    MMM-GoogleMapsTraffic
    87 Posts 27 Posters 95.4k Views 28 Watching
    • E
      Egnos @sdetweil
      @sdetweil said in MMM-GoogleMapsTraffic:
      @Egnos from here, right?
      https://github.com/sdetweil/MMM-GoogleMapsTraffic
      Hi @sdetweil ,
      using the second link the module starts but I see this message:
      “This page didn’t load Google Maps correctly”
      The screen shot
      https://ibb.co/bm6BqJ6
      Can you help me?
      Thanks.
        sdetweil @Egnos
        @Egnos are u doing this over vnc? I don’t see that problem using the display connected to the pi
        • E
          Egnos @sdetweil
          Virtualize Raspbian with Virtualbox…
            sdetweil @Egnos
            @Egnos running on Intel?
            I use VMware Workstation mostly.
            But virtual box for a couple systems
            • E
              Egnos @sdetweil
              @sdetweil are there problems with Magic Mirror if using VirtualBox?
                sdetweil @Egnos
                @Egnos I don’t know. Haven’t tried that
                • E
                  Egnos @sdetweil
                  What does it mean when this message appears:
                    sdetweil @Egnos
                    @Egnos I do not know
                      sdetweil @Egnos
                      @Egnos sounds like u didn’t setup the API key
                      https://www.google.com/amp/s/www.liontreegroup.com/tips-and-tricks/fixing-the-this-page-cant-load-google-maps-correctly-error/amp/
                      • E
                        Egnos
                        Hi @sdetweil
                        It would seem that to have a valid API Key you need to “Enabling billing on Google Cloud Platform …”.
                        To receive the API Key, you need to enter a valid credit card number.
                        Did you do this too?
                        Do you agree?
                        Thanks.
                          sdetweil @Egnos
                          @Egnos yes. The apis are not free, altho our usage is typically below the 1st tier charge level
                          • E
                            Egnos @sdetweil
                            @sdetweil so you also entered your credit card?
                            How many accesses does this module make per day?
                              sdetweil @Egnos
                              @Egnos yes, credit card. I don’t know number of accesses. U can control that I think. Not my module.
                              Readme says default is once every 15 minutes
                              updateInterval
                              So, 96 times per day
                                MisterT
                                Hi, i just a question about MMM-GoogleMapsTraffic and google console plateform. My period of free account is finished so my apy key is not usable. If i understand the only solution to obtain a valid api key with google maps is to pay ?
                                An other question is if the result is the same with api key for MMM-Google photos and MMM- MK2 ?
                                Thanks for next answers
                                • W
                                  wilbur245 @knubbl
                                  @knubbl
                                  Hello for me the map is shown briefly then a picture with ops went wrong java script console ???
                                  Api key is active. Account opened. api embed map
                                  W S 2 Replies Last reply Reply Quote 0
                                  • W
                                    wilbur245 @wilbur245
                                      sdetweil @wilbur245
                                      @wilbur245 thought u needed JavaScript maps API.
                                        banbutcher
                                        question… as im running GoogleMapsTraffic as a full screen page i was wondering if its possible to show the quickest routes on the map between an origin and destination? also using MMM-MyCommute.
                                          banbutcher
                                          hi folks,
                                          ive an issue with googlemapstraffic,and hotword… if i leave out the api key it hotword works fine except i get this page cant load google maps corrctly, whereas if i put in the api key goglemapstraffic works fine but hotword wont work properly, when i open dev i get this error when i try to use hotword
                                          MMM-Hotword.js:205 Uncaught TypeError: console.log is not a function
                                              at Class.doCommand (MMM-Hotword.js:205)
                                              at Class.socketNotificationReceived (MMM-Hotword.js:159)
                                              at module.js:246
                                              at r.<anonymous> (socketclient.js:25)
                                              at r.emit (index.js:83)
                                              at r.onevent (index.js:83)
                                              at r.MMSocket.self.socket.onevent (socketclient.js:19)
                                              at r.onpacket (index.js:83)
                                              at r.<anonymous> (index.js:83)
                                          please help :(
                                            banbutcher @banbutcher
                                            @banbutcher
                                            so i looked back a couple of pages on the MMM-AssistantMk2 page and found out that the version of GoogleMapsTraffic (vicmora) had a bug in it so ive updated to @sdetweil version and its working fine now thanks for the fix @sdetweil
                                            • 4 / 5
