    602 Posts 67 Posters 2.3m Views 68 Watching
    • BKeyportB
      BKeyport Module Developer
      OK, it’s appearing more and more like the author of this module is MIA, and the module isn’t working well enough anymore to get a consistent stream (ffmpeg is the only thing that works at all in my installs, and even that will crash and burn every 3-6 hours, or get corrupted) - is there anything out there to replace this module?
      • K
        kris1208
        @BKeyport said in [MMM-RTSPStream] - Video Streaming from Live Feeds & Security Cameras:
        I redid an installation of the module but it is the same, the display is partial. Do you have another module to advise me? Thank you
        • evroomE
          evroom @BKeyport
          @BKeyport
          Depends on what you want to stream and with what you want to stream it with.
          I, for example, am streaming a single Axis IP cam (supposing it is h.264) using omxplayer. Standalone, controlled by pm2.
          The MMM-RTSPStream does work, but I was having problems placing the stream on the screen to my likings.
          You may need to check this list if there is a module that suites your needs:
          https://github.com/MichMich/MagicMirror/wiki/3rd-party-modules#utility--iot--3rd-party--integration
          MagicMirror version: 2.37.0
          • evroomE
            evroom
            @kris1208 said in [MMM-RTSPStream] - Video Streaming from Live Feeds & Security Cameras:
            So you got rid of the errors in the pm2 log?
            pm2 flush
            pm2 restart mm
            pm2 logs --lines 200
            Do you see an entry like this?
            Starting stream stream1 with args:
            If yes, what are the arguments?
            Using vlc or omxplayer?
            ps -eaf | grep -v grep | egrep 'omxplayer|vlc'
            Still difficult to determine what you mean by partial.
            I think it is looking good.
            Perhaps you want to get rid of the white frame?
            vi ~/MagicMirror/css/custom.css
            Add:
            .MMM-RTSPStream .innerWrapper {
              border-style: none;
              //border: 1px solid red;
            • K
              kris1208
              Merci de votre aide,
              J’ai mis quelques post plus avant le resultat du log pm2.
              Pareil pour l’affichage on vois sur les copies ecran qu’il manque une partie de l’image sur la droite.
              C’est VLC qui est utilisé mais j’ai mis omx et c’est pareil.
              • I
                iorifly
                Dear, I need help!
                I am experiencing the following error while trying to start module configuration. When adding the line in config.js:
                                    module: 'MMM-RTSPStream',
                                    position: 'middle_center',
                                        initialSetup: true
                I have the following error
                [14:14:56.732] [ERROR]  WARNING! Could not validate config file. Starting with default configuration. Please correct syntax errors at or above this line: /home/pi/MagicMirror/modules/MMM-RTSPStream/node_modules/semver/semver.js:1
                (function (exports, require, module, __filename, __dirname, process, global, Buffer) { return function (exports, require, module, __filename, __dirname) { !
                SyntaxError: Invalid or unexpected token
                    at new Script (vm.js:74:7)
                    at createScript (vm.js:246:10)
                    at Object.runInThisContext (vm.js:298:10)
                    at Module._compile (internal/modules/cjs/loader.js:678:28)
                    at Object.Module._extensions..js (internal/modules/cjs/loader.js:722:10)
                    at Module.load (internal/modules/cjs/loader.js:620:32)
                    at tryModuleLoad (internal/modules/cjs/loader.js:559:12)
                    at Function.Module._load (internal/modules/cjs/loader.js:551:3)
                    at Module.require (internal/modules/cjs/loader.js:658:17)
                    at require (internal/modules/cjs/helpers.js:20:18)
                [14:14:56.735] [LOG]    Loading module helpers ...
                • evroomE
                  evroom @iorifly
                  @iorifly said in [MMM-RTSPStream] - Video Streaming from Live Feeds & Security Cameras:
                  'MMM-RTSPStream
                  what do you expect to happen with this particular config?
                  Did you execute all the steps from the “Using the module” paragraph in
                  https://github.com/shbatm/MMM-RTSPStream
                  I would suggest to read the instructions once more and then let us know the result.
                  Success.
                  • I
                    iorifly @evroom
                    @evroom Hello, how are you ?
                      Thanks for answering me.
                    So if I didn’t have the error. I was hoping to be able to access the URL:
                    http: // your-mirror-ip: 8080 / MMM-RTSPStream / config.html
                    and proceed with the setup. However, the server does not go up. I can’t access the url. I believe the error I described is preventing it.
                    If you can, help me.
                    • evroomE
                      evroom @iorifly
                      @iorifly
                      Okay, that makes sense.
                      Has been a while since I set it up myself, but I will take a look.
                      Cannot promise anything :-)
                      What are you trying / hoping to stream?
                      • I
                        iorifly @evroom
                        @evroom Thanks for trying to help me.
                          My intention is to stream the video stream from my UBIQUITI cameras. In particular I would like to call a camera.
                        evroomE 2 Replies Last reply Reply Quote 0
                        • evroomE
                          evroom @iorifly
                          @iorifly
                          had troubles opening that config.html myself.
                          Try this:
                          1/ Install the module using:
                          sh -c "$(curl -s https://raw.githubusercontent.com/shbatm/MMM-RTSPStream/develop/scripts/installer.sh)"
                          2/ Add the module to the config.js:
                          vi ~/MagicMirror/config/config.js
                          	disabled: false,
                                      initialSetup: true,
                          3/ Restart mm:
                          pm2 restart mm
                          4/ Start Chromium Web Browser on Pi (direct or using VNC).
                          Use URL:
                          http://localhost:8080/MMM-RTSPStream/config.html
                          5/ Follow the instructions and save the config.
                          6/ Add the module to the config.js (replace the initial one):
                          7/ Flush the logs:
                          pm2 flush
                          8/ Restart mm:
                          pm2 restart mm
                          9/ Check the logs:
                          10/ Look for this line (when there are no blocking errors):
                          Starting stream stream1 using:
                          • evroomE
                            evroom @iorifly
                            @iorifly
                            You can try this config for testing:
                                module: "MMM-RTSPStream",
                                position: "middle_center",
                                header: "MMM-RTSPStream Test",
                                    autoStart: true,
                                    rotateStreams: false,
                                    rotateStreamTimeout: 10,
                                    moduleWidth: 640,
                                    moduleHeight: 360,
                                    localPlayer: 'omxplayer',
                                    remotePlayer: 'none',
                                    showSnapWhenPaused: true,
                                    remoteSnaps: true,
                                    stream1: {
                                        url: 'rtsp://wowzaec2demo.streamlock.net/vod/mp4:BigBuckBunny_115k.mov',
                                        frameRate: 'undefined',
                                        snapshotType: 'url',
                                        snapshotRefresh: 10,
                                        width: 640,
                                        height: 360,
                              claudia003
                              The following forum is illustrative and commendable. I just want to add on that I am facing a vigorous circumstances regarding my home security camera Arlo pro 2 about the video streaming.I have been trying to fix this issues regarding the video streaming is not working in arlo pro add on camera.=by following the manuals as guided by the help desk support.Suggest us if we have to add on anything.
                              • N
                                Number_5
                                Hello i have a similar problem,
                                I can’t see my ip- camera stream on the mirror. The stream can be seen by entering the IP in the VLC player but not in MagicMirror. In the MagicMirror i can only see a white frame.
