    Problems with my Config file
    12 Posts 4 Posters 3.8k Views 4 Watching
    • O Offline
      Omensch
      well I don’t know what this really means.
      do you have an idea?
      pi@raspberrypi:~ $ npm run config:check
      npm ERR! Linux 4.4.50-v7+
      npm ERR! argv "/usr/bin/node" "/usr/bin/npm" "run" "config:check"
      npm ERR! node v6.17.1
      npm ERR! npm  v3.10.10
      npm ERR! code ENOENT
      npm ERR! errno -2
      npm ERR! syscall open
      npm ERR! enoent ENOENT: no such file or directory, open '/home/pi/package.json'
      npm ERR! enoent This is most likely not a problem with npm itself
      npm ERR! enoent and is related to npm not being able to find a file.
      npm ERR! enoent
      npm ERR!     /home/pi/npm-debug.log
      • O Offline
        Omensch @EdO
        @EdO my problem is that when I run MM, it sais: please create config file
          sdetweil @Omensch
          @Omensch please, run that in the MagicMirror folder
            sdetweil @Omensch
            @Omensch I ran config:check and don’t see any errors…
            what problem are u having?
            • E Offline
              EdO
              I’m not seeing anything jump out at me though I’m not familiar with all of your modules. If the config:check doesn’t show any errors, then you need to go through each module definition to make sure it is correct.
              You can go through each one checking the documentation as you go or you can do what I’ve done. When I ran into a similar problem I commented out every module except one. Then one at a time I restarted MM to see if that module was defined properly until I found the offending module. Once you know the one that is causing problems, you will need to pull up the documentation for it to find out what is wrong.
              When you find the offending module, now you need to check to see what is wrong with that module definition. Chances are it’s a parameter that is misspelled or not applicable or specified incorrectly.
                sdetweil @Omensch
                @Omensch also, how did u do the setup of MagicMirror?
                Manually, or with my automated install script?
                From here
                • O Offline
                  Omensch @EdO
                  @EdO thanks I’ll try that
                  • O Offline
                    Omensch @sdetweil
                    @sdetweil with the command from the website of MagicMirror
                    S Mykle1M 2 Replies Last reply Reply Quote 0
                      sdetweil @Omensch
                      @Omensch the old installer?
                      try the new one, rename the MagicMirror folder out of the way
                      then execute this from a terminal window or ssh session
                      bash -c "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/raspberry.sh)"
                        Mykle1 Project Sponsor Module Developer @Omensch
                        @Omensch
                        Save yourself a lot of time and trouble and follow @sdetweil’s suggestion.
