    MMM-SmartWebDisplay : display web contents (including YouTube) on your MM
    89 Posts 35 Posters 134.4k Views 38 Watching
    • T Offline
      ttarzan
      Hello everyone, I have 2 instances of the module MMM-SmartWebDisplay running. This works well.
      I also use MMM-Pages to rotate contents of the screen. I would also like to rotate one instance of the module MMM-SmartWebDisplay against one with another module. But how do I address it if I have 2 instances? Both instances have the same module name and are only different in size, position and content.
        chassain 0
        hello,
        Rename the folder MMM-SmartWebDisplay2…then the MMM-SmartWebDisplay2.js and inside Module.register(“MMM-SmartWebDisplay2” like this
        and call MMM-SmartWebDisplay on page 1 and MMM-SmartWebDisplay2 on page 2
          sdetweil @Alain
          @Alain in the future, please use the markup wrapper for config or code entries…
          paste the text, select it, and hit the </> button
          • T Offline
            ttarzan @chassain 0
            @chassain-0 Thanks, that works. You have to change the name of the module in the js file to “MMM-SmartWebDisplay2”. But I noticed that after each change of the modules the URL is reloaded, although I set updateInterval to 0. So the background is briefly white, which I don’t like. So I leave that with the rotation. Thanks for the help anyway.
            • SergeS Offline
              Serge @AgP42
              @AgP42 said in MMM-SmartWebDisplay : display web contents (including YouTube) on your MM:
              Hi @Alain,
              first please remove all your apikey on your post before :winking_face:
              I see that you also use the MMM-PIR-sensor module, with a delay of 100s, this is probably the root cause of the strange behavior that you saw.
              Let me explains you my analysis :
              Good luck and let me know if you still face issues,
              Bye
              AgP42
              Exactly the same behavior that my mirror shows.
              I have a PIR sensor and i am using https://github.com/paviro/MMM-PIR-Sensor
              I have 60 sec powersaving delay for display turning-off, but user presence is translated as soon as the is detected by sensor. This cause some inconsistencies.
              Is it possible to add time delay in config.js file in order to make more easier integration of PIR modules and SWD module?
              Also, it would be good to have the ability to switch-off the Presence notification dependency.
              Sometime I just want to run youtube (say classic music) even when the display is turned off (as a background music)
              Such command/config will let do that.
              • SergeS Offline
                Serge
                Also, as an idea for the function “continuous play”. Function will allow module to pause current video when the screen turned off by PIR and continue to play it again when screen turned on by PIR.
                Now video starts from the beginning each time the module getting an user presence notification.
                  AgP42 Project Sponsor Module Developer @Serge
                  Hello everyone and happy new year !
                  @Serge said in MMM-SmartWebDisplay : display web contents (including YouTube) on your MM:
                  It would have been better to change the behavior of the PIR module, but it is also possible to change it on the SWD module and yes it also can be possible to totally deactivate it to let the youtube music run in background.
                  I will try to find some time this week to add those modifications.
                  I already answer this several time and it is even written on the documentation, the module itself don’t have access to the video, so it is not possible to play/pause the video itself. To do so I should have implemented the youtube API (and all other video api !). The play/pause function is about the url rotation and not about the video playing itself. And this is something I unfortunately cannot change… sorry !
                  SergeS 1 Reply Last reply Reply Quote 1
                  • SergeS Offline
                    Serge @AgP42
                    I have made some work to make this happen.
                    See my pull request https://github.com/AgP42/MMM-SmartWebDisplay/pull/11/commits/38684b4349f073041983bd11bcfcbe151063fc6a
                      @Serge
                      Thank you for your work, I just review it on Github and merge your code. It is now available for everyone !
                        BeatIdo
                        Has anyone tried to use MMM-SmartWebDisplay module configured in fullscreen-above region ?
                        I’ve made several tests and each time I try to use a fullscreen region it displays nothing.
                        I’ll be glad to run some test or other configuration if you’ve got any idea 🙂
                        Regards.
                          CutiePatootie
                          Hey AgP42, awesome job on this. Is there any way to remove or block an element from the url referenced?
                          Edit: Nevermind. I don’t think it’s possible and just as easy to download the site, host it on the pi itself, then reference the site in the module.
                            pdawg17
                            I am trying to use this module but no matter what URL I use, nothing shows up on my MM and when looking at it from my browser it says the URL “refused to connect”. Any ideas?
                              sdetweil @pdawg17
                              @pdawg17 said in MMM-SmartWebDisplay : display web contents (including YouTube) on your MM:
                              what is ‘it’?? MM or the URL U are trying to view?
                                pdawg17 @sdetweil
                                @sdetweil ‘It’ would be the MM setup from my browser: MM_IPaddress:8080. Thanks!
                                  sdetweil @pdawg17
                                  @pdawg17 in your config.js, more than likely u have
                                  address: 'localhost',
                                  ipwhiteList:[.......]
                                  this means that ONLY apps INSIDE the mirror machine can access the mirror app (usually a mirror hangs on the wall and no-one accesses it (or should) )…
                                  u need to allow outside access
                                  address="0.0.0.0",
                                  ipWhiteList:[],
                                  allow anyone to access on any network interface (wifi or lan if both enabled)
                                    pdawg17
                                    @sdetweil said in MMM-SmartWebDisplay : display web contents (including YouTube) on your MM:
                                    address="0.0.0.0",
                                    ipWhiteList:[],
                                    Unfortunately, your solution is what I have already :(
                                      sdetweil @pdawg17
                                      @pdawg17 that doesn’t sound right…
                                      MM_IPaddress:8080
                                      that should bring up the MM interface
                                      refused to connect”
                                      could also mean wrong ip address
                                        pdawg17
                                        MM_IPaddress:8080
                                        refused to connect”
                                        I’m sorry. What I mean is the MMM-SmartWebDisplay part of the Mirror gives that error. I can access the mirror from a browser just fine.
                                          sdetweil @pdawg17
                                          @pdawg17 ok, I don’t know the module, but I ‘think’ it displays ANOTHER web page ON the MM screen… (according to the readme)
                                          MMM-SmartWebDisplay is a module for MagicMirror². It allow to display any web content to your MagicMirror and interact with it(the web content) through notifications or with MMM-TelegramBot.
                                          so, I’m not sure U access it via the MM web page url…
                                          now, remote control is also not a web page access tool…
                                          you can SEND it requests and it will do the action…
                                            pdawg17 @sdetweil
                                            Ok I’ve got it working but not with the website I want to use. I can get YouTube videos to work now but not this site:
                                            https://www.wunderground.com/dashboard/pws/KCASANMA271
                                            • 4 / 5
