    Hello-Lucy
    Scheduled Pinned Locked Moved Fun & Games
    285 Posts 27 Posters 765.1k Views 27 Watching
    • Mykle1M
      Download:
      [card:mykle1/Hello-Lucy]
      Version 1.0.2 Update
      • No swapping of module files (as in previous version)
      • Improved visual cues.
      • Customizable random startup greetings
      • Customizable confirmation sound when Lucy accepts commands
      • Simple pages setup.
      • Will work with any module.
      • Mykle1M
        Added modules that will now work by default with Lucy
        1. MMM-MLB
        2. MMM-MLBStandings
        3. MMM-Recipe
        4. MMM-rfacts
        5. MMM-Holiday
        6. MMM-NiceThings
        7. MMM-MusicCharts
        8. MMM-Advice
        9. MMM-NHL
        • Mykle1M
          @TheGeekfather
          When I try “0” no flashing mic but still “undefined”
          I can hear “hello Michael what would you like to see” and then say “Hello Lucy”
          When you say Hello Lucy the microphone does not turn green and start blinking? Just for verification
          T 1 Reply Last reply
          • Mykle1M
            Lets verify some other things too.
            the path to your Hello-Lucy folder is home/MagicMirror/modules/Hello-Lucy?
            Inside the Hello-Lucy folder is a node_modules folder?
            • Mykle1M
              Also, please open a new terminal and type
              cat /proc/asound/cards and post the result here please.
              Mine looks like this:
              pop@e8300:~/MagicMirror$ cat /proc/asound/cards
               0 [PCH            ]: HDA-Intel - HDA Intel PCH
                                    HDA Intel PCH at 0xf7130000 irq 29
               1 [NVidia         ]: HDA-Intel - HDA NVidia
                                    HDA NVidia at 0xf7080000 irq 17
              • T
                TheGeekfather @Mykle1
                @Mykle1
                Maybe a problem
                It seems all my modules are in
                modules/default/
                Mykle1M T 3 Replies Last reply
                • Mykle1M
                  Mykle1 Project Sponsor Module Developer @TheGeekfather
                  @TheGeekfather
                  Definitely a problem
                  • T
                    TheGeekfather @TheGeekfather
                    @TheGeekfather
                     0 [ALSA           ]: bcm2835_alsa - bcm2835 ALSA
                                          bcm2835 ALSA
                     1 [Device         ]: USB-Audio - USB Audio Device
                                          C-Media Electronics Inc. USB Audio Device at usb-0000:01:00.0-1.1, full speed
                    • Mykle1M
                      @TheGeekfather said in Hello-Lucy:
                      modules/default/
                      We went over this earlier, I think. Only the default MM modules go there. All other modules go on the root of the modules folder
                      • T
                        @Mykle1
                        Other modules installed there are working but had to change paths for icons to work
                        Mykle1M cowboysdudeC T 3 Replies Last reply
                        • Mykle1M
                          I don’t even know how to reply to that. Modules belong in the modules folder
                          • cowboysdudeC
                            cowboysdude Module Developer @TheGeekfather
                            @TheGeekfather The problem is when you try to change things you also are changing the way the mirror works and this will lead to issues…the kind you are having LOL.
                            Default modules are wired to work out of that directory - /modules/default
                            3rd party modules are wired to work out of the modules directory. /modules
                            Seems like a lot of extra work and if you miss something then you will have issues. So my suggestion is that if you get a module from github you do this:
                            in the MagicMirror/modules directory
                            git clone https://github.com/mykle1/Hello-Lucy.git
                            Then go to the dir you just cloned the repository in ie MagicMirror/modules/Hello-Lucy
                            [typically from there if a module has dependencies you’d run ‘npm install’… for Lucy you have to be in the MagicMirror/modules/Hello-Lucy/installers directory and you would run a bash command]
                            Put the module in your config and you’re off an running…
                            This will put your modules in the correct place to run without having to change the module itself… Where you are going to run into issues is when a developer hard codes something you can’t find…
                            It’s already happened and that creates issues that are VERY difficult to solve…
                            But I am glad you are trying to learn something and seem very enthusiastic about it :)
                            • T
                              @TheGeekfather
                              I guess the best thing is to re-install all my modules in the correct folder. Is that the only way to get Lucy to work.
                              Thank you again for all your help
                              • T
                                TheGeekfather @cowboysdude
                                @cowboysdude
                                OK, here is what I did
                                1. deleted Hello-Lucy folder from default directory
                                2. cloned hello-lucy in modules directory
                                3. cd installers and ran bash dependencies.sh
                                4. npm start
                                in modules/default directory In the defaultmodules.js file I added
                                var defaultModules = [
                                	"alert",
                                	"calendar",
                                	"clock",
                                	"compliments",
                                	"currentweather",
                                	"helloworld",
                                	"newsfeed",
                                	"weatherforecast",
                                	"updatenotification",
                                	"MMM-Swipe",
                                	"MMM-NHL",
                                	"MMM-BMW-DS",
                                	"modules/Hello-Lucy",
                                	"MMM-iFrame",
                                	"MMM-Astro",
                                lucy started and microphone icon no longer had “undefined” error but icon not flashing and commands like “show clock” or hide “clock” don’t seem to be working
                                • cowboysdudeC
                                  @TheGeekfather Well in all honesty what you’re doing is just making a huge mess. You need to delete ALL the modules that don’t belong in the default folder. ANY changes you made to any files undo…
                                  Install modules as they are intended and we can help you, other then that I have no answers for you.
                                  • T
                                    @cowboysdude
                                    I understand - and yes I will re-install
                                    One last question - should the mic icon flash when you speak?
                                    Again, THANK YOU for all your help :)
                                    • cowboysdudeC
                                      @TheGeekfather Yes, green :)
                                      • T
                                        @Mykle1
                                        Hi, you mentioned you were going to fix the install problem after noticing microphone not working with a fresh install.
                                        Any progress?
                                        Thank you for updates
                                        • cowboysdudeC
                                          @TheGeekfather The mic is an easy fix if you’re using a pi…
                                          Open terminal and type in ‘arecord -l’ it will give you all the info on your mic… more than likely if your using a USB mic it will be most likely 1,0.
                                          In your config in Hello-Lucy in the ‘config’ section of Hello-Lucy you would put:
                                          "microphone: “1,0”,
                                          That’s it…pretty simple. Yes I realize simple if you know it LOL.
                                          • T
                                            @cowboysdude
                                            :) Knowledge is Power - That is what I always told my students
                                            This is the mic I have
                                            **** List of CAPTURE Hardware Devices ****
                                            card 1: Device [USB PnP Sound Device], device 0: USB Audio [USB Audio]
                                              Subdevices: 1/1
                                              Subdevice #0: subdevice #0
                                            • 10
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 10 / 15
