    602 Posts 67 Posters 2.4m Views 68 Watching
    • K
      kris1208
      Merci de votre aide,
      J’ai mis quelques post plus avant le resultat du log pm2.
      Pareil pour l’affichage on vois sur les copies ecran qu’il manque une partie de l’image sur la droite.
      C’est VLC qui est utilisé mais j’ai mis omx et c’est pareil.
      • I
        iorifly
        Dear, I need help!
        I am experiencing the following error while trying to start module configuration. When adding the line in config.js:
                            module: 'MMM-RTSPStream',
                            position: 'middle_center',
                                initialSetup: true
        I have the following error
        [14:14:56.732] [ERROR]  WARNING! Could not validate config file. Starting with default configuration. Please correct syntax errors at or above this line: /home/pi/MagicMirror/modules/MMM-RTSPStream/node_modules/semver/semver.js:1
        (function (exports, require, module, __filename, __dirname, process, global, Buffer) { return function (exports, require, module, __filename, __dirname) { !
        SyntaxError: Invalid or unexpected token
            at new Script (vm.js:74:7)
            at createScript (vm.js:246:10)
            at Object.runInThisContext (vm.js:298:10)
            at Module._compile (internal/modules/cjs/loader.js:678:28)
            at Object.Module._extensions..js (internal/modules/cjs/loader.js:722:10)
            at Module.load (internal/modules/cjs/loader.js:620:32)
            at tryModuleLoad (internal/modules/cjs/loader.js:559:12)
            at Function.Module._load (internal/modules/cjs/loader.js:551:3)
            at Module.require (internal/modules/cjs/loader.js:658:17)
            at require (internal/modules/cjs/helpers.js:20:18)
        [14:14:56.735] [LOG]    Loading module helpers ...
        evroomE 1 Reply Last reply
        • evroomE
          evroom @iorifly
          @iorifly said in [MMM-RTSPStream] - Video Streaming from Live Feeds & Security Cameras:
          'MMM-RTSPStream
          what do you expect to happen with this particular config?
          Did you execute all the steps from the “Using the module” paragraph in
          https://github.com/shbatm/MMM-RTSPStream
          I would suggest to read the instructions once more and then let us know the result.
          Success.
          MagicMirror version: 2.37.0
          I 1 Reply Last reply
          • I
            iorifly @evroom
            @evroom Hello, how are you ?
              Thanks for answering me.
            So if I didn’t have the error. I was hoping to be able to access the URL:
            http: // your-mirror-ip: 8080 / MMM-RTSPStream / config.html
            and proceed with the setup. However, the server does not go up. I can’t access the url. I believe the error I described is preventing it.
            If you can, help me.
            • evroomE
              evroom @iorifly
              @iorifly
              Okay, that makes sense.
              Has been a while since I set it up myself, but I will take a look.
              Cannot promise anything :-)
              What are you trying / hoping to stream?
              • I
                iorifly @evroom
                @evroom Thanks for trying to help me.
                  My intention is to stream the video stream from my UBIQUITI cameras. In particular I would like to call a camera.
                evroomE 2 Replies Last reply
                • evroomE
                  evroom @iorifly
                  @iorifly
                  had troubles opening that config.html myself.
                  Try this:
                  1/ Install the module using:
                  sh -c "$(curl -s https://raw.githubusercontent.com/shbatm/MMM-RTSPStream/develop/scripts/installer.sh)"
                  2/ Add the module to the config.js:
                  vi ~/MagicMirror/config/config.js
                  	disabled: false,
                              initialSetup: true,
                  3/ Restart mm:
                  pm2 restart mm
                  4/ Start Chromium Web Browser on Pi (direct or using VNC).
                  Use URL:
                  http://localhost:8080/MMM-RTSPStream/config.html
                  5/ Follow the instructions and save the config.
                  6/ Add the module to the config.js (replace the initial one):
                  7/ Flush the logs:
                  pm2 flush
                  8/ Restart mm:
                  pm2 restart mm
                  9/ Check the logs:
                  pm2 logs --lines 200
                  10/ Look for this line (when there are no blocking errors):
                  Starting stream stream1 using:
                  • evroomE
                    evroom @iorifly
                    @iorifly
                    You can try this config for testing:
                        module: "MMM-RTSPStream",
                        position: "middle_center",
                        header: "MMM-RTSPStream Test",
                            autoStart: true,
                            rotateStreams: false,
                            rotateStreamTimeout: 10,
                            moduleWidth: 640,
                            moduleHeight: 360,
                            localPlayer: 'omxplayer',
                            remotePlayer: 'none',
                            showSnapWhenPaused: true,
                            remoteSnaps: true,
                            stream1: {
                                url: 'rtsp://wowzaec2demo.streamlock.net/vod/mp4:BigBuckBunny_115k.mov',
                                frameRate: 'undefined',
                                snapshotType: 'url',
                                snapshotRefresh: 10,
                                width: 640,
                                height: 360,
                      claudia003
                      The following forum is illustrative and commendable. I just want to add on that I am facing a vigorous circumstances regarding my home security camera Arlo pro 2 about the video streaming.I have been trying to fix this issues regarding the video streaming is not working in arlo pro add on camera.=by following the manuals as guided by the help desk support.Suggest us if we have to add on anything.
                      • N
                        Number_5
                        Hello i have a similar problem,
                        I can’t see my ip- camera stream on the mirror. The stream can be seen by entering the IP in the VLC player but not in MagicMirror. In the MagicMirror i can only see a white frame.
                        The recommendation
                        implement in config.js i followeld.
                        After a restart I could see the film in the mirror, but unfortunately only once, I swear I don’t have anything in the config. changed. Now I have only a white frame on the Mirror.
                        I had to adjust the script from the configurator by a comma, otherwise the file config.js could not be found.
                        My entry in the config.js for IP.camera:
                        module: “MMM-RTSPStream”,
                        position: “middle_center”,
                        header: “test1”,
                        autoStart: true,
                        rotateStreams: true,
                        moduleWidth: 354,
                        moduleHeight: 240,
                        localPlayer: ‘vlc’,
                        remotePlayer: ‘none’,
                        remoteSnaps: true,
                        shutdownDelay: 12,
                        stream1: {
                        url: ‘rtsp://XXXX:XXXXX@192.XXX.2.108:80/cam/realmonitor?channel=2&subtype=0’,
                        frameRate: ‘undefined’,
                        snapshotType: ‘url’,
                        width: undefined,
                        height: undefined,
                        My entry in the config.js for Testvideo:
                        header: “MMM-RTSPStream Test”,
                        autoStart: true,
                        moduleWidth: 640,
                        moduleHeight: 360,
                        localPlayer: ‘omxplayer’,
                        remoteSnaps: true,
                        stream1: {
                        url: ‘rtsp://wowzaec2demo.streamlock.net/vod/mp4:BigBuckBunny_115k.mov’,
                        width: 640,
                        height: 360,
                        step 7) pm2 flush
                        pi@raspberrypi:~ $ pm2 flush
                        [PM2] Flushing /home/pi/.pm2/pm2.log
                        [PM2] Flushing:
                        [PM2] /home/pi/.pm2/logs/MagicMirror-out.log
                        [PM2] /home/pi/.pm2/logs/MagicMirror-error.log
                        [PM2] Flushing:
                        [PM2] /dev/null
                        [PM2] /home/pi/.pm2/logs/omx-stream1-error.log
                        [PM2] Logs flushed
                        pi@raspberrypi:~ $
                        step 8) restart MM
                        pi@raspberrypi:~ $ pm2 restart MagicMirror
                        [PM2] Applying action restartProcessId on app [MagicMirror](ids: 0)
                        [PM2] MagicMirror ✓
                        │ id │ name │ namespace │ version │ mode │ pid │ uptime │ ↺ │ status │ cpu │ mem │ user │ watching │
                        │ 0 │ MagicMirror │ default │ 2.10.0 │ fork │ 8828 │ 0s │ 1 │ online │ 0% │ 2.5mb │ pi │ disabled │
                        │ 1 │ omx_stream1 │ default │ N/A │ fork │ 8774 │ 4s │ 226 │ online │ 0% │ 2.5mb │ pi │ disabled │
                        pi@raspberrypi:~ $
                        step 9) check the logs
                        pi@raspberrypi:~ $ pm2 logs --lines 200
                        [TAILING] Tailing last 200 lines for [all] processes (change the value with --lines option)
                        /home/pi/.pm2/pm2.log last 200 lines:
                        PM2 | 2020-02-01T16:03:54: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
                        PM2 | 2020-02-01T16:03:54: PM2 log: App [omx_stream1:1] starting in -fork mode-
                        PM2 | 2020-02-01T16:03:54: PM2 log: App [omx_stream1:1] online
                        PM2 | 2020-02-01T16:04:00: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
                        PM2 | 2020-02-01T16:04:00: PM2 log: App [omx_stream1:1] starting in -fork mode-
                        PM2 | 2020-02-01T16:04:00: PM2 log: App [omx_stream1:1] online
                        PM2 | 2020-02-01T16:04:05: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
                        PM2 | 2020-02-01T16:04:05: PM2 log: App [omx_stream1:1] starting in -fork mode-
                        PM2 | 2020-02-01T16:04:05: PM2 log: App [omx_stream1:1] online
                        PM2 | 2020-02-01T16:04:11: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
                        PM2 | 2020-02-01T16:04:11: PM2 log: App [omx_stream1:1] starting in -fork mode-
