    Can't install; trouble with nodejs and npm
    4 Posts 3 Posters 1.3k Views 3 Watching
      bm
      I have tried so much troubleshooting and I just don’t know what to do anymore. After restarting everything and completely reinstalling raspbian and FINALLY installing node, and npm, I get this after trying to install (I couldn’t fit the last few lines):
      pi@raspberrypi:~/MagicMirror $ npm install
      npm WARN deprecated time-grunt@2.0.0: Deprecated because Grunt is practically unmaintained. Move on to something better. This package will continue to work with Grunt v1, but it will not receive any updates.
      npm WARN deprecated rrule-alt@2.2.8: Please use rrule instead
      npm WARN engine chai@4.2.0: wanted: {"node":">=4"} (current: {"node":"0.10.29","npm":"1.4.21"})
      npm WARN engine grunt-eslint@22.0.0: wanted: {"node":">=8"} (current: {"node":"0.10.29","npm":"1.4.21"})
      npm WARN engine grunt-jsonlint@2.1.1: wanted: {"node":">=6"} (current: {"node":"0.10.29","npm":"1.4.21"})
      npm WARN engine grunt-markdownlint@2.9.0: wanted: {"node":">=6","npm":">=3"} (current: {"node":"0.10.29","npm":"1.4.21"})
      npm WARN engine http-auth@3.2.4: wanted: {"node":">=4.6.1"} (current: {"node":"0.10.29","npm":"1.4.21"})
      npm WARN engine spectron@3.8.0: wanted: {"node":">=0.12.4"} (current: {"node":"0.10.29","npm":"1.4.21"})
      npm WARN engine express-ipfilter@1.1.1: wanted: {"node":">=8.9.0"} (current: {"node":"0.10.29","npm":"1.4.21"})
      npm WARN engine feedme@1.2.0: wanted: {"node":">=4"} (current: {"node":"0.10.29","npm":"1.4.21"})
      npm WARN engine helmet@3.21.2: wanted: {"node":">=4.0.0"} (current: {"node":"0.10.29","npm":"1.4.21"})
      npm WARN engine request@2.88.0: wanted: {"node":">= 4"} (current: {"node":"0.10.29","npm":"1.4.21"})
      npm WARN engine mocha@4.1.0: wanted: {"node":">= 4.0.0"} (current: {"node":"0.10.29","npm":"1.4.21"})
      npm WARN engine electron@3.1.13: wanted: {"node":">= 4.0"} (current: {"node":"0.10.29","npm":"1.4.21"})
      npm WARN engine mocha@5.2.0: wanted: {"node":">= 4.0.0"} (current: {"node":"0.10.29","npm":"1.4.21"})
      npm ERR! Error: Method Not Allowed
      npm ERR!     at errorResponse (/usr/share/npm/lib/cache/add-named.js:260:10)
      npm ERR!     at /usr/share/npm/lib/cache/add-named.js:120:12
      npm ERR!     at saved (/usr/share/npm/node_modules/npm-registry-client/lib/get.js:167:7)
      npm ERR!     at Object.oncomplete (fs.js:107:15)
      npm ERR! If you need help, you may report this *entire* log,
      npm ERR! including the npm and node versions, at:
      npm ERR!     <http://github.com/npm/npm/issues>
      npm ERR! System Linux 4.4.34-v7+
      npm ERR! command "/usr/bin/nodejs" "/usr/bin/npm" "install"
      npm ERR! cwd /home/pi/MagicMirror
      npm ERR! node -v v0.10.29
      npm ERR! npm -v 1.4.21
      npm ERR! code E405
      npm WARN engine expect-ct@0.2.0: wanted: {"node":">=4.0.0"} (current: {"node":"0.10.29","npm":"1.4.21"})
