MMM-YOUTUBE, "STOP VIDEO, PAUSE VIDEO" COMMANDS Friend!
17 Posts 7 Posters 4.1k Views 7 Watching
    meusprojetoskali
    Re: MMM-AssistantMk2 (v3)
    Friend!
    First congratulations on the excellent work!
    Everything is working perfectly on my MagicMirror / raspberry PI4.
    But I can’t get the STOP VIDEO, PAUSE VIDEO commands to work …
    Could you explain in more detail how to make these commands work and also explain how to change the language for these commands (pt-BR)? Thanks!
    ? 1 Reply Last reply Jan 28, 2020, 1:55 PM Reply Quote 0
      A Former User @meusprojetoskali
      @meusprojetoskali
      If you are using this recipe;
      https://github.com/eouia/MMM-AssistantMk2/blob/master/recipes/with-MMM-Youtube.js
      Change this line for your prefer pattern as your language.
        transcriptionHooks: {
          "STOP_YOUTUBE": {
            pattern: "stop video",
            command: "STOP_YOUTUBE"
      Then save it as with-MMM-Youtube-PTBR.js(or any name you want), then in configuration, use that file instead with-MMM-Youtube.js
      • L Offline
        ludacriss57
        I have the same problem but I don’t think it comes from the language.
        in fact even saying “stop video”, nothing happens.
        similarly for Reboot- Restart-Shutdown, if I ask “reboot please” nothing happens.
        you have to start the assistant before or you have to say “stop video” or “reboot please” directly?
        otherwise I think I have a problem with the microphone in the google assistant. during config it marks me “configuarion not work” while it works on “hotword”.
        ? 1 Reply Last reply Jan 31, 2020, 12:17 PM Reply Quote 0
          A Former User @ludacriss57
          @ludacriss57
          what log says?
          M 1 Reply Last reply Jan 31, 2020, 12:44 PM Reply Quote 0
            meusprojetoskali @Guest
            In my case the problem is not really the language, kept the default language (English), when I say “STOP VIDEO”, instead of stopping the video, he makes a new search on youtube for a video called “STOP VIDEO”.
            Any suggestion?
            Use the recipe: with-MMM-Youtube.js
            ? L 2 Replies Last reply Jan 31, 2020, 1:07 PM Reply Quote 0
              @meusprojetoskali
              See your recipe / transcriptionHook, whether stop video pattern is defined properly.
              • L Offline
                ludacriss57 @meusprojetoskali
                @meusprojetoskali
                that’s exactly it, it opens a video called “stop video”
                how will i see the logs? sorry i’m very bad at raspberry …
                • L Offline
                  ludacriss57
                  at my place i have that
                  var recipe = {
                  “STOP_YOUTUBE”: {
                  pattern: “stop video”,
                  command: “STOP_YOUTUBE”
                  • L Offline
                    ludacriss57
                    module: "MMM-AssistantMk2",
                    position: "top_center",
                      ui: "Classic",
                      assistantConfig: {
                      latitude: ****
                      longitude: ****
                    responseConfig: {
                        useScreenOutput: true,
                        useAudioOutput: true,
                        useChime: true,
                        timer: 5000,
                        myMagicWord: false
                     micConfig: { // put there configuration generated by auto-installer
                       recorder: "arecord",
                       device: "plughw:1",
                    recipes: [ "with-MMM-Hotword.js", "with-MMM-Youtube.js", "Reboot-Restart-Shutdown.js" ],
                    profiles: {
                        "default": {
                          profileFile: "default.json",
                          lang: "fr-FR",
                      A Former User
                      @ludacriss57 : votre souci est il résolu ? ou avez-vous besoin de mon aide en français ?
                      @bugsounet (MMM-AssistantMK2 développeur)
