    Hello-Lucy installation troubles
    31 Posts 4 Posters 13.2k Views 4 Watching
      SSkull995
      Hello MMM community!
      Hope you can help me out:
      As already mentioned on GitHub, I am having some problems during Lucy installation. The problems rely one on the fact that some npm packages are missing and had to install manually. The second is that Lucy does not recognize my microphone, even if the pi does (alsamixer finds the card and the mic can record). I set the card as in the readme: 0,0 is the card and the device.
      No clue why this happens, why both the things happen actually.
      I also asked the holo to Mykle1, so I have a question for him: I saw you put the MM on a Windows machine. Is the AI model developed by HackeShackOfficial? I wanted the holo to make the mirror more smart, but I saw they installed it on a Mac based machine, not raspi.
      Do you think it could be set for a raspi?
      Thanks for the help, any help is much appreciated!!!
        Mykle1 Project Sponsor Module Developer @SSkull995
        @SSkull995
        Ok, and thanks for bringing your issue here. It’s just easier to troubleshoot here than github.
        After installation, did you cd Hello-Lucy/installers and then run bash dependencies.sh in your terminal? You should not have to install any dependencies manually after that.
        Did you follow the directions here?
        https://github.com/mykle1/Hello-Lucy/blob/master/piAudioSetup.md
        Please run this command in your terminal. arecord -ls and post the result here (in a code block).
        All my machines are running Ubuntu
        Lucy (the holo) is an animated gif file. It doesn’t matter what platform you are running MagicMirror on. It will work. I will supply you with the gif but I have to warn you. A Pi will struggle to run that gif smoothly, if at all, and it will certainly be to the detriment of the Pi’s performance and almost certainly create a heat issue. You will already experience some lag just running Hello-Lucy on a Pi. However, the choice is yours.
          SSkull995
          Hi Mykle!
          First, thank you for the response! Second, I just reinstalled Lucy and the whole MM from the beginning. I still get an error while launching MM with Lucy, the pocket sphinx-continuous module is missing. I tried to install it via npm, but nothing. I do not know if I need to install it in a specific directory, like the Hello-Lucy one, or not.
          For the microphone let’s see because I made a change, but until the module starts I cannot see if it is working or not.
          What do you suggest to do now? I follow the guide, step by step, I really do not know what is missing right now.
          Many thanks and have a nice day!
            sdetweil @SSkull995
            @SSkull995 pocketsphinx is installed by the installers/dependencies.sh script
            YOU have to run that manually, as the readme says
            S 3 Replies Last reply Reply Quote 0
              SSkull995 @sdetweil
              @sdetweil hey man, as I wrote I already ran the dependencies.sh in the installer directory. I have the log, everything went fine.
              Still don’t have the module in the system
                SSkull995 @sdetweil
                @sdetweil So I just ran again the installer, weird thing happens. I don’t know why, the package.json is not present in the directory. So this message comes up:
                npm WARN saveError ENOENT: no such file or directory, open ‘/root/pocketsphinx/package.json’
                npm WARN enoent ENOENT: no such file or directory, open ‘/root/pocketsphinx/package.json’
                npm WARN pocketsphinx No description
                npm WARN pocketsphinx No repository field.
                npm WARN pocketsphinx No README data
                npm WARN pocketsphinx No license field.
                That is why I don’t have it installed! Should I generate a random package.json with the npm init command?
                  SSkull995 @sdetweil
                  This is the output error when I run npm start. I generated the config.json with the npm init, no more errors during dependencies installation.
