    Black screen when insert https://github.com/paphko/mmm-weatherchart
    15 Posts 4 Posters 4.7k Views 4 Watching
      prototype0815
      Hey folks,
      I have updated my whole MM-SD-Card to a new “Raspbian Buster with desktop and recommended software” and also up to MM². I got everything to work except the weatherchart of paphko (https://github.com/paphko/mmm-weatherchart). If I put the module inside config.js the MM will not come up again. the monitor stays completely black (irrelevant to mention that I tried also the default module “code” :expressionless_face: ). By the way, its possible to kill the pm2 prcoess with CTRL+Q.
      Then I tried the fork of that weatherchart-module from szech (https://github.com/szech/mmm-weatherchart). So I decided to rename the paphko-weatherchart-module-folder and to install the szech one at the correct location (/home/pi/MagicMirror/modules/mmm-weatherchart/). First I tried the default module-code and (a little success :smiling_face_with_open_mouth_smiling_eyes: ) the MM² came up again!
      But without any weatherchart :sleepy_face: . So I decided to alter the module-config to my own settings, but nothing changed. Then I have tried some different locations for the weatherchart module, but nothing worked. The MM² shows all modules but not the desired weatherchart.
      However, one thing was noticed, as I set the same location as the newsfeed module (region = bottom_bar) the newsfeed appeared two inches higher than before :hushed_face: . So I guess something took that space below the newsfeed. I suspect that is the szech mmm-weatherchart, but a kind of invisible.
      Thx in advance, I appreciate your help. :smiling_face_with_smiling_eyes:
      • lavolp3L Offline
        lavolp3 Module Developer @prototype0815
        @prototype0815 You really need to learn how to debug/troubleshoot. There are two kinds of logs, one on the server side (in the console of your Raspberry pi) and one on the client side (in the browser).
        Open your mirror in the browser of a laptop and press F12 for dev tools. You can see on the console tab if there is an error. That’s the client side logging.
        Or go via ssh into your Raspberry pi and try dev mode. This will show you the server side logs.
        pm2 stop all
        cd ~/MagicMIrror && npm start dev
        But my bet is on the issue on github
        So try out this
        cd ~/MagicMirror/modules/MMM-weatherchart
        npm install del
        pm2 restart mm
        How to troubleshoot modules
        MMM-soccer v2, MMM-AVStock
          prototype0815
          Yes I do! But unfortunately I’m not very familiar with linux. I’ll give it a try. Thank you
          EDIT: npm install del doesn’t work for both modules.
          EDIT2: after the installation of “del”, the MM² come up again. But there is still no weatherchart.
          EDIT3: cd ~/MagicMIrror && npm start dev
          console issued the following text --> { [Error: EACCES: permission denied, open ‘/home/pi/MagicMirror/modules/mmm-weatherchart/cache/map-1581788960498.png’]
          errno: -13,
          code: ‘EACCES’,
          syscall: ‘open’,
          path: ‘/home/pi/MagicMirror/modules/mmm-weatherchart/cache/map-1581788960498.png’ }
          I tried ‘sudo chmod -R 777 .’ inside the mmm-weatherchart module directory. But this also dosn’t help.
            A Former User
            generaly caused by
            maybe:
            1. you have installed this module with root account (by using sudo ?)
            2. git clone with sudo
            3. npm install with sudo
            notes: ALL modules and MagicMirror program sould be installed with user account (pi with raspberry)
            and NOT with root account (sudo command)
            If you install with sudo command is equal to modify or rewrite a file in windows system -> you can’t access or modify it with simple windows user account
              I installed this module yesterday and did a little debugging. The request for the graphic works ok (code=200), but the saving to disk doesn’t work for some reason.
              The web URL error also means not found. I am away from my system til late today before I can look at it again
                ok, we have a timing problem… the file is written, but erased
                workaround
                change these lines in node_helper.js
                			http.get(options, function (response) {
                				var pngFiles = payload.mmDir + 'modules/mmm-weatherchart/cache/*.png';
                				del([pngFiles]);
                to
                			del.sync([pngFiles]);
                  prototype0815 @Guest
                  @Bugsounet ok thank you for the explanation. I tried it with and without sudo, but it doesn’t matter. I have left the last clone of the module without the sudo command.
                    prototype0815
                    Today it was very weird, I started my MM² to reinstall the module as @Bugsounet said, and the weatherchart was visible (the first time on my MM²)! After that I decided to change the region of the weatherchart, unfortunately the weatherchart is now gone again. No region is working reliable.
                      sdetweil @prototype0815
                      @prototype0815 see the fix above
                        @prototype0815 see my reply above
                          @prototype0815 better solution, download my fork of the module with both fixes
                          stop your magicmirror
                          mv mmm-weatherchart mmm-weatherchart.original
                          git clone https://github.com/sdetweil/mmm-weatherchart.git
                          cd mmm-weatherchart
                          npm install
                          npm start
                            prototype0815
                            Hey guys thank you all for your help! The sdetweil fork is working very well if “del” is installed too.
                            :handshake: :thumbs_up: great community
                              @prototype0815 said in Black screen when insert https://github.com/paphko/mmm-weatherchart:
                              what does that mean? del was added to the package.json file and should have been installed when u did the new npm install after cloning my repo…
                                "dependencies": {
                                  "del": "^5.1.0",
                                  "request": "latest"
                                prototype0815
                                I did exactly what you had written, but the weatherchart didnt work.
                                I had to install “del” separately after --> “cloning your repo and use npm install”
                                  @prototype0815 thx… weird…
                                  thats the whole point the dependencies section