      npm WARN engine x-xss-protection@1.3.0: wanted: {"node":">=4.0.0"} (current: {"node":"0.10.29","npm":"1.4.21"})
      npm WARN engine dont-sniff-mimetype@1.1.0: wanted: {"node":">=4.0.0"} (current: {"node":"0.10.29","npm":"1.4.21"})
      npm WARN engine dns-prefetch-control@0.2.0: wanted: {"node":">=4.0.0"} (current: {"node":"0.10.29","npm":"1.4.21"})
      npm WARN engine feature-policy@0.3.0: wanted: {"node":">=4.0.0"} (current: {"node":"0.10.29","npm":"1.4.21"})
      npm WARN engine frameguard@3.1.0: wanted: {"node":">=4.0.0"} (current: {"node":"0.10.29","npm":"1.4.21"})
      npm WARN engine helmet-crossdomain@0.4.0: wanted: {"node":">=4.0.0"} (current: {"node":"0.10.29","npm":"1.4.21"})
      npm WARN engine nocache@2.1.0: wanted: {"node":">=4.0.0"} (current: {"node":"0.10.29","npm":"1.4.21"})
      npm WARN engine hide-powered-by@1.1.0: wanted: {"node":">=4.0.0"} (current: {"node":"0.10.29","npm":"1.4.21"})
      npm WARN engine referrer-policy@1.2.0: wanted: {"node":">=4.0.0"} (current: {"node":"0.10.29","npm":"1.4.21"})
      npm WARN engine hsts@2.2.0: wanted: {"node":">=4.0.0"} (current: {"node":"0.10.29","npm":"1.4.21"})
      npm WARN engine helmet-csp@2.9.4: wanted: {"node":">=4.0.0"} (current: {"node":"0.10.29","npm":"1.4.21"})
      npm WARN engine ienoopen@1.1.0: wanted: {"node":">=4.0.0"} (current: {"node":"0.10.29","npm":"1.4.21"})
      npm WARN engine eventyoshi@0.2.1: wanted: {"node":">=4"} (current: {"node":"0.10.29","npm":"1.4.21"})
      npm WARN engine chalk@2.4.2: wanted: {"node":">=4"} (current: {"node":"0.10.29","npm":"1.4.21"})
      npm WARN engine eslint@6.8.0: wanted: {"node":"^8.10.0 || ^10.13.0 || >=11.10.1"} (current: {"node":"0.10.29","npm":"1.4.21"})
      npm WARN engine apache-crypt@1.2.1: wanted: {"node":">=4.6.1"} (current: {"node":"0.10.29","npm":"1.4.21"})
      npm WARN engine apache-md5@1.1.2: wanted: {"node":">=4.6.1"} (current: {"node":"0.10.29","npm":"1.4.21"})
      npm WARN engine markdownlint@0.19.0: wanted: {"node":">=10"} (current: {"node":"0.10.29","npm":"1.4.21"})
      npm WARN engine grunt-legacy-util@1.1.1: wanted: {"node":">= 6"} (current: {"node":"0.10.29","npm":"1.4.21"})
      npm WARN engine supports-color@5.5.0: wanted: {"node":">=4"} (current: {"node":"0.10.29","npm":"1.4.21"})
      npm WARN engine ansi-styles@3.2.1: wanted: {"node":">=4"} (current: {"node":"0.10.29","npm":"1.4.21"})
      npm WARN deprecated webdriverio@4.14.4: outdated version, please use @next
      npm WARN engine has-flag@3.0.0: wanted: {"node":">=4"} (current: {"node":"0.10.29","npm":"1.4.21"})
      npm WARN engine content-security-policy-builder@2.1.0: wanted: {"node":">=4.0.0"} (current: {"node":"0.10.29","npm":"1.4.21"})
      npm WARN engine webdriverio@4.14.4: wanted: {"node":">= 4.8.5"} (current: {"node":"0.10.29","npm":"1.4.21"})
      npm WARN engine har-validator@5.1.3: wanted: {"node":">=6"} (current: {"node":"0.10.29","npm":"1.4.21"})
