    multiple calendars
    14 Posts 5 Posters 27.8k Views 5 Watching
      brownco9
      Okay I’ve tried that exactly as it is with my two additional calendars and I can’t get it to show anything but the Holidays one even if I change the order of them listed. I made sure to grab the private Ical along with checking it in the debugger which returns results of calendar items from my personal calendar. Thoughts?
        Mykle1 Project Sponsor Module Developer @brownco9
        @brownco9
        Post a copy of that portion of your config.js file here so that people can take a look at it. You’ll likely get an answer quicker that way. Just x-out any private info or keys before you post it. If you care to try again, here is my calendar entry. It SHOULD work if you replace a correct url with mine.
        			module: 'calendar',
        			position: 'top_left',
        			urgency: 0,
        			getRelative: 0,
        			fadePoint: 0.25, // Start on 1/4th of the list.
        						symbol: 'calendar-check-o ',
        						url: 'https://calendar.google.com/calendar/ical/xxxxxxxxxxxxxxxxxx.com/private-xxxxxxxxxxxxx/basic.ics'
          brownco9 @Mykle1
          @Mykle1
          module: 'calendar',
          			header: 'Calendars',
          			urgency: 0,
          			getRelative: 0,
          						url: 'https://calendar.google.com/calendar/ical/browncxxx.org/private-xxx/basics.ics'
          						url: 'https://calendar.google.com/calendar/ical/browncxxx.com/private-xxx/basics.ics'
            brownco9 @brownco9
            @brownco9 I added the urgency and getRelative after seeing yours and it didn’t change.
              @brownco9 said in multiple calendars:
              First thing I see is you are missing a comma after the last ]
              It should look like this ],
                brownco9 @Mykle1
                @Mykle1 fixed the comma, no change. I made sure to wait 5 minutes so the fetch could go.
                  @brownco9
                  You might also want to check on your google calendar page that the calendar you want to appear in the MM module is appearing on your calendar pages. On the left side of the google calendar page you’ll see “My calendars” and “Other calendars.” When you click on the colored square to the left of each calendar it will enable/disable that particular calendar in your main visible calendar (The big one, day to day). Make sure the calendar is showing in the main calendar.
                  Restart your MM
                    brownco9 @Mykle1
                    @Mykle1 I can’t copy correctly… I had .basics.ics instead of .basic.ics made the change it worked. Thanks for the help :tired_face:
                      You’re welcome. We’ve all been there. I certainly have been.
                        castletonroad @andrewchumchal
                        @andrewchumchal
                        Thanks - I was stupidly omitting the ‘,’ after the ‘{’