                                The recommendation
                                implement in config.js i followeld.
                                After a restart I could see the film in the mirror, but unfortunately only once, I swear I don’t have anything in the config. changed. Now I have only a white frame on the Mirror.
                                I had to adjust the script from the configurator by a comma, otherwise the file config.js could not be found.
                                My entry in the config.js for IP.camera:
                                module: “MMM-RTSPStream”,
                                position: “middle_center”,
                                header: “test1”,
                                autoStart: true,
                                rotateStreams: true,
                                moduleWidth: 354,
                                moduleHeight: 240,
                                localPlayer: ‘vlc’,
                                remotePlayer: ‘none’,
                                remoteSnaps: true,
                                shutdownDelay: 12,
                                stream1: {
                                url: ‘rtsp://XXXX:XXXXX@192.XXX.2.108:80/cam/realmonitor?channel=2&subtype=0’,
                                frameRate: ‘undefined’,
                                snapshotType: ‘url’,
                                width: undefined,
                                height: undefined,
                                My entry in the config.js for Testvideo:
                                header: “MMM-RTSPStream Test”,
                                autoStart: true,
                                moduleWidth: 640,
                                moduleHeight: 360,
                                localPlayer: ‘omxplayer’,
                                remoteSnaps: true,
                                stream1: {
                                url: ‘rtsp://wowzaec2demo.streamlock.net/vod/mp4:BigBuckBunny_115k.mov’,
                                width: 640,
                                height: 360,
                                step 7) pm2 flush
                                pi@raspberrypi:~ $ pm2 flush
                                [PM2] Flushing /home/pi/.pm2/pm2.log
                                [PM2] Flushing:
                                [PM2] /home/pi/.pm2/logs/MagicMirror-out.log
                                [PM2] /home/pi/.pm2/logs/MagicMirror-error.log
                                [PM2] Flushing:
                                [PM2] /dev/null
                                [PM2] /home/pi/.pm2/logs/omx-stream1-error.log
                                [PM2] Logs flushed
                                pi@raspberrypi:~ $
                                step 8) restart MM
                                pi@raspberrypi:~ $ pm2 restart MagicMirror
                                [PM2] Applying action restartProcessId on app [MagicMirror](ids: 0)
                                [PM2] MagicMirror ✓
                                │ id │ name │ namespace │ version │ mode │ pid │ uptime │ ↺ │ status │ cpu │ mem │ user │ watching │
                                │ 0 │ MagicMirror │ default │ 2.10.0 │ fork │ 8828 │ 0s │ 1 │ online │ 0% │ 2.5mb │ pi │ disabled │
                                │ 1 │ omx_stream1 │ default │ N/A │ fork │ 8774 │ 4s │ 226 │ online │ 0% │ 2.5mb │ pi │ disabled │
                                pi@raspberrypi:~ $
                                step 9) check the logs
                                pi@raspberrypi:~ $ pm2 logs --lines 200
                                [TAILING] Tailing last 200 lines for [all] processes (change the value with --lines option)
                                /home/pi/.pm2/pm2.log last 200 lines:
                                PM2 | 2020-02-01T16:03:54: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
                                PM2 | 2020-02-01T16:03:54: PM2 log: App [omx_stream1:1] starting in -fork mode-
                                PM2 | 2020-02-01T16:03:54: PM2 log: App [omx_stream1:1] online
                                PM2 | 2020-02-01T16:04:00: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
                                PM2 | 2020-02-01T16:04:00: PM2 log: App [omx_stream1:1] starting in -fork mode-
                                PM2 | 2020-02-01T16:04:00: PM2 log: App [omx_stream1:1] online
                                PM2 | 2020-02-01T16:04:05: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
                                PM2 | 2020-02-01T16:04:05: PM2 log: App [omx_stream1:1] starting in -fork mode-
                                PM2 | 2020-02-01T16:04:05: PM2 log: App [omx_stream1:1] online
                                PM2 | 2020-02-01T16:04:11: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
                                PM2 | 2020-02-01T16:04:11: PM2 log: App [omx_stream1:1] starting in -fork mode-
                                PM2 | 2020-02-01T16:04:11: PM2 log: App [omx_stream1:1] online
                                PM2 | 2020-02-01T16:04:16: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
                                PM2 | 2020-02-01T16:04:16: PM2 log: App [omx_stream1:1] starting in -fork mode-
                                PM2 | 2020-02-01T16:04:16: PM2 log: App [omx_stream1:1] online
                                PM2 | 2020-02-01T16:04:22: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
                                PM2 | 2020-02-01T16:04:22: PM2 log: App [omx_stream1:1] starting in -fork mode-
                                PM2 | 2020-02-01T16:04:22: PM2 log: App [omx_stream1:1] online
                                PM2 | 2020-02-01T16:04:28: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
                                PM2 | 2020-02-01T16:04:28: PM2 log: App [omx_stream1:1] starting in -fork mode-
                                PM2 | 2020-02-01T16:04:28: PM2 log: App [omx_stream1:1] online
                                PM2 | 2020-02-01T16:04:33: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
                                PM2 | 2020-02-01T16:04:33: PM2 log: App [omx_stream1:1] starting in -fork mode-
                                PM2 | 2020-02-01T16:04:33: PM2 log: App [omx_stream1:1] online
                                PM2 | 2020-02-01T16:04:39: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
                                PM2 | 2020-02-01T16:04:39: PM2 log: App [omx_stream1:1] starting in -fork mode-
                                PM2 | 2020-02-01T16:04:39: PM2 log: App [omx_stream1:1] online
                                PM2 | 2020-02-01T16:04:45: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
                                PM2 | 2020-02-01T16:04:45: PM2 log: App [omx_stream1:1] starting in -fork mode-
                                PM2 | 2020-02-01T16:04:45: PM2 log: App [omx_stream1:1] online
                                PM2 | 2020-02-01T16:04:50: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
                                PM2 | 2020-02-01T16:04:50: PM2 log: App [omx_stream1:1] starting in -fork mode-
                                PM2 | 2020-02-01T16:04:50: PM2 log: App [omx_stream1:1] online
                                PM2 | 2020-02-01T16:04:56: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
                                PM2 | 2020-02-01T16:04:56: PM2 log: App [omx_stream1:1] starting in -fork mode-
                                PM2 | 2020-02-01T16:04:56: PM2 log: App [omx_stream1:1] online
                                PM2 | 2020-02-01T16:05:00: PM2 log: Stopping app:MagicMirror id:0
                                PM2 | 2020-02-01T16:05:00: PM2 log: pid=863 msg=failed to kill - retrying in 100ms
                                PM2 | 2020-02-01T16:05:00: PM2 log: App [MagicMirror:0] exited with code [0] via signal [SIGINT]
                                PM2 | 2020-02-01T16:05:00: PM2 log: pid=863 msg=process killed
                                PM2 | 2020-02-01T16:05:00: PM2 log: App [MagicMirror:0] starting in -fork mode-
                                PM2 | 2020-02-01T16:05:00: PM2 log: App [MagicMirror:0] online
                                PM2 | 2020-02-01T16:05:02: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
                                PM2 | 2020-02-01T16:05:02: PM2 log: App [omx_stream1:1] starting in -fork mode-