      npm WARN engine form-data@2.3.3: wanted: {"node":">= 0.12"} (current: {"node":"0.10.29","npm":"1.4.21"})
      npm WARN engine base64id@2.0.0: wanted: {"node":"^4.5.0 || >= 5.9"} (current: {"node":"0.10.29","npm":"1.4.21"})
      npm WARN engine ws@7.2.1: wanted: {"node":">=8.3.0"} (current: {"node":"0.10.29","npm":"1.4.21"})
      npm WARN engine grunt-legacy-log-utils@2.0.1: wanted: {"node":">=6"} (current: {"node":"0.10.29","npm":"1.4.21"})
      npm WARN engine electron-download@4.1.1: wanted: {"node":">= 4.0"} (current: {"node":"0.10.29","npm":"1.4.21"})
      npm WARN engine har-schema@2.0.0: wanted: {"node":">=4"} (current: {"node":"0.10.29","npm":"1.4.21"})
      npm WARN engine mime@1.6.0: wanted: {"node":">=4"} (current: {"node":"0.10.29","npm":"1.4.21"})
      npm WARN optional dep failed, continuing electron@3.1.13
      npm WARN engine path-exists@3.0.0: wanted: {"node":">=4"} (current: {"node":"0.10.29","npm":"1.4.21"})
      npm WARN engine sumchecker@2.0.2: wanted: {"node":">= 4.0"} (current: {"node":"0.10.29","npm":"1.4.21"})
      npm WARN engine env-paths@1.0.0: wanted: {"node":">=4"} (current: {"node":"0.10.29","npm":"1.4.21"})
      npm WARN engine esprima@4.0.1: wanted: {"node":">=4"} (current: {"node":"0.10.29","npm":"1.4.21"})
      npm WARN engine deep-extend@0.6.0: wanted: {"node":">=4.0.0"} (current: {"node":"0.10.29","npm":"1.4.21"})
      npm WARN engine universalify@0.1.2: wanted: {"node":">= 4.0.0"} (current: {"node":"0.10.29","npm":"1.4.21"})
      npm WARN engine deep-eql@3.0.1: wanted: {"node":">=0.12"} (current: {"node":"0.10.29","npm":"1.4.21"})
      npm WARN engine type-detect@4.0.8: wanted: {"node":">=4"} (current: {"node":"0.10.29","npm":"1.4.21"})
      npm WARN engine supports-color@4.4.0: wanted: {"node":">=4"} (current: {"node":"0.10.29","npm":"1.4.21"})
      npm WARN engine growl@1.10.3: wanted: {"node":">=4.x"} (current: {"node":"0.10.29","npm":"1.4.21"})
      > console-stamp@0.2.9 postinstall /home/pi/MagicMirror/node_modules/console-stamp
      > node ./msg.js
      Attention
          Console-stamp version 3.0.0 Release Candidate is out. Install by using the tag '@next'. NB: Breaking changes.
          For more details goto: https://www.npmjs.com/package/console-stamp/v/next
      npm WARN engine growl@1.10.5: wanted: {"node":">=4.x"} (current: {"node":"0.10.29","npm":"1.4.21"})
      npm WARN engine supports-color@5.4.0: wanted: {"node":">=4"} (current: {"node":"0.10.29","npm":"1.4.21"})
      > utf-8-validate@5.0.2 install /home/pi/MagicMirror/node_modules/socket.io/node_modules/engine.io/node_modules/utf-8-validate
      > node-gyp-build
      make: Entering directory '/home/pi/MagicMirror/node_modules/socket.io/node_modules/engine.io/node_modules/utf-8-validate/build'
        CC(target) Release/obj.target/validation/src/validation.o
      ../src/validation.c:3:22: fatal error: node_api.h: No such file or directory
       #include <node_api.h>
      compilation terminated.
