Solved Fresh install but pm2 error
I think so, if this below is not an Error.
But what caused the error or what was the mistake?/home/pi/.pm2/logs/MagicMirror-error.log last 15 lines: 0|MagicMir | + arch=armv7l 0|MagicMir | + false=false 0|MagicMir | ++ grep -i serveronly: 0|MagicMir | ++ awk '{print tolower($2)}' 0|MagicMir | ++ tr -d ',"'\''' 0|MagicMir | ++ grep -v '^\s//' config/config.js 0|MagicMir | + serveronly= 0|MagicMir | + serveronly=false 0|MagicMir | ++ pgrep Xorg 0|MagicMir | + xorg=429 0|MagicMir | ++ uname 0|MagicMir | + mac=Linux 0|MagicMir | + '[' false. '!=' false. -o armv7l == armv6l ']' 0|MagicMir | + '[' 429. == . -a Linux '!=' Darwin ']' 0|MagicMir | + electron js/electron.js
@Hubschra01 u can remove the -x from run-start.sh 1st line.
That is just debugging
Strange…
I flushed the log and i remove the -x from the run-start.sh.
after reboot i see this in the log again./home/pi/.pm2/logs/MagicMirror-error.log last 15 lines: 0|MagicMir | npm ERR! code ELIFECYCLE 0|MagicMir | npm ERR! errno 1 0|MagicMir | npm ERR! magicmirror@2.10.1 start: `./run-start.sh` 0|MagicMir | npm ERR! Exit status 1 0|MagicMir | npm ERR! 0|MagicMir | npm ERR! Failed at the magicmirror@2.10.1 start script. 0|MagicMir | npm ERR! This is probably not a problem with npm. There is likely additional logging output above. 0|MagicMir | 0|MagicMir | npm ERR! A complete log of this run can be found in: 0|MagicMir | npm ERR! /home/pi/.npm/_logs/2020-01-21T16_37_02_810Z-debug.log /home/pi/.npm/_logs/2020-01-21T16_37_02_810Z-debug.log 0 info it worked if it ends with ok 1 verbose cli [ '/usr/bin/node', '/usr/bin/npm', 'start' ] 2 info using npm@6.13.4 3 info using node@v10.18.1 4 verbose run-script [ 'prestart', 'start', 'poststart' ] 5 info lifecycle magicmirror@2.10.1~prestart: magicmirror@2.10.1 6 info lifecycle magicmirror@2.10.1~start: magicmirror@2.10.1 7 verbose lifecycle magicmirror@2.10.1~start: unsafe-perm in lifecycle true 8 verbose lifecycle magicmirror@2.10.1~start: PATH: /usr/lib/node_modules/npm/node_modules/npm-lifecycle/node-gyp-bin:/home/pi/MagicMirror/node_modules/.bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/local/games:/usr/games 9 verbose lifecycle magicmirror@2.10.1~start: CWD: /home/pi/MagicMirror 10 silly lifecycle magicmirror@2.10.1~start: Args: [ '-c', './run-start.sh' ] 11 silly lifecycle magicmirror@2.10.1~start: Returned: code: 1 signal: null 12 info lifecycle magicmirror@2.10.1~start: Failed to exec start script 13 verbose stack Error: magicmirror@2.10.1 start: `./run-start.sh` 13 verbose stack Exit status 1 13 verbose stack at EventEmitter.<anonymous> (/usr/lib/node_modules/npm/node_modules/npm-lifecycle/index.js:332:16) 13 verbose stack at EventEmitter.emit (events.js:198:13) 13 verbose stack at ChildProcess.<anonymous> (/usr/lib/node_modules/npm/node_modules/npm-lifecycle/lib/spawn.js:55:14) 13 verbose stack at ChildProcess.emit (events.js:198:13) 13 verbose stack at maybeClose (internal/child_process.js:982:16) 13 verbose stack at Process.ChildProcess._handle.onexit (internal/child_process.js:259:5) 14 verbose pkgid magicmirror@2.10.1 15 verbose cwd /home/pi/MagicMirror 16 verbose Linux 4.19.75-v7+ 17 verbose argv "/usr/bin/node" "/usr/bin/npm" "start" 18 verbose node v10.18.1 19 verbose npm v6.13.4 20 error code ELIFECYCLE 21 error errno 1 22 error magicmirror@2.10.1 start: `./run-start.sh` 22 error Exit status 1 23 error Failed at the magicmirror@2.10.1 start script. 23 error This is probably not a problem with npm. There is likely additional logging output above. 24 verbose exit [ 1, true ]
weird:pouting_face:
@Hubschra01 and the mirror did not start?