                                PM2 | 2020-02-01T16:05:02: PM2 log: App [omx_stream1:1] online
                                PM2 | 2020-02-01T16:05:08: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
                                PM2 | 2020-02-01T16:05:08: PM2 log: App [omx_stream1:1] starting in -fork mode-
                                PM2 | 2020-02-01T16:05:08: PM2 log: App [omx_stream1:1] online
                                PM2 | 2020-02-01T16:05:09: PM2 log: Stopping app:omx_stream1 id:1
                                PM2 | 2020-02-01T16:05:09: PM2 log: App [omx_stream1:1] exited with code [0] via signal [SIGINT]
                                PM2 | 2020-02-01T16:05:09: PM2 log: pid=8949 msg=process killed
                                PM2 | 2020-02-01T16:05:13: PM2 log: App [omx_stream1:1] starting in -fork mode-
                                PM2 | 2020-02-01T16:05:13: PM2 log: App [omx_stream1:1] online
                                PM2 | 2020-02-01T16:05:19: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
                                PM2 | 2020-02-01T16:05:19: PM2 log: App [omx_stream1:1] starting in -fork mode-
                                PM2 | 2020-02-01T16:05:19: PM2 log: App [omx_stream1:1] online
                                PM2 | 2020-02-01T16:05:25: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
                                PM2 | 2020-02-01T16:05:25: PM2 log: App [omx_stream1:1] starting in -fork mode-
                                PM2 | 2020-02-01T16:05:25: PM2 log: App [omx_stream1:1] online
                                PM2 | 2020-02-01T16:05:30: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
                                PM2 | 2020-02-01T16:05:30: PM2 log: App [omx_stream1:1] starting in -fork mode-
                                PM2 | 2020-02-01T16:05:30: PM2 log: App [omx_stream1:1] online
                                PM2 | 2020-02-01T16:05:36: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
                                PM2 | 2020-02-01T16:05:36: PM2 log: App [omx_stream1:1] starting in -fork mode-
                                PM2 | 2020-02-01T16:05:36: PM2 log: App [omx_stream1:1] online
                                PM2 | 2020-02-01T16:05:41: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
                                PM2 | 2020-02-01T16:05:41: PM2 log: App [omx_stream1:1] starting in -fork mode-
                                PM2 | 2020-02-01T16:05:41: PM2 log: App [omx_stream1:1] online
                                PM2 | 2020-02-01T16:05:47: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
                                PM2 | 2020-02-01T16:05:47: PM2 log: App [omx_stream1:1] starting in -fork mode-
                                PM2 | 2020-02-01T16:05:47: PM2 log: App [omx_stream1:1] online
                                PM2 | 2020-02-01T16:05:53: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
                                PM2 | 2020-02-01T16:05:53: PM2 log: App [omx_stream1:1] starting in -fork mode-
                                PM2 | 2020-02-01T16:05:53: PM2 log: App [omx_stream1:1] online
                                PM2 | 2020-02-01T16:05:58: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
                                PM2 | 2020-02-01T16:05:58: PM2 log: App [omx_stream1:1] starting in -fork mode-
                                PM2 | 2020-02-01T16:05:58: PM2 log: App [omx_stream1:1] online
                                PM2 | 2020-02-01T16:06:04: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
                                PM2 | 2020-02-01T16:06:04: PM2 log: App [omx_stream1:1] starting in -fork mode-
                                PM2 | 2020-02-01T16:06:04: PM2 log: App [omx_stream1:1] online
                                PM2 | 2020-02-01T16:06:09: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
                                PM2 | 2020-02-01T16:06:09: PM2 log: App [omx_stream1:1] starting in -fork mode-
                                PM2 | 2020-02-01T16:06:09: PM2 log: App [omx_stream1:1] online
                                PM2 | 2020-02-01T16:06:15: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
                                PM2 | 2020-02-01T16:06:15: PM2 log: App [omx_stream1:1] starting in -fork mode-
                                PM2 | 2020-02-01T16:06:15: PM2 log: App [omx_stream1:1] online
                                PM2 | 2020-02-01T16:06:20: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
                                PM2 | 2020-02-01T16:06:20: PM2 log: App [omx_stream1:1] starting in -fork mode-
                                PM2 | 2020-02-01T16:06:20: PM2 log: App [omx_stream1:1] online
                                PM2 | 2020-02-01T16:06:26: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
                                PM2 | 2020-02-01T16:06:26: PM2 log: App [omx_stream1:1] starting in -fork mode-
                                PM2 | 2020-02-01T16:06:26: PM2 log: App [omx_stream1:1] online
                                PM2 | 2020-02-01T16:06:31: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
                                PM2 | 2020-02-01T16:06:31: PM2 log: App [omx_stream1:1] starting in -fork mode-
                                PM2 | 2020-02-01T16:06:31: PM2 log: App [omx_stream1:1] online
                                PM2 | 2020-02-01T16:06:37: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
                                PM2 | 2020-02-01T16:06:37: PM2 log: App [omx_stream1:1] starting in -fork mode-
                                PM2 | 2020-02-01T16:06:37: PM2 log: App [omx_stream1:1] online
                                PM2 | 2020-02-01T16:06:43: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
                                PM2 | 2020-02-01T16:06:43: PM2 log: App [omx_stream1:1] starting in -fork mode-
                                PM2 | 2020-02-01T16:06:43: PM2 log: App [omx_stream1:1] online
                                /home/pi/.pm2/logs/MagicMirror-error.log last 200 lines:
                                /home/pi/.pm2/logs/omx-stream1-error.log last 200 lines:
                                /home/pi/.pm2/logs/MagicMirror-out.log last 200 lines:
                                0|MagicMir | [16:05:00.464] [LOG] Shutting down server…
                                0|MagicMir | [16:05:00.465] [LOG] Stopping module helper: updatenotification
                                0|MagicMir | [16:05:00.466] [LOG] Shutting down MMM-RTSPStream streams that were using vlc
                                0|MagicMir | [16:05:00.467] [LOG] Killing DevilsPie2…
                                0|MagicMir | [16:05:00.471] [LOG] Killing All VLC Streams…
                                0|MagicMir | [16:05:00.472] [LOG] Stopping module helper: MMM-PublicTransportHafas
                                0|MagicMir | [16:05:00.472] [LOG] Stopping module helper: calendar
                                0|MagicMir | [16:05:00.473] [LOG] Stopping module helper: newsfeed
                                0|MagicMir |
                                0|MagicMir | > magicmirror@2.10.0 start /home/pi/MagicMirror
                                0|MagicMir | > ./run-start.sh
                                0|MagicMir |
                                0|MagicMir | [16:05:07.112] [LOG] Starting MagicMirror: v2.10.0
                                0|MagicMir | [16:05:07.122] [LOG] Loading config …
                                0|MagicMir | [16:05:07.129] [LOG] Loading module helpers …
                                0|MagicMir | [16:05:07.131] [LOG] No helper found for module: alert.
                                0|MagicMir | [16:05:07.187] [LOG] Initializing new module helper …
                                0|MagicMir | [16:05:07.189] [LOG] Module helper loaded: updatenotification
                                0|MagicMir | [16:05:08.315] [LOG] Initializing new module helper …
                                0|MagicMir | [16:05:08.315] [LOG] Module helper loaded: MMM-RTSPStream
                                0|MagicMir | [16:05:08.628] [LOG] Initializing new module helper …
                                0|MagicMir | [16:05:08.629] [LOG] Module helper loaded: MMM-PublicTransportHafas
                                0|MagicMir | [16:05:08.630] [LOG] No helper found for module: clock.