      validation.target.mk:82: recipe for target 'Release/obj.target/validation/src/validation.o' failed
      make: *** [Release/obj.target/validation/src/validation.o] Error 1
      make: Leaving directory '/home/pi/MagicMirror/node_modules/socket.io/node_modules/engine.io/node_modules/utf-8-validate/build'
      gyp ERR! build error
      gyp ERR! stack Error: `make` failed with exit code: 2
      gyp ERR! stack     at ChildProcess.onExit (/usr/share/node-gyp/lib/build.js:267:23)
      gyp ERR! stack     at ChildProcess.emit (events.js:98:17)
      gyp ERR! stack     at Process.ChildProcess._handle.onexit (child_process.js:809:12)
      gyp ERR! System Linux 4.4.34-v7+
      gyp ERR! command "nodejs" "/usr/bin/node-gyp" "rebuild"
      gyp ERR! cwd /home/pi/MagicMirror/node_modules/socket.io/node_modules/engine.io/node_modules/utf-8-validate
      gyp ERR! node -v v0.10.29
      gyp ERR! node-gyp -v v0.12.2
      gyp ERR! not ok
      npm WARN This failure might be due to the use of legacy binary "node"
      npm WARN For further explanations, please read
      /usr/share/doc/nodejs/README.Debian
      > bufferutil@4.0.1 install /home/pi/MagicMirror/node_modules/socket.io/node_modules/engine.io/node_modules/bufferutil
      > node-gyp-build
      node.js:815
          var cwd = process.cwd();
      Error: ENOENT, no such file or directory
          at Function.startup.resolveArgv0 (node.js:815:23)
          at startup (node.js:58:13)
          at node.js:906:3
      npm ERR! Error: ENOENT, lstat '/home/pi/MagicMirror/node_modules/socket.io/node_modules/socket.io-client/dist/socket.io.slim.js.map'
      npm ERR! path /home/pi/MagicMirror/node_modules/socket.io/node_modules/socket.io-client/dist/socket.io.slim.js.map
      npm ERR! fstream_path /home/pi/MagicMirror/node_modules/socket.io/node_modules/socket.io-client/dist/socket.io.slim.js.map
      npm ERR! fstream_type File
      npm ERR! fstream_class FileWriter
      npm ERR! code ENOENT
      npm ERR! errno 34
      npm ERR! fstream_stack /usr/lib/nodejs/fstream/lib/writer.js:284:26
      npm ERR! fstream_stack Object.oncomplete (evalmachine.<anonymous>:107:15)
      > electron-chromedriver@1.8.0 install /home/pi/MagicMirror/node_modules/spectron/node_modules/electron-chromedriver
      > node ./download-chromedriver.js
      /home/pi/MagicMirror/node_modules/spectron/node_modules/electron-chromedriver/node_modules/electron-download/lib/index.js:3
      const arch = require('./arch')
      SyntaxError: Use of const in strict mode.
