    MMM-Instagram - Pull and animate photos from Instagram feed
    87 Posts 26 Posters 125.1k Views 27 Watching
    • rudibaraniR
      rudibarani Project Sponsor @kapsolas
      @kapsolas Thanks for the quick reply. Another question on the side: It seems that only images are are loaded that where on Instagram before I restarted my MM. Is that intended behaviour or am I doing something wrong?
      			module: 'MMM-Instagram',
      			position: 'middle_center',
      			disabled: false,
      				access_token: '####.####',
      				count: 200,
      				min_timestamp: 0,
      				animationSpeed: 2500,
      				updateInterval: 30000
      I waited an hour but non of my new images showed up. Only old ones. Even create a new account with only three images before booting my MM - and it keeps cycling those three and ignores later uploads…
      Any idea?
      • Y
        Yurick
        Read my post 4 months ago. I changed the code and it works fine for me. As I am a copy-paste coder, I can’t post it here for not to be damned. :) But if we ask a author to fix it using my clues it would be nice to have a working module.
        rudibaraniR 1 Reply Last reply Reply Quote 0
        • rudibaraniR
          rudibarani Project Sponsor @Yurick
          Thanks @Yurick for finding the solution to the problem. Would be great to see this implemented so everyone could benefit from @kapsolas module.
          • K
            kapsolas Module Developer
            The module was not loading new images. I was thinking to fix that and I have a solution i am testing.
            Sounds like @Yurick has a solution for this too. If he pm’s it i can test it and incorporate into the code
            • Y
              Yurick
              Here is my MMM-Instagram.js
              /* global Module */
              /* Magic Mirror
               * Module: MMM-Instagram
               * By Jim Kapsalis https://github.com/kapsolas
               * MIT Licensed.
              Module.register('MMM-Instagram', {
                  defaults: {
                      format: 'json',
                      lang: 'en-us',
                      animationSpeed: 1000,
                      updateInterval: 60000, // 10 minutes
                      access_token: '',
                      count: 200,
                      min_timestamp: 0,
                      loadingText: 'Loading...'
                  // Define required scripts
                  getScripts: function() {
                      return ["moment.js"];
                  // Define required translations
                  getTranslations: function() {
                      return false;
                  // Define start sequence
                  start: function() {
              	var self = this;
                      Log.info('Starting module: ' + this.name);
                      this.data.classes = 'bright medium';
                      this.loaded = false;
                      this.images = {};
                      this.activeItem = 0;
                      this.url = 'https://api.instagram.com/v1/users/self/media/recent' + this.getParams();
              	var insturl = this.url;
              //        Log.info('instaurl = ' + this.url);
              	setInterval(function() {
              //				Log.info('NewUrl = ' + this.url);
              			        self.sendSocketNotification("INSTAGRAM_GET", insturl);
              				    }, 40000); //perform every 1000 milliseconds.
                  getStyles: function() {
                      return ['instagram.css', 'font-awesome.css'];
                  // Override the dom generator
                  getDom: function() {
                      var imageDisplay = document.createElement('div'); //support for config.changeColor
                      if (!this.loaded) {
                          wrapper.innerHTML = this.config.loadingText;
                          return wrapper;
                      // set the first item in the list...
                      if (this.activeItem >= this.images.photo.length) {
                      var tempimage = this.images.photo[this.activeItem];
                      // image
                      var imageLink = document.createElement('div');
                      //imageLink.innerHTML = "<img src='https://www.google.com/images/branding/googlelogo/1x/googlelogo_color_272x92dp.png'>";
                      imageLink.id = "MMM-Instagram-image";
                      imageLink.innerHTML = "<img src='" + tempimage.photolink + "'>";
                      imageDisplay.appendChild(imageLink);
                      wrapper.appendChild(imageDisplay);
                      return wrapper;
                  /* scheduleUpdateInterval()
                   * Schedule visual update.
                  scheduleUpdateInterval: function() {
                      var self = this;
                      Log.info("Scheduled update interval set up...");
                      self.updateDom(self.config.animationSpeed);
                          Log.info("incrementing the activeItem and refreshing");
                          self.activeItem++;
                      }, this.config.updateInterval);
                   * getParams()
                   * returns the query string required for the request to flickr to get the
                   * photo stream of the user requested
                  getParams: function() {
                      var params = '?';
                      params += 'count=' + this.config.count;
                      params += '&min_timestamp=' + this.config.min_timestamp;
                      params += '&access_token=' + this.config.access_token;
                      return params;
                  // override socketNotificationReceived
                      //Log.info('socketNotificationReceived: ' + notification);
                      if (notification === 'INSTAGRAM_IMAGE_LIST')
                          //Log.info('received INSTAGRAM_IMAGE_LIST');
                          this.images = payload;
                          //Log.info("count: " +  this.images.photo.length);
                          // we want to update the dom the first time and then schedule next updates
                          if (!this.loaded) {
                          this.updateDom(1000);
                              this.scheduleUpdateInterval();
                          this.loaded = true;
              Spoiler Text
                microkost
                  microkost @microkost
                  Is this module still working? Because after clonning and providing access_token according to manual is still stucked on Loading… warning.
                  Output from starting MagicMirror:
                  Connecting socket for: MMM-Instagram
                  Starting node_helper for module [MMM-Instagram]
                  OK, some debug… I finally used multi account fork from O5ten and used his API key from README 1160247792.b119586.49fa97770ee34deb92e621069c760cee then it started to show pictures, so finall problem is on my access_token. Good to know for debuging, should help someone else…
                  How to test that access token is OK?
                  Put to web browser:
                  https://api.instagram.com/v1/users/self/media/recent?access_token=1160247792.b119586.49fa97770ee34deb92e621069c760cee
                  did you see some data as result?
                  "data": [{"id": "1698285770916717663...
                  So now test your key
                  https://api.instagram.com/v1/users/self/media/recent?access_token=[TOKEN_HERE]
                  If there is result, everything is OK, if you get
                  data	[]
                  then is time to investigate! Do you have content on your wall? Because your’s last 20 posts are only accessible in sandbox https://www.instagram.com/developer/sandbox/ (!!!)
                  For rest and another use cases read carefully https://www.instagram.com/developer/ guide.
                  My problem was empty my wall… Sorry for spam, but maybe it helps someone not familiar with that with debuging.
                  • N
                    nobita @kapsolas
                    @kapsolas
                    I have 3 questions
                    1. What happen after install this module, Loading…status on monitor (not show photo)
                    2. How to get API KEY
                    3. in config, ask access_token so I have to put access_token or API KEY
                      Thanks for all your kind
                      benderstwin
                      This works great, but is it possible to make it actually reload the pictures from instagram without reloading MM?
                      • A
                        AlexanderSalter
                        Hi all, had the same problem, Instagram was acquired by Facebook who have updated the way the API works.
                        I spent a couple of days writing and testing a new module for Instagram that was based off the original.
                        It requires a Facebook developer account and app, but I have explained it as best i can in readme
                        Intro_Post
                        MMM-Instagram2020
                          chassain 0 @AlexanderSalter
                          @AlexanderSalter
                          It works fine. Thanks Alexander.
                          • K
                            Kkardi
                            @yo-less said in MMM-Instagram - Pull and animate photos from Instagram feed:
                            @kapsolas
                            @kapsolas is it possible to show only the photos you liked with this??
                            • 5 / 5