                        PM2 | 2020-02-01T16:04:11: PM2 log: App [omx_stream1:1] online
                        PM2 | 2020-02-01T16:04:16: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
                        PM2 | 2020-02-01T16:04:16: PM2 log: App [omx_stream1:1] starting in -fork mode-
                        PM2 | 2020-02-01T16:04:16: PM2 log: App [omx_stream1:1] online
                        PM2 | 2020-02-01T16:04:22: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
                        PM2 | 2020-02-01T16:04:22: PM2 log: App [omx_stream1:1] starting in -fork mode-
                        PM2 | 2020-02-01T16:04:22: PM2 log: App [omx_stream1:1] online
                        PM2 | 2020-02-01T16:04:28: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
                        PM2 | 2020-02-01T16:04:28: PM2 log: App [omx_stream1:1] starting in -fork mode-
                        PM2 | 2020-02-01T16:04:28: PM2 log: App [omx_stream1:1] online
                        PM2 | 2020-02-01T16:04:33: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
                        PM2 | 2020-02-01T16:04:33: PM2 log: App [omx_stream1:1] starting in -fork mode-
                        PM2 | 2020-02-01T16:04:33: PM2 log: App [omx_stream1:1] online
                        PM2 | 2020-02-01T16:04:39: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
                        PM2 | 2020-02-01T16:04:39: PM2 log: App [omx_stream1:1] starting in -fork mode-
                        PM2 | 2020-02-01T16:04:39: PM2 log: App [omx_stream1:1] online
                        PM2 | 2020-02-01T16:04:45: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
                        PM2 | 2020-02-01T16:04:45: PM2 log: App [omx_stream1:1] starting in -fork mode-
                        PM2 | 2020-02-01T16:04:45: PM2 log: App [omx_stream1:1] online
                        PM2 | 2020-02-01T16:04:50: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
                        PM2 | 2020-02-01T16:04:50: PM2 log: App [omx_stream1:1] starting in -fork mode-
                        PM2 | 2020-02-01T16:04:50: PM2 log: App [omx_stream1:1] online
                        PM2 | 2020-02-01T16:04:56: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
                        PM2 | 2020-02-01T16:04:56: PM2 log: App [omx_stream1:1] starting in -fork mode-
                        PM2 | 2020-02-01T16:04:56: PM2 log: App [omx_stream1:1] online
                        PM2 | 2020-02-01T16:05:00: PM2 log: Stopping app:MagicMirror id:0
                        PM2 | 2020-02-01T16:05:00: PM2 log: pid=863 msg=failed to kill - retrying in 100ms
                        PM2 | 2020-02-01T16:05:00: PM2 log: App [MagicMirror:0] exited with code [0] via signal [SIGINT]
                        PM2 | 2020-02-01T16:05:00: PM2 log: pid=863 msg=process killed
                        PM2 | 2020-02-01T16:05:00: PM2 log: App [MagicMirror:0] starting in -fork mode-
                        PM2 | 2020-02-01T16:05:00: PM2 log: App [MagicMirror:0] online
                        PM2 | 2020-02-01T16:05:02: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
                        PM2 | 2020-02-01T16:05:02: PM2 log: App [omx_stream1:1] starting in -fork mode-
                        PM2 | 2020-02-01T16:05:02: PM2 log: App [omx_stream1:1] online
                        PM2 | 2020-02-01T16:05:08: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
                        PM2 | 2020-02-01T16:05:08: PM2 log: App [omx_stream1:1] starting in -fork mode-
                        PM2 | 2020-02-01T16:05:08: PM2 log: App [omx_stream1:1] online
                        PM2 | 2020-02-01T16:05:09: PM2 log: Stopping app:omx_stream1 id:1
                        PM2 | 2020-02-01T16:05:09: PM2 log: App [omx_stream1:1] exited with code [0] via signal [SIGINT]
                        PM2 | 2020-02-01T16:05:09: PM2 log: pid=8949 msg=process killed
                        PM2 | 2020-02-01T16:05:13: PM2 log: App [omx_stream1:1] starting in -fork mode-
                        PM2 | 2020-02-01T16:05:13: PM2 log: App [omx_stream1:1] online
                        PM2 | 2020-02-01T16:05:19: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
                        PM2 | 2020-02-01T16:05:19: PM2 log: App [omx_stream1:1] starting in -fork mode-
                        PM2 | 2020-02-01T16:05:19: PM2 log: App [omx_stream1:1] online
                        PM2 | 2020-02-01T16:05:25: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
                        PM2 | 2020-02-01T16:05:25: PM2 log: App [omx_stream1:1] starting in -fork mode-
                        PM2 | 2020-02-01T16:05:25: PM2 log: App [omx_stream1:1] online
                        PM2 | 2020-02-01T16:05:30: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
                        PM2 | 2020-02-01T16:05:30: PM2 log: App [omx_stream1:1] starting in -fork mode-
                        PM2 | 2020-02-01T16:05:30: PM2 log: App [omx_stream1:1] online
                        PM2 | 2020-02-01T16:05:36: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
                        PM2 | 2020-02-01T16:05:36: PM2 log: App [omx_stream1:1] starting in -fork mode-
                        PM2 | 2020-02-01T16:05:36: PM2 log: App [omx_stream1:1] online
                        PM2 | 2020-02-01T16:05:41: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
                        PM2 | 2020-02-01T16:05:41: PM2 log: App [omx_stream1:1] starting in -fork mode-
                        PM2 | 2020-02-01T16:05:41: PM2 log: App [omx_stream1:1] online
                        PM2 | 2020-02-01T16:05:47: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
                        PM2 | 2020-02-01T16:05:47: PM2 log: App [omx_stream1:1] starting in -fork mode-
                        PM2 | 2020-02-01T16:05:47: PM2 log: App [omx_stream1:1] online
                        PM2 | 2020-02-01T16:05:53: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
                        PM2 | 2020-02-01T16:05:53: PM2 log: App [omx_stream1:1] starting in -fork mode-
                        PM2 | 2020-02-01T16:05:53: PM2 log: App [omx_stream1:1] online
                        PM2 | 2020-02-01T16:05:58: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
                        PM2 | 2020-02-01T16:05:58: PM2 log: App [omx_stream1:1] starting in -fork mode-
                        PM2 | 2020-02-01T16:05:58: PM2 log: App [omx_stream1:1] online
                        PM2 | 2020-02-01T16:06:04: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
                        PM2 | 2020-02-01T16:06:04: PM2 log: App [omx_stream1:1] starting in -fork mode-
                        PM2 | 2020-02-01T16:06:04: PM2 log: App [omx_stream1:1] online
                        PM2 | 2020-02-01T16:06:09: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
                        PM2 | 2020-02-01T16:06:09: PM2 log: App [omx_stream1:1] starting in -fork mode-
                        PM2 | 2020-02-01T16:06:09: PM2 log: App [omx_stream1:1] online
                        PM2 | 2020-02-01T16:06:15: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
                        PM2 | 2020-02-01T16:06:15: PM2 log: App [omx_stream1:1] starting in -fork mode-
                        PM2 | 2020-02-01T16:06:15: PM2 log: App [omx_stream1:1] online
                        PM2 | 2020-02-01T16:06:20: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
                        PM2 | 2020-02-01T16:06:20: PM2 log: App [omx_stream1:1] starting in -fork mode-
                        PM2 | 2020-02-01T16:06:20: PM2 log: App [omx_stream1:1] online
                        PM2 | 2020-02-01T16:06:26: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
                        PM2 | 2020-02-01T16:06:26: PM2 log: App [omx_stream1:1] starting in -fork mode-
                        PM2 | 2020-02-01T16:06:26: PM2 log: App [omx_stream1:1] online
                        PM2 | 2020-02-01T16:06:31: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
                        PM2 | 2020-02-01T16:06:31: PM2 log: App [omx_stream1:1] starting in -fork mode-
                        PM2 | 2020-02-01T16:06:31: PM2 log: App [omx_stream1:1] online
                        PM2 | 2020-02-01T16:06:37: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
                        PM2 | 2020-02-01T16:06:37: PM2 log: App [omx_stream1:1] starting in -fork mode-
                        PM2 | 2020-02-01T16:06:37: PM2 log: App [omx_stream1:1] online
                        PM2 | 2020-02-01T16:06:43: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
                        PM2 | 2020-02-01T16:06:43: PM2 log: App [omx_stream1:1] starting in -fork mode-
                        PM2 | 2020-02-01T16:06:43: PM2 log: App [omx_stream1:1] online
                        /home/pi/.pm2/logs/MagicMirror-error.log last 200 lines:
                        /home/pi/.pm2/logs/omx-stream1-error.log last 200 lines:
                        /home/pi/.pm2/logs/MagicMirror-out.log last 200 lines:
                        0|MagicMir | [16:05:00.464] [LOG] Shutting down server…
                        0|MagicMir | [16:05:00.465] [LOG] Stopping module helper: updatenotification
                        0|MagicMir | [16:05:00.466] [LOG] Shutting down MMM-RTSPStream streams that were using vlc
                        0|MagicMir | [16:05:00.467] [LOG] Killing DevilsPie2…
                        0|MagicMir | [16:05:00.471] [LOG] Killing All VLC Streams…
                        0|MagicMir | [16:05:00.472] [LOG] Stopping module helper: MMM-PublicTransportHafas
                        0|MagicMir | [16:05:00.472] [LOG] Stopping module helper: calendar
                        0|MagicMir | [16:05:00.473] [LOG] Stopping module helper: newsfeed
                        0|MagicMir |
                        0|MagicMir | > magicmirror@2.10.0 start /home/pi/MagicMirror
                        0|MagicMir | > ./run-start.sh
                        0|MagicMir |
                        0|MagicMir | [16:05:07.112] [LOG] Starting MagicMirror: v2.10.0
                        0|MagicMir | [16:05:07.122] [LOG] Loading config …
                        0|MagicMir | [16:05:07.129] [LOG] Loading module helpers …
                        0|MagicMir | [16:05:07.131] [LOG] No helper found for module: alert.
                        0|MagicMir | [16:05:07.187] [LOG] Initializing new module helper …
                        0|MagicMir | [16:05:07.189] [LOG] Module helper loaded: updatenotification
                        0|MagicMir | [16:05:08.315] [LOG] Initializing new module helper …
                        0|MagicMir | [16:05:08.315] [LOG] Module helper loaded: MMM-RTSPStream
                        0|MagicMir | [16:05:08.628] [LOG] Initializing new module helper …
                        0|MagicMir | [16:05:08.629] [LOG] Module helper loaded: MMM-PublicTransportHafas
                        0|MagicMir | [16:05:08.630] [LOG] No helper found for module: clock.
