    Black screen when insert https://github.com/paphko/mmm-weatherchart
    15 Posts 4 Posters 4.9k Views 4 Watching
      I installed this module yesterday and did a little debugging. The request for the graphic works ok (code=200), but the saving to disk doesn’t work for some reason.
      The web URL error also means not found. I am away from my system til late today before I can look at it again
        ok, we have a timing problem… the file is written, but erased
        workaround
        change these lines in node_helper.js
        			http.get(options, function (response) {
        				var pngFiles = payload.mmDir + 'modules/mmm-weatherchart/cache/*.png';
        				del([pngFiles]);
        to
        			del.sync([pngFiles]);
        • prototype0815P
          prototype0815 @Guest
          @Bugsounet ok thank you for the explanation. I tried it with and without sudo, but it doesn’t matter. I have left the last clone of the module without the sudo command.
          • prototype0815P
            prototype0815
            Today it was very weird, I started my MM² to reinstall the module as @Bugsounet said, and the weatherchart was visible (the first time on my MM²)! After that I decided to change the region of the weatherchart, unfortunately the weatherchart is now gone again. No region is working reliable.
              sdetweil @prototype0815
              @prototype0815 see the fix above
                @prototype0815 see my reply above
                  @prototype0815 better solution, download my fork of the module with both fixes
                  stop your magicmirror
                  cd ~/MagicMirror/modules
                  mv mmm-weatherchart mmm-weatherchart.original
                  git clone https://github.com/sdetweil/mmm-weatherchart.git
                  cd mmm-weatherchart
                  npm install
                  npm start
                  • prototype0815P
                    prototype0815
                    Hey guys thank you all for your help! The sdetweil fork is working very well if “del” is installed too.
                    :handshake: :thumbs_up: great community
                      @prototype0815 said in Black screen when insert https://github.com/paphko/mmm-weatherchart:
                      what does that mean? del was added to the package.json file and should have been installed when u did the new npm install after cloning my repo…
                        "dependencies": {
                          "del": "^5.1.0",
                          "request": "latest"
                      • prototype0815P
                        prototype0815
                        I did exactly what you had written, but the weatherchart didnt work.
                        I had to install “del” separately after --> “cloning your repo and use npm install”
                          @prototype0815 thx… weird…
                          thats the whole point the dependencies section