          at Module._compile (module.js:439:25)
          at Object.Module._extensions..js (module.js:474:10)
          at Module.load (module.js:356:32)
          at Function.Module._load (module.js:312:12)
          at Module.require (module.js:364:17)
          at require (module.js:380:17)
          at Object.<anonymous> (/home/pi/MagicMirror/node_modules/spectron/node_modules/electron-chromedriver/download-chromedriver.js:3:24)
          at Module._compile (module.js:456:26)
      npm ERR! error rolling back Error: ENOTEMPTY, rmdir '/home/pi/MagicMirror/node_modules/spectron/node_modules/webdriverio/docs/guide'
      npm ERR! error rolling back  spectron@3.8.0 { [Error: ENOTEMPTY, rmdir '/home/pi/MagicMirror/node_modules/spectron/node_modules/webdriverio/docs/guide']
      npm ERR! error rolling back   errno: 53,
      npm ERR! error rolling back   code: 'ENOTEMPTY',
      npm ERR! error rolling back   path: '/home/pi/MagicMirror/node_modules/spectron/node_modules/webdriverio/docs/guide' }
      npm WARN engine punycode@2.1.1: wanted: {"node":">=6"} (current: {"node":"0.10.29","npm":"1.4.21"})
      npm WARN engine get-stdin@7.0.0: wanted: {"node":">=8"} (current: {"node":"0.10.29","npm":"1.4.21"})
      npm WARN engine string-width@4.2.0: wanted: {"node":">=8"} (current: {"node":"0.10.29","npm":"1.4.21"})
      npm WARN engine meow@6.0.0: wanted: {"node":">=8"} (current: {"node":"0.10.29","npm":"1.4.21"})
      npm WARN engine strip-ansi@6.0.0: wanted: {"node":">=8"} (current: {"node":"0.10.29","npm":"1.4.21"})
      npm WARN engine execall@2.0.0: wanted: {"node":">=8"} (current: {"node":"0.10.29","npm":"1.4.21"})
      npm WARN engine chalk@3.0.0: wanted: {"node":">=8"} (current: {"node":"0.10.29","npm":"1.4.21"})
      npm WARN engine leven@3.1.0: wanted: {"node":">=6"} (current: {"node":"0.10.29","npm":"1.4.21"})
      npm WARN engine log-symbols@3.0.0: wanted: {"node":">=8"} (current: {"node":"0.10.29","npm":"1.4.21"})
      npm WARN engine import-lazy@4.0.0: wanted: {"node":">=8"} (current: {"node":"0.10.29","npm":"1.4.21"})
      npm WARN engine global-modules@2.0.0: wanted: {"node":">=6"} (current: {"node":"0.10.29","npm":"1.4.21"})
      npm WARN engine resolve-from@5.0.0: wanted: {"node":">=8"} (current: {"node":"0.10.29","npm":"1.4.21"})
      npm WARN engine slash@3.0.0: wanted: {"node":">=8"} (current: {"node":"0.10.29","npm":"1.4.21"})
      npm WARN engine postcss-safe-parser@4.0.1: wanted: {"node":">=6.0.0"} (current: {"node":"0.10.29","npm":"1.4.21"})
      npm WARN engine html-tags@3.1.0: wanted: {"node":">=8"} (current: {"node":"0.10.29","npm":"1.4.21"})
      npm WARN engine postcss-reporter@6.0.1: wanted: {"node":">=6"} (current: {"node":"0.10.29","npm":"1.4.21"})
      npm WARN engine file-entry-cache@5.0.1: wanted: {"node":">=4"} (current: {"node":"0.10.29","npm":"1.4.21"})
      npm WARN engine globby@11.0.0: wanted: {"node":">=10"} (current: {"node":"0.10.29","npm":"1.4.21"})
      npm WARN engine postcss-scss@2.0.0: wanted: {"node":">=6.0.0"} (current: {"node":"0.10.29","npm":"1.4.21"})
      npm WARN engine postcss-less@3.1.4: wanted: {"node":">=6.14.4"} (current: {"node":"0.10.29","npm":"1.4.21"})
      npm WARN engine postcss-selector-parser@3.1.1: wanted: {"node":">=4"} (current: {"node":"0.10.29","npm":"1.4.21"})
