    602 Posts 67 Posters 2.3m Views 68 Watching
    • BKeyportB
      BKeyport Module Developer
      The white box is easy to get rid of:
      In ~/MagicMirror/css/custom.css
      /* This removes the white border around the RTSP feed(s). */
      .MMM-RTSPStream .innerWrapper {
        border: 0;
      As far as the play button, I’ve never seen it, so I don’t know how to get rid of it, I don’t use keyboard or mouse on my mirror.
      FYI, other css that might be useful:
      /* This shrinks the left and right regions so that RTSPStream don't overlap. */
      .region.right .module-content,
      .region.left .module-content {
        min-width: 450px;
        max-width: 450px;
      – B
      twosquirrelsT 1 Reply Last reply Reply Quote 0
      • twosquirrelsT
        twosquirrels @BKeyport
        @BKeyport That worked to remove the white box, thanks!
        I’m still struggling with getting the module to just show where I want it. I don’t know why it doesn’t just listen to “position” like every other module where I can tell them all to be top_right and they’d all line up in the appropriate order. I’m fighting with moduleOffset entering random numbers to see if I can find a decent spot, but it still overlaps, causes indentation, and is just a mess. Then often times the module will just disappear after being on screen for a couple minutes.
        • BKeyportB
          Odd - I’m having no problem moving it around - although, if you’re using OMXPlayer, it’s overlaying on top of the screen, it won’t play nice with other modules in the same position…
          • O
            osnapus
            Hello, I’m Peter,
            when I add RTSTStream to my MagicMirror, I have a little problem with RTSPStream module.
            When display is in normal mode on 27’ screen, everything is ok, picture from Cam is good, normal dimensions etc
            https://photos.app.goo.gl/czoZvwryGmqfJRDg6
            But when in /boot/config.txt in rpi3 the display_rotation=1, picture form cam is cut like on screen.
            https://photos.app.goo.gl/VRycUb7zMw9LQVxh6
            Someone could help me with this problem?
            Many thanks to You All
            Peter
            buzzkcB 1 Reply Last reply Reply Quote 0
            • buzzkcB
              buzzkc @osnapus
              @osnapus
              Try using the GL driver to rotate…
              https://github.com/michmich/magicmirror/wiki/configuring-the-raspberry-pi#enable-the-open-gl-driver-to-decrease-electrons-cpu-usage
              I’ll post my config.txt and autostart settings tonight, don’t have access to them right now.
              Darren
              My Build: https://forum.magicmirror.builders/topic/11153/new-non-mirror
              • A
                acimail01
                Is it possible to define a stream for playing a local file (e.g. .mp4 or .avi)?
                • A
                  acimail01
                  works with
                  			module: "MMM-RTSPStream",
                  			position: "middle_center",
                  				autoStart			: true,
                  				rotateStreams		: false,
                  				rotateStreamTimeout	: 30,
                  				moduleWidth			: 354,
                  				moduleHeight		: 240,
                  				localPlayer			: 'omxplayer',
                  				shutdownDelay		: 0,
                  					stream1: {
                  						url: 'file:///home/pi/MagicMirror/modules/MMM-RTSPStream/Videos/Feuer.mp4',
                  but no sound !
                  in bash console works with: omxplayer -o alsa Feuer.mp4
                  How to set hdmi sound as default ?
                    p4lsec
                    Just wanted to cross-post this in case people are looking in this thread for a way to monitor and restart streams that have stopped:
                    https://forum.magicmirror.builders/topic/11828/short-script-to-monitor-and-restart-your-mmm-rtspstreams
                    • K
                      kris1208
                      hello, I have a problem with this module, I have the displays which are truncated and this since the update.
                      bonjour, j’ai un probleme avec ce module, j’ai les affichages qui sont tronqué et ce depuis la mise a jour.
                      Merci.
                      • K
                        kris1208
                        nobody to tell me how to solve my cut image problem? Thank you
                        • evroomE
                          evroom @kris1208
                          @kris1208
                          Perhaps you can share the config.js part for MMM-RTSPStream with us?
                          The pm2 log output for this module is useful too.
                          The part where it shows the applied coordinates.
                          MagicMirror version: 2.37.0
                          • K
                            kris1208
                            @evroom said in [MMM-RTSPStream] - Video Streaming from Live Feeds & Security Cameras:
                            Thank you for your response, could you tell me the file I need to post to you?
