    Unable to install dependencies, NPM install not working
    66 Posts 19 Posters 128.1k Views 16 Watching
      MarkAlisch
      I have the same error with a newly installed system
      • G
        geeflaxx
        same, i thought its because the electron doesn’t work look http://www.bilder-upload.eu/show.php?file=967e7b-1477258720.png
        why it’s red?
        and i haven’t in the folder electron any data … maybe by you too ?
        http://www.bilder-upload.eu/show.php?file=58e559-1477259579.png
          PaulB
          Hello guys, I have the same problem.
          Here is the code:
          Cloning MagigMirror Done!
          Installing dependencies …
          bash: line 109: nom: command not found
          Unable to install dependencies!
          Do you an idea on how to solve this Problem?
          Thanks a lot and many greetings from Germany :)
            PaulB
            Hello guys,
            I tried to overwrite everything. Well, I installed NPM with:
            sudo apt-get install nodejs npm node-semver
            After that, I renamed the initial Magic Mirror folder. Then I tried to installed the MM2 again.
            Conlusion:
            I have the same problem as @joey12725 .
            Any suggestions?
              jamlid
              Yep, same issues as everyone else.
              @MichMich : Need any specific output or logs, etc. to help? I’m desperate to get my mirror up and running again and happy to help.
              Interesting to note though, is since formatting my Pi to do a fresh install and it failing, I’ve really missed my Magic Mirror. I hadn’t realised how much a part of my daily routine it had become, using it!
              • MichMichM
                MichMich
                @jamlid My wife and I noticed the same when our Mirror was off a few weeks ago. Can’t live without it. ;)
                About solving the issue:
                • What steps did you try to install it?
                • And what did you try to fix it?
                • How do you try start your mirror?
                • Does this repository work on your pi? https://github.com/electron/electron-quick-start
                If the last repository doesn’t work for you, please open an issue in that repo, since it is a issue with electron.
                  jamlid
                  @MichMich For some reason I can’t seem to post my full post, saying it’s been flagged as spam. I’m doing everything as per the manual process on github. My node/npm versions show as:
                  pi@raspberrypi:~/MagicMirror $ dpkg -s node | grep Version
                  Version: 0.3.2-7.4
                  pi@raspberrypi:~/MagicMirror $ dpkg -s npm | grep Version
                  Version: 1.4.21+ds-2
                  And here’s what I think is the important bit of my npm install output:
                  npm WARN deprecated electron-prebuilt@1.3.8: electron-prebuilt has been renamed to electron. For more details, see http://electron.atom.io/blog/2016/08/16/npm-install-electron
                  npm WARN engine grunt-jsonlint@1.1.0: wanted: {"node":">=4.0"} (current: {"node":"0.10.29","npm":"1.4.21"})
                  npm WARN engine grunt-eslint@19.0.0: wanted: {"node":">=4"} (current: {"node":"0.10.29","npm":"1.4.21"})
                  npm WARN engine eslint@3.8.1: wanted: {"node":">=4"} (current: {"node":"0.10.29","npm":"1.4.21"})
                  npm WARN engine stylelint@7.5.0: wanted: {"node":">=4.2.1"} (current: {"node":"0.10.29","npm":"1.4.21"})
                  npm WARN engine deep-extend@0.4.1: wanted: {"node":">=0.12.0","iojs":">=1.0.0"} (current: {"node":"0.10.29","npm":"1.4.21"})
                  npm WARN engine form-data@2.1.1: wanted: {"node":">= 0.12"} (current: {"node":"0.10.29","npm":"1.4.21"})
                  npm WARN engine hawk@3.1.3: wanted: {"node":">=0.10.32"} (current: {"node":"0.10.29","npm":"1.4.21"})
                  npm WARN engine hoek@2.16.3: wanted: {"node":">=0.10.40"} (current: {"node":"0.10.29","npm":"1.4.21"})
                  npm WARN engine boom@2.10.1: wanted: {"node":">=0.10.40"} (current: {"node":"0.10.29","npm":"1.4.21"})
                  npm WARN engine cryptiles@2.0.5: wanted: {"node":">=0.10.40"} (current: {"node":"0.10.29","npm":"1.4.21"})
                    joey12725
                    I think the issue is from that first unable to install dependencies issue. Maybe the electron-v1.3.8-linux-arm.zip is in /.electron folder was in the dependencies that were not installed causing npm install to have issues
                      jamlid
                      I can’t find .electron/ within the MagicMirror folder. Am I supposed to clone electron separately and install that first?
                      • MichMichM
                        MichMich
                        @jamlid Your Node version is extremely old. Just use the installer as noted in the documentation.
                          jamlid
                          @MichMich I’m running a Pi 1 so the installer isn’t compatible. I ran through the manual instructions and used apt-get for my Node. (Bear with me as I’m not too hot on Linux. I worked on CentOS servers for a while a few years ago but that’s about it)
                          • G
                            geeflaxx
                            maybe us pi firmware is old ?
                            cause i can’t use ‘sudo rpi update’
                            command not found
                            J 1 Reply Last reply
                              jamlid @geeflaxx
                              @geeflaxx I’ve tried it on a fresh install of Jessie, but you’re right, I don’t have rpi-update either. Come to think of it, I did install Jessie Lite rather than the full verison. Not sure what exactly is stripped out of the Lite version and if it’s enough to make a difference to this?
                              • yawnsY
                                yawns Moderator
                                Did you try sudo apt-get install rpi-update to install rpi-updat before running it?
                                • G
                                  geeflaxx
                                  http://www.bilder-upload.eu/show.php?file=df2e81-1477496516.png
                                  http://www.bilder-upload.eu/show.php?file=64ba61-1477496550.png
                                  it doesn’t work anything any other ideas ? :/
                                  • yawnsY
                                    yawns Moderator
                                    In your first screenshot the command install is missing
                                      cpramhofer
                                      hi guys,
                                      i have actually the same problem.
                                      i started with a fresh version of jessie with pixel and followed the setup tutorial mentioned above.
                                      with update upgrade a new kernel was installed.
                                      i also recognized that there have been a few lines telling me that “electron” has now a new name…maybe this could be some reason?
                                      electron-quick-start is also not working!!
                                      • G
                                        geeflaxx
                                        oh i wanted to use ‘sudo rpi update’
                                        look on my second command i wanted to install it
                                        i forget remove the apt-get …
                                        but ‘sudo rpi update’ is still not working
                                        electron is the problem
                                        • G
                                          geeflaxx
                                          BRO I GOT IT !!!
                                          sudo apt-get upgrade
                                          and than npm install npm install
                                          I LOVE YOU ALL !
                                            cpramhofer
                                            where exactly did you run npm install?
                                            • 2 / 4