                                0|MagicMir | [16:05:08.631] [LOG] No helper found for module: currentweather.
                                0|MagicMir | [16:05:08.632] [LOG] No helper found for module: weatherforecast.
                                0|MagicMir | [16:05:08.706] [LOG] Initializing new module helper …
                                0|MagicMir | [16:05:08.706] [LOG] Module helper loaded: calendar
                                0|MagicMir | [16:05:08.740] [LOG] Initializing new module helper …
                                0|MagicMir | [16:05:08.741] [LOG] Module helper loaded: newsfeed
                                0|MagicMir | [16:05:08.741] [LOG] All module helpers loaded.
                                0|MagicMir | [16:05:08.743] [LOG] Starting server on port 8080 …
                                0|MagicMir | [16:05:08.758] [LOG] Server started …
                                0|MagicMir | [16:05:08.760] [LOG] Connecting socket for: updatenotification
                                0|MagicMir | [16:05:08.761] [LOG] Connecting socket for: MMM-RTSPStream
                                0|MagicMir | [16:05:08.762] [LOG] PM2: Stopping all OMXPlayer Streams…
                                0|MagicMir | [16:05:08.765] [LOG] Connecting socket for: MMM-PublicTransportHafas
                                0|MagicMir | [16:05:08.766] [LOG] Connecting socket for: calendar
                                0|MagicMir | [16:05:08.767] [LOG] Starting node helper for: calendar
                                0|MagicMir | [16:05:08.768] [LOG] Connecting socket for: newsfeed
                                0|MagicMir | [16:05:08.769] [LOG] Starting module: newsfeed
                                0|MagicMir | [16:05:08.770] [LOG] Sockets connected & modules started …
                                0|MagicMir | [16:05:08.999] [LOG] Launching application.
                                0|MagicMir | [16:05:09.244] [LOG] PM2: Checking if omx_stream1 is running…
                                0|MagicMir | [16:05:09.245] [LOG] PM2: Stopping omx_stream1…
                                0|MagicMir | [16:05:11.221] [LOG] Transportation fetcher for station with id ‘xxx’ created.
                                0|MagicMir | [16:05:11.394] [LOG] Transportation fetcher for station with id ‘xxx’ created.
                                0|MagicMir | [16:05:11.398] [LOG] Create new calendar fetcher for url: https://calendar.gxxx- Interval: 300000
                                0|MagicMir | [16:05:11.409] [LOG] Create new news fetcher for url: https://www.swr.de/~rss/swraktuell/swraktuell-bw-100.xml - Interval: 300000
                                0|MagicMir | [16:05:13.214] [LOG] Starting stream stream1 using: omxplayer --avdict rtsp_transport:tcp --win 6xxx,874 --live --video_queue 4 --fps 30 --no-osd rtsp://xxx:xxx@xxx.xxx.2.108:80/cam/realmonitor?channel=2&subtype=0
                                0|MagicMir | [16:05:13.241] [LOG] Starting PM2 for omx_stream1
                                0|MagicMir | [16:05:13.401] [LOG] PM2 started for omx_stream1
                                0|MagicMir | [16:05:13.411] [LOG] Starting stream stream1 using VLC with args --width 352 --height 242 -I dummy --video-on-top --no-video-deco --no-embedded-video --video-title=stream1 rtsp://XXX@xxx.xxx.2.108:80/cam/realmonitor?channel=2&subtype=0…
                                0|MagicMir | [16:05:13.445] [INFO] DP2: Running window resizers…
                                0|MagicMir | [16:05:20.485] [INFO] DP2: Running window resizers…
                                1|omx_stream1 | have a nice day ;)
                                PM2 | App [omx_stream1:1] exited with code [1] via signal [SIGINT]
                                PM2 | App [omx_stream1:1] starting in -fork mode-
                                PM2 | App [omx_stream1:1] online
                                Can someone help me, to see the ip-camera on the magic-mirror ?
                                thanks,
                                • BKeyportB
                                  Try the other stream types. VLC don’t work within the magic mirror. I had to edit the string to get it to even launch using the arguments supplied by the module author, and then launching it under MM’s system didn’t ever work right, would produce a blank window. change the local player to omxplayer or ffmpeg.
                                  • N
                                    Number_5
                                    Hello BKeyport,
                                    thanks a lot for for the quick response. . Excuse me please,
                                    I don’t speak English very well. did I understand you correctly. My syntax in the config.js is correct?
                                    Now I have changed the player ( omxplayer or ffmpeg) in the config.js but nothing happened. i have only two white frames. i will show you below .
                                    Here the moduls in the config.js
                                    header: “test1”,
                                    autoStart: true,
                                    moduleWidth: 354,
                                    moduleHeight: 240,
                                    localPlayer: ‘ffmpeg’,
                                    remoteSnaps: true,
                                    shutdownDelay: 12,
                                    stream1: {
                                    url: ‘rtsp://XXX:XXX@XXX.XXX.2.108:80/cam/realmonitor?channel=2&subtype=0’,
                                    width: undefined,
                                    height: undefined,
                                    autoStart: true,
                                    moduleWidth: 640,
                                    moduleHeight: 360,
                                    remoteSnaps: true,
                                    stream1: {
                                    width: 640,
                                    height: 360,
                                    actuell screen: can not insert maximum filesize exceeded
                                    step 7 pm2 flush
                                    pi@raspberrypi:~/MagicMirror/config $ pm2 flush
                                    [PM2] Flushing:
                                    [PM2] Flushing:
                                    [PM2] /dev/null
                                    [PM2] Logs flushed
                                    step 8 restart MM
                                    pi@raspberrypi:~/MagicMirror $ pm2 restart MagicMirror
                                    [PM2] MagicMirror ✓
                                    │ 0 │ MagicMirror │ default │ 2.10.0 │ fork │ 20066 │ 0s │ 1 │ online │ 0% │ 2.6mb │ pi │ disabled │
                                    │ 1 │ omx_stream1 │ default │ N/A │ fork │ 20024 │ 6s │ 487 │ online │ 0% │ 2.5mb │ pi │ disabled │
                                    pi@raspberrypi:~/MagicMirror $ pm2 logs --lines 200
                                    PM2 | 2020-02-01T20:40:28: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
                                    PM2 | 2020-02-01T20:40:28: PM2 log: App [omx_stream1:1] starting in -fork mode-
                                    PM2 | 2020-02-01T20:40:28: PM2 log: App [omx_stream1:1] online
                                    PM2 | 2020-02-01T20:40:33: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
                                    PM2 | 2020-02-01T20:40:33: PM2 log: App [omx_stream1:1] starting in -fork mode-
                                    PM2 | 2020-02-01T20:40:33: PM2 log: App [omx_stream1:1] online
                                    PM2 | 2020-02-01T20:40:39: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
                                    PM2 | 2020-02-01T20:40:39: PM2 log: App [omx_stream1:1] starting in -fork mode-
                                    PM2 | 2020-02-01T20:40:39: PM2 log: App [omx_stream1:1] online
                                    PM2 | 2020-02-01T20:40:44: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
