    Hello-Lucy installation troubles
    31 Posts 4 Posters 14.6k Views 4 Watching
      SSkull995
      Hi Mykle!
      First, thank you for the response! Second, I just reinstalled Lucy and the whole MM from the beginning. I still get an error while launching MM with Lucy, the pocket sphinx-continuous module is missing. I tried to install it via npm, but nothing. I do not know if I need to install it in a specific directory, like the Hello-Lucy one, or not.
      For the microphone let’s see because I made a change, but until the module starts I cannot see if it is working or not.
      What do you suggest to do now? I follow the guide, step by step, I really do not know what is missing right now.
      Many thanks and have a nice day!
        sdetweil @SSkull995
        @SSkull995 pocketsphinx is installed by the installers/dependencies.sh script
        YOU have to run that manually, as the readme says
        S 3 Replies Last reply Reply Quote 0
          SSkull995 @sdetweil
          @sdetweil hey man, as I wrote I already ran the dependencies.sh in the installer directory. I have the log, everything went fine.
          Still don’t have the module in the system
            SSkull995 @sdetweil
            @sdetweil So I just ran again the installer, weird thing happens. I don’t know why, the package.json is not present in the directory. So this message comes up:
            npm WARN saveError ENOENT: no such file or directory, open ‘/root/pocketsphinx/package.json’
            npm WARN enoent ENOENT: no such file or directory, open ‘/root/pocketsphinx/package.json’
            npm WARN pocketsphinx No description
            npm WARN pocketsphinx No repository field.
            npm WARN pocketsphinx No README data
            npm WARN pocketsphinx No license field.
            That is why I don’t have it installed! Should I generate a random package.json with the npm init command?
              SSkull995 @sdetweil
              This is the output error when I run npm start. I generated the config.json with the npm init, no more errors during dependencies installation.
              [17:54:16.999] [ERROR] App threw an error during load
              [17:54:17.000] [ERROR] Error: Cannot find module ‘pocketsphinx-continuous’
              at Module._resolveFilename (internal/modules/cjs/loader.js:602:15)
              at Function.Module._resolveFilename (/home/pi/MM/node_modules/electron/dist/resources/electron.asar/common/reset-search-paths.js:35:12)
              at Function.Module._resolveFilename (/home/pi/MM/node_modules/module-alias/index.js:49:29)
              at Function.Module._load (internal/modules/cjs/loader.js:528:25)
              at Module.require (internal/modules/cjs/loader.js:658:17)
              at require (internal/modules/cjs/helpers.js:20:18)
              at Object. (/home/pi/MM/modules/Hello-Lucy/node_helper.js:2:13)
              at Object. (/home/pi/MM/modules/Hello-Lucy/node_helper.js:410:3)
              at Module._compile (internal/modules/cjs/loader.js:711:30)
              at Object.Module._extensions…js (internal/modules/cjs/loader.js:722:10)
              [17:54:17.002] [LOG] Whoops! There was an uncaught exception…
              [17:54:17.002] [ERROR] { Error: Cannot find module ‘pocketsphinx-continuous’
              at Object.Module._extensions…js (internal/modules/cjs/loader.js:722:10) code: ‘MODULE_NOT_FOUND’ }
              There still is this:
              [STEP 3/5] Installing pocketsphinx | Done
              [STEP 4/5] Exporting paths
              [STEP 4/5] Exporting paths | Done
              [STEP 5/5] Installing npm dependencies
              dependencies.sh: line 89: cd: /root/MagicMirror/modules/Hello-Lucy: No such file or directory
              Why no directory in root? Many thanks and sorry!
                sdetweil @SSkull995
                @SSkull995 you have to
                cd ~/MagicMirror/modules/MMM-Hello-Lucy/installers
                ./dependencies.sh
                  AND NOT sudo
                  And logged on as normal user, not root
                    SSkull995 @sdetweil
                    @sdetweil man, I never ran sudo.
