    MMM-GoogleMapsTraffic
    87 Posts 27 Posters 95.4k Views 28 Watching
      sdetweil @Egnos
      @Egnos yes. The apis are not free, altho our usage is typically below the 1st tier charge level
      • E
        Egnos @sdetweil
        @sdetweil so you also entered your credit card?
        How many accesses does this module make per day?
          sdetweil @Egnos
          @Egnos yes, credit card. I don’t know number of accesses. U can control that I think. Not my module.
          Readme says default is once every 15 minutes
          updateInterval
          So, 96 times per day
            MisterT
            Hi, i just a question about MMM-GoogleMapsTraffic and google console plateform. My period of free account is finished so my apy key is not usable. If i understand the only solution to obtain a valid api key with google maps is to pay ?
            An other question is if the result is the same with api key for MMM-Google photos and MMM- MK2 ?
            Thanks for next answers
            • W
              wilbur245 @knubbl
              @knubbl
              Hello for me the map is shown briefly then a picture with ops went wrong java script console ???
              Api key is active. Account opened. api embed map
              W S 2 Replies Last reply Reply Quote 0
              • W
                wilbur245 @wilbur245
                  sdetweil @wilbur245
                  @wilbur245 thought u needed JavaScript maps API.
                    banbutcher
                    question… as im running GoogleMapsTraffic as a full screen page i was wondering if its possible to show the quickest routes on the map between an origin and destination? also using MMM-MyCommute.
                      banbutcher
                      hi folks,
                      ive an issue with googlemapstraffic,and hotword… if i leave out the api key it hotword works fine except i get this page cant load google maps corrctly, whereas if i put in the api key goglemapstraffic works fine but hotword wont work properly, when i open dev i get this error when i try to use hotword
                      MMM-Hotword.js:205 Uncaught TypeError: console.log is not a function
                          at Class.doCommand (MMM-Hotword.js:205)
                          at Class.socketNotificationReceived (MMM-Hotword.js:159)
                          at module.js:246
                          at r.<anonymous> (socketclient.js:25)
                          at r.emit (index.js:83)
                          at r.onevent (index.js:83)
                          at r.MMSocket.self.socket.onevent (socketclient.js:19)
                          at r.onpacket (index.js:83)
                          at r.<anonymous> (index.js:83)
                      please help :(
                        banbutcher @banbutcher
                        @banbutcher
                        so i looked back a couple of pages on the MMM-AssistantMk2 page and found out that the version of GoogleMapsTraffic (vicmora) had a bug in it so ive updated to @sdetweil version and its working fine now thanks for the fix @sdetweil
                        • 5 / 5
