602 Posts 67 Posters 1.8m Views 68 Watching
    p4lsec
    Just wanted to cross-post this in case people are looking in this thread for a way to monitor and restart streams that have stopped:
    https://forum.magicmirror.builders/topic/11828/short-script-to-monitor-and-restart-your-mmm-rtspstreams
    • K Offline
      kris1208
      hello, I have a problem with this module, I have the displays which are truncated and this since the update.
      bonjour, j’ai un probleme avec ce module, j’ai les affichages qui sont tronqué et ce depuis la mise a jour.
      Merci.
      • K Offline
        kris1208
        nobody to tell me how to solve my cut image problem? Thank you
        E 1 Reply Last reply Dec 27, 2019, 11:03 AM Reply Quote 0
        • E Offline
          evroom @kris1208
          @kris1208
          Perhaps you can share the config.js part for MMM-RTSPStream with us?
          The pm2 log output for this module is useful too.
          The part where it shows the applied coordinates.
          MagicMirror version: 2.30.0
          Test environment:
          MagicMirror version: v2.30.0
          • K Offline
            kris1208
            @evroom said in [MMM-RTSPStream] - Video Streaming from Live Feeds & Security Cameras:
            Thank you for your response, could you tell me the file I need to post to you?
            module: “MMM-RTSPStream”,
            position: “top_center”,
            rotateStreamTimeout: 20, // Seconds
            stream1: {
            url: “rtsp://MDP@192.168.1.16/MediaInput/h264”
            stream2: {
            url: “rtsp://MDP@192.168.1.17/12”
            E 1 Reply Last reply Dec 28, 2019, 7:25 PM Reply Quote 0
            • E Offline
              evroom @kris1208
              @kris1208
              Hi, bonjour, to be honest I do not see the problem right away. With truncated you mean you expect to see more? Of the top stream or the bottom stream, or both? What resolution(s) do you expect to see?
              I suppose you followed the instructions from this repository:
              https://github.com/shbatm/MMM-RTSPStream
              Including the “To use this module, use the configuration builder tool included.” part to produce a recommended config for your stream(s).
              I think your config defaults to the vlc player. Could you please do:
              ps -eaf | grep -v grep | egrep 'omxplayer|vlc'
              If you (re)start MagicMirror (or mm), then you will find some MMM-RTSPStream module related info.
              pm2 logs --lines 200
              It will start with something like this:
              Starting stream stream1 with args:
              I personally use omxplayer, but standalone, without using MMM-RTSPStream. Since it is an overlay anyway, I feel I can control it more.
              Good luck gathering the information.
              Test environment:
              • K Offline
                kris1208
                ps -eaf | grep -v grep | egrep ‘omxplayer|vlc’
                0|mm | Whoops! There was an uncaught exception…
                0|mm | TypeError: Cannot convert undefined or null to object
                0|mm | at Function.keys ()
                0|mm | at stopProcs (/home/pi/MagicMirror/modules/MMM-RTSPStream/node_helper.js:469:32)
                0|mm | at pm2.list (/home/pi/MagicMirror/modules/MMM-RTSPStream/node_helper.js:498:17)
                0|mm | at /home/pi/MagicMirror/modules/MMM-RTSPStream/node_modules/pm2/lib/API.js:606:19
                0|mm | at /home/pi/MagicMirror/modules/MMM-RTSPStream/node_modules/pm2-axon-rpc/lib/client.js:45:10
                0|mm | at Parser. (/home/pi/MagicMirror/modules/MMM-RTSPStream/node_modules/pm2-axon/lib/sockets/req.js:67:8)
                0|mm | at Parser.emit (events.js:182:13)
                0|mm | at Parser._write (/home/pi/MagicMirror/modules/MMM-RTSPStream/node_modules/amp/lib/stream.js:91:16)
                0|mm | at doWrite (_stream_writable.js:410:12)
                0|mm | at writeOrBuffer (_stream_writable.js:394:5)
                0|mm | MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                0|mm | If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                0|mm | ATTENTION: default value of option force_s3tc_enable overridden by environment.