                        0|MagicMir | [16:05:08.631] [LOG] No helper found for module: currentweather.
                        0|MagicMir | [16:05:08.632] [LOG] No helper found for module: weatherforecast.
                        0|MagicMir | [16:05:08.706] [LOG] Initializing new module helper …
                        0|MagicMir | [16:05:08.706] [LOG] Module helper loaded: calendar
                        0|MagicMir | [16:05:08.740] [LOG] Initializing new module helper …
                        0|MagicMir | [16:05:08.741] [LOG] Module helper loaded: newsfeed
                        0|MagicMir | [16:05:08.741] [LOG] All module helpers loaded.
                        0|MagicMir | [16:05:08.743] [LOG] Starting server on port 8080 …
                        0|MagicMir | [16:05:08.758] [LOG] Server started …
                        0|MagicMir | [16:05:08.760] [LOG] Connecting socket for: updatenotification
                        0|MagicMir | [16:05:08.761] [LOG] Connecting socket for: MMM-RTSPStream
                        0|MagicMir | [16:05:08.762] [LOG] PM2: Stopping all OMXPlayer Streams…
                        0|MagicMir | [16:05:08.765] [LOG] Connecting socket for: MMM-PublicTransportHafas
                        0|MagicMir | [16:05:08.766] [LOG] Connecting socket for: calendar
                        0|MagicMir | [16:05:08.767] [LOG] Starting node helper for: calendar
                        0|MagicMir | [16:05:08.768] [LOG] Connecting socket for: newsfeed
                        0|MagicMir | [16:05:08.769] [LOG] Starting module: newsfeed
                        0|MagicMir | [16:05:08.770] [LOG] Sockets connected & modules started …
                        0|MagicMir | [16:05:08.999] [LOG] Launching application.
                        0|MagicMir | [16:05:09.244] [LOG] PM2: Checking if omx_stream1 is running…
                        0|MagicMir | [16:05:09.245] [LOG] PM2: Stopping omx_stream1…
                        0|MagicMir | [16:05:11.221] [LOG] Transportation fetcher for station with id ‘xxx’ created.
                        0|MagicMir | [16:05:11.394] [LOG] Transportation fetcher for station with id ‘xxx’ created.
                        0|MagicMir | [16:05:11.398] [LOG] Create new calendar fetcher for url: https://calendar.gxxx- Interval: 300000
                        0|MagicMir | [16:05:11.409] [LOG] Create new news fetcher for url: https://www.swr.de/~rss/swraktuell/swraktuell-bw-100.xml - Interval: 300000
                        0|MagicMir | [16:05:13.214] [LOG] Starting stream stream1 using: omxplayer --avdict rtsp_transport:tcp --win 6xxx,874 --live --video_queue 4 --fps 30 --no-osd rtsp://xxx:xxx@xxx.xxx.2.108:80/cam/realmonitor?channel=2&subtype=0
                        0|MagicMir | [16:05:13.241] [LOG] Starting PM2 for omx_stream1
                        0|MagicMir | [16:05:13.401] [LOG] PM2 started for omx_stream1
                        0|MagicMir | [16:05:13.411] [LOG] Starting stream stream1 using VLC with args --width 352 --height 242 -I dummy --video-on-top --no-video-deco --no-embedded-video --video-title=stream1 rtsp://XXX@xxx.xxx.2.108:80/cam/realmonitor?channel=2&subtype=0…
                        0|MagicMir | [16:05:13.445] [INFO] DP2: Running window resizers…
                        0|MagicMir | [16:05:20.485] [INFO] DP2: Running window resizers…
                        1|omx_stream1 | have a nice day ;)
                        PM2 | App [omx_stream1:1] exited with code [1] via signal [SIGINT]
                        PM2 | App [omx_stream1:1] starting in -fork mode-
                        PM2 | App [omx_stream1:1] online
                        Can someone help me, to see the ip-camera on the magic-mirror ?
                        thanks,
                        • BKeyportB
                          BKeyport Module Developer
                          Try the other stream types. VLC don’t work within the magic mirror. I had to edit the string to get it to even launch using the arguments supplied by the module author, and then launching it under MM’s system didn’t ever work right, would produce a blank window. change the local player to omxplayer or ffmpeg.
                          • N
                            Number_5
                            Hello BKeyport,
                            thanks a lot for for the quick response. . Excuse me please,
                            I don’t speak English very well. did I understand you correctly. My syntax in the config.js is correct?
                            Now I have changed the player ( omxplayer or ffmpeg) in the config.js but nothing happened. i have only two white frames. i will show you below .
                            Here the moduls in the config.js
                            header: “test1”,
                            autoStart: true,
                            moduleWidth: 354,
                            moduleHeight: 240,
                            localPlayer: ‘ffmpeg’,
                            remoteSnaps: true,
                            shutdownDelay: 12,
                            stream1: {
                            url: ‘rtsp://XXX:XXX@XXX.XXX.2.108:80/cam/realmonitor?channel=2&subtype=0’,
                            width: undefined,
                            height: undefined,
                            autoStart: true,
                            moduleWidth: 640,
                            moduleHeight: 360,
                            remoteSnaps: true,
                            stream1: {
                            width: 640,
                            height: 360,
                            actuell screen: can not insert maximum filesize exceeded
                            step 7 pm2 flush
                            pi@raspberrypi:~/MagicMirror/config $ pm2 flush
                            [PM2] Flushing:
                            [PM2] Flushing:
                            [PM2] /dev/null
                            [PM2] Logs flushed
                            step 8 restart MM
                            pi@raspberrypi:~/MagicMirror $ pm2 restart MagicMirror
                            [PM2] MagicMirror ✓
                            │ 0 │ MagicMirror │ default │ 2.10.0 │ fork │ 20066 │ 0s │ 1 │ online │ 0% │ 2.6mb │ pi │ disabled │
                            │ 1 │ omx_stream1 │ default │ N/A │ fork │ 20024 │ 6s │ 487 │ online │ 0% │ 2.5mb │ pi │ disabled │
                            pi@raspberrypi:~/MagicMirror $ pm2 logs --lines 200
                            PM2 | 2020-02-01T20:40:28: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
                            PM2 | 2020-02-01T20:40:28: PM2 log: App [omx_stream1:1] starting in -fork mode-
                            PM2 | 2020-02-01T20:40:28: PM2 log: App [omx_stream1:1] online
                            PM2 | 2020-02-01T20:40:33: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
                            PM2 | 2020-02-01T20:40:33: PM2 log: App [omx_stream1:1] starting in -fork mode-
                            PM2 | 2020-02-01T20:40:33: PM2 log: App [omx_stream1:1] online
                            PM2 | 2020-02-01T20:40:39: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
                            PM2 | 2020-02-01T20:40:39: PM2 log: App [omx_stream1:1] starting in -fork mode-
                            PM2 | 2020-02-01T20:40:39: PM2 log: App [omx_stream1:1] online
                            PM2 | 2020-02-01T20:40:44: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
                            PM2 | 2020-02-01T20:40:44: PM2 log: App [omx_stream1:1] starting in -fork mode-
                            PM2 | 2020-02-01T20:40:44: PM2 log: App [omx_stream1:1] online
                            PM2 | 2020-02-01T20:40:50: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
                            PM2 | 2020-02-01T20:40:50: PM2 log: App [omx_stream1:1] starting in -fork mode-
                            PM2 | 2020-02-01T20:40:50: PM2 log: App [omx_stream1:1] online
                            PM2 | 2020-02-01T20:40:55: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
                            PM2 | 2020-02-01T20:40:55: PM2 log: App [omx_stream1:1] starting in -fork mode-
                            PM2 | 2020-02-01T20:40:55: PM2 log: App [omx_stream1:1] online
                            PM2 | 2020-02-01T20:41:01: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
                            PM2 | 2020-02-01T20:41:01: PM2 log: App [omx_stream1:1] starting in -fork mode-
                            PM2 | 2020-02-01T20:41:01: PM2 log: App [omx_stream1:1] online
                            PM2 | 2020-02-01T20:41:07: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
                            PM2 | 2020-02-01T20:41:07: PM2 log: App [omx_stream1:1] starting in -fork mode-
                            PM2 | 2020-02-01T20:41:07: PM2 log: App [omx_stream1:1] online
                            PM2 | 2020-02-01T20:41:12: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
                            PM2 | 2020-02-01T20:41:12: PM2 log: App [omx_stream1:1] starting in -fork mode-
                            PM2 | 2020-02-01T20:41:12: PM2 log: App [omx_stream1:1] online
                            PM2 | 2020-02-01T20:41:18: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
                            PM2 | 2020-02-01T20:41:18: PM2 log: App [omx_stream1:1] starting in -fork mode-
                            PM2 | 2020-02-01T20:41:18: PM2 log: App [omx_stream1:1] online
                            PM2 | 2020-02-01T20:41:23: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
                            PM2 | 2020-02-01T20:41:23: PM2 log: App [omx_stream1:1] starting in -fork mode-
                            PM2 | 2020-02-01T20:41:23: PM2 log: App [omx_stream1:1] online
                            PM2 | 2020-02-01T20:41:29: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
                            PM2 | 2020-02-01T20:41:29: PM2 log: App [omx_stream1:1] starting in -fork mode-
                            PM2 | 2020-02-01T20:41:29: PM2 log: App [omx_stream1:1] online
                            PM2 | 2020-02-01T20:41:34: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
                            PM2 | 2020-02-01T20:41:34: PM2 log: App [omx_stream1:1] starting in -fork mode-
                            PM2 | 2020-02-01T20:41:34: PM2 log: App [omx_stream1:1] online
                            PM2 | 2020-02-01T20:41:40: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
                            PM2 | 2020-02-01T20:41:40: PM2 log: App [omx_stream1:1] starting in -fork mode-
                            PM2 | 2020-02-01T20:41:40: PM2 log: App [omx_stream1:1] online
