    Hello-Lucy
    Scheduled Pinned Locked Moved Fun & Games
    285 Posts 27 Posters 752.8k Views 27 Watching
    • StoffbeuteluweS
      Stoffbeuteluwe Project Sponsor @Mykle1
      @Mykle1 nice Pictures
      • StoffbeuteluweS
        @Mykle1 is it possible to do show and hide in german (an) and (aus)?
        thanks for the nice module
        • Mykle1M
          Mykle1 Project Sponsor Module Developer @Stoffbeuteluwe
          @Stoffbeuteluwe said in Hello-Lucy:
          nice Pictures
          Thanks! That’s my granddaughter, Lucy. I named Hello-Lucy after her.
          I don’t think you would have much success with anything but English. There are other voice modules that will perform better in those cases
          • Mykle1M
            Neurotransmitters giving way to all that cuteness.
            • Mykle1M
              Download:
              [card:mykle1/Hello-Lucy]
              Version 1.0.1
              New and improved. Still a work in progress but usable.
              Comments welcome.
              • Mykle1M
                Mykle1 Project Sponsor Module Developer @AxLed
                @AxLed said in Hello-Lucy:
                USB Soundcard (USB-Audio C-Media) with 2x 3.5mm jack for microphone and speaker
                Do you have a specific model number for this? I was thinking I would get one and test it with Lucy which I recently updated/upgraded If it works as well as as you say then I would recommend it and mention it in the repo. :thumbsup:.
                • Mykle1M
                  Download:
                  Version 1.0.2 Update
                  • No swapping of module files (as in previous version)
                  • Improved visual cues.
                  • Customizable random startup greetings
                  • Customizable confirmation sound when Lucy accepts commands
                  • Simple pages setup.
                  • Will work with any module.
                  • Mykle1M
                    Added modules that will now work by default with Lucy
                    1. MMM-MLB
                    2. MMM-MLBStandings
                    3. MMM-Recipe
                    4. MMM-rfacts
                    5. MMM-Holiday
                    6. MMM-NiceThings
                    7. MMM-MusicCharts
                    8. MMM-Advice
                    9. MMM-NHL
                    • Mykle1M
                      @TheGeekfather
                      When I try “0” no flashing mic but still “undefined”
                      I can hear “hello Michael what would you like to see” and then say “Hello Lucy”
                      When you say Hello Lucy the microphone does not turn green and start blinking? Just for verification
                      • Mykle1M
                        Lets verify some other things too.
                        the path to your Hello-Lucy folder is home/MagicMirror/modules/Hello-Lucy?
                        Inside the Hello-Lucy folder is a node_modules folder?
                        • Mykle1M
                          Also, please open a new terminal and type
                          cat /proc/asound/cards and post the result here please.
                          Mine looks like this:
                          pop@e8300:~/MagicMirror$ cat /proc/asound/cards
                           0 [PCH            ]: HDA-Intel - HDA Intel PCH
                                                HDA Intel PCH at 0xf7130000 irq 29
                           1 [NVidia         ]: HDA-Intel - HDA NVidia
                                                HDA NVidia at 0xf7080000 irq 17
                          • T
                            TheGeekfather @Mykle1
                            @Mykle1
                            Maybe a problem
                            It seems all my modules are in
                            modules/default/
                            Mykle1M T 3 Replies Last reply Reply Quote 0
                            • Mykle1M
                              Mykle1 Project Sponsor Module Developer @TheGeekfather
                              @TheGeekfather
                              Definitely a problem
                              • T
                                TheGeekfather @TheGeekfather
                                @TheGeekfather
                                 0 [ALSA           ]: bcm2835_alsa - bcm2835 ALSA
                                                      bcm2835 ALSA
                                 1 [Device         ]: USB-Audio - USB Audio Device
                                                      C-Media Electronics Inc. USB Audio Device at usb-0000:01:00.0-1.1, full speed
                                • Mykle1M
                                  @TheGeekfather said in Hello-Lucy:
                                  modules/default/
                                  We went over this earlier, I think. Only the default MM modules go there. All other modules go on the root of the modules folder
                                  • T
                                    @Mykle1
                                    Other modules installed there are working but had to change paths for icons to work
                                    Mykle1M cowboysdudeC T 3 Replies Last reply Reply Quote 0
                                    • Mykle1M
                                      I don’t even know how to reply to that. Modules belong in the modules folder
                                      • cowboysdudeC
                                        cowboysdude Module Developer @TheGeekfather
                                        @TheGeekfather The problem is when you try to change things you also are changing the way the mirror works and this will lead to issues…the kind you are having LOL.
                                        Default modules are wired to work out of that directory - /modules/default
                                        3rd party modules are wired to work out of the modules directory. /modules
                                        Seems like a lot of extra work and if you miss something then you will have issues. So my suggestion is that if you get a module from github you do this:
                                        in the MagicMirror/modules directory
                                        git clone https://github.com/mykle1/Hello-Lucy.git
                                        Then go to the dir you just cloned the repository in ie MagicMirror/modules/Hello-Lucy
                                        [typically from there if a module has dependencies you’d run ‘npm install’… for Lucy you have to be in the MagicMirror/modules/Hello-Lucy/installers directory and you would run a bash command]
                                        Put the module in your config and you’re off an running…
                                        This will put your modules in the correct place to run without having to change the module itself… Where you are going to run into issues is when a developer hard codes something you can’t find…
                                        It’s already happened and that creates issues that are VERY difficult to solve…
                                        But I am glad you are trying to learn something and seem very enthusiastic about it :)
                                        • T
                                          @TheGeekfather
                                          I guess the best thing is to re-install all my modules in the correct folder. Is that the only way to get Lucy to work.
                                          Thank you again for all your help
                                          • T
                                            TheGeekfather @cowboysdude
                                            @cowboysdude
                                            OK, here is what I did
                                            1. deleted Hello-Lucy folder from default directory
                                            2. cloned hello-lucy in modules directory
                                            3. cd installers and ran bash dependencies.sh
                                            4. npm start
                                            in modules/default directory In the defaultmodules.js file I added
                                            var defaultModules = [
                                            	"alert",
                                            	"calendar",
                                            	"clock",
                                            	"compliments",
                                            	"currentweather",
                                            	"helloworld",
                                            	"newsfeed",
                                            	"weatherforecast",
                                            	"updatenotification",
                                            	"MMM-Swipe",
                                            	"MMM-NHL",
                                            	"MMM-BMW-DS",
                                            	"modules/Hello-Lucy",
                                            	"MMM-iFrame",
                                            	"MMM-Astro",
                                            lucy started and microphone icon no longer had “undefined” error but icon not flashing and commands like “show clock” or hide “clock” don’t seem to be working
                                            • 10
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 10 / 15