                0|mm | Create new news fetcher for url: https://www.bfmtv.com/rss/info/flux-rss/flux-toutes-les-actualites/ - Interval: 300000
                0|mm | Starting stream stream1 using VLC with args --width 352 --height 242 -I dummy --video-on-top --no-video-deco --no-embedded-video --video-title=stream1 rtsp://MDP@192.168.1.16/MediaInput/h264…
                0|mm | Starting stream stream2 using VLC with args --width 352 --height 242 -I dummy --video-on-top --no-video-deco --no-embedded-video --video-title=stream2 rtsp://MDP@192.168.1.17/12…
                0|mm | DP2: Running window resizers…
                0|mm | at stopProcs (/home/pi/MagicMirror/modules/MMM-RTSPStream/node_ helper.js:469:32)
                0|mm | at pm2.list (/home/pi/MagicMirror/modules/MMM-RTSPStream/node_h elper.js:498:17)
                0|mm | at /home/pi/MagicMirror/modules/MMM-RTSPStream/node_modules/pm2 /lib/API.js:606:19
                0|mm | at /home/pi/MagicMirror/modules/MMM-RTSPStream/node_modules/pm2 -axon-rpc/lib/client.js:45:10
                0|mm | at Parser. (/home/pi/MagicMirror/modules/MMM-RTSPStr eam/node_modules/pm2-axon/lib/sockets/req.js:67:8)
                0|mm | at Parser._write (/home/pi/MagicMirror/modules/MMM-RTSPStream/n ode_modules/amp/lib/stream.js:91:16)
                0|mm | npm ERR! code ELIFECYCLE
                0|mm | npm ERR! errno 1
                0|mm | npm ERR! magicmirror@2.9.0 start: sh run-start.sh
                0|mm | npm ERR! Exit status 1
                0|mm | npm ERR!
                0|mm | npm ERR! Failed at the magicmirror@2.9.0 start script.
                0|mm | npm ERR! This is probably not a problem with npm. There is likely a dditional logging output above.
                0|mm |
                0|mm | npm ERR! A complete log of this run can be found in:
                0|mm | npm ERR! /home/pi/.npm/logs/2019-12-27T19_17_29_282Z-debug.log
                0|mm | getrandom indicates that the entropy pool has not been initialized. Rather than continue with poor entropy, this process will block until entropy i s available.
                helper.js:469:32)
                0|mm | at writeOrBuffer (stream_writable.js:394:5)
                helper.js:469:32)
                0|mm | fatal: unable to access ‘https://github.com/shbatm/MMM-RTSPStream.g it/’: Could not resolve host: github.com
                0|mm |
                0|mm | fatal: unable to access ‘https://github.com/prysme01/MMM-Jeedom.git /’: Could not resolve host: github.com
                here is what i found. before it worked well, I think the best is to delete the plugin properly but I do not know how?
                E 1 Reply Last reply Dec 29, 2019, 8:02 PM Reply Quote 0
                • E Offline
                  evroom @kris1208
                  @kris1208
                  Okay, this looks like a bit more than a “truncated stream” issue.
                  That you see something at all is a miracle, I would say :-)
                  First of all, please use the </> button when providing output or pieces of config.
                  Select the text and press on the </> button.
                  Makes it a bit easier to read.
                  You can disable the module by putting ‘disabled: true’ in the config.js.
                  With the value false you can enable it again later.
                  module: "MMM-RTSPStream",
                      disabled: true,
                  Or remove the whole module entry, but this is not necessary when there are no syntax errors.
                  Then restart mm.
                  I always use
                  pm2 restart mm
                  provided mm is the pm2 app name.
                  See
                  pm2 status
                  To remove the module completely you can simply remove or disable it from the config.js and then delete the structure
                  rm -rf ~/MagicMirror/modules/MMM-RTSPStream
                  Or move it out of the way when you want to attempt a second try:
                  mv ~/MagicMirror/modules/MMM-RTSPStream ~/MagicMirror/modules/MMM-RTSPStream.old
                  Test environment:
                    BKeyport Module Developer
                    OK, it’s appearing more and more like the author of this module is MIA, and the module isn’t working well enough anymore to get a consistent stream (ffmpeg is the only thing that works at all in my installs, and even that will crash and burn every 3-6 hours, or get corrupted) - is there anything out there to replace this module?
                    E 1 Reply Last reply Jan 3, 2020, 3:25 PM Reply Quote 0
                    • K Offline
                      kris1208
                      @BKeyport said in [MMM-RTSPStream] - Video Streaming from Live Feeds & Security Cameras:
                      I redid an installation of the module but it is the same, the display is partial. Do you have another module to advise me? Thank you
                      • 35
                      • 36
                      • 37
                      • 38
                      • 39
                      • 60
                      • 61
                      • 37 / 61
                      37 / 61
