    Unable to install dependencies, NPM install not working
    66 Posts 19 Posters 128.1k Views 16 Watching
    • K
      kiefersmith @MichMich
      @MichMich I seem to be having the same problem as folks above. Whenever I try npm install from inside the MM folder, the electron installation either stalls or fails.
      • F
        FlorianRD
        @MichMich, yes i did run npm install. I’ve just finished a new installation of this project.
        Step by step by the tutorial. And, same problem.
        electron-v1.3.8-linux-arm.zip is in /.electron folder
        • MichMichM
          MichMich
          Did the npm install finish without issues?
            Patrick
            Sounds strange but did set a system time?
            Sometimes it’s messing around without.
              MarkAlisch
              I have the same error with a newly installed system
              • G
                geeflaxx
                same, i thought its because the electron doesn’t work look http://www.bilder-upload.eu/show.php?file=967e7b-1477258720.png
                why it’s red?
                and i haven’t in the folder electron any data … maybe by you too ?
                http://www.bilder-upload.eu/show.php?file=58e559-1477259579.png
                  PaulB
                  Hello guys, I have the same problem.
                  Here is the code:
                  Cloning MagigMirror Done!
                  Installing dependencies …
                  bash: line 109: nom: command not found
                  Unable to install dependencies!
                  Do you an idea on how to solve this Problem?
                  Thanks a lot and many greetings from Germany :)
                    PaulB
                    Hello guys,
                    I tried to overwrite everything. Well, I installed NPM with:
                    sudo apt-get install nodejs npm node-semver
                    After that, I renamed the initial Magic Mirror folder. Then I tried to installed the MM2 again.
                    Conlusion:
                    I have the same problem as @joey12725 .
                    Any suggestions?
                      jamlid
                      Yep, same issues as everyone else.
                      @MichMich : Need any specific output or logs, etc. to help? I’m desperate to get my mirror up and running again and happy to help.
                      Interesting to note though, is since formatting my Pi to do a fresh install and it failing, I’ve really missed my Magic Mirror. I hadn’t realised how much a part of my daily routine it had become, using it!
                      • MichMichM
                        MichMich
                        @jamlid My wife and I noticed the same when our Mirror was off a few weeks ago. Can’t live without it. ;)
                        About solving the issue:
                        • What steps did you try to install it?
                        • And what did you try to fix it?
                        • How do you try start your mirror?
                        • Does this repository work on your pi? https://github.com/electron/electron-quick-start
                        If the last repository doesn’t work for you, please open an issue in that repo, since it is a issue with electron.
                          jamlid
                          @MichMich For some reason I can’t seem to post my full post, saying it’s been flagged as spam. I’m doing everything as per the manual process on github. My node/npm versions show as:
                          pi@raspberrypi:~/MagicMirror $ dpkg -s node | grep Version
                          Version: 0.3.2-7.4
                          pi@raspberrypi:~/MagicMirror $ dpkg -s npm | grep Version
                          Version: 1.4.21+ds-2
                          And here’s what I think is the important bit of my npm install output:
                          npm WARN deprecated electron-prebuilt@1.3.8: electron-prebuilt has been renamed to electron. For more details, see http://electron.atom.io/blog/2016/08/16/npm-install-electron
                          npm WARN engine grunt-jsonlint@1.1.0: wanted: {"node":">=4.0"} (current: {"node":"0.10.29","npm":"1.4.21"})
                          npm WARN engine grunt-eslint@19.0.0: wanted: {"node":">=4"} (current: {"node":"0.10.29","npm":"1.4.21"})
                          npm WARN engine eslint@3.8.1: wanted: {"node":">=4"} (current: {"node":"0.10.29","npm":"1.4.21"})
                          npm WARN engine stylelint@7.5.0: wanted: {"node":">=4.2.1"} (current: {"node":"0.10.29","npm":"1.4.21"})
                          npm WARN engine deep-extend@0.4.1: wanted: {"node":">=0.12.0","iojs":">=1.0.0"} (current: {"node":"0.10.29","npm":"1.4.21"})
                          npm WARN engine form-data@2.1.1: wanted: {"node":">= 0.12"} (current: {"node":"0.10.29","npm":"1.4.21"})
                          npm WARN engine hawk@3.1.3: wanted: {"node":">=0.10.32"} (current: {"node":"0.10.29","npm":"1.4.21"})
                          npm WARN engine hoek@2.16.3: wanted: {"node":">=0.10.40"} (current: {"node":"0.10.29","npm":"1.4.21"})
                          npm WARN engine boom@2.10.1: wanted: {"node":">=0.10.40"} (current: {"node":"0.10.29","npm":"1.4.21"})
                          npm WARN engine cryptiles@2.0.5: wanted: {"node":">=0.10.40"} (current: {"node":"0.10.29","npm":"1.4.21"})
                            joey12725
                            I think the issue is from that first unable to install dependencies issue. Maybe the electron-v1.3.8-linux-arm.zip is in /.electron folder was in the dependencies that were not installed causing npm install to have issues
                              jamlid
                              I can’t find .electron/ within the MagicMirror folder. Am I supposed to clone electron separately and install that first?
                              • MichMichM
                                MichMich
                                @jamlid Your Node version is extremely old. Just use the installer as noted in the documentation.
                                  jamlid
                                  @MichMich I’m running a Pi 1 so the installer isn’t compatible. I ran through the manual instructions and used apt-get for my Node. (Bear with me as I’m not too hot on Linux. I worked on CentOS servers for a while a few years ago but that’s about it)
                                  • G
                                    geeflaxx
                                    maybe us pi firmware is old ?
                                    cause i can’t use ‘sudo rpi update’
                                    command not found
                                    J 1 Reply Last reply
                                      jamlid @geeflaxx
                                      @geeflaxx I’ve tried it on a fresh install of Jessie, but you’re right, I don’t have rpi-update either. Come to think of it, I did install Jessie Lite rather than the full verison. Not sure what exactly is stripped out of the Lite version and if it’s enough to make a difference to this?
                                      • yawnsY
                                        yawns Moderator
                                        Did you try sudo apt-get install rpi-update to install rpi-updat before running it?
                                        • G
                                          geeflaxx
                                          http://www.bilder-upload.eu/show.php?file=df2e81-1477496516.png
                                          http://www.bilder-upload.eu/show.php?file=64ba61-1477496550.png
                                          it doesn’t work anything any other ideas ? :/
                                          • yawnsY
                                            yawns Moderator
                                            In your first screenshot the command install is missing
                                            • 2 / 4