      npm WARN engine ignore@5.1.4: wanted: {"node":">= 4"} (current: {"node":"0.10.29","npm":"1.4.21"})
      npm WARN engine cosmiconfig@6.0.0: wanted: {"node":">=8"} (current: {"node":"0.10.29","npm":"1.4.21"})
      npm WARN engine table@5.4.6: wanted: {"node":">=6.0.0"} (current: {"node":"0.10.29","npm":"1.4.21"})
      npm WARN engine micromatch@4.0.2: wanted: {"node":">=8"} (current: {"node":"0.10.29","npm":"1.4.21"})
      npm WARN engine autoprefixer@9.7.4: wanted: {"node":">=6.0.0"} (current: {"node":"0.10.29","npm":"1.4.21"})
      npm WARN engine postcss@7.0.26: wanted: {"node":">=6.0.0"} (current: {"node":"0.10.29","npm":"1.4.21"})
      npm WARN deprecated left-pad@1.3.0: use String.prototype.padStart()
      npm WARN engine ansi-regex@5.0.0: wanted: {"node":">=8"} (current: {"node":"0.10.29","npm":"1.4.21"})
      npm WARN engine global-prefix@3.0.0: wanted: {"node":">=6"} (current: {"node":"0.10.29","npm":"1.4.21"})
      npm WARN engine clone-regexp@2.2.0: wanted: {"node":">=6"} (current: {"node":"0.10.29","npm":"1.4.21"})
      npm WARN engine is-fullwidth-code-point@3.0.0: wanted: {"node":">=8"} (current: {"node":"0.10.29","npm":"1.4.21"})
      npm ERR! error rolling back Error: ENOTEMPTY, rmdir '/home/pi/MagicMirror/node_modules/stylelint/node_modules/postcss-jsx'
      npm ERR! error rolling back  stylelint@13.0.0 { [Error: ENOTEMPTY, rmdir '/home/pi/MagicMirror/node_modules/stylelint/node_modules/postcss-jsx']
      npm ERR! error rolling back   path: '/home/pi/MagicMirror/node_modules/stylelint/node_modules/postcss-jsx' }
      npm ERR! Error: ENOENT, lstat '/home/pi/MagicMirror/node_modules/stylelint/node_modules/ignore/README.md'
      npm ERR! path /home/pi/MagicMirror/node_modules/stylelint/node_modules/ignore/README.md
      npm ERR! fstream_path /home/pi/MagicMirror/node_modules/stylelint/node_modules/ignore/README.md
      npm ERR! errno 34
      npm ERR! Error: ENOENT, lstat '/home/pi/MagicMirror/node_modules/stylelint/node_modules/postcss-syntax/README.md'
      npm ERR! path /home/pi/MagicMirror/node_modules/stylelint/node_modules/postcss-syntax/README.md
      npm ERR! fstream_path /home/pi/MagicMirror/node_modules/stylelint/node_modules/postcss-syntax/README.md
      npm ERR! errno 34
      npm ERR! Error: ENOENT, lstat '/home/pi/MagicMirror/node_modules/stylelint/node_modules/cosmiconfig/dist/cacheWrapper.d.ts.map'
      npm ERR! path /home/pi/MagicMirror/node_modules/stylelint/node_modules/cosmiconfig/dist/cacheWrapper.d.ts.map
      npm ERR! fstream_path /home/pi/MagicMirror/node_modules/stylelint/node_modules/cosmiconfig/dist/cacheWrapper.d.ts.map
      npm ERR! errno 34
      npm ERR! Error: ENOENT, lstat '/home/pi/MagicMirror/node_modules/stylelint/node_modules/autoprefixer/lib/hacks/block-logical.js'
      npm ERR! path /home/pi/MagicMirror/node_modules/stylelint/node_modules/autoprefixer/lib/hacks/block-logical.js
      npm ERR! fstream_path /home/pi/MagicMirror/node_modules/stylelint/node_modules/autoprefixer/lib/hacks/block-logical.js
      npm ERR! errno 34
      npm ERR! Error: ENOENT, utime '/home/pi/MagicMirror/node_modules/stylelint/node_modules/log-symbols/node_modules/chalk/index.js.flow'
      npm ERR! path /home/pi/MagicMirror/node_modules/stylelint/node_modules/log-symbols/node_modules/chalk/index.js.flow