                            module: “MMM-RTSPStream”,
                            position: “top_center”,
                            rotateStreamTimeout: 20, // Seconds
                            stream1: {
                            url: “rtsp://MDP@192.168.1.16/MediaInput/h264”
                            stream2: {
                            url: “rtsp://MDP@192.168.1.17/12”
                            • evroomE
                              evroom @kris1208
                              @kris1208
                              Hi, bonjour, to be honest I do not see the problem right away. With truncated you mean you expect to see more? Of the top stream or the bottom stream, or both? What resolution(s) do you expect to see?
                              I suppose you followed the instructions from this repository:
                              https://github.com/shbatm/MMM-RTSPStream
                              Including the “To use this module, use the configuration builder tool included.” part to produce a recommended config for your stream(s).
                              I think your config defaults to the vlc player. Could you please do:
                              ps -eaf | grep -v grep | egrep 'omxplayer|vlc'
                              If you (re)start MagicMirror (or mm), then you will find some MMM-RTSPStream module related info.
                              pm2 logs --lines 200
                              It will start with something like this:
                              Starting stream stream1 with args:
                              I personally use omxplayer, but standalone, without using MMM-RTSPStream. Since it is an overlay anyway, I feel I can control it more.
                              Good luck gathering the information.
                              • K
                                kris1208
                                ps -eaf | grep -v grep | egrep ‘omxplayer|vlc’
                                0|mm | Whoops! There was an uncaught exception…
                                0|mm | TypeError: Cannot convert undefined or null to object
                                0|mm | at Function.keys ()
                                0|mm | at stopProcs (/home/pi/MagicMirror/modules/MMM-RTSPStream/node_helper.js:469:32)
                                0|mm | at pm2.list (/home/pi/MagicMirror/modules/MMM-RTSPStream/node_helper.js:498:17)
                                0|mm | at /home/pi/MagicMirror/modules/MMM-RTSPStream/node_modules/pm2/lib/API.js:606:19
                                0|mm | at /home/pi/MagicMirror/modules/MMM-RTSPStream/node_modules/pm2-axon-rpc/lib/client.js:45:10
                                0|mm | at Parser. (/home/pi/MagicMirror/modules/MMM-RTSPStream/node_modules/pm2-axon/lib/sockets/req.js:67:8)
                                0|mm | at Parser.emit (events.js:182:13)
                                0|mm | at Parser._write (/home/pi/MagicMirror/modules/MMM-RTSPStream/node_modules/amp/lib/stream.js:91:16)
                                0|mm | at doWrite (_stream_writable.js:410:12)
                                0|mm | at writeOrBuffer (_stream_writable.js:394:5)
                                0|mm | MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                                0|mm | If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                                0|mm | ATTENTION: default value of option force_s3tc_enable overridden by environment.
                                0|mm | Create new news fetcher for url: https://www.bfmtv.com/rss/info/flux-rss/flux-toutes-les-actualites/ - Interval: 300000
                                0|mm | Starting stream stream1 using VLC with args --width 352 --height 242 -I dummy --video-on-top --no-video-deco --no-embedded-video --video-title=stream1 rtsp://MDP@192.168.1.16/MediaInput/h264…
                                0|mm | Starting stream stream2 using VLC with args --width 352 --height 242 -I dummy --video-on-top --no-video-deco --no-embedded-video --video-title=stream2 rtsp://MDP@192.168.1.17/12…
                                0|mm | DP2: Running window resizers…
                                0|mm | at stopProcs (/home/pi/MagicMirror/modules/MMM-RTSPStream/node_ helper.js:469:32)
                                0|mm | at pm2.list (/home/pi/MagicMirror/modules/MMM-RTSPStream/node_h elper.js:498:17)
                                0|mm | at /home/pi/MagicMirror/modules/MMM-RTSPStream/node_modules/pm2 /lib/API.js:606:19
                                0|mm | at /home/pi/MagicMirror/modules/MMM-RTSPStream/node_modules/pm2 -axon-rpc/lib/client.js:45:10
                                0|mm | at Parser. (/home/pi/MagicMirror/modules/MMM-RTSPStr eam/node_modules/pm2-axon/lib/sockets/req.js:67:8)
                                0|mm | at Parser._write (/home/pi/MagicMirror/modules/MMM-RTSPStream/n ode_modules/amp/lib/stream.js:91:16)
                                0|mm | npm ERR! code ELIFECYCLE
                                0|mm | npm ERR! errno 1
                                0|mm | npm ERR! magicmirror@2.9.0 start: sh run-start.sh
                                0|mm | npm ERR! Exit status 1
                                0|mm | npm ERR!