                            PM2 | 2020-02-01T20:41:45: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
                            PM2 | 2020-02-01T20:41:45: PM2 log: App [omx_stream1:1] starting in -fork mode-
                            PM2 | 2020-02-01T20:41:45: PM2 log: App [omx_stream1:1] online
                            PM2 | 2020-02-01T20:41:51: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
                            PM2 | 2020-02-01T20:41:51: PM2 log: App [omx_stream1:1] starting in -fork mode-
                            PM2 | 2020-02-01T20:41:51: PM2 log: App [omx_stream1:1] online
                            PM2 | 2020-02-01T20:41:57: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
                            PM2 | 2020-02-01T20:41:57: PM2 log: App [omx_stream1:1] starting in -fork mode-
                            PM2 | 2020-02-01T20:41:57: PM2 log: App [omx_stream1:1] online
                            PM2 | 2020-02-01T20:42:02: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
                            PM2 | 2020-02-01T20:42:02: PM2 log: App [omx_stream1:1] starting in -fork mode-
                            PM2 | 2020-02-01T20:42:02: PM2 log: App [omx_stream1:1] online
                            PM2 | 2020-02-01T20:42:08: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
                            PM2 | 2020-02-01T20:42:08: PM2 log: App [omx_stream1:1] starting in -fork mode-
                            PM2 | 2020-02-01T20:42:08: PM2 log: App [omx_stream1:1] online
                            PM2 | 2020-02-01T20:42:13: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
                            PM2 | 2020-02-01T20:42:13: PM2 log: App [omx_stream1:1] starting in -fork mode-
                            PM2 | 2020-02-01T20:42:13: PM2 log: App [omx_stream1:1] online
                            PM2 | 2020-02-01T20:42:19: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
                            PM2 | 2020-02-01T20:42:19: PM2 log: App [omx_stream1:1] starting in -fork mode-
                            PM2 | 2020-02-01T20:42:19: PM2 log: App [omx_stream1:1] online
                            PM2 | 2020-02-01T20:42:24: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
                            PM2 | 2020-02-01T20:42:24: PM2 log: App [omx_stream1:1] starting in -fork mode-
                            PM2 | 2020-02-01T20:42:24: PM2 log: App [omx_stream1:1] online
                            PM2 | 2020-02-01T20:42:30: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
                            PM2 | 2020-02-01T20:42:30: PM2 log: App [omx_stream1:1] starting in -fork mode-
                            PM2 | 2020-02-01T20:42:30: PM2 log: App [omx_stream1:1] online
                            PM2 | 2020-02-01T20:42:35: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
                            PM2 | 2020-02-01T20:42:35: PM2 log: App [omx_stream1:1] starting in -fork mode-
                            PM2 | 2020-02-01T20:42:35: PM2 log: App [omx_stream1:1] online
                            PM2 | 2020-02-01T20:42:41: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
                            PM2 | 2020-02-01T20:42:41: PM2 log: App [omx_stream1:1] starting in -fork mode-
                            PM2 | 2020-02-01T20:42:41: PM2 log: App [omx_stream1:1] online
                            PM2 | 2020-02-01T20:42:47: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
                            PM2 | 2020-02-01T20:42:47: PM2 log: App [omx_stream1:1] starting in -fork mode-
                            PM2 | 2020-02-01T20:42:47: PM2 log: App [omx_stream1:1] online
                            PM2 | 2020-02-01T20:42:52: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
                            PM2 | 2020-02-01T20:42:52: PM2 log: App [omx_stream1:1] starting in -fork mode-
                            PM2 | 2020-02-01T20:42:52: PM2 log: App [omx_stream1:1] online
                            PM2 | 2020-02-01T20:42:58: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
                            PM2 | 2020-02-01T20:42:58: PM2 log: App [omx_stream1:1] starting in -fork mode-
                            PM2 | 2020-02-01T20:42:58: PM2 log: App [omx_stream1:1] online
                            PM2 | 2020-02-01T20:43:03: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
                            PM2 | 2020-02-01T20:43:03: PM2 log: App [omx_stream1:1] starting in -fork mode-
                            PM2 | 2020-02-01T20:43:03: PM2 log: App [omx_stream1:1] online
                            PM2 | 2020-02-01T20:43:09: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
                            PM2 | 2020-02-01T20:43:09: PM2 log: App [omx_stream1:1] starting in -fork mode-
                            PM2 | 2020-02-01T20:43:09: PM2 log: App [omx_stream1:1] online
                            PM2 | 2020-02-01T20:43:14: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
                            PM2 | 2020-02-01T20:43:14: PM2 log: App [omx_stream1:1] starting in -fork mode-
                            PM2 | 2020-02-01T20:43:14: PM2 log: App [omx_stream1:1] online
                            PM2 | 2020-02-01T20:43:20: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
                            PM2 | 2020-02-01T20:43:20: PM2 log: App [omx_stream1:1] starting in -fork mode-
                            PM2 | 2020-02-01T20:43:20: PM2 log: App [omx_stream1:1] online
                            PM2 | 2020-02-01T20:43:25: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
                            PM2 | 2020-02-01T20:43:25: PM2 log: App [omx_stream1:1] starting in -fork mode-
                            PM2 | 2020-02-01T20:43:25: PM2 log: App [omx_stream1:1] online
                            PM2 | 2020-02-01T20:43:31: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
                            PM2 | 2020-02-01T20:43:31: PM2 log: App [omx_stream1:1] starting in -fork mode-
                            PM2 | 2020-02-01T20:43:31: PM2 log: App [omx_stream1:1] online
                            PM2 | 2020-02-01T20:43:36: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
                            PM2 | 2020-02-01T20:43:36: PM2 log: App [omx_stream1:1] starting in -fork mode-
                            PM2 | 2020-02-01T20:43:36: PM2 log: App [omx_stream1:1] online
                            PM2 | 2020-02-01T20:43:42: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
                            PM2 | 2020-02-01T20:43:42: PM2 log: App [omx_stream1:1] starting in -fork mode-
                            PM2 | 2020-02-01T20:43:42: PM2 log: App [omx_stream1:1] online
                            PM2 | 2020-02-01T20:43:48: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
                            PM2 | 2020-02-01T20:43:48: PM2 log: App [omx_stream1:1] starting in -fork mode-
                            PM2 | 2020-02-01T20:43:48: PM2 log: App [omx_stream1:1] online
                            PM2 | 2020-02-01T20:43:53: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
                            PM2 | 2020-02-01T20:43:53: PM2 log: App [omx_stream1:1] starting in -fork mode-
                            PM2 | 2020-02-01T20:43:53: PM2 log: App [omx_stream1:1] online
                            PM2 | 2020-02-01T20:43:59: PM2 log: Stopping app:MagicMirror id:0
                            PM2 | 2020-02-01T20:43:59: PM2 log: App [MagicMirror:0] exited with code [0] via signal [SIGINT]
                            PM2 | 2020-02-01T20:43:59: PM2 log: pid=17271 msg=process killed
                            PM2 | 2020-02-01T20:43:59: PM2 log: App [MagicMirror:0] starting in -fork mode-
                            PM2 | 2020-02-01T20:43:59: PM2 log: App [MagicMirror:0] online
                            PM2 | 2020-02-01T20:43:59: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
                            PM2 | 2020-02-01T20:43:59: PM2 log: App [omx_stream1:1] starting in -fork mode-
                            PM2 | 2020-02-01T20:43:59: PM2 log: App [omx_stream1:1] online
                            PM2 | 2020-02-01T20:44:05: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
                            PM2 | 2020-02-01T20:44:05: PM2 log: App [omx_stream1:1] starting in -fork mode-
                            PM2 | 2020-02-01T20:44:05: PM2 log: App [omx_stream1:1] online
                            PM2 | 2020-02-01T20:44:07: PM2 log: Stopping app:omx_stream1 id:1
                            PM2 | 2020-02-01T20:44:07: PM2 log: App [omx_stream1:1] exited with code [0] via signal [SIGINT]
                            PM2 | 2020-02-01T20:44:07: PM2 log: pid=20164 msg=process killed
                            PM2 | 2020-02-01T20:44:11: PM2 log: App [omx_stream1:1] starting in -fork mode-
                            PM2 | 2020-02-01T20:44:11: PM2 log: App [omx_stream1:1] online
                            PM2 | 2020-02-01T20:44:17: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
                            PM2 | 2020-02-01T20:44:17: PM2 log: App [omx_stream1:1] starting in -fork mode-
                            PM2 | 2020-02-01T20:44:17: PM2 log: App [omx_stream1:1] online
                            PM2 | 2020-02-01T20:44:23: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
                            PM2 | 2020-02-01T20:44:23: PM2 log: App [omx_stream1:1] starting in -fork mode-
                            PM2 | 2020-02-01T20:44:23: PM2 log: App [omx_stream1:1] online
                            PM2 | 2020-02-01T20:44:28: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
                            PM2 | 2020-02-01T20:44:28: PM2 log: App [omx_stream1:1] starting in -fork mode-
                            PM2 | 2020-02-01T20:44:28: PM2 log: App [omx_stream1:1] online
                            PM2 | 2020-02-01T20:44:34: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
                            PM2 | 2020-02-01T20:44:34: PM2 log: App [omx_stream1:1] starting in -fork mode-
                            PM2 | 2020-02-01T20:44:34: PM2 log: App [omx_stream1:1] online
                            PM2 | 2020-02-01T20:44:39: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
                            PM2 | 2020-02-01T20:44:39: PM2 log: App [omx_stream1:1] starting in -fork mode-
                            PM2 | 2020-02-01T20:44:39: PM2 log: App [omx_stream1:1] online
                            PM2 | 2020-02-01T20:44:45: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
                            PM2 | 2020-02-01T20:44:45: PM2 log: App [omx_stream1:1] starting in -fork mode-
