    MMM-SmartWebDisplay : display web contents (including YouTube) on your MM
    89 Posts 35 Posters 135.0k Views 38 Watching
    • SergeS Offline
      Serge
      Also, as an idea for the function “continuous play”. Function will allow module to pause current video when the screen turned off by PIR and continue to play it again when screen turned on by PIR.
      Now video starts from the beginning each time the module getting an user presence notification.
        AgP42 Project Sponsor Module Developer @Serge
        Hello everyone and happy new year !
        @Serge said in MMM-SmartWebDisplay : display web contents (including YouTube) on your MM:
        Is it possible to add time delay in config.js file in order to make more easier integration of PIR modules and SWD module?
        Also, it would be good to have the ability to switch-off the Presence notification dependency.
        Sometime I just want to run youtube (say classic music) even when the display is turned off (as a background music)
        Such command/config will let do that.
        It would have been better to change the behavior of the PIR module, but it is also possible to change it on the SWD module and yes it also can be possible to totally deactivate it to let the youtube music run in background.
        I will try to find some time this week to add those modifications.
        I already answer this several time and it is even written on the documentation, the module itself don’t have access to the video, so it is not possible to play/pause the video itself. To do so I should have implemented the youtube API (and all other video api !). The play/pause function is about the url rotation and not about the video playing itself. And this is something I unfortunately cannot change… sorry !
        SergeS 1 Reply Last reply Reply Quote 1
        • SergeS Offline
          Serge @AgP42
          @AgP42 said in MMM-SmartWebDisplay : display web contents (including YouTube) on your MM:
          I have made some work to make this happen.
          See my pull request https://github.com/AgP42/MMM-SmartWebDisplay/pull/11/commits/38684b4349f073041983bd11bcfcbe151063fc6a
            @Serge
            Thank you for your work, I just review it on Github and merge your code. It is now available for everyone !
              BeatIdo
              Has anyone tried to use MMM-SmartWebDisplay module configured in fullscreen-above region ?
              I’ve made several tests and each time I try to use a fullscreen region it displays nothing.
              I’ll be glad to run some test or other configuration if you’ve got any idea 🙂
              Regards.
                CutiePatootie
                Hey AgP42, awesome job on this. Is there any way to remove or block an element from the url referenced?
                Edit: Nevermind. I don’t think it’s possible and just as easy to download the site, host it on the pi itself, then reference the site in the module.
                  pdawg17
                  I am trying to use this module but no matter what URL I use, nothing shows up on my MM and when looking at it from my browser it says the URL “refused to connect”. Any ideas?
                    sdetweil @pdawg17
                    @pdawg17 said in MMM-SmartWebDisplay : display web contents (including YouTube) on your MM:
                    what is ‘it’?? MM or the URL U are trying to view?
                      pdawg17 @sdetweil
                      @sdetweil ‘It’ would be the MM setup from my browser: MM_IPaddress:8080. Thanks!
                        sdetweil @pdawg17
                        @pdawg17 in your config.js, more than likely u have
                        address: 'localhost',
                        ipwhiteList:[.......]
                        this means that ONLY apps INSIDE the mirror machine can access the mirror app (usually a mirror hangs on the wall and no-one accesses it (or should) )…
                        u need to allow outside access
                        address="0.0.0.0",
                        ipWhiteList:[],
                        allow anyone to access on any network interface (wifi or lan if both enabled)
                          pdawg17
                          @sdetweil said in MMM-SmartWebDisplay : display web contents (including YouTube) on your MM:
                          address="0.0.0.0",
                          ipWhiteList:[],
                          Unfortunately, your solution is what I have already :(
                            sdetweil @pdawg17
                            @pdawg17 that doesn’t sound right…
                            MM_IPaddress:8080
                            that should bring up the MM interface
                            refused to connect”
                            could also mean wrong ip address
                              pdawg17
                              MM_IPaddress:8080
                              refused to connect”
                              I’m sorry. What I mean is the MMM-SmartWebDisplay part of the Mirror gives that error. I can access the mirror from a browser just fine.
                                sdetweil @pdawg17
                                @pdawg17 ok, I don’t know the module, but I ‘think’ it displays ANOTHER web page ON the MM screen… (according to the readme)
                                MMM-SmartWebDisplay is a module for MagicMirror². It allow to display any web content to your MagicMirror and interact with it(the web content) through notifications or with MMM-TelegramBot.
                                so, I’m not sure U access it via the MM web page url…
                                now, remote control is also not a web page access tool…
                                you can SEND it requests and it will do the action…
                                  pdawg17 @sdetweil
                                  Ok I’ve got it working but not with the website I want to use. I can get YouTube videos to work now but not this site:
                                  https://www.wunderground.com/dashboard/pws/KCASANMA271
                                    CutiePatootie
                                    So last night, I had this module running perfectly along with all my other modules. This morning, I’m getting errors on all the site images stating “This browser does not support svg”. No images display and they are a mixture of svgs and pngs.
                                    I’d made a copy of an existing website using HTTrack and I’m hosting it locally using Apache2. I’m not familiar with how MagicMirror renders pages so I’m not really sure where to look or what to change to resolve this issue.
                                    Edit: Not sure how, but the referring page was one level deeper and had to be referenced correctly. Fixed!
                                    • E Offline
                                      Egnos
                                      Hello everybody,
                                      I am going crazy to find ways to disable audio from this module.
                                      It’s possible?
                                      If yes, how?
                                      Thank you.
                                        costascontis
                                        hello,is there a way to resize iframe and still shows all of my camera’s screen area?If i resize iframe window using config it just crop my camera’s view.My cam’s screen is 640x480 and to view it all i have to set the iframe to 640x480 too.Thats to big for my mirror…
                                          AgP42 Project Sponsor Module Developer @Egnos
                                          @Egnos said in MMM-SmartWebDisplay : display web contents (including YouTube) on your MM:
                                          Hello everybody,
                                          It’s possible?
                                          If yes, how?
                                          Thank you.
                                          from the module itself : no it is not managed.
                                          But it depend the kind of source you are playing, if it is YouTube, you just have to click on the “Mute” button on the YouTube interface !
                                            maxxxxpower @costascontis
                                            @costascontis @AgP42 Same issue here. Adjusting any of the variables, either by percent or pixel, just seems to resize the window, but not the feed itself. It doesn’t zoom accordingly.
                                            • 4 / 5
