@1.3.8: electron-prebuilt has been renamed to electron. For more details, see http://electron.atom.io/blog/2016/08/16/npm-install-electron
                                            npm WARN engine grunt-jsonlint@1.1.0: wanted: {"node":">=4.0"} (current: {"node":"0.10.29","npm":"1.4.21"})
                                            npm WARN engine grunt-eslint@19.0.0: wanted: {"node":">=4"} (current: {"node":"0.10.29","npm":"1.4.21"})
                                            npm WARN engine eslint@3.8.1: wanted: {"node":">=4"} (current: {"node":"0.10.29","npm":"1.4.21"})
                                            npm WARN engine stylelint@7.5.0: wanted: {"node":">=4.2.1"} (current: {"node":"0.10.29","npm":"1.4.21"})
                                            npm WARN engine deep-extend@0.4.1: wanted: {"node":">=0.12.0","iojs":">=1.0.0"} (current: {"node":"0.10.29","npm":"1.4.21"})
                                            npm WARN engine form-data@2.1.1: wanted: {"node":">= 0.12"} (current: {"node":"0.10.29","npm":"1.4.21"})
                                            npm WARN engine hawk@3.1.3: wanted: {"node":">=0.10.32"} (current: {"node":"0.10.29","npm":"1.4.21"})
                                            npm WARN engine hoek@2.16.3: wanted: {"node":">=0.10.40"} (current: {"node":"0.10.29","npm":"1.4.21"})
                                            npm WARN engine boom@2.10.1: wanted: {"node":">=0.10.40"} (current: {"node":"0.10.29","npm":"1.4.21"})
                                            npm WARN engine cryptiles@2.0.5: wanted: {"node":">=0.10.40"} (current: {"node":"0.10.29","npm":"1.4.21"})
                                            • 1 / 4