                            PM2 | 2020-02-01T20:44:45: PM2 log: App [omx_stream1:1] online
                            PM2 | 2020-02-01T20:44:50: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
                            PM2 | 2020-02-01T20:44:50: PM2 log: App [omx_stream1:1] starting in -fork mode-
                            PM2 | 2020-02-01T20:44:50: PM2 log: App [omx_stream1:1] online
                            PM2 | 2020-02-01T20:44:56: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
                            PM2 | 2020-02-01T20:44:56: PM2 log: App [omx_stream1:1] starting in -fork mode-
                            PM2 | 2020-02-01T20:44:56: PM2 log: App [omx_stream1:1] online
                            PM2 | 2020-02-01T20:45:02: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
                            PM2 | 2020-02-01T20:45:02: PM2 log: App [omx_stream1:1] starting in -fork mode-
                            PM2 | 2020-02-01T20:45:02: PM2 log: App [omx_stream1:1] online
                            PM2 | 2020-02-01T20:45:07: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
                            PM2 | 2020-02-01T20:45:07: PM2 log: App [omx_stream1:1] starting in -fork mode-
                            PM2 | 2020-02-01T20:45:07: PM2 log: App [omx_stream1:1] online
                            PM2 | 2020-02-01T20:45:13: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
                            PM2 | 2020-02-01T20:45:13: PM2 log: App [omx_stream1:1] starting in -fork mode-
                            PM2 | 2020-02-01T20:45:13: PM2 log: App [omx_stream1:1] online
                            PM2 | 2020-02-01T20:45:18: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
                            PM2 | 2020-02-01T20:45:18: PM2 log: App [omx_stream1:1] starting in -fork mode-
                            PM2 | 2020-02-01T20:45:18: PM2 log: App [omx_stream1:1] online
                            PM2 | 2020-02-01T20:45:24: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
                            PM2 | 2020-02-01T20:45:24: PM2 log: App [omx_stream1:1] starting in -fork mode-
                            PM2 | 2020-02-01T20:45:24: PM2 log: App [omx_stream1:1] online
                            PM2 | 2020-02-01T20:45:29: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
                            PM2 | 2020-02-01T20:45:29: PM2 log: App [omx_stream1:1] starting in -fork mode-
                            PM2 | 2020-02-01T20:45:29: PM2 log: App [omx_stream1:1] online
                            PM2 | 2020-02-01T20:45:35: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
                            PM2 | 2020-02-01T20:45:35: PM2 log: App [omx_stream1:1] starting in -fork mode-
                            PM2 | 2020-02-01T20:45:35: PM2 log: App [omx_stream1:1] online
                            0|MagicMir | [20:44:09.697] [ERROR] TypeError: port or a server must be provided
                            0|MagicMir | at new WebSocketServer (/home/pi/MagicMirror/modules/MMM-RTSPStream/node_modules/node-rtsp-stream-es6/node_modules/ws/lib/WebSocketServer.js:44:11)
                            0|MagicMir | at VideoStream.stream2Socket (/home/pi/MagicMirror/modules/MMM-RTSPStream/node_modules/node-rtsp-stream-es6/src/videoStream.js:32:23)
                            0|MagicMir | at new VideoStream (/home/pi/MagicMirror/modules/MMM-RTSPStream/node_modules/node-rtsp-stream-es6/src/videoStream.js:27:14)
                            0|MagicMir | at Class.startListener (/home/pi/MagicMirror/modules/MMM-RTSPStream/node_helper.js:74:40)
                            0|MagicMir | at streams.forEach (/home/pi/MagicMirror/modules/MMM-RTSPStream/node_helper.js:524:22)
                            0|MagicMir | at Array.forEach ()
                            0|MagicMir | at Class.socketNotificationReceived (/home/pi/MagicMirror/modules/MMM-RTSPStream/node_helper.js:523:21)
                            0|MagicMir | at Socket. (/home/pi/MagicMirror/js/node_helper.js:113:11)
                            0|MagicMir | at Socket.emit (events.js:182:13)
                            0|MagicMir | at /home/pi/MagicMirror/node_modules/socket.io/lib/socket.js:528:12
                            0|MagicMir |
                            0|MagicMir |
                            0|MagicMir | [20:44:05.677] [LOG] Starting MagicMirror: v2.10.0
                            0|MagicMir | [20:44:05.687] [LOG] Loading config …
                            0|MagicMir | [20:44:05.694] [LOG] Loading module helpers …
                            0|MagicMir | [20:44:05.696] [LOG] No helper found for module: alert.
                            0|MagicMir | [20:44:05.752] [LOG] Initializing new module helper …
                            0|MagicMir | [20:44:05.753] [LOG] Module helper loaded: updatenotification
                            0|MagicMir | [20:44:06.890] [LOG] Initializing new module helper …
                            0|MagicMir | [20:44:06.891] [LOG] Module helper loaded: MMM-RTSPStream
                            0|MagicMir | [20:44:07.197] [LOG] Initializing new module helper …
                            0|MagicMir | [20:44:07.198] [LOG] Module helper loaded: MMM-PublicTransportHafas
                            0|MagicMir | [20:44:07.199] [LOG] No helper found for module: currentweather.
                            0|MagicMir | [20:44:07.199] [LOG] No helper found for module: weatherforecast.
                            0|MagicMir | [20:44:07.272] [LOG] Initializing new module helper …
                            0|MagicMir | [20:44:07.273] [LOG] Module helper loaded: calendar
                            0|MagicMir | [20:44:07.307] [LOG] Initializing new module helper …
                            0|MagicMir | [20:44:07.307] [LOG] Module helper loaded: newsfeed
                            0|MagicMir | [20:44:07.308] [LOG] All module helpers loaded.
                            0|MagicMir | [20:44:07.309] [LOG] Starting server on port 8080 …
                            0|MagicMir | [20:44:07.325] [LOG] Server started …
                            0|MagicMir | [20:44:07.327] [LOG] Connecting socket for: updatenotification
                            0|MagicMir | [20:44:07.328] [LOG] Connecting socket for: MMM-RTSPStream
                            0|MagicMir | [20:44:07.329] [LOG] PM2: Stopping all OMXPlayer Streams…
                            0|MagicMir | [20:44:07.332] [LOG] Connecting socket for: MMM-PublicTransportHafas
                            0|MagicMir | [20:44:07.333] [LOG] Connecting socket for: calendar
                            0|MagicMir | [20:44:07.334] [LOG] Starting node helper for: calendar
                            0|MagicMir | [20:44:07.335] [LOG] Connecting socket for: newsfeed
                            0|MagicMir | [20:44:07.336] [LOG] Starting module: newsfeed
                            0|MagicMir | [20:44:07.336] [LOG] Sockets connected & modules started …
                            0|MagicMir | [20:44:07.548] [LOG] Launching application.
                            0|MagicMir | [20:44:07.769] [LOG] PM2: Checking if omx_stream1 is running…
                            0|MagicMir | [20:44:07.770] [LOG] PM2: Stopping omx_stream1…
                            0|MagicMir | [20:44:09.660] [LOG] Transportation fetcher for station with id ‘xxx’ created.
                            0|MagicMir | [20:44:09.685] [LOG] Starting WebSocket server on port undefined. Waiting for connections…
                            0|MagicMir | [20:44:09.694] [LOG] Whoops! There was an uncaught exception…
                            0|MagicMir | [20:44:09.702] [LOG] MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                            0|MagicMir | [20:44:09.705] [LOG] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                            0|MagicMir | [20:44:09.846] [LOG] Transportation fetcher for station with id ‘xxx’ created.
                            0|MagicMir | [20:44:09.866] [LOG] Create new calendar fetcher for url: https://calendar.google.com/calendar/ical/xxxgroup.calendar.google.com/private-xxx/basic.ics - Interval: 300000
                            0|MagicMir | [20:44:09.877] [LOG] Create new news fetcher for url: https://www.swr.de/~rss/swraktuell/swraktuell-bw-100.xml - Interval: 300000
                            0|MagicMir | [20:44:11.651] [LOG] Starting stream stream1 using: omxplayer --avdict rtsp_transport:tcp --win 643,514,1283,874 --live --video_queue 4 --fps 30 --no-osd rtsp://xxx:xxx@xxx.xxx.2.108:80/cam/realmonitor?channel=2&subtype=0
                            0|MagicMir | [20:44:11.673] [LOG] Starting PM2 for omx_stream1
                            0|MagicMir | [20:44:11.826] [LOG] PM2 started for omx_stream1
                            do you have a other idea ?
                              sdetweil @Number_5
                              @Number_5 said in [MMM-RTSPStream] - Video Streaming from Live Feeds & Security Cameras:
                              looks like a config error for the rtspstream server
                              magicmirror’s server and port working
                              • N
                                Number_5
                                Hello Sam,
                                during the implementation I kept to the instruction in:
                                I was denied access to http://your-mirror-ip:8080/MMM-RTSPStream/config.html. After weeks i found a post with the adress
                                http://127.0.0.1:8080/MMM-RTSPStream/config.html.With this adress it was possible to use the tool to generate the config details.
                                do I have to change the address elsewhere?
                                  sdetweil @Number_5
                                  this is because the mirror defaults to listening on localhost and ipWhiteList[] only allows localhost to connect (on same machine as mirror app)
                                  change address: “locathost”
                                  to
                                  address: “0.0.0.0”
                                  and ipWhitelist: […]
                                  to
                                  ipWhiteList: []
                                  I don’t know anything about the rtspstream stuff… only reporting what is in the log u posted.
                                  looks like it might be the port… note mirror is on 8080
                                  that server also might be trying 8080, both can’t have it at the same time
                                  • N
                                    Number_5
                                    Hello Sam,
                                    thanks also for the quick response.
