    MMM-Lunartic only a picture when static
    5 Posts 2 Posters 1.7k Views 2 Watching
      shgmongohh
      MMM-Lunartic only shows a picture of the moon when the image is static
      image: "static", // animation, current, DayNight or static
      No other option is working.
      • Mykle1M
        Mykle1 Project Sponsor Module Developer @shgmongohh
        @shgmongohh said in MMM-Lunartic only a picture when static:
        animation and static are both working. I just tested them both.
        DayNight is out of order until the API resumes normal operation (April)
        current will work if you replace the MMM-Lunartic.js file with the one that is in the temporary fix folder that is inside the MMM-Lunartic folder. (But the other three won’t until the API resumes normal operation in April)
        @sdetweil - Don’t say you told me so! :-)
          shgmongohh
          @Mykle1 Thanks its working
          Mykle1M 2 Replies Last reply Reply Quote 1
          • Mykle1M
            @shgmongohh
            Thanks its working
            Cool. I’ll make an announcement when the API is working correctly. Thanks for your interest in the module. :thumbsup:
            • Mykle1M
              @shgmongohh
              Kindly mark the topic as solved. :-)