      npm ERR! fstream_path /home/pi/MagicMirror/node_modules/stylelint/node_modules/log-symbols/node_modules/chalk/index.js.flow
      npm ERR! fstream_finish_call utimes
      npm ERR! errno 34
      npm ERR! fstream_stack /usr/lib/nodejs/fstream/lib/writer.js:305:19
      npm ERR! Error: ENOENT, lstat '/home/pi/MagicMirror/node_modules/stylelint/node_modules/specificity/test/test.js'
      npm ERR! path /home/pi/MagicMirror/node_modules/stylelint/node_modules/specificity/test/test.js
      npm ERR! fstream_path /home/pi/MagicMirror/node_modules/stylelint/node_modules/specificity/test/test.js
      npm ERR! errno 34
      npm ERR! Error: ENOENT, lstat '/home/pi/MagicMirror/node_modules/stylelint/node_modules/sugarss/parser.js'
      npm ERR! path /home/pi/MagicMirror/node_modules/stylelint/node_modules/sugarss/parser.js
      npm ERR! fstream_path /home/pi/MagicMirror/node_modules/stylelint/node_modules/sugarss/parser.js
      npm ERR! errno 34
      npm ERR! Error: ENOENT, lstat '/home/pi/MagicMirror/node_modules/stylelint/node_modules/micromatch/README.md'
      npm ERR! path /home/pi/MagicMirror/node_modules/stylelint/node_modules/micromatch/README.md
      npm ERR! fstream_path /home/pi/MagicMirror/node_modules/stylelint/node_modules/micromatch/README.md
      npm ERR! errno 34
      npm ERR! Error: ENOENT, lstat '/home/pi/MagicMirror/node_modules/stylelint/node_modules/debug/dist/debug.js'
      npm ERR! path /home/pi/MagicMirror/node_modules/stylelint/node_modules/debug/dist/debug.js
      npm ERR! fstream_path /home/pi/MagicMirror/node_modules/stylelint/node_modules/debug/dist/debug.js
      npm ERR! errno 34
      npm WARN engine log-symbols@2.2.0: wanted: {"node":">=4"} (current: {"node":"0.10.29","npm":"1.4.21"})
      npm ERR! Error: ENOENT, lstat '/home/pi/MagicMirror/node_modules/stylelint/node_modules/postcss-sass/parser.js'
      npm ERR! path /home/pi/MagicMirror/node_modules/stylelint/node_modules/postcss-sass/parser.js
      npm ERR! fstream_path /home/pi/MagicMirror/node_modules/stylelint/node_modules/postcss-sass/parser.js
      npm ERR! errno 34
      npm ERR! Error: ENOENT, lstat '/home/pi/MagicMirror/node_modules/stylelint/node_modules/postcss-selector-parser/dist/parser.js'
      npm ERR! path /home/pi/MagicMirror/node_modules/stylelint/node_modules/postcss-selector-parser/dist/parser.js
      npm ERR! fstream_path /home/pi/MagicMirror/node_modules/stylelint/node_modules/postcss-selector-parser/dist/parser.js
      npm ERR! errno 34
      npm WARN engine flat-cache@2.0.1: wanted: {"node":">=4"} (current: {"node":"0.10.29","npm":"1.4.21"})
      npm ERR! Error: ENOENT, lstat '/home/pi/MagicMirror/node_modules/stylelint/node_modules/postcss/lib/container.js'
      npm ERR! path /home/pi/MagicMirror/node_modules/stylelint/node_modules/postcss/lib/container.js
      npm ERR! fstream_path /home/pi/MagicMirror/node_modules/stylelint/node_modules/postcss/lib/container.js
      npm ERR! errno 34
      npm WARN engine request-promise-native@1.0.8: wanted: {"node":">=0.12.0"} (current: {"node":"0.10.29","npm":"1.4.21"})
      npm WARN engine escodegen@1.13.0: wanted: {"node":">=4.0"} (current: {"node":"0.10.29","npm":"1.4.21"})
      npm WARN engine array-union@2.1.0: wanted: {"node":">=8"} (current: {"node":"0.10.29","npm":"1.4.21"})