                                    PM2 | 2020-02-01T20:40:44: PM2 log: App [omx_stream1:1] starting in -fork mode-
                                    PM2 | 2020-02-01T20:40:44: PM2 log: App [omx_stream1:1] online
                                    PM2 | 2020-02-01T20:40:50: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
                                    PM2 | 2020-02-01T20:40:50: PM2 log: App [omx_stream1:1] starting in -fork mode-
                                    PM2 | 2020-02-01T20:40:50: PM2 log: App [omx_stream1:1] online
                                    PM2 | 2020-02-01T20:40:55: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
                                    PM2 | 2020-02-01T20:40:55: PM2 log: App [omx_stream1:1] starting in -fork mode-
                                    PM2 | 2020-02-01T20:40:55: PM2 log: App [omx_stream1:1] online
                                    PM2 | 2020-02-01T20:41:01: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
                                    PM2 | 2020-02-01T20:41:01: PM2 log: App [omx_stream1:1] starting in -fork mode-
                                    PM2 | 2020-02-01T20:41:01: PM2 log: App [omx_stream1:1] online
                                    PM2 | 2020-02-01T20:41:07: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
                                    PM2 | 2020-02-01T20:41:07: PM2 log: App [omx_stream1:1] starting in -fork mode-
                                    PM2 | 2020-02-01T20:41:07: PM2 log: App [omx_stream1:1] online
                                    PM2 | 2020-02-01T20:41:12: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
                                    PM2 | 2020-02-01T20:41:12: PM2 log: App [omx_stream1:1] starting in -fork mode-
                                    PM2 | 2020-02-01T20:41:12: PM2 log: App [omx_stream1:1] online
                                    PM2 | 2020-02-01T20:41:18: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
                                    PM2 | 2020-02-01T20:41:18: PM2 log: App [omx_stream1:1] starting in -fork mode-
                                    PM2 | 2020-02-01T20:41:18: PM2 log: App [omx_stream1:1] online
                                    PM2 | 2020-02-01T20:41:23: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
                                    PM2 | 2020-02-01T20:41:23: PM2 log: App [omx_stream1:1] starting in -fork mode-
                                    PM2 | 2020-02-01T20:41:23: PM2 log: App [omx_stream1:1] online
                                    PM2 | 2020-02-01T20:41:29: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
                                    PM2 | 2020-02-01T20:41:29: PM2 log: App [omx_stream1:1] starting in -fork mode-
                                    PM2 | 2020-02-01T20:41:29: PM2 log: App [omx_stream1:1] online
                                    PM2 | 2020-02-01T20:41:34: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
                                    PM2 | 2020-02-01T20:41:34: PM2 log: App [omx_stream1:1] starting in -fork mode-
                                    PM2 | 2020-02-01T20:41:34: PM2 log: App [omx_stream1:1] online
                                    PM2 | 2020-02-01T20:41:40: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
                                    PM2 | 2020-02-01T20:41:40: PM2 log: App [omx_stream1:1] starting in -fork mode-
                                    PM2 | 2020-02-01T20:41:40: PM2 log: App [omx_stream1:1] online
                                    PM2 | 2020-02-01T20:41:45: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
                                    PM2 | 2020-02-01T20:41:45: PM2 log: App [omx_stream1:1] starting in -fork mode-
                                    PM2 | 2020-02-01T20:41:45: PM2 log: App [omx_stream1:1] online
                                    PM2 | 2020-02-01T20:41:51: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
                                    PM2 | 2020-02-01T20:41:51: PM2 log: App [omx_stream1:1] starting in -fork mode-
                                    PM2 | 2020-02-01T20:41:51: PM2 log: App [omx_stream1:1] online
                                    PM2 | 2020-02-01T20:41:57: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
                                    PM2 | 2020-02-01T20:41:57: PM2 log: App [omx_stream1:1] starting in -fork mode-
                                    PM2 | 2020-02-01T20:41:57: PM2 log: App [omx_stream1:1] online
                                    PM2 | 2020-02-01T20:42:02: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
                                    PM2 | 2020-02-01T20:42:02: PM2 log: App [omx_stream1:1] starting in -fork mode-
                                    PM2 | 2020-02-01T20:42:02: PM2 log: App [omx_stream1:1] online
                                    PM2 | 2020-02-01T20:42:08: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
                                    PM2 | 2020-02-01T20:42:08: PM2 log: App [omx_stream1:1] starting in -fork mode-
                                    PM2 | 2020-02-01T20:42:08: PM2 log: App [omx_stream1:1] online
                                    PM2 | 2020-02-01T20:42:13: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
                                    PM2 | 2020-02-01T20:42:13: PM2 log: App [omx_stream1:1] starting in -fork mode-
                                    PM2 | 2020-02-01T20:42:13: PM2 log: App [omx_stream1:1] online
                                    PM2 | 2020-02-01T20:42:19: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
                                    PM2 | 2020-02-01T20:42:19: PM2 log: App [omx_stream1:1] starting in -fork mode-
                                    PM2 | 2020-02-01T20:42:19: PM2 log: App [omx_stream1:1] online
                                    PM2 | 2020-02-01T20:42:24: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
                                    PM2 | 2020-02-01T20:42:24: PM2 log: App [omx_stream1:1] starting in -fork mode-
                                    PM2 | 2020-02-01T20:42:24: PM2 log: App [omx_stream1:1] online
                                    PM2 | 2020-02-01T20:42:30: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
                                    PM2 | 2020-02-01T20:42:30: PM2 log: App [omx_stream1:1] starting in -fork mode-
                                    PM2 | 2020-02-01T20:42:30: PM2 log: App [omx_stream1:1] online
                                    PM2 | 2020-02-01T20:42:35: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
                                    PM2 | 2020-02-01T20:42:35: PM2 log: App [omx_stream1:1] starting in -fork mode-
                                    PM2 | 2020-02-01T20:42:35: PM2 log: App [omx_stream1:1] online
                                    PM2 | 2020-02-01T20:42:41: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
                                    PM2 | 2020-02-01T20:42:41: PM2 log: App [omx_stream1:1] starting in -fork mode-
                                    PM2 | 2020-02-01T20:42:41: PM2 log: App [omx_stream1:1] online
                                    PM2 | 2020-02-01T20:42:47: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
                                    PM2 | 2020-02-01T20:42:47: PM2 log: App [omx_stream1:1] starting in -fork mode-
                                    PM2 | 2020-02-01T20:42:47: PM2 log: App [omx_stream1:1] online
                                    PM2 | 2020-02-01T20:42:52: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
                                    PM2 | 2020-02-01T20:42:52: PM2 log: App [omx_stream1:1] starting in -fork mode-
                                    PM2 | 2020-02-01T20:42:52: PM2 log: App [omx_stream1:1] online
                                    PM2 | 2020-02-01T20:42:58: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
                                    PM2 | 2020-02-01T20:42:58: PM2 log: App [omx_stream1:1] starting in -fork mode-
                                    PM2 | 2020-02-01T20:42:58: PM2 log: App [omx_stream1:1] online
                                    PM2 | 2020-02-01T20:43:03: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