                                    I have changed the address ,but now my mirror shows only a black screen, ;-(
                                    after correction:
                                    var config = {
                                    address: “0.0.0.0”, // Address to listen on, can be:
                                    // - “”, “0.0.0.0”, “::” to listen on any interface
                                    // Default, when address config is left out, is “localhost”
                                    port: 8080,
                                    ipWhitelist: [“”, “::ffff:127.0.0.1”, “::1”], // Set [] to allow all IP addresses
                                    // [“127.0.0.1”, “::ffff:127.0.0.1”, “::1”, “::ffff:192.168.1.5”],
                                    // [“127.0.0.1”, “::ffff:127.0.0.1”, “::1”, “::ffff:192.168.3.0/28”],
                                    before correction :
                                    var config = {
                                    port: 8080,
                                    ipWhitelist: [“127.0.0.1”, “::ffff:127.0.0.1”, “::1”], // Set [] to allow all IP addresses
                                    step 7 pm2 flush
                                    pi@raspberrypi:~/MagicMirror $ pm2 flush
                                    [PM2] Flushing:
                                    [PM2] Flushing:
                                    [PM2] /dev/null
                                    [PM2] Logs flushed
                                    step 8 restart MM
                                    [PM2] MagicMirror ✓
                                    │ 0 │ MagicMirror │ default │ 2.10.0 │ fork │ 15909 │ 0s │ 2 │ online │ 0% │ 2.4mb │ pi │ disabled │
                                    │ 1 │ omx_stream1 │ default │ N/A │ fork │ 0 │ 0 │ 1189 │ stopped │ 0% │ 0b │ pi │ disabled │
                                    PM2 | 2020-02-01T21:52:06: PM2 log: Stopping app:MagicMirror id:0
                                    PM2 | 2020-02-01T21:52:07: PM2 log: pid=15652 msg=failed to kill - retrying in 100ms
                                    PM2 | 2020-02-01T21:52:07: PM2 log: App [MagicMirror:0] exited with code [0] via signal [SIGINT]
                                    PM2 | 2020-02-01T21:52:07: PM2 log: pid=15652 msg=process killed
                                    PM2 | 2020-02-01T21:52:07: PM2 log: App [MagicMirror:0] starting in -fork mode-
                                    PM2 | 2020-02-01T21:52:07: PM2 log: App [MagicMirror:0] online
                                    0|MagicMir | [21:52:07.028] [LOG] Shutting down server…
                                    0|MagicMir | [21:52:07.030] [LOG] Stopping module helper: updatenotification
                                    0|MagicMir | [21:52:07.031] [LOG] Shutting down MMM-RTSPStream streams that were using undefined
                                    0|MagicMir | [21:52:07.031] [LOG] Stopping module helper: MMM-PublicTransportHafas
                                    0|MagicMir | [21:52:07.032] [LOG] Stopping module helper: calendar
                                    0|MagicMir | [21:52:07.032] [LOG] Stopping module helper: newsfeed
                                    0|MagicMir |
                                    0|MagicMir |
                                    0|MagicMir | [21:52:12.731] [LOG] Starting MagicMirror: v2.10.0
                                    0|MagicMir | [21:52:12.739] [LOG] Loading config …
                                    0|MagicMir | [21:52:12.745] [LOG] Loading module helpers …
                                    0|MagicMir | [21:52:12.746] [LOG] No helper found for module: alert.
                                    0|MagicMir | [21:52:12.793] [LOG] Initializing new module helper …
                                    0|MagicMir | [21:52:12.794] [LOG] Module helper loaded: updatenotification
                                    0|MagicMir | [21:52:13.749] [LOG] Initializing new module helper …
                                    0|MagicMir | [21:52:13.749] [LOG] Module helper loaded: MMM-RTSPStream
                                    0|MagicMir | [21:52:14.002] [LOG] Initializing new module helper …
                                    0|MagicMir | [21:52:14.003] [LOG] Module helper loaded: MMM-PublicTransportHafas
                                    0|MagicMir | [21:52:14.003] [LOG] No helper found for module: currentweather.
                                    0|MagicMir | [21:52:14.004] [LOG] No helper found for module: weatherforecast.
                                    0|MagicMir | [21:52:14.071] [LOG] Initializing new module helper …
                                    0|MagicMir | [21:52:14.071] [LOG] Module helper loaded: calendar
                                    0|MagicMir | [21:52:14.101] [LOG] Initializing new module helper …
                                    0|MagicMir | [21:52:14.102] [LOG] Module helper loaded: newsfeed
                                    0|MagicMir | [21:52:14.102] [LOG] All module helpers loaded.
                                    0|MagicMir | [21:52:14.103] [LOG] Starting server on port 8080 …
                                    0|MagicMir | [21:52:14.116] [LOG] Server started …
                                    0|MagicMir | [21:52:14.117] [LOG] Connecting socket for: updatenotification
                                    0|MagicMir | [21:52:14.118] [LOG] Connecting socket for: MMM-RTSPStream
                                    0|MagicMir | [21:52:14.119] [LOG] PM2: Stopping all OMXPlayer Streams…
                                    0|MagicMir | [21:52:14.121] [LOG] Connecting socket for: MMM-PublicTransportHafas
                                    0|MagicMir | [21:52:14.122] [LOG] Connecting socket for: calendar
                                    0|MagicMir | [21:52:14.123] [LOG] Starting node helper for: calendar
                                    0|MagicMir | [21:52:14.123] [LOG] Connecting socket for: newsfeed
                                    0|MagicMir | [21:52:14.124] [LOG] Starting module: newsfeed
                                    0|MagicMir | [21:52:14.124] [LOG] Sockets connected & modules started …
                                    0|MagicMir | [21:52:14.285] [LOG] Launching application.
                                    0|MagicMir | [21:52:14.407] [LOG] Access denied to IP address: 127.0.0.1
                                    0|MagicMir | [21:52:14.441] [LOG] PM2: Checking if omx_stream1 is running…
                                    I changed the address as described above, but in the logfile there is still the same adress.
                                    Did i change the address in the wrong place?
                                      sdetweil @Number_5
                                      No, you didn’t change ipWhitelist to [] as I documented above
                                      • N
                                        Number_5
                                        Hallo Sam,
                                        sorry i have fixed it now.
                                        after:
                                        var config = {
                                        port: 8080,
                                        ipWhitelist: [], // Set [] to allow all IP addresses
                                        After newstart I can see the white frame again. Inside the frame the title “Buck Bunny” and “Aussentür”
                                        as well as the symbol “play” can be seen. But not the stream.
                                        step 7 pm2 flush
                                        [PM2] Flushing:
                                        [PM2] Flushing:
                                        [PM2] /dev/null
                                        [PM2] Logs flushed
                                        step 8 restart MM
                                        pi@raspberrypi:~/MagicMirror/config $ pm2 restart MagicMirror
                                        [PM2] MagicMirror ✓
                                        │ 0 │ MagicMirror │ default │ 2.10.0 │ fork │ 3001 │ 0s │ 1 │ online │ 0% │ 2.4mb │ pi │ disabled │
                                        │ 1 │ omx_stream1 │ default │ N/A │ fork │ 0 │ 0 │ 57 │ stopped │ 0% │ 0b │ pi │ disabled │
                                        pi@raspberrypi:~/MagicMirror/config $ pm2 logs --lines 200
                                        PM2 | 2020-02-02T16:57:52: PM2 log: Stopping app:MagicMirror id:0
                                        PM2 | 2020-02-02T16:57:52: PM2 log: App [MagicMirror:0] exited with code [0] via signal [SIGINT]
                                        PM2 | 2020-02-02T16:57:52: PM2 log: pid=2049 msg=process killed
                                        PM2 | 2020-02-02T16:57:52: PM2 log: App [MagicMirror:0] starting in -fork mode-
                                        PM2 | 2020-02-02T16:57:52: PM2 log: App [MagicMirror:0] online
                                        PM2 | 2020-02-02T16:58:03: PM2 log: App [omx_stream1:1] starting in -fork mode-
                                        PM2 | 2020-02-02T16:58:03: PM2 log: App [omx_stream1:1] online
                                        PM2 | 2020-02-02T16:58:09: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
                                        PM2 | 2020-02-02T16:58:09: PM2 log: App [omx_stream1:1] starting in -fork mode-
                                        PM2 | 2020-02-02T16:58:09: PM2 log: App [omx_stream1:1] online
                                        PM2 | 2020-02-02T16:58:15: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
                                        PM2 | 2020-02-02T16:58:15: PM2 log: App [omx_stream1:1] starting in -fork mode-
                                        PM2 | 2020-02-02T16:58:15: PM2 log: App [omx_stream1:1] online
                                        PM2 | 2020-02-02T16:58:20: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
                                        PM2 | 2020-02-02T16:58:20: PM2 log: App [omx_stream1:1] starting in -fork mode-
                                        PM2 | 2020-02-02T16:58:20: PM2 log: App [omx_stream1:1] online
                                        PM2 | 2020-02-02T16:58:26: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
                                        PM2 | 2020-02-02T16:58:26: PM2 log: App [omx_stream1:1] starting in -fork mode-
                                        PM2 | 2020-02-02T16:58:26: PM2 log: App [omx_stream1:1] online
                                        PM2 | 2020-02-02T16:58:31: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
                                        PM2 | 2020-02-02T16:58:31: PM2 log: App [omx_stream1:1] starting in -fork mode-
                                        PM2 | 2020-02-02T16:58:31: PM2 log: App [omx_stream1:1] online
                                        PM2 | 2020-02-02T16:58:37: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
                                        PM2 | 2020-02-02T16:58:37: PM2 log: App [omx_stream1:1] starting in -fork mode-
                                        PM2 | 2020-02-02T16:58:37: PM2 log: App [omx_stream1:1] online
                                        PM2 | 2020-02-02T16:58:43: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
                                        PM2 | 2020-02-02T16:58:43: PM2 log: App [omx_stream1:1] starting in -fork mode-
                                        PM2 | 2020-02-02T16:58:43: PM2 log: App [omx_stream1:1] online
                                        PM2 | 2020-02-02T16:58:48: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
                                        PM2 | 2020-02-02T16:58:48: PM2 log: App [omx_stream1:1] starting in -fork mode-
                                        PM2 | 2020-02-02T16:58:48: PM2 log: App [omx_stream1:1] online
                                        PM2 | 2020-02-02T16:58:54: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
                                        PM2 | 2020-02-02T16:58:54: PM2 log: App [omx_stream1:1] starting in -fork mode-
                                        PM2 | 2020-02-02T16:58:54: PM2 log: App [omx_stream1:1] online
                                        PM2 | 2020-02-02T16:58:59: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
                                        PM2 | 2020-02-02T16:58:59: PM2 log: App [omx_stream1:1] starting in -fork mode-
                                        PM2 | 2020-02-02T16:58:59: PM2 log: App [omx_stream1:1] online
                                        PM2 | 2020-02-02T16:59:05: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
                                        PM2 | 2020-02-02T16:59:05: PM2 log: App [omx_stream1:1] starting in -fork mode-
                                        PM2 | 2020-02-02T16:59:05: PM2 log: App [omx_stream1:1] online
                                        0|MagicMir | [16:58:01.715] [ERROR] TypeError: port or a server must be provided
                                        0|MagicMir |
                                        0|MagicMir |
                                        0|MagicMir | [16:57:58.071] [LOG] Starting MagicMirror: v2.10.0
                                        0|MagicMir | [16:57:58.080] [LOG] Loading config …
                                        0|MagicMir | [16:57:58.086] [LOG] Loading module helpers …
                                        0|MagicMir | [16:57:58.087] [LOG] No helper found for module: alert.
