    npm ERR! Can't install MagicMirror on my Raspberry pi 3
    11 Posts 2 Posters 3.3k Views 2 Watching
    • L Offline
      lusiess01
      • L Offline
        lusiess01 @sdetweil
        unfortunately i get the same error
        pi@raspberrypi:~ $ bash -c "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/raspberry.sh)"
        $$$\    $$$ |                    \__|          $$$\    $$$ |\__|                                        $$  __$$\
        $$$$\  $$$$ | $$$$$$\   $$$$$$\  $$\  $$$$$$$\ $$$$\  $$$$ |$$\  $$$$$$\   $$$$$$\   $$$$$$\   $$$$$$\  \__/  $$ |
        $$\$$\$$ $$ | \____$$\ $$  __$$\ $$ |$$  _____|$$\$$\$$ $$ |$$ |$$  __$$\ $$  __$$\ $$  __$$\ $$  __$$\  $$$$$$  |
        $$ \$$$  $$ | $$$$$$$ |$$ /  $$ |$$ |$$ /      $$ \$$$  $$ |$$ |$$ |  \__|$$ |  \__|$$ /  $$ |$$ |  \__|$$  ____/
        $$ |\$  /$$ |$$  __$$ |$$ |  $$ |$$ |$$ |      $$ |\$  /$$ |$$ |$$ |      $$ |      $$ |  $$ |$$ |      $$ |
        $$ | \_/ $$ |\$$$$$$$ |\$$$$$$$ |$$ |\$$$$$$$\ $$ | \_/ $$ |$$ |$$ |      $$ |      \$$$$$$  |$$ |      $$$$$$$$\
        \__|     \__| \_______| \____$$ |\__| \_______|\__|     \__|\__|\__|      \__|       \______/ \__|      \________|
                                \______/
        install log being saved to /home/pi/install.log
        Updating packages ...
        Installing helper tools ...
        Minimum Node version: v10.1.0
        Installed Node version: v10.19.0
        No Node.js upgrade necessary.
        Minimum npm version: V6.0.0
        Installed npm version: V6.13.4
        No npm upgrade necessary.
        Cloning MagicMirror ...
        Klone nach 'MagicMirror' ...
        remote: Enumerating objects: 331, done.
        remote: Counting objects: 100% (331/331), done.
        remote: Compressing objects: 100% (295/295), done.
        remote: Total 331 (delta 42), reused 194 (delta 23), pack-reused 0
        Empfange Objekte: 100% (331/331), 676.44 KiB | 1.74 MiB/s, Fertig.
        Löse Unterschiede auf: 100% (42/42), Fertig.
        Cloning MagicMirror Done!
        Installing dependencies ...
        npm WARN deprecated time-grunt@2.0.0: Deprecated because Grunt is practically unmaintained. Move on to something better. This package will continue to work with Grunt v1, but it will not receive any updates.
        npm WARN deprecated @types/vfile-message@2.0.0: This is a stub types definition. vfile-message provides its own type definitions, so you do not need this installed.
        npm WARN tarball cached data for qs@6.7.0 (sha512-VCdBRNFTX1fyE7Nb6FYoURo/SPe62QCaAyzJvUjwRaIsc+NePBEniHlvxFmmX56+HZphIGtV0XeCirBtpDrTyQ==) seems to be corrupted. Refreshing cache.
        npm WARN tarball cached data for deep-extend@0.6.0 (sha512-LOHxIOaPYdHlJRtCQfDIVZtfw/ufM8+rVj649RIHzcm/vGwQRXFt6OPqIFWsm2XEMrNIEtWR64sY1LEKD2vAOA==) seems to be corrupted. Refreshing cache.
        npm WARN tarball cached data for delayed-stream@1.0.0 (sha1-3zrhmayt+31ECqrgsp4icrJOxhk=) seems to be corrupted. Refreshing cache.
        npm WARN tarball cached data for combined-stream@1.0.8 (sha512-FQN4MRfuJeHf7cBbBMJFXhKSDq+2kAArBlmRBvcvFE5BB1HZKXtSFASDhdlz9zOYwxh8lDdnvmMOe/+5cdoEdg==) seems to be corrupted. Refreshing cache.
        npm WARN tarball cached data for depd@1.1.2 (sha1-m81S4UwJd2PnSbJ0xDRu0uVgtak=) seems to be corrupted. Refreshing cache.
        > console-stamp@0.2.9 postinstall /home/pi/MagicMirror/node_modules/console-stamp
        > node ./msg.js
        internal/modules/cjs/loader.js:638
            throw err;
        Error: Cannot find module 'escape-string-regexp'
            at Function.Module._resolveFilename (internal/modules/cjs/loader.js:636:15)
            at Function.Module._load (internal/modules/cjs/loader.js:562:25)
            at Module.require (internal/modules/cjs/loader.js:692:17)
            at require (internal/modules/cjs/helpers.js:25:18)
            at Object.<anonymous> (/home/pi/MagicMirror/node_modules/chalk/index.js:2:26)
        npm WARN grunt-stylelint@0.13.0 requires a peer of stylelint@^12.0.0 but none is installed. You must install peer dependencies yourself.
        npm ERR! code ELIFECYCLE
        npm ERR! errno 1
        npm ERR! console-stamp@0.2.9 postinstall: `node ./msg.js`
        npm ERR! Exit status 1
        npm ERR!
        npm ERR! Failed at the console-stamp@0.2.9 postinstall script.
        npm ERR!     /home/pi/.npm/_logs/2020-02-12T17_36_30_674Z-debug.log
        Unable to install dependencies!
          sdetweil @lusiess01
          @lusiess01 ok, we have seen this only a few times… but in each case it was a problem with the memory card. stuff written doesn’t stick…
          • L Offline
            lusiess01
            So what should i do? try another memory card?
              sdetweil @lusiess01
              @lusiess01 yes
                @sdetweil I just ran the script on a pi 3, and pi 0 without problems…
                • L Offline
                  lusiess01 @sdetweil
                  Thanks a lot with the new sd card it works
                    sdetweil @lusiess01
                    @lusiess01 cool. Thanks for the feedback. Sorry about the SD card…