                                    PM2 | 2020-02-01T20:43:03: PM2 log: App [omx_stream1:1] starting in -fork mode-
                                    PM2 | 2020-02-01T20:43:03: PM2 log: App [omx_stream1:1] online
                                    PM2 | 2020-02-01T20:43:09: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
                                    PM2 | 2020-02-01T20:43:09: PM2 log: App [omx_stream1:1] starting in -fork mode-
                                    PM2 | 2020-02-01T20:43:09: PM2 log: App [omx_stream1:1] online
                                    PM2 | 2020-02-01T20:43:14: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
                                    PM2 | 2020-02-01T20:43:14: PM2 log: App [omx_stream1:1] starting in -fork mode-
                                    PM2 | 2020-02-01T20:43:14: PM2 log: App [omx_stream1:1] online
                                    PM2 | 2020-02-01T20:43:20: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
                                    PM2 | 2020-02-01T20:43:20: PM2 log: App [omx_stream1:1] starting in -fork mode-
                                    PM2 | 2020-02-01T20:43:20: PM2 log: App [omx_stream1:1] online
                                    PM2 | 2020-02-01T20:43:25: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
                                    PM2 | 2020-02-01T20:43:25: PM2 log: App [omx_stream1:1] starting in -fork mode-
                                    PM2 | 2020-02-01T20:43:25: PM2 log: App [omx_stream1:1] online
                                    PM2 | 2020-02-01T20:43:31: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
                                    PM2 | 2020-02-01T20:43:31: PM2 log: App [omx_stream1:1] starting in -fork mode-
                                    PM2 | 2020-02-01T20:43:31: PM2 log: App [omx_stream1:1] online
                                    PM2 | 2020-02-01T20:43:36: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
                                    PM2 | 2020-02-01T20:43:36: PM2 log: App [omx_stream1:1] starting in -fork mode-
                                    PM2 | 2020-02-01T20:43:36: PM2 log: App [omx_stream1:1] online
                                    PM2 | 2020-02-01T20:43:42: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
                                    PM2 | 2020-02-01T20:43:42: PM2 log: App [omx_stream1:1] starting in -fork mode-
                                    PM2 | 2020-02-01T20:43:42: PM2 log: App [omx_stream1:1] online
                                    PM2 | 2020-02-01T20:43:48: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
                                    PM2 | 2020-02-01T20:43:48: PM2 log: App [omx_stream1:1] starting in -fork mode-
                                    PM2 | 2020-02-01T20:43:48: PM2 log: App [omx_stream1:1] online
                                    PM2 | 2020-02-01T20:43:53: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
                                    PM2 | 2020-02-01T20:43:53: PM2 log: App [omx_stream1:1] starting in -fork mode-
                                    PM2 | 2020-02-01T20:43:53: PM2 log: App [omx_stream1:1] online
                                    PM2 | 2020-02-01T20:43:59: PM2 log: Stopping app:MagicMirror id:0
                                    PM2 | 2020-02-01T20:43:59: PM2 log: App [MagicMirror:0] exited with code [0] via signal [SIGINT]
                                    PM2 | 2020-02-01T20:43:59: PM2 log: pid=17271 msg=process killed
                                    PM2 | 2020-02-01T20:43:59: PM2 log: App [MagicMirror:0] starting in -fork mode-
                                    PM2 | 2020-02-01T20:43:59: PM2 log: App [MagicMirror:0] online
                                    PM2 | 2020-02-01T20:43:59: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
                                    PM2 | 2020-02-01T20:43:59: PM2 log: App [omx_stream1:1] starting in -fork mode-
                                    PM2 | 2020-02-01T20:43:59: PM2 log: App [omx_stream1:1] online
                                    PM2 | 2020-02-01T20:44:05: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
                                    PM2 | 2020-02-01T20:44:05: PM2 log: App [omx_stream1:1] starting in -fork mode-
                                    PM2 | 2020-02-01T20:44:05: PM2 log: App [omx_stream1:1] online
                                    PM2 | 2020-02-01T20:44:07: PM2 log: Stopping app:omx_stream1 id:1
                                    PM2 | 2020-02-01T20:44:07: PM2 log: App [omx_stream1:1] exited with code [0] via signal [SIGINT]
                                    PM2 | 2020-02-01T20:44:07: PM2 log: pid=20164 msg=process killed
                                    PM2 | 2020-02-01T20:44:11: PM2 log: App [omx_stream1:1] starting in -fork mode-
                                    PM2 | 2020-02-01T20:44:11: PM2 log: App [omx_stream1:1] online
                                    PM2 | 2020-02-01T20:44:17: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
                                    PM2 | 2020-02-01T20:44:17: PM2 log: App [omx_stream1:1] starting in -fork mode-
                                    PM2 | 2020-02-01T20:44:17: PM2 log: App [omx_stream1:1] online
                                    PM2 | 2020-02-01T20:44:23: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
                                    PM2 | 2020-02-01T20:44:23: PM2 log: App [omx_stream1:1] starting in -fork mode-
                                    PM2 | 2020-02-01T20:44:23: PM2 log: App [omx_stream1:1] online
                                    PM2 | 2020-02-01T20:44:28: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
                                    PM2 | 2020-02-01T20:44:28: PM2 log: App [omx_stream1:1] starting in -fork mode-
                                    PM2 | 2020-02-01T20:44:28: PM2 log: App [omx_stream1:1] online
                                    PM2 | 2020-02-01T20:44:34: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
                                    PM2 | 2020-02-01T20:44:34: PM2 log: App [omx_stream1:1] starting in -fork mode-
                                    PM2 | 2020-02-01T20:44:34: PM2 log: App [omx_stream1:1] online
                                    PM2 | 2020-02-01T20:44:39: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
                                    PM2 | 2020-02-01T20:44:39: PM2 log: App [omx_stream1:1] starting in -fork mode-
                                    PM2 | 2020-02-01T20:44:39: PM2 log: App [omx_stream1:1] online
                                    PM2 | 2020-02-01T20:44:45: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
                                    PM2 | 2020-02-01T20:44:45: PM2 log: App [omx_stream1:1] starting in -fork mode-
                                    PM2 | 2020-02-01T20:44:45: PM2 log: App [omx_stream1:1] online
                                    PM2 | 2020-02-01T20:44:50: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
                                    PM2 | 2020-02-01T20:44:50: PM2 log: App [omx_stream1:1] starting in -fork mode-
                                    PM2 | 2020-02-01T20:44:50: PM2 log: App [omx_stream1:1] online
                                    PM2 | 2020-02-01T20:44:56: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
                                    PM2 | 2020-02-01T20:44:56: PM2 log: App [omx_stream1:1] starting in -fork mode-
                                    PM2 | 2020-02-01T20:44:56: PM2 log: App [omx_stream1:1] online
                                    PM2 | 2020-02-01T20:45:02: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
                                    PM2 | 2020-02-01T20:45:02: PM2 log: App [omx_stream1:1] starting in -fork mode-
                                    PM2 | 2020-02-01T20:45:02: PM2 log: App [omx_stream1:1] online
                                    PM2 | 2020-02-01T20:45:07: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
                                    PM2 | 2020-02-01T20:45:07: PM2 log: App [omx_stream1:1] starting in -fork mode-
