    Hello-Lucy installation troubles
    31 Posts 4 Posters 12.0k Views 4 Watching
      Mykle1 Project Sponsor Module Developer @SSkull995
      @SSkull995
      Ok, and thanks for bringing your issue here. It’s just easier to troubleshoot here than github.
      After installation, did you cd Hello-Lucy/installers and then run bash dependencies.sh in your terminal? You should not have to install any dependencies manually after that.
      Lucy does not recognize my microphone
      Did you follow the directions here?
      https://github.com/mykle1/Hello-Lucy/blob/master/piAudioSetup.md
      Please run this command in your terminal. arecord -ls and post the result here (in a code block).
      I saw you put the MM on a Windows machine
      All my machines are running Ubuntu
      Lucy (the holo) is an animated gif file. It doesn’t matter what platform you are running MagicMirror on. It will work. I will supply you with the gif but I have to warn you. A Pi will struggle to run that gif smoothly, if at all, and it will certainly be to the detriment of the Pi’s performance and almost certainly create a heat issue. You will already experience some lag just running Hello-Lucy on a Pi. However, the choice is yours.
        SSkull995
        Hi Mykle!
        First, thank you for the response! Second, I just reinstalled Lucy and the whole MM from the beginning. I still get an error while launching MM with Lucy, the pocket sphinx-continuous module is missing. I tried to install it via npm, but nothing. I do not know if I need to install it in a specific directory, like the Hello-Lucy one, or not.
        For the microphone let’s see because I made a change, but until the module starts I cannot see if it is working or not.
        What do you suggest to do now? I follow the guide, step by step, I really do not know what is missing right now.
        Many thanks and have a nice day!
          sdetweil @SSkull995
          @SSkull995 pocketsphinx is installed by the installers/dependencies.sh script
          YOU have to run that manually, as the readme says
          S 3 Replies Last reply Reply Quote 0
            SSkull995 @sdetweil
            @sdetweil hey man, as I wrote I already ran the dependencies.sh in the installer directory. I have the log, everything went fine.
            Still don’t have the module in the system
              SSkull995 @sdetweil
              @sdetweil So I just ran again the installer, weird thing happens. I don’t know why, the package.json is not present in the directory. So this message comes up:
              npm WARN saveError ENOENT: no such file or directory, open ‘/root/pocketsphinx/package.json’
              npm WARN enoent ENOENT: no such file or directory, open ‘/root/pocketsphinx/package.json’
              npm WARN pocketsphinx No description
              npm WARN pocketsphinx No repository field.
              npm WARN pocketsphinx No README data
              npm WARN pocketsphinx No license field.
              That is why I don’t have it installed! Should I generate a random package.json with the npm init command?
                SSkull995 @sdetweil
                This is the output error when I run npm start. I generated the config.json with the npm init, no more errors during dependencies installation.
                [17:54:16.999] [ERROR] App threw an error during load
                [17:54:17.000] [ERROR] Error: Cannot find module ‘pocketsphinx-continuous’
                at Module._resolveFilename (internal/modules/cjs/loader.js:602:15)
                at Function.Module._resolveFilename (/home/pi/MM/node_modules/electron/dist/resources/electron.asar/common/reset-search-paths.js:35:12)
                at Function.Module._resolveFilename (/home/pi/MM/node_modules/module-alias/index.js:49:29)
                at Function.Module._load (internal/modules/cjs/loader.js:528:25)
                at Module.require (internal/modules/cjs/loader.js:658:17)
                at require (internal/modules/cjs/helpers.js:20:18)
                at Object. (/home/pi/MM/modules/Hello-Lucy/node_helper.js:2:13)
                at Object. (/home/pi/MM/modules/Hello-Lucy/node_helper.js:410:3)
                at Module._compile (internal/modules/cjs/loader.js:711:30)
                at Object.Module._extensions…js (internal/modules/cjs/loader.js:722:10)
                [17:54:17.002] [LOG] Whoops! There was an uncaught exception…
                [17:54:17.002] [ERROR] { Error: Cannot find module ‘pocketsphinx-continuous’
                at Object.Module._extensions…js (internal/modules/cjs/loader.js:722:10) code: ‘MODULE_NOT_FOUND’ }
                There still is this:
                [STEP 3/5] Installing pocketsphinx | Done
                [STEP 4/5] Exporting paths
                [STEP 4/5] Exporting paths | Done
                [STEP 5/5] Installing npm dependencies
                dependencies.sh: line 89: cd: /root/MagicMirror/modules/Hello-Lucy: No such file or directory
                Why no directory in root? Many thanks and sorry!
                  sdetweil @SSkull995
                  @SSkull995 you have to
                  cd ~/MagicMirror/modules/MMM-Hello-Lucy/installers
                  ./dependencies.sh
                    AND NOT sudo
                    And logged on as normal user, not root
                      SSkull995 @sdetweil
                      @sdetweil man, I never ran sudo.
                      And I still don’t know why the program gives me the error about the config.json file and the dependencies.sh
                      Btw, ./dependencies is no command
                      S S 2 Replies Last reply Reply Quote 0
                        SSkull995 @SSkull995
                        @SSkull995 just to be sure, I ran the program again, the installer. This time with the ./dependencies. Errors+no dependencies directory found
                        • 1 / 4