                                        0|MagicMir | [16:57:58.134] [LOG] Initializing new module helper …
                                        0|MagicMir | [16:57:58.135] [LOG] Module helper loaded: updatenotification
                                        0|MagicMir | [16:57:59.093] [LOG] Initializing new module helper …
                                        0|MagicMir | [16:57:59.093] [LOG] Module helper loaded: MMM-RTSPStream
                                        0|MagicMir | [16:57:59.348] [LOG] Initializing new module helper …
                                        0|MagicMir | [16:57:59.348] [LOG] Module helper loaded: MMM-PublicTransportHafas
                                        0|MagicMir | [16:57:59.349] [LOG] No helper found for module: currentweather.
                                        0|MagicMir | [16:57:59.350] [LOG] No helper found for module: weatherforecast.
                                        0|MagicMir | [16:57:59.417] [LOG] Initializing new module helper …
                                        0|MagicMir | [16:57:59.417] [LOG] Module helper loaded: calendar
                                        0|MagicMir | [16:57:59.447] [LOG] Initializing new module helper …
                                        0|MagicMir | [16:57:59.448] [LOG] Module helper loaded: newsfeed
                                        0|MagicMir | [16:57:59.448] [LOG] All module helpers loaded.
                                        0|MagicMir | [16:57:59.449] [LOG] Starting server on port 8080 …
                                        0|MagicMir | [16:57:59.456] [INFO] You’re using a full whitelist configuration to allow for all IPs
                                        0|MagicMir | [16:57:59.463] [LOG] Server started …
                                        0|MagicMir | [16:57:59.464] [LOG] Connecting socket for: updatenotification
                                        0|MagicMir | [16:57:59.465] [LOG] Connecting socket for: MMM-RTSPStream
                                        0|MagicMir | [16:57:59.466] [LOG] PM2: Stopping all OMXPlayer Streams…
                                        0|MagicMir | [16:57:59.468] [LOG] Connecting socket for: MMM-PublicTransportHafas
                                        0|MagicMir | [16:57:59.469] [LOG] Connecting socket for: calendar
                                        0|MagicMir | [16:57:59.470] [LOG] Starting node helper for: calendar
                                        0|MagicMir | [16:57:59.471] [LOG] Connecting socket for: newsfeed
                                        0|MagicMir | [16:57:59.471] [LOG] Starting module: newsfeed
                                        0|MagicMir | [16:57:59.472] [LOG] Sockets connected & modules started …
                                        0|MagicMir | [16:57:59.645] [LOG] Launching application.
                                        0|MagicMir | [16:57:59.829] [LOG] PM2: Checking if omx_stream1 is running…
                                        0|MagicMir | [16:58:01.702] [LOG] Transportation fetcher for station with id ‘xxx’ created.
                                        0|MagicMir | [16:58:01.707] [LOG] Starting WebSocket server on port undefined. Waiting for connections…
                                        0|MagicMir | [16:58:01.714] [LOG] Whoops! There was an uncaught exception…
                                        0|MagicMir | [16:58:01.721] [LOG] MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                                        0|MagicMir | [16:58:01.722] [LOG] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                                        0|MagicMir | [16:58:01.744] [LOG] Transportation fetcher for station with id’xxx’ created.
                                        0|MagicMir | [16:58:01.747] [LOG] Create new calendar fetcher for url: https://calendar.google.com/calendar/ical/xxxgroup.calendar.google.com/private-xxxc/basic.ics - Interval: 300000
                                        0|MagicMir | [16:58:01.759] [LOG] Create new news fetcher for url: https://www.swr.de/~rss/swraktuell/swraktuell-bw-100.xml - Interval: 300000
                                        0|MagicMir | [16:58:03.761] [LOG] Starting stream stream1 using: omxplayer --avdict rtsp_transport:tcp --win 643,514,1283,874 --live --video_queue 4 --fps 30 --no-osd rtsp://xxx.xxx@xxx.xxx.2.108:80/cam/realmonitor?channel=2&subtype=0
                                        0|MagicMir | [16:58:03.793] [LOG] Starting PM2 for omx_stream1
                                        0|MagicMir | [16:58:03.960] [LOG] PM2 started for omx_stream1
                                        What else can I do ?
                                        Thanks for your help.
                                        • evroomE
                                          evroom @Number_5
                                          If I see it correctly, then you have 2 MMM-RTSPStream modules active in your config and 2 stream1 defined, and therefore are trying to start 2 omx_stream1 processes.
                                          I would concentrate on 1 config with 1 stream1.
                                          To see if things works, try it with the BucksBunny config first.
                                          Then give the other one a try (with the bunny removed).
                                          I also would give the rtsp stream a go without MM, so standalone.
                                          Somewhere in this thread there should be a description on how to do this; would need to search my notes for it.
                                          N 1 Reply Last reply
                                          • N
                                            Number_5
                                            update:
                                            the test video is now running, thanks. I had left the entry of the IP cam in the config, sorry. Now I see a white frame, unfortunately the camera stream cannot be seen. by clicking on the window you can see the “Play” icon.
                                            step 7 pm2 flush
                                            [PM2] Flushing:
                                            [PM2] Flushing:
                                            [PM2] /dev/null
                                            [PM2] Logs flushed
                                            step 8 restart MM
                                            [PM2] MagicMirror ✓
                                            │ 0 │ MagicMirror │ default │ 2.10.0 │ fork │ 4841 │ 0s │ 2 │ online │ 0% │ 2.5mb │ pi │ disabled │
                                            │ 1 │ omx_stream1 │ default │ N/A │ fork │ 4814 │ 3s │ 90 │ online │ 0% │ 2.5mb │ pi │ disabled │
                                            PM2 | 2020-02-02T19:33:48: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
                                            PM2 | 2020-02-02T19:33:48: PM2 log: App [omx_stream1:1] starting in -fork mode-
                                            PM2 | 2020-02-02T19:33:48: PM2 log: App [omx_stream1:1] online
                                            PM2 | 2020-02-02T19:33:54: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
                                            PM2 | 2020-02-02T19:33:54: PM2 log: App [omx_stream1:1] starting in -fork mode-
                                            PM2 | 2020-02-02T19:33:54: PM2 log: App [omx_stream1:1] online
                                            PM2 | 2020-02-02T19:33:59: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
                                            PM2 | 2020-02-02T19:33:59: PM2 log: App [omx_stream1:1] starting in -fork mode-
                                            PM2 | 2020-02-02T19:33:59: PM2 log: App [omx_stream1:1] online
                                            PM2 | 2020-02-02T19:34:05: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
                                            PM2 | 2020-02-02T19:34:05: PM2 log: App [omx_stream1:1] starting in -fork mode-
                                            PM2 | 2020-02-02T19:34:05: PM2 log: App [omx_stream1:1] online
                                            PM2 | 2020-02-02T19:34:11: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
                                            PM2 | 2020-02-02T19:34:11: PM2 log: App [omx_stream1:1] starting in -fork mode-
                                            PM2 | 2020-02-02T19:34:11: PM2 log: App [omx_stream1:1] online
                                            PM2 | 2020-02-02T19:34:16: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
                                            PM2 | 2020-02-02T19:34:16: PM2 log: App [omx_stream1:1] starting in -fork mode-
                                            PM2 | 2020-02-02T19:34:16: PM2 log: App [omx_stream1:1] online
                                            PM2 | 2020-02-02T19:34:22: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
                                            PM2 | 2020-02-02T19:34:22: PM2 log: App [omx_stream1:1] starting in -fork mode-
                                            PM2 | 2020-02-02T19:34:22: PM2 log: App [omx_stream1:1] online
                                            PM2 | 2020-02-02T19:34:27: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
                                            PM2 | 2020-02-02T19:34:27: PM2 log: App [omx_stream1:1] starting in -fork mode-
                                            PM2 | 2020-02-02T19:34:27: PM2 log: App [omx_stream1:1] online
                                            PM2 | 2020-02-02T19:34:33: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
                                            PM2 | 2020-02-02T19:34:33: PM2 log: App [omx_stream1:1] starting in -fork mode-
                                            PM2 | 2020-02-02T19:34:33: PM2 log: App [omx_stream1:1] online
                                            PM2 | 2020-02-02T19:34:38: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
                                            PM2 | 2020-02-02T19:34:38: PM2 log: App [omx_stream1:1] starting in -fork mode-
                                            PM2 | 2020-02-02T19:34:38: PM2 log: App [omx_stream1:1] online
                                            PM2 | 2020-02-02T19:34:44: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
                                            PM2 | 2020-02-02T19:34:44: PM2 log: App [omx_stream1:1] starting in -fork mode-
                                            PM2 | 2020-02-02T19:34:44: PM2 log: App [omx_stream1:1] online
                                            PM2 | 2020-02-02T19:34:49: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
                                            PM2 | 2020-02-02T19:34:49: PM2 log: App [omx_stream1:1] starting in -fork mode-
                                            PM2 | 2020-02-02T19:34:49: PM2 log: App [omx_stream1:1] online
                                            PM2 | 2020-02-02T19:34:55: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
                                            PM2 | 2020-02-02T19:34:55: PM2 log: App [omx_stream1:1] starting in -fork mode-
                                            PM2 | 2020-02-02T19:34:55: PM2 log: App [omx_stream1:1] online
                                            PM2 | 2020-02-02T19:35:01: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
                                            PM2 | 2020-02-02T19:35:01: PM2 log: App [omx_stream1:1] starting in -fork mode-
                                            PM2 | 2020-02-02T19:35:01: PM2 log: App [omx_stream1:1] online