                                    PM2 | 2020-02-01T20:45:07: PM2 log: App [omx_stream1:1] online
                                    PM2 | 2020-02-01T20:45:13: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
                                    PM2 | 2020-02-01T20:45:13: PM2 log: App [omx_stream1:1] starting in -fork mode-
                                    PM2 | 2020-02-01T20:45:13: PM2 log: App [omx_stream1:1] online
                                    PM2 | 2020-02-01T20:45:18: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
                                    PM2 | 2020-02-01T20:45:18: PM2 log: App [omx_stream1:1] starting in -fork mode-
                                    PM2 | 2020-02-01T20:45:18: PM2 log: App [omx_stream1:1] online
                                    PM2 | 2020-02-01T20:45:24: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
                                    PM2 | 2020-02-01T20:45:24: PM2 log: App [omx_stream1:1] starting in -fork mode-
                                    PM2 | 2020-02-01T20:45:24: PM2 log: App [omx_stream1:1] online
                                    PM2 | 2020-02-01T20:45:29: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
                                    PM2 | 2020-02-01T20:45:29: PM2 log: App [omx_stream1:1] starting in -fork mode-
                                    PM2 | 2020-02-01T20:45:29: PM2 log: App [omx_stream1:1] online
                                    PM2 | 2020-02-01T20:45:35: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
                                    PM2 | 2020-02-01T20:45:35: PM2 log: App [omx_stream1:1] starting in -fork mode-
                                    PM2 | 2020-02-01T20:45:35: PM2 log: App [omx_stream1:1] online
                                    0|MagicMir | [20:44:09.697] [ERROR] TypeError: port or a server must be provided
                                    0|MagicMir | at new WebSocketServer (/home/pi/MagicMirror/modules/MMM-RTSPStream/node_modules/node-rtsp-stream-es6/node_modules/ws/lib/WebSocketServer.js:44:11)
                                    0|MagicMir | at VideoStream.stream2Socket (/home/pi/MagicMirror/modules/MMM-RTSPStream/node_modules/node-rtsp-stream-es6/src/videoStream.js:32:23)
                                    0|MagicMir | at new VideoStream (/home/pi/MagicMirror/modules/MMM-RTSPStream/node_modules/node-rtsp-stream-es6/src/videoStream.js:27:14)
                                    0|MagicMir | at Class.startListener (/home/pi/MagicMirror/modules/MMM-RTSPStream/node_helper.js:74:40)
                                    0|MagicMir | at streams.forEach (/home/pi/MagicMirror/modules/MMM-RTSPStream/node_helper.js:524:22)
                                    0|MagicMir | at Array.forEach ()
                                    0|MagicMir | at Class.socketNotificationReceived (/home/pi/MagicMirror/modules/MMM-RTSPStream/node_helper.js:523:21)
                                    0|MagicMir | at Socket. (/home/pi/MagicMirror/js/node_helper.js:113:11)
                                    0|MagicMir | at Socket.emit (events.js:182:13)
                                    0|MagicMir | at /home/pi/MagicMirror/node_modules/socket.io/lib/socket.js:528:12
                                    0|MagicMir |
                                    0|MagicMir |
                                    0|MagicMir | [20:44:05.677] [LOG] Starting MagicMirror: v2.10.0
                                    0|MagicMir | [20:44:05.687] [LOG] Loading config …
                                    0|MagicMir | [20:44:05.694] [LOG] Loading module helpers …
                                    0|MagicMir | [20:44:05.696] [LOG] No helper found for module: alert.
                                    0|MagicMir | [20:44:05.752] [LOG] Initializing new module helper …
                                    0|MagicMir | [20:44:05.753] [LOG] Module helper loaded: updatenotification
                                    0|MagicMir | [20:44:06.890] [LOG] Initializing new module helper …
                                    0|MagicMir | [20:44:06.891] [LOG] Module helper loaded: MMM-RTSPStream
                                    0|MagicMir | [20:44:07.197] [LOG] Initializing new module helper …
                                    0|MagicMir | [20:44:07.198] [LOG] Module helper loaded: MMM-PublicTransportHafas
                                    0|MagicMir | [20:44:07.199] [LOG] No helper found for module: currentweather.
                                    0|MagicMir | [20:44:07.199] [LOG] No helper found for module: weatherforecast.
                                    0|MagicMir | [20:44:07.272] [LOG] Initializing new module helper …
                                    0|MagicMir | [20:44:07.273] [LOG] Module helper loaded: calendar
                                    0|MagicMir | [20:44:07.307] [LOG] Initializing new module helper …
                                    0|MagicMir | [20:44:07.307] [LOG] Module helper loaded: newsfeed
                                    0|MagicMir | [20:44:07.308] [LOG] All module helpers loaded.
                                    0|MagicMir | [20:44:07.309] [LOG] Starting server on port 8080 …
                                    0|MagicMir | [20:44:07.325] [LOG] Server started …
                                    0|MagicMir | [20:44:07.327] [LOG] Connecting socket for: updatenotification
                                    0|MagicMir | [20:44:07.328] [LOG] Connecting socket for: MMM-RTSPStream
                                    0|MagicMir | [20:44:07.329] [LOG] PM2: Stopping all OMXPlayer Streams…
                                    0|MagicMir | [20:44:07.332] [LOG] Connecting socket for: MMM-PublicTransportHafas
                                    0|MagicMir | [20:44:07.333] [LOG] Connecting socket for: calendar
                                    0|MagicMir | [20:44:07.334] [LOG] Starting node helper for: calendar
                                    0|MagicMir | [20:44:07.335] [LOG] Connecting socket for: newsfeed
                                    0|MagicMir | [20:44:07.336] [LOG] Starting module: newsfeed
                                    0|MagicMir | [20:44:07.336] [LOG] Sockets connected & modules started …
                                    0|MagicMir | [20:44:07.548] [LOG] Launching application.
                                    0|MagicMir | [20:44:07.769] [LOG] PM2: Checking if omx_stream1 is running…
                                    0|MagicMir | [20:44:07.770] [LOG] PM2: Stopping omx_stream1…
                                    0|MagicMir | [20:44:09.660] [LOG] Transportation fetcher for station with id ‘xxx’ created.
                                    0|MagicMir | [20:44:09.685] [LOG] Starting WebSocket server on port undefined. Waiting for connections…
                                    0|MagicMir | [20:44:09.694] [LOG] Whoops! There was an uncaught exception…
                                    0|MagicMir | [20:44:09.702] [LOG] MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                                    0|MagicMir | [20:44:09.705] [LOG] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                                    0|MagicMir | [20:44:09.846] [LOG] Transportation fetcher for station with id ‘xxx’ created.
                                    0|MagicMir | [20:44:09.866] [LOG] Create new calendar fetcher for url: https://calendar.google.com/calendar/ical/xxxgroup.calendar.google.com/private-xxx/basic.ics - Interval: 300000
                                    0|MagicMir | [20:44:09.877] [LOG] Create new news fetcher for url: https://www.swr.de/~rss/swraktuell/swraktuell-bw-100.xml - Interval: 300000
                                    0|MagicMir | [20:44:11.651] [LOG] Starting stream stream1 using: omxplayer --avdict rtsp_transport:tcp --win 643,514,1283,874 --live --video_queue 4 --fps 30 --no-osd rtsp://xxx:xxx@xxx.xxx.2.108:80/cam/realmonitor?channel=2&subtype=0
                                    0|MagicMir | [20:44:11.673] [LOG] Starting PM2 for omx_stream1
                                    0|MagicMir | [20:44:11.826] [LOG] PM2 started for omx_stream1
                                    do you have a other idea ?
