    Black screen when insert https://github.com/paphko/mmm-weatherchart
    15 Posts 4 Posters 4.9k Views 4 Watching
    • lavolp3L
      lavolp3 Module Developer @prototype0815
      @prototype0815 You really need to learn how to debug/troubleshoot. There are two kinds of logs, one on the server side (in the console of your Raspberry pi) and one on the client side (in the browser).
      Open your mirror in the browser of a laptop and press F12 for dev tools. You can see on the console tab if there is an error. That’s the client side logging.
      Or go via ssh into your Raspberry pi and try dev mode. This will show you the server side logs.
      pm2 stop all
      cd ~/MagicMIrror && npm start dev
      But my bet is on the issue on github
      So try out this
      cd ~/MagicMirror/modules/MMM-weatherchart
      npm install del
      pm2 restart mm
      How to troubleshoot modules
      MMM-soccer v2, MMM-AVStock
      • prototype0815P
        prototype0815
        Yes I do! But unfortunately I’m not very familiar with linux. I’ll give it a try. Thank you
        EDIT: npm install del doesn’t work for both modules.
        EDIT2: after the installation of “del”, the MM² come up again. But there is still no weatherchart.
        EDIT3: cd ~/MagicMIrror && npm start dev
        console issued the following text --> { [Error: EACCES: permission denied, open ‘/home/pi/MagicMirror/modules/mmm-weatherchart/cache/map-1581788960498.png’]
        errno: -13,
        code: ‘EACCES’,
        syscall: ‘open’,
        path: ‘/home/pi/MagicMirror/modules/mmm-weatherchart/cache/map-1581788960498.png’ }
        I tried ‘sudo chmod -R 777 .’ inside the mmm-weatherchart module directory. But this also dosn’t help.
          A Former User
          generaly caused by
          maybe:
          1. you have installed this module with root account (by using sudo ?)
          2. git clone with sudo
          3. npm install with sudo
          notes: ALL modules and MagicMirror program sould be installed with user account (pi with raspberry)
          and NOT with root account (sudo command)
          If you install with sudo command is equal to modify or rewrite a file in windows system -> you can’t access or modify it with simple windows user account
          prototype0815P 1 Reply Last reply
            I installed this module yesterday and did a little debugging. The request for the graphic works ok (code=200), but the saving to disk doesn’t work for some reason.
            The web URL error also means not found. I am away from my system til late today before I can look at it again
              ok, we have a timing problem… the file is written, but erased
              workaround
              change these lines in node_helper.js
              			http.get(options, function (response) {
              				var pngFiles = payload.mmDir + 'modules/mmm-weatherchart/cache/*.png';
              				del([pngFiles]);
              to
              			del.sync([pngFiles]);
              • prototype0815P
                prototype0815 @Guest
                @Bugsounet ok thank you for the explanation. I tried it with and without sudo, but it doesn’t matter. I have left the last clone of the module without the sudo command.
                • prototype0815P
                  prototype0815
                  Today it was very weird, I started my MM² to reinstall the module as @Bugsounet said, and the weatherchart was visible (the first time on my MM²)! After that I decided to change the region of the weatherchart, unfortunately the weatherchart is now gone again. No region is working reliable.
                    sdetweil @prototype0815
                    @prototype0815 see the fix above
                      @prototype0815 see my reply above
                        @prototype0815 better solution, download my fork of the module with both fixes
                        stop your magicmirror
                        mv mmm-weatherchart mmm-weatherchart.original
                        git clone https://github.com/sdetweil/mmm-weatherchart.git
                        cd mmm-weatherchart
                        npm install
                        npm start
                        • prototype0815P
                          prototype0815
                          Hey guys thank you all for your help! The sdetweil fork is working very well if “del” is installed too.
                          :handshake: :thumbs_up: great community
                            @prototype0815 said in Black screen when insert https://github.com/paphko/mmm-weatherchart:
                            what does that mean? del was added to the package.json file and should have been installed when u did the new npm install after cloning my repo…
                              "dependencies": {
                                "del": "^5.1.0",
                                "request": "latest"
                            • prototype0815P
                              prototype0815
                              I did exactly what you had written, but the weatherchart didnt work.
                              I had to install “del” separately after --> “cloning your repo and use npm install”
                                @prototype0815 thx… weird…
                                thats the whole point the dependencies section
