    MMM-GoogleMapsTraffic
    87 Posts 27 Posters 91.3k Views 28 Watching
      sdetweil @Egnos
      @Egnos I don’t know. Haven’t tried that
      • E Offline
        Egnos @sdetweil
        What does it mean when this message appears:
        “This page didn’t load Google Maps correctly”
          sdetweil @Egnos
          @Egnos I do not know
            sdetweil @Egnos
            @Egnos sounds like u didn’t setup the API key
            https://www.google.com/amp/s/www.liontreegroup.com/tips-and-tricks/fixing-the-this-page-cant-load-google-maps-correctly-error/amp/
            • E Offline
              Egnos
              Hi @sdetweil
              It would seem that to have a valid API Key you need to “Enabling billing on Google Cloud Platform …”.
              To receive the API Key, you need to enter a valid credit card number.
              Did you do this too?
              Do you agree?
              Thanks.
                sdetweil @Egnos
                @Egnos yes. The apis are not free, altho our usage is typically below the 1st tier charge level
                • E Offline
                  Egnos @sdetweil
                  @sdetweil so you also entered your credit card?
                  How many accesses does this module make per day?
                    sdetweil @Egnos
                    @Egnos yes, credit card. I don’t know number of accesses. U can control that I think. Not my module.
                    Readme says default is once every 15 minutes
                    updateInterval
                    So, 96 times per day
                      MisterT
                      Hi, i just a question about MMM-GoogleMapsTraffic and google console plateform. My period of free account is finished so my apy key is not usable. If i understand the only solution to obtain a valid api key with google maps is to pay ?
                      An other question is if the result is the same with api key for MMM-Google photos and MMM- MK2 ?
                      Thanks for next answers
                      • W Offline
                        wilbur245 @knubbl
                        @knubbl
                        Hello for me the map is shown briefly then a picture with ops went wrong java script console ???
                        Api key is active. Account opened. api embed map
                        W S 2 Replies Last reply Reply Quote 0
                        • W Offline
                          wilbur245 @wilbur245
                            sdetweil @wilbur245
                            @wilbur245 thought u needed JavaScript maps API.
                              banbutcher
                              question… as im running GoogleMapsTraffic as a full screen page i was wondering if its possible to show the quickest routes on the map between an origin and destination? also using MMM-MyCommute.
                                banbutcher
                                hi folks,
                                ive an issue with googlemapstraffic,and hotword… if i leave out the api key it hotword works fine except i get this page cant load google maps corrctly, whereas if i put in the api key goglemapstraffic works fine but hotword wont work properly, when i open dev i get this error when i try to use hotword
                                MMM-Hotword.js:205 Uncaught TypeError: console.log is not a function
                                    at Class.doCommand (MMM-Hotword.js:205)
                                    at Class.socketNotificationReceived (MMM-Hotword.js:159)
                                    at module.js:246
                                    at r.<anonymous> (socketclient.js:25)
                                    at r.emit (index.js:83)
                                    at r.onevent (index.js:83)
                                    at r.MMSocket.self.socket.onevent (socketclient.js:19)
                                    at r.onpacket (index.js:83)
                                    at r.<anonymous> (index.js:83)
                                please help :(
                                  banbutcher @banbutcher
                                  @banbutcher
                                  so i looked back a couple of pages on the MMM-AssistantMk2 page and found out that the version of GoogleMapsTraffic (vicmora) had a bug in it so ive updated to @sdetweil version and its working fine now thanks for the fix @sdetweil
                                  • 5 / 5