                                      sdetweil @Number_5
                                      @Number_5 said in [MMM-RTSPStream] - Video Streaming from Live Feeds & Security Cameras:
                                      looks like a config error for the rtspstream server
                                      magicmirror’s server and port working
                                      • N
                                        Number_5
                                        Hello Sam,
                                        during the implementation I kept to the instruction in:
                                        I was denied access to http://your-mirror-ip:8080/MMM-RTSPStream/config.html. After weeks i found a post with the adress
                                        http://127.0.0.1:8080/MMM-RTSPStream/config.html.With this adress it was possible to use the tool to generate the config details.
                                        do I have to change the address elsewhere?
                                          sdetweil @Number_5
                                          this is because the mirror defaults to listening on localhost and ipWhiteList[] only allows localhost to connect (on same machine as mirror app)
                                          change address: “locathost”
                                          to
                                          address: “0.0.0.0”
                                          and ipWhitelist: […]
                                          to
                                          ipWhiteList: []
                                          I don’t know anything about the rtspstream stuff… only reporting what is in the log u posted.
                                          looks like it might be the port… note mirror is on 8080
                                          that server also might be trying 8080, both can’t have it at the same time
                                          • N
                                            Number_5
                                            Hello Sam,
                                            thanks also for the quick response.
                                            I have changed the address ,but now my mirror shows only a black screen, ;-(
                                            after correction:
                                            var config = {
                                            address: “0.0.0.0”, // Address to listen on, can be:
                                            // - “”, “0.0.0.0”, “::” to listen on any interface
                                            // Default, when address config is left out, is “localhost”
                                            port: 8080,
                                            ipWhitelist: [“”, “::ffff:127.0.0.1”, “::1”], // Set [] to allow all IP addresses
                                            // [“127.0.0.1”, “::ffff:127.0.0.1”, “::1”, “::ffff:192.168.1.5”],
                                            // [“127.0.0.1”, “::ffff:127.0.0.1”, “::1”, “::ffff:192.168.3.0/28”],
                                            before correction :
                                            var config = {
                                            port: 8080,
                                            ipWhitelist: [“127.0.0.1”, “::ffff:127.0.0.1”, “::1”], // Set [] to allow all IP addresses
                                            step 7 pm2 flush
                                            pi@raspberrypi:~/MagicMirror $ pm2 flush
                                            [PM2] Flushing:
                                            [PM2] Flushing:
                                            [PM2] /dev/null
                                            [PM2] Logs flushed
                                            step 8 restart MM
                                            [PM2] MagicMirror ✓
                                            │ 0 │ MagicMirror │ default │ 2.10.0 │ fork │ 15909 │ 0s │ 2 │ online │ 0% │ 2.4mb │ pi │ disabled │
                                            │ 1 │ omx_stream1 │ default │ N/A │ fork │ 0 │ 0 │ 1189 │ stopped │ 0% │ 0b │ pi │ disabled │
                                            PM2 | 2020-02-01T21:52:06: PM2 log: Stopping app:MagicMirror id:0
                                            PM2 | 2020-02-01T21:52:07: PM2 log: pid=15652 msg=failed to kill - retrying in 100ms
                                            PM2 | 2020-02-01T21:52:07: PM2 log: App [MagicMirror:0] exited with code [0] via signal [SIGINT]
                                            PM2 | 2020-02-01T21:52:07: PM2 log: pid=15652 msg=process killed
                                            PM2 | 2020-02-01T21:52:07: PM2 log: App [MagicMirror:0] starting in -fork mode-
                                            PM2 | 2020-02-01T21:52:07: PM2 log: App [MagicMirror:0] online
                                            0|MagicMir | [21:52:07.028] [LOG] Shutting down server…
                                            0|MagicMir | [21:52:07.030] [LOG] Stopping module helper: updatenotification
                                            0|MagicMir | [21:52:07.031] [LOG] Shutting down MMM-RTSPStream streams that were using undefined
                                            0|MagicMir | [21:52:07.031] [LOG] Stopping module helper: MMM-PublicTransportHafas
                                            0|MagicMir | [21:52:07.032] [LOG] Stopping module helper: calendar
                                            0|MagicMir | [21:52:07.032] [LOG] Stopping module helper: newsfeed
                                            0|MagicMir |
                                            0|MagicMir |
                                            0|MagicMir | [21:52:12.731] [LOG] Starting MagicMirror: v2.10.0
                                            0|MagicMir | [21:52:12.739] [LOG] Loading config …
                                            0|MagicMir | [21:52:12.745] [LOG] Loading module helpers …
                                            0|MagicMir | [21:52:12.746] [LOG] No helper found for module: alert.
                                            0|MagicMir | [21:52:12.793] [LOG] Initializing new module helper …
                                            0|MagicMir | [21:52:12.794] [LOG] Module helper loaded: updatenotification
                                            0|MagicMir | [21:52:13.749] [LOG] Initializing new module helper …
                                            0|MagicMir | [21:52:13.749] [LOG] Module helper loaded: MMM-RTSPStream
                                            0|MagicMir | [21:52:14.002] [LOG] Initializing new module helper …
                                            0|MagicMir | [21:52:14.003] [LOG] Module helper loaded: MMM-PublicTransportHafas
                                            0|MagicMir | [21:52:14.003] [LOG] No helper found for module: currentweather.
                                            0|MagicMir | [21:52:14.004] [LOG] No helper found for module: weatherforecast.
                                            0|MagicMir | [21:52:14.071] [LOG] Initializing new module helper …
                                            0|MagicMir | [21:52:14.071] [LOG] Module helper loaded: calendar
                                            0|MagicMir | [21:52:14.101] [LOG] Initializing new module helper …
                                            0|MagicMir | [21:52:14.102] [LOG] Module helper loaded: newsfeed
                                            0|MagicMir | [21:52:14.102] [LOG] All module helpers loaded.
                                            0|MagicMir | [21:52:14.103] [LOG] Starting server on port 8080 …
                                            0|MagicMir | [21:52:14.116] [LOG] Server started …
                                            0|MagicMir | [21:52:14.117] [LOG] Connecting socket for: updatenotification
                                            0|MagicMir | [21:52:14.118] [LOG] Connecting socket for: MMM-RTSPStream
                                            0|MagicMir | [21:52:14.119] [LOG] PM2: Stopping all OMXPlayer Streams…
                                            0|MagicMir | [21:52:14.121] [LOG] Connecting socket for: MMM-PublicTransportHafas
                                            0|MagicMir | [21:52:14.122] [LOG] Connecting socket for: calendar
                                            0|MagicMir | [21:52:14.123] [LOG] Starting node helper for: calendar
                                            0|MagicMir | [21:52:14.123] [LOG] Connecting socket for: newsfeed
                                            0|MagicMir | [21:52:14.124] [LOG] Starting module: newsfeed
                                            0|MagicMir | [21:52:14.124] [LOG] Sockets connected & modules started …
                                            0|MagicMir | [21:52:14.285] [LOG] Launching application.
                                            0|MagicMir | [21:52:14.407] [LOG] Access denied to IP address: 127.0.0.1
                                            0|MagicMir | [21:52:14.441] [LOG] PM2: Checking if omx_stream1 is running…
                                            I changed the address as described above, but in the logfile there is still the same adress.
                                            Did i change the address in the wrong place?
                                            • 17
                                            • 18
                                            • 19
                                            • 20
                                            • 21
                                            • 30
                                            • 31
                                            • 19 / 31