                                            PM2 | 2020-02-02T19:35:06: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
                                            PM2 | 2020-02-02T19:35:06: PM2 log: App [omx_stream1:1] starting in -fork mode-
                                            PM2 | 2020-02-02T19:35:06: PM2 log: App [omx_stream1:1] online
                                            PM2 | 2020-02-02T19:35:12: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
                                            PM2 | 2020-02-02T19:35:12: PM2 log: App [omx_stream1:1] starting in -fork mode-
                                            PM2 | 2020-02-02T19:35:12: PM2 log: App [omx_stream1:1] online
                                            PM2 | 2020-02-02T19:35:17: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
                                            PM2 | 2020-02-02T19:35:17: PM2 log: App [omx_stream1:1] starting in -fork mode-
                                            PM2 | 2020-02-02T19:35:17: PM2 log: App [omx_stream1:1] online
                                            PM2 | 2020-02-02T19:35:20: PM2 log: Stopping app:MagicMirror id:0
                                            PM2 | 2020-02-02T19:35:21: PM2 log: App [MagicMirror:0] exited with code [0] via signal [SIGINT]
                                            PM2 | 2020-02-02T19:35:21: PM2 log: pid=2360 msg=process killed
                                            PM2 | 2020-02-02T19:35:21: PM2 log: App [MagicMirror:0] starting in -fork mode-
                                            PM2 | 2020-02-02T19:35:21: PM2 log: App [MagicMirror:0] online
                                            PM2 | 2020-02-02T19:35:24: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
                                            PM2 | 2020-02-02T19:35:24: PM2 log: App [omx_stream1:1] starting in -fork mode-
                                            PM2 | 2020-02-02T19:35:24: PM2 log: App [omx_stream1:1] online
                                            PM2 | 2020-02-02T19:35:29: PM2 log: Stopping app:omx_stream1 id:1
                                            PM2 | 2020-02-02T19:35:29: PM2 log: App [omx_stream1:1] exited with code [0] via signal [SIGINT]
                                            PM2 | 2020-02-02T19:35:29: PM2 log: pid=4878 msg=process killed
                                            PM2 | 2020-02-02T19:35:33: PM2 log: App [omx_stream1:1] starting in -fork mode-
                                            PM2 | 2020-02-02T19:35:33: PM2 log: App [omx_stream1:1] online
                                            PM2 | 2020-02-02T19:35:39: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
                                            PM2 | 2020-02-02T19:35:39: PM2 log: App [omx_stream1:1] starting in -fork mode-
                                            PM2 | 2020-02-02T19:35:39: PM2 log: App [omx_stream1:1] online
                                            PM2 | 2020-02-02T19:35:45: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
                                            PM2 | 2020-02-02T19:35:45: PM2 log: App [omx_stream1:1] starting in -fork mode-
                                            PM2 | 2020-02-02T19:35:45: PM2 log: App [omx_stream1:1] online
                                            PM2 | 2020-02-02T19:35:50: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
                                            PM2 | 2020-02-02T19:35:50: PM2 log: App [omx_stream1:1] starting in -fork mode-
                                            PM2 | 2020-02-02T19:35:50: PM2 log: App [omx_stream1:1] online
                                            PM2 | 2020-02-02T19:35:56: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
                                            PM2 | 2020-02-02T19:35:56: PM2 log: App [omx_stream1:1] starting in -fork mode-
                                            PM2 | 2020-02-02T19:35:56: PM2 log: App [omx_stream1:1] online
                                            PM2 | 2020-02-02T19:36:01: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
                                            PM2 | 2020-02-02T19:36:01: PM2 log: App [omx_stream1:1] starting in -fork mode-
                                            PM2 | 2020-02-02T19:36:01: PM2 log: App [omx_stream1:1] online
                                            PM2 | 2020-02-02T19:36:07: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
                                            PM2 | 2020-02-02T19:36:07: PM2 log: App [omx_stream1:1] starting in -fork mode-
                                            PM2 | 2020-02-02T19:36:07: PM2 log: App [omx_stream1:1] online
                                            PM2 | 2020-02-02T19:36:12: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
                                            PM2 | 2020-02-02T19:36:12: PM2 log: App [omx_stream1:1] starting in -fork mode-
                                            PM2 | 2020-02-02T19:36:12: PM2 log: App [omx_stream1:1] online
                                            PM2 | 2020-02-02T19:36:18: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
                                            PM2 | 2020-02-02T19:36:18: PM2 log: App [omx_stream1:1] starting in -fork mode-
                                            PM2 | 2020-02-02T19:36:18: PM2 log: App [omx_stream1:1] online
                                            PM2 | 2020-02-02T19:36:24: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
                                            PM2 | 2020-02-02T19:36:24: PM2 log: App [omx_stream1:1] starting in -fork mode-
                                            PM2 | 2020-02-02T19:36:24: PM2 log: App [omx_stream1:1] online
                                            PM2 | 2020-02-02T19:36:29: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
                                            PM2 | 2020-02-02T19:36:29: PM2 log: App [omx_stream1:1] starting in -fork mode-
                                            PM2 | 2020-02-02T19:36:29: PM2 log: App [omx_stream1:1] online
                                            PM2 | 2020-02-02T19:36:35: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
                                            PM2 | 2020-02-02T19:36:35: PM2 log: App [omx_stream1:1] starting in -fork mode-
                                            PM2 | 2020-02-02T19:36:35: PM2 log: App [omx_stream1:1] online
                                            0|MagicMir |
                                            0|MagicMir |
                                            0|MagicMir | [19:35:27.493] [LOG] Starting MagicMirror: v2.10.0
                                            0|MagicMir | [19:35:27.503] [LOG] Loading config …
                                            0|MagicMir | [19:35:27.509] [LOG] Loading module helpers …
                                            0|MagicMir | [19:35:27.511] [LOG] No helper found for module: alert.
                                            0|MagicMir | [19:35:27.575] [LOG] Initializing new module helper …
                                            0|MagicMir | [19:35:27.576] [LOG] Module helper loaded: updatenotification
                                            0|MagicMir | [19:35:28.715] [LOG] Initializing new module helper …
                                            0|MagicMir | [19:35:28.716] [LOG] Module helper loaded: MMM-RTSPStream
                                            0|MagicMir | [19:35:29.021] [LOG] Initializing new module helper …
                                            0|MagicMir | [19:35:29.022] [LOG] Module helper loaded: MMM-PublicTransportHafas
                                            0|MagicMir | [19:35:29.023] [LOG] No helper found for module: currentweather.
                                            0|MagicMir | [19:35:29.023] [LOG] No helper found for module: weatherforecast.
                                            0|MagicMir | [19:35:29.096] [LOG] Initializing new module helper …
                                            0|MagicMir | [19:35:29.097] [LOG] Module helper loaded: calendar
                                            0|MagicMir | [19:35:29.132] [LOG] Initializing new module helper …
                                            0|MagicMir | [19:35:29.132] [LOG] Module helper loaded: newsfeed
                                            0|MagicMir | [19:35:29.133] [LOG] All module helpers loaded.
                                            0|MagicMir | [19:35:29.134] [LOG] Starting server on port 8080 …
                                            0|MagicMir | [19:35:29.143] [INFO] You’re using a full whitelist configuration to allow for all IPs
                                            0|MagicMir | [19:35:29.152] [LOG] Server started …
                                            0|MagicMir | [19:35:29.153] [LOG] Connecting socket for: updatenotification
                                            0|MagicMir | [19:35:29.155] [LOG] Connecting socket for: MMM-RTSPStream
                                            0|MagicMir | [19:35:29.156] [LOG] PM2: Stopping all OMXPlayer Streams…
                                            0|MagicMir | [19:35:29.159] [LOG] Connecting socket for: MMM-PublicTransportHafas
                                            0|MagicMir | [19:35:29.160] [LOG] Connecting socket for: calendar
                                            0|MagicMir | [19:35:29.161] [LOG] Starting node helper for: calendar
                                            0|MagicMir | [19:35:29.162] [LOG] Connecting socket for: newsfeed
                                            0|MagicMir | [19:35:29.163] [LOG] Starting module: newsfeed
                                            0|MagicMir | [19:35:29.164] [LOG] Sockets connected & modules started …
                                            0|MagicMir | [19:35:29.353] [LOG] Launching application.
                                            0|MagicMir | [19:35:29.596] [LOG] PM2: Checking if omx_stream1 is running…
                                            0|MagicMir | [19:35:29.597] [LOG] PM2: Stopping omx_stream1…
                                            0|MagicMir | [19:35:31.438] [LOG] Transportation fetcher for station with id ‘xxx’ created.
                                            0|MagicMir | [19:35:31.613] [LOG] Transportation fetcher for station with id ‘xxx’ created.
                                            0|MagicMir | [19:35:31.618] [LOG] Create new calendar fetcher for url: https://calendar.google.com/calendar/ical/xxgroup.calendar.google.com/private-xxx/basic.ics - Interval: 300000
                                            0|MagicMir | [19:35:31.639] [LOG] Create new news fetcher for url: https://www.swr.de/~rss/swraktuell/swraktuell-bw-100.xml - Interval: 300000
                                            0|MagicMir | [19:35:33.506] [LOG] Starting stream stream1 using: omxplayer --avdict rtsp_transport:tcp --win 786,424,1138,666 --live --video_queue 4 --fps 30 --no-osd rtsp://admin:roland!?1971@192.168.2.108:80/cam/realmonitor?channel=2&subtype=0
                                            0|MagicMir | [19:35:33.531] [LOG] Starting PM2 for omx_stream1
                                            0|MagicMir | [19:35:33.676] [LOG] PM2 started for omx_stream1
                                            Is there still an idea?
                                            • 18
                                            • 19
                                            • 20
                                            • 21
                                            • 22
                                            • 30
                                            • 31
                                            • 20 / 31