                                0|mm | npm ERR! Failed at the magicmirror@2.9.0 start script.
                                0|mm | npm ERR! This is probably not a problem with npm. There is likely a dditional logging output above.
                                0|mm |
                                0|mm | npm ERR! A complete log of this run can be found in:
                                0|mm | npm ERR! /home/pi/.npm/logs/2019-12-27T19_17_29_282Z-debug.log
                                0|mm | getrandom indicates that the entropy pool has not been initialized. Rather than continue with poor entropy, this process will block until entropy i s available.
                                helper.js:469:32)
                                0|mm | at writeOrBuffer (stream_writable.js:394:5)
                                helper.js:469:32)
                                0|mm | fatal: unable to access ‘https://github.com/shbatm/MMM-RTSPStream.g it/’: Could not resolve host: github.com
                                0|mm |
                                0|mm | fatal: unable to access ‘https://github.com/prysme01/MMM-Jeedom.git /’: Could not resolve host: github.com
                                here is what i found. before it worked well, I think the best is to delete the plugin properly but I do not know how?
                                • evroomE
                                  evroom @kris1208
                                  @kris1208
                                  Okay, this looks like a bit more than a “truncated stream” issue.
                                  That you see something at all is a miracle, I would say :-)
                                  First of all, please use the </> button when providing output or pieces of config.
                                  Select the text and press on the </> button.
                                  Makes it a bit easier to read.
                                  You can disable the module by putting ‘disabled: true’ in the config.js.
                                  With the value false you can enable it again later.
                                      disabled: true,
                                  Or remove the whole module entry, but this is not necessary when there are no syntax errors.
                                  Then restart mm.
                                  I always use
                                  pm2 restart mm
                                  provided mm is the pm2 app name.
                                  See
                                  pm2 status
                                  To remove the module completely you can simply remove or disable it from the config.js and then delete the structure
                                  rm -rf ~/MagicMirror/modules/MMM-RTSPStream
                                  Or move it out of the way when you want to attempt a second try:
                                  mv ~/MagicMirror/modules/MMM-RTSPStream ~/MagicMirror/modules/MMM-RTSPStream.old
                                  • BKeyportB
                                    OK, it’s appearing more and more like the author of this module is MIA, and the module isn’t working well enough anymore to get a consistent stream (ffmpeg is the only thing that works at all in my installs, and even that will crash and burn every 3-6 hours, or get corrupted) - is there anything out there to replace this module?
                                    • K
                                      kris1208
                                      @BKeyport said in [MMM-RTSPStream] - Video Streaming from Live Feeds & Security Cameras:
                                      I redid an installation of the module but it is the same, the display is partial. Do you have another module to advise me? Thank you
                                      • evroomE
                                        evroom @BKeyport
                                        @BKeyport
                                        Depends on what you want to stream and with what you want to stream it with.
                                        I, for example, am streaming a single Axis IP cam (supposing it is h.264) using omxplayer. Standalone, controlled by pm2.
                                        The MMM-RTSPStream does work, but I was having problems placing the stream on the screen to my likings.
                                        You may need to check this list if there is a module that suites your needs:
                                        https://github.com/MichMich/MagicMirror/wiki/3rd-party-modules#utility--iot--3rd-party--integration
                                        • evroomE
                                          evroom
                                          @kris1208 said in [MMM-RTSPStream] - Video Streaming from Live Feeds & Security Cameras:
                                          So you got rid of the errors in the pm2 log?
                                          pm2 flush
                                          pm2 restart mm
                                          Do you see an entry like this?
                                          If yes, what are the arguments?
                                          Using vlc or omxplayer?
                                          Still difficult to determine what you mean by partial.
                                          I think it is looking good.
                                          Perhaps you want to get rid of the white frame?
                                          vi ~/MagicMirror/css/custom.css
                                          Add:
                                            border-style: none;
                                            //border: 1px solid red;
                                          • K
                                            kris1208
                                            Merci de votre aide,
                                            J’ai mis quelques post plus avant le resultat du log pm2.
                                            Pareil pour l’affichage on vois sur les copies ecran qu’il manque une partie de l’image sur la droite.
                                            C’est VLC qui est utilisé mais j’ai mis omx et c’est pareil.
                                            • 17
                                            • 18
                                            • 19
                                            • 20
                                            • 21
                                            • 30
                                            • 31
                                            • 19 / 31