                  [17:54:16.999] [ERROR] App threw an error during load
                  [17:54:17.000] [ERROR] Error: Cannot find module ‘pocketsphinx-continuous’
                  at Module._resolveFilename (internal/modules/cjs/loader.js:602:15)
                  at Function.Module._resolveFilename (/home/pi/MM/node_modules/electron/dist/resources/electron.asar/common/reset-search-paths.js:35:12)
                  at Function.Module._resolveFilename (/home/pi/MM/node_modules/module-alias/index.js:49:29)
                  at Function.Module._load (internal/modules/cjs/loader.js:528:25)
                  at Module.require (internal/modules/cjs/loader.js:658:17)
                  at require (internal/modules/cjs/helpers.js:20:18)
                  at Object. (/home/pi/MM/modules/Hello-Lucy/node_helper.js:2:13)
                  at Object. (/home/pi/MM/modules/Hello-Lucy/node_helper.js:410:3)
                  at Module._compile (internal/modules/cjs/loader.js:711:30)
                  at Object.Module._extensions…js (internal/modules/cjs/loader.js:722:10)
                  [17:54:17.002] [LOG] Whoops! There was an uncaught exception…
                  [17:54:17.002] [ERROR] { Error: Cannot find module ‘pocketsphinx-continuous’
                  at Object.Module._extensions…js (internal/modules/cjs/loader.js:722:10) code: ‘MODULE_NOT_FOUND’ }
                  There still is this:
                  [STEP 3/5] Installing pocketsphinx | Done
                  [STEP 4/5] Exporting paths
                  [STEP 4/5] Exporting paths | Done
                  [STEP 5/5] Installing npm dependencies
                  dependencies.sh: line 89: cd: /root/MagicMirror/modules/Hello-Lucy: No such file or directory
                  Why no directory in root? Many thanks and sorry!
                    sdetweil @SSkull995
                    @SSkull995 you have to
                    cd ~/MagicMirror/modules/MMM-Hello-Lucy/installers
                    ./dependencies.sh
                      AND NOT sudo
                      And logged on as normal user, not root
                        SSkull995 @sdetweil
                        @sdetweil man, I never ran sudo.
                        And I still don’t know why the program gives me the error about the config.json file and the dependencies.sh
                        Btw, ./dependencies is no command
                        S S 2 Replies Last reply Reply Quote 0
                          SSkull995 @SSkull995
                          @SSkull995 just to be sure, I ran the program again, the installer. This time with the ./dependencies. Errors+no dependencies directory found
                            sdetweil @SSkull995
                            @SSkull995 did u look in the folder?
                            It’s ./dependencies.sh
                            The only file in the module/installers folder
                              we may have to start over, as I have no idea what ‘installer’ u have been running or how
                              rm -rf MMM-Hello-Lucy
                              Then git clone Mykles repo
                              cd MMM-Hello-Lucy
                              cd installers
                              ./dependencies.sh
                              cd ..
                              npm install
                                SSkull995 @sdetweil
                                @sdetweil actually I have dependencies.sh, because the ./ makes it invisible even if it was there. Typing ls in installers makes me see the normal dependencies.sh
                                  sdetweil @SSkull995
                                  @SSkull995 but it is not in the path, do you have to use ./ to select it
                                    From the readme
                                    Please complete all 3
                                    Open a terminal.
                                    git clone https://github.com/mykle1/Hello-Lucy into the ~/MagicMirror/modules directory
                                    Then
                                    Then
                                      SSkull995
                                      I can see I did not really explained myself, and I am sorry for that. I did the three passages of yours in the readme, and after reinstalling everything now it does not show me any error during installation! Yes!
                                      BUT, now I run MagicMirror with the module installed and put in the config.js, and this message comes up:
                                      [15:12:13.980] [ERROR] WARNING! Could not validate config file. Starting with default configuration. Please correct syntax errors at or above this line: SyntaxError: Unexpected token ] in JSON at position 6643
                                      This occurs only when I put the module in config.js, but I don’t know where the error is, what is the JSON file?
                                        @SSkull995 said in Hello-Lucy installation troubles:
                                        I see. I just did an install on a new machine and encountered the same error. I’m looking into it. Even my working Lucy installation is suffering the same error. Weird.
                                          First, forgive me. This entire issue was my fault.
                                          I recently added some defaults to the checkCommands.json file and left a trailing comma at the end of the file. I’ve corrected the problem, tested it and pushed the corrected file to the repo. To clear the SyntaxError: Unexpected token ] in JSON at position 6643 error, following this instruction.
                                          Do a git pull in the Hello-Lucy directory.
                                          Please advise on the result. :-)
                                            SSkull995 @Mykle1
                                            @Mykle1 Perfect! I will do it right now, let me just boot my raspi. Many thanks and sorry once more, I was into solving this problem, but I could not figure out where the json was ahah!
