    Unable to install dependencies, NPM install not working
    66 Posts 19 Posters 122.2k Views 16 Watching
      joey12725
      When I installed MM2 it gave me an error saying “unable to install dependencies!” Then when I ran NPM install it gave me a list of errors.
      npm WARN deprecated electron-prebuilt@1.4.3: electron-prebuilt has been renamed to electron. For more details, see http://electron.atom.io/blog/2016/08/16/npm-install-electron
      npm ERR! Linux 4.1.19-v7+
      npm ERR! argv “/usr/local/bin/node” “/usr/local/bin/npm” “install”
      npm ERR! node v4.0.0
      npm ERR! npm v3.10.8
      npm ERR! file /home/pi/.npm/electron-download/3.0.1/package/package.json
      npm ERR! code EJSONPARSE
      npm ERR! Failed to parse json
      npm ERR! No data, empty input at 1:1
      npm ERR!
      npm ERR! ^
      npm ERR! File: /home/pi/.npm/electron-download/3.0.1/package/package.json
      npm ERR! Failed to parse package.json data.
      npm ERR! package.json must be actual JSON, not just JavaScript.
      npm ERR!
      npm ERR! This is not a bug in npm.
      npm ERR! Tell the package author to fix their package.json file. JSON.parse
      npm ERR! /home/pi/MagicMirror/npm-debug.log
      • cowboysdudeC Offline
        Interesting… was trying to install it on my windows computer to test some modules and was getting the same error… no idea…
          joey12725
          Weird, I cannot find a solution to this, I have updated NPM and NodeJS, but not of any use
          • KirAsh4K Offline
            KirAsh4 Moderator
            Seems to be specific to Electron having been updated (as the WARNing implies.) Feel free to direct any flogging that way …
              Jopyth Moderator @KirAsh4
              @KirAsh4 Can we find out, which version is compatible, and set that? I am experiencing a similar error after chaging to the development branch, but maybe it is unrelated to this specific problem. But I do not know which version of electron I had previously.
              • KirAsh4K Offline
                KirAsh4 Moderator
                Look in your ~pi/.electron folder. There should be old(er) versions downloaded there. Mine lists two:
                pi@magicmirror:~/.electron $ ls -al
                total 67944
                drwxr-xr-x  2 pi pi     4096 May 24 23:54 ./
                drwxr-xr-x 24 pi pi     4096 Oct 10 02:09 ../
                -rw-r--r--  1 pi pi 34490964 May  2 20:52 electron-v0.37.8-linux-arm.zip
                -rw-r--r--  1 pi pi 35072121 May 24 23:54 electron-v1.1.2-linux-arm.zip
                As of right now, my mirror is running v1.1.2 - I haven’t updated in about a week. How you go about (re)installing that one however … I’ll leave that as an exercise for the user. :) Mainly because right now I don’t have the time to figure it out. One possible place to start is also looking in the .npm folder for the older stuff:
                pi@magicmirror:~ $ ls -l .npm/electron-prebuilt
                .npm/electron-prebuilt:
                total 32
                drwxr-xr-x   4 pi pi  4096 May 24 23:50 ./
                drwxr-xr-x 509 pi pi 20480 Jul  1 02:40 ../
                drwxr-xr-x   3 pi pi  4096 May  2 20:50 0.37.8/
                drwxr-xr-x   3 pi pi  4096 May 24 23:50 1.1.2/
                  After I get back from my 5 day vacation :)
                  KirAsh4K 1 Reply Last reply Reply Quote 0
                  • KirAsh4K Offline
                    KirAsh4 Moderator @cowboysdude
                    @cowboysdude, I don’t know who gave you permission to take a vacation, but they need to be fired. First thing you will need to do when you return.
                      joey12725
                      I re-installed magic mirror and got this above the unable to install dependencies error
                      npm ERR! file /home/pi/.npm/extract-zip/1.5.0/package/package.json
                      npm ERR!
                      npm ERR! ^
                      npm ERR! File: /home/pi/.npm/extract-zip/1.5.0/package/package.json
                      npm ERR!
                      Unable to install dependencies!
                        joey12725
                        Could that be related to the npm install issue?
                          jamlid
                          It looks like I’m having the same problem. Trying to manually install on a Pi 1…
                          33914 error electron-prebuilt@1.4.3 postinstall: node install.js
                          33914 error Exit status 1
                          33915 error Failed at the electron-prebuilt@1.4.3 postinstall script.
                          33915 error This is most likely a problem with the electron-prebuilt package,
                          33915 error not with npm itself.
                          33915 error Tell the author that this fails on your system:
                          33915 error node install.js
                          33915 error You can get their info via:
                          33915 error npm owner ls electron-prebuilt
                          33915 error There is likely additional logging output above.
                          33916 error System Linux 4.4.21+
                          33917 error command “/usr/bin/nodejs” “/usr/bin/npm” “install”
                          33918 error cwd /home/pi/MagicMirror
                          33919 error node -v v0.10.29
                          33920 error npm -v 1.4.21
                          33921 error code ELIFECYCLE
                            joey12725
                            Im on a pi 2 B
                            • F Offline
                              FlorianRD
                              Yesterday i perform a install for MM². I get step by step from a user who made an InstallGuide.
                              And finaly the same error as shown below. I’ve buy the complete Hardware for the Mirror. The frame are handmade an looks fine. But the Software goes wrong. There should be a project for the incomming autumn here in Germany. I hope that any can fix this problem and tell us.
                              I used a RaspberryPi 3 with Jessie
                              Greetings from North of Germany
                              • strawberry 3.141S Offline
                                strawberry 3.141 Project Sponsor Module Developer @FlorianRD
                                @FlorianRD did you use this tutorial? https://forum.magicmirror.builders/topic/236/complete-setup-tutorial
                                you forgot to append your errors
                                • F Offline
                                  FlorianRD
                                  Yes i am use this tutorial.
                                  Here the errors:
                                  magicmirror@2.0.0 start /home/pi/MagicMirror
                                  electron js/electron.js
                                  npm ERR! Linux 4.4.23-v7+
                                  npm ERR! argv “/usr/bin/nodejs” “/usr/bin/npm” “start”
                                  npm ERR! node v6.9.0
                                  npm ERR! code ELIFECYCLE
                                  npm ERR! magicmirror@2.0.0 start: electron js/electron.js
                                  npm ERR! Exit status 1
                                  npm ERR!
                                  npm ERR! Failed at the magicmirror@2.0.0 start script ‘electron js/electron.js’.
                                  npm ERR! If you do, this is most likely a problem with the magicmirror package,
                                  npm ERR! not with npm itself.
                                  npm ERR! electron js/electron.js
                                  npm ERR! npm bugs magicmirror
                                  npm ERR! Or if that isn’t available, you can get their info via:
                                  npm ERR! npm owner ls magicmirror
                                  • MichMichM Offline
                                    MichMich
                                    @FlorianRD, did you run npm install from within the MagicMirror folder?
                                    • K Offline
                                      kiefersmith @MichMich
                                      @MichMich I seem to be having the same problem as folks above. Whenever I try npm install from inside the MM folder, the electron installation either stalls or fails.
                                      • F Offline
                                        FlorianRD
                                        @MichMich, yes i did run npm install. I’ve just finished a new installation of this project.
                                        Step by step by the tutorial. And, same problem.
                                        electron-v1.3.8-linux-arm.zip is in /.electron folder
                                        • MichMichM Offline
                                          MichMich
                                          Did the npm install finish without issues?
                                            Patrick
                                            Sounds strange but did set a system time?
                                            Sometimes it’s messing around without.
                                            • 1 / 4