The Mirror start an work fine now. :-) Thanks to you
So i have to consider the error in the log as normal? -
@Hubschra01 i wonder if that is the shutdown log, on the reboot…
but there should be more on restart
if i understand you right your oppinion is that this error meassage is the shutdown message and not a start up error? -
@Hubschra01 yes
dopm2 logs --lines=100
[TAILING] Tailing last 100 lines for [all] processes (change the value with --lines option)/home/pi/.pm2/logs/MagicMirror-error.log last 100 lines:
0|MagicMir | npm ERR! magicmirror@2.10.1 start:./run-start.sh
0|MagicMir |
0|MagicMir | npm ERR! /home/pi/.npm/_logs/2020-01-21T16_37_02_810Z-debug.log/home/pi/.pm2/logs/MagicMirror-out.log last 100 lines:
0|MagicMir |
0|MagicMir | > magicmirror@2.10.1 start /home/pi/MagicMirror
0|MagicMir | > ./run-start.sh
0|MagicMir |
0|MagicMir |
0|MagicMir |
0|MagicMir | [17:37:28.657] [LOG] Starting MagicMirror: v2.10.1
0|MagicMir | [17:37:28.673] [LOG] Loading config …
0|MagicMir | [17:37:28.686] [LOG] Loading module helpers …
0|MagicMir | [17:37:28.689] [LOG] No helper found for module: alert.
0|MagicMir | [17:37:28.825] [LOG] Initializing new module helper …
0|MagicMir | [17:37:28.827] [LOG] Module helper loaded: updatenotification
0|MagicMir | [17:37:28.829] [LOG] No helper found for module: clock.
0|MagicMir | [17:37:30.081] [LOG] Initializing new module helper …
0|MagicMir | [17:37:30.082] [LOG] Module helper loaded: calendar
0|MagicMir | [17:37:30.083] [LOG] No helper found for module: currentweather.
0|MagicMir | [17:37:30.084] [LOG] No helper found for module: weatherforecast.
0|MagicMir | [17:37:30.172] [LOG] Initializing new module helper …
0|MagicMir | [17:37:30.173] [LOG] Module helper loaded: newsfeed
0|MagicMir | [17:37:30.173] [LOG] All module helpers loaded.
0|MagicMir | [17:37:30.175] [LOG] Starting server on port 8080 …
0|MagicMir | [17:37:30.199] [LOG] Server started …
0|MagicMir | [17:37:30.201] [LOG] Connecting socket for: updatenotification
0|MagicMir | [17:37:30.202] [LOG] Connecting socket for: calendar
0|MagicMir | [17:37:30.204] [LOG] Starting node helper for: calendar
0|MagicMir | [17:37:30.205] [LOG] Connecting socket for: newsfeed
0|MagicMir | [17:37:30.206] [LOG] Starting module: newsfeed
0|MagicMir | [17:37:30.207] [LOG] Sockets connected & modules started …
0|MagicMir | [17:37:30.821] [LOG] Launching application. -
@Hubschra01 said in Fresh install but pm2 error:
yeh,
there are two launches,1 ended at 2020-01-21T16_37_02_810Z
1 still running,