      npm WARN engine merge2@1.3.0: wanted: {"node":">= 6"} (current: {"node":"0.10.29","npm":"1.4.21"})
      npm WARN engine dir-glob@3.0.1: wanted: {"node":">=8"} (current: {"node":"0.10.29","npm":"1.4.21"})
      npm WARN engine fast-glob@3.1.1: wanted: {"node":">=8"} (current: {"node":"0.10.29","npm":"1.4.21"})
      npm WARN engine supports-color@7.1.0: wanted: {"node":">=8"} (current: {"node":"0.10.29","npm":"1.4.21"})
      npm WARN engine ansi-styles@4.2.1: wanted: {"node":">=8"} (current: {"node":"0.10.29","npm":"1.4.21"})
      npm WARN engine is-regexp@2.1.0: wanted: {"node":">=6"} (current: {"node":"0.10.29","npm":"1.4.21"})
      npm WARN engine path-type@4.0.0: wanted: {"node":">=8"} (current: {"node":"0.10.29","npm":"1.4.21"})
      npm WARN engine has-flag@4.0.0: wanted: {"node":">=8"} (current: {"node":"0.10.29","npm":"1.4.21"})
      npm WARN engine write@1.0.3: wanted: {"node":">=4"} (current: {"node":"0.10.29","npm":"1.4.21"})
      npm WARN engine readable-stream@3.5.0: wanted: {"node":">= 6"} (current: {"node":"0.10.29","npm":"1.4.21"})
      npm WARN engine estraverse@4.3.0: wanted: {"node":">=4.0"} (current: {"node":"0.10.29","npm":"1.4.21"})
      npm ERR! error rolling back Error: ENOTEMPTY, rmdir '/home/pi/MagicMirror/node_modules/stylelint/node_modules/postcss-markdown/node_modules/remark/node_modules/remark-parse/lib'
      npm ERR! error rolling back  remark@10.0.1 { [Error: ENOTEMPTY, rmdir '/home/pi/MagicMirror/node_modules/stylelint/node_modules/postcss-markdown/node_modules/remark/node_modules/remark-parse/lib']
      npm ERR! error rolling back   path: '/home/pi/MagicMirror/node_modules/stylelint/node_modules/postcss-markdown/node_modules/remark/node_modules/remark-parse/lib' }
      npm ERR! Error: ENOENT, open '/home/pi/MagicMirror/node_modules/stylelint/node_modules/postcss-markdown/node_modules/remark/node_modules/remark-stringify/lib/visitors/delete.js'
      npm ERR! path /home/pi/MagicMirror/node_modules/stylelint/node_modules/postcss-markdown/node_modules/remark/node_modules/remark-stringify/lib/visitors/delete.js
      npm ERR! errno 34
      npm ERR! Error: ENOENT, lstat '/home/pi/MagicMirror/node_modules/stylelint/node_modules/postcss-markdown/node_modules/remark/node_modules/remark-parse/lib/tokenize/definition.js'
      npm ERR! path /home/pi/MagicMirror/node_modules/stylelint/node_modules/postcss-markdown/node_modules/remark/node_modules/remark-parse/lib/tokenize/definition.js
      npm ERR! fstream_path /home/pi/MagicMirror/node_modules/stylelint/node_modules/postcss-markdown/node_modules/remark/node_modules/remark-parse/lib/tokenize/definition.js
      S Mykle1M 3 Replies Last reply Reply Quote 1
        sdetweil @bm
        @bm erase the MagicMirror folder and use my install script from here
        Node and npm are way downlevel.
        current node is 10.17 or higher
        current npm is 6.x
        The automated install script fixes that
          Mykle1 Project Sponsor Module Developer @bm
          @bm
          And please use a code block when posting code or terminal output. Your post is incredibly difficult to read otherwise.
          https://forum.magicmirror.builders/topic/4247/how-to-post-code-on-the-forum-for-absolute-beginners
            sdetweil @bm
            @bm did you get your system set up ?