                    And I still don’t know why the program gives me the error about the config.json file and the dependencies.sh
                    Btw, ./dependencies is no command
                    S S 2 Replies Last reply Reply Quote 0
                      SSkull995 @SSkull995
                      @SSkull995 just to be sure, I ran the program again, the installer. This time with the ./dependencies. Errors+no dependencies directory found
                        sdetweil @SSkull995
                        @SSkull995 did u look in the folder?
                        It’s ./dependencies.sh
                        The only file in the module/installers folder
                          we may have to start over, as I have no idea what ‘installer’ u have been running or how
                          rm -rf MMM-Hello-Lucy
                          Then git clone Mykles repo
                          cd MMM-Hello-Lucy
                          cd installers
                          ./dependencies.sh
                          cd ..
                          npm install
                            SSkull995 @sdetweil
                            @sdetweil actually I have dependencies.sh, because the ./ makes it invisible even if it was there. Typing ls in installers makes me see the normal dependencies.sh
                              sdetweil @SSkull995
                              @SSkull995 but it is not in the path, do you have to use ./ to select it
                              • Mykle1M
                                From the readme
                                Please complete all 3
                                Open a terminal.
                                git clone https://github.com/mykle1/Hello-Lucy into the ~/MagicMirror/modules directory
                                Then
                                cd Hello-Lucy/installers
                                Then
                                bash dependencies.sh
                                  SSkull995
                                  I can see I did not really explained myself, and I am sorry for that. I did the three passages of yours in the readme, and after reinstalling everything now it does not show me any error during installation! Yes!
                                  BUT, now I run MagicMirror with the module installed and put in the config.js, and this message comes up:
                                  [15:12:13.980] [ERROR] WARNING! Could not validate config file. Starting with default configuration. Please correct syntax errors at or above this line: SyntaxError: Unexpected token ] in JSON at position 6643
                                  This occurs only when I put the module in config.js, but I don’t know where the error is, what is the JSON file?
                                  • Mykle1M
                                    Mykle1 Project Sponsor Module Developer @SSkull995
                                    @SSkull995 said in Hello-Lucy installation troubles:
                                    I see. I just did an install on a new machine and encountered the same error. I’m looking into it. Even my working Lucy installation is suffering the same error. Weird.
                                    • Mykle1M
                                      First, forgive me. This entire issue was my fault.
                                      I recently added some defaults to the checkCommands.json file and left a trailing comma at the end of the file. I’ve corrected the problem, tested it and pushed the corrected file to the repo. To clear the SyntaxError: Unexpected token ] in JSON at position 6643 error, following this instruction.
                                      Do a git pull in the Hello-Lucy directory.
                                      Please advise on the result. :-)
                                        SSkull995 @Mykle1
                                        @Mykle1 Perfect! I will do it right now, let me just boot my raspi. Many thanks and sorry once more, I was into solving this problem, but I could not figure out where the json was ahah!
                                          SSkull995 @Mykle1
                                          @Mykle1 You are the man! Now it works without problems! I just can’t get my intro .mp3 work, but that is simple fix. Many thanks Mykle! Have a nice day and sorry for the problems :)
                                            SSkull995
                                            Ok so, troubles again sorry! I just restarted MM and now Lucy starts but does not hide my modules and does not get the starting phrase. The microphone is working as the speaker, and the modules are the same as before.
                                            No clue why this occurs, no errors during MM startup
                                            Edit:
                                            I notice that the intro voice starts, as well as the mic icon and the string “Say Hello Lucy”. However, all my modules are there, as the program does not hide them, and the start phrase is not recognised. I just used alsamixer to check the card number, which matches the config.js one. Further, I tried to record myself and the microphone works without problems, I can clearly hear my voice and the hello Lucy phrase.
                                            Maybe something in the program is still making some troubles? Many thanks again Mykle!
                                            So many edit:
                                            Now when I start the MM, the microphone blinks barred, like no microphone. And it’s stated “Command Please”. It is weird, because I launched it and it froze on the “command” and no mic and no welcome phrases. Sometimes it starts tho, without really a scheme
