    Starting my project
    6 Posts 5 Posters 3.7k Views 4 Watching
      paulofernandesjr
      Hi guys, I would like to know if what is in my mind is correct.
      To start my project I need a Laptop Monitor right?
      paviroP 1 Reply Last reply Reply Quote 0
      • Wilco89W Offline
        Wilco89
        I’m using a normal Screen, 27".
        • paviroP Offline
          paviro @paulofernandesjr
          @paulofernandesjr a laptop monitor might be complicated to connect a Pi to. Most of use just use a simple desktop monitor and remove it’s housing :)
          – The Doctor
          • MitchfarinoM Offline
            Mitchfarino Module Developer
            I’m using this - http://www.iiyama.com/gb_en/products/prolite-x2775hds-1/
              paulofernandesjr
              nice!
              Another question, what do you think about install a small monitor on the top of the mirror?
              KirAsh4K 1 Reply Last reply Reply Quote 0
              • KirAsh4K Offline
                KirAsh4 Moderator @paulofernandesjr
                @paulofernandesjr, you can install your monitor any which way you want, it’s your project to build and customize. If that’s the easier path to go, then by all means, go with it. Displaying MM on a regular monitor without a two-way mirror in front of that is perfectly fine. My development setup is exactly that, a 27" monitor rotated vertically sitting on my desk with an rPi connected to it. You can just as easy take a 7" Lilliput monitor and stick it ON an existing mirror.
