    npm ERR! Can't install MagicMirror on my Raspberry pi 3
    11 Posts 2 Posters 4.2k Views 2 Watching
      sdetweil @lusiess01
      @lusiess01 the old installer is broken (how did u find that link, as its been removed for over a month now)
      use the updated one
      have to remove or rename the MagicMirror folder out of the way
      bash -c “$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/raspberry.sh)”
      L 1 Reply Last reply
      • L
        lusiess01
        • L
          lusiess01
          • L
            lusiess01 @sdetweil
            unfortunately i get the same error
            pi@raspberrypi:~ $ bash -c "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/raspberry.sh)"
            $$$\    $$$ |                    \__|          $$$\    $$$ |\__|                                        $$  __$$\
            $$$$\  $$$$ | $$$$$$\   $$$$$$\  $$\  $$$$$$$\ $$$$\  $$$$ |$$\  $$$$$$\   $$$$$$\   $$$$$$\   $$$$$$\  \__/  $$ |
            $$\$$\$$ $$ | \____$$\ $$  __$$\ $$ |$$  _____|$$\$$\$$ $$ |$$ |$$  __$$\ $$  __$$\ $$  __$$\ $$  __$$\  $$$$$$  |
            $$ \$$$  $$ | $$$$$$$ |$$ /  $$ |$$ |$$ /      $$ \$$$  $$ |$$ |$$ |  \__|$$ |  \__|$$ /  $$ |$$ |  \__|$$  ____/
            $$ |\$  /$$ |$$  __$$ |$$ |  $$ |$$ |$$ |      $$ |\$  /$$ |$$ |$$ |      $$ |      $$ |  $$ |$$ |      $$ |
            $$ | \_/ $$ |\$$$$$$$ |\$$$$$$$ |$$ |\$$$$$$$\ $$ | \_/ $$ |$$ |$$ |      $$ |      \$$$$$$  |$$ |      $$$$$$$$\
            \__|     \__| \_______| \____$$ |\__| \_______|\__|     \__|\__|\__|      \__|       \______/ \__|      \________|
                                    \______/
            install log being saved to /home/pi/install.log
            Updating packages ...
            Installing helper tools ...
            Minimum Node version: v10.1.0
            Installed Node version: v10.19.0
            No Node.js upgrade necessary.
            Minimum npm version: V6.0.0
            Installed npm version: V6.13.4
            No npm upgrade necessary.
            Cloning MagicMirror ...
            Klone nach 'MagicMirror' ...
            remote: Enumerating objects: 331, done.
            remote: Counting objects: 100% (331/331), done.
            remote: Compressing objects: 100% (295/295), done.
            remote: Total 331 (delta 42), reused 194 (delta 23), pack-reused 0
            Empfange Objekte: 100% (331/331), 676.44 KiB | 1.74 MiB/s, Fertig.
            Löse Unterschiede auf: 100% (42/42), Fertig.
            Cloning MagicMirror Done!
            Installing dependencies ...
            npm WARN deprecated time-grunt@2.0.0: Deprecated because Grunt is practically unmaintained. Move on to something better. This package will continue to work with Grunt v1, but it will not receive any updates.
            npm WARN deprecated @types/vfile-message@2.0.0: This is a stub types definition. vfile-message provides its own type definitions, so you do not need this installed.
            npm WARN tarball cached data for qs@6.7.0 (sha512-VCdBRNFTX1fyE7Nb6FYoURo/SPe62QCaAyzJvUjwRaIsc+NePBEniHlvxFmmX56+HZphIGtV0XeCirBtpDrTyQ==) seems to be corrupted. Refreshing cache.
            npm WARN tarball cached data for deep-extend@0.6.0 (sha512-LOHxIOaPYdHlJRtCQfDIVZtfw/ufM8+rVj649RIHzcm/vGwQRXFt6OPqIFWsm2XEMrNIEtWR64sY1LEKD2vAOA==) seems to be corrupted. Refreshing cache.
            npm WARN tarball cached data for delayed-stream@1.0.0 (sha1-3zrhmayt+31ECqrgsp4icrJOxhk=) seems to be corrupted. Refreshing cache.
            npm WARN tarball cached data for combined-stream@1.0.8 (sha512-FQN4MRfuJeHf7cBbBMJFXhKSDq+2kAArBlmRBvcvFE5BB1HZKXtSFASDhdlz9zOYwxh8lDdnvmMOe/+5cdoEdg==) seems to be corrupted. Refreshing cache.
            npm WARN tarball cached data for depd@1.1.2 (sha1-m81S4UwJd2PnSbJ0xDRu0uVgtak=) seems to be corrupted. Refreshing cache.
            > console-stamp@0.2.9 postinstall /home/pi/MagicMirror/node_modules/console-stamp
            > node ./msg.js
            internal/modules/cjs/loader.js:638
                throw err;
            Error: Cannot find module 'escape-string-regexp'
                at Function.Module._resolveFilename (internal/modules/cjs/loader.js:636:15)
                at Function.Module._load (internal/modules/cjs/loader.js:562:25)
                at Module.require (internal/modules/cjs/loader.js:692:17)
                at require (internal/modules/cjs/helpers.js:25:18)
                at Object.<anonymous> (/home/pi/MagicMirror/node_modules/chalk/index.js:2:26)
            npm WARN grunt-stylelint@0.13.0 requires a peer of stylelint@^12.0.0 but none is installed. You must install peer dependencies yourself.
            npm ERR! code ELIFECYCLE
            npm ERR! errno 1
            npm ERR! console-stamp@0.2.9 postinstall: `node ./msg.js`
            npm ERR! Exit status 1
            npm ERR!
            npm ERR! Failed at the console-stamp@0.2.9 postinstall script.
            npm ERR!     /home/pi/.npm/_logs/2020-02-12T17_36_30_674Z-debug.log
            Unable to install dependencies!
              sdetweil @lusiess01
              @lusiess01 ok, we have seen this only a few times… but in each case it was a problem with the memory card. stuff written doesn’t stick…
              Reply Quote 3
              • L
                lusiess01
                So what should i do? try another memory card?
                  sdetweil @lusiess01
                  @lusiess01 yes
                    @sdetweil I just ran the script on a pi 3, and pi 0 without problems…
                    • L
                      lusiess01 @sdetweil
                      Thanks a lot with the new sd card it works
                        sdetweil @lusiess01
                        @lusiess01 cool. Thanks for the feedback. Sorry about the SD card…
