    Weather
    13 Posts 4 Posters 3.9k Views 4 Watching
    • BKeyportB Offline
      BKeyport Module Developer
      https://github.com/cowboysdude/MMM-NOAA has install instructions - then you just delete the section with the “weather” module in it to get rid of it.
        Peter Leemon
        I’d also love to install cowboysdud/MMM-NOAA3 inot magic mirror have tried but only thing on screen was “loading …” and nothing ended deleting it and staying with sample one but would love to have the color icons as well as local hourly rain information, just dont know how to do this, yet
          Mykle1 Project Sponsor Module Developer @Peter Leemon
          @Peter-Leemon
          After you cloned the repo did you cd MMM-NOAA3 and then run npm install ? Can you post your config entry for NOAA3 here (in a code block) so I can take a look at it for you? I’ve been using this module for quite some time. It is my favorite weather module (besides my own). I should be able to help you get it up and running.
            Peter Leemon @Mykle1
            @Mykle1 yes i did how do i do find and do that thanks?
              @Peter-Leemon
              In your config.js file. One of the entries you should have made is for MMM-NOAA3. Copy just that entry and paste it here in the topic. The 5th icon from the right above the post window is the code block icon. Looks like this </>. Click it and paste where it tells you.
                @Mykle1 }
                module: ‘MMM-NOAA3’,
                position: ‘top_right’,
                provider: “Darksky”, // From list above
                apiKey: “XXXXXXXX”, // From one of the providers listed above
                airKey: “XXXXXXXXX”,
                css: “NOAA3”, // THIS MUST CONTAIN A CSS STYLE NAME
                userlat: “-XXXXX”, //MUST HAVE BOTH
                userlon: “XXXXXXX” //MUST HAVE BOTH
                at this point its not loading at all its coming up with the “Create a config file” screen
                  @Peter-Leemon
                  Your entry MUST start with an open curly bracket { Yours does not.
                  My “darksky” is all lower case.
                  Verify your api keys and userlat and userlng
                  I suggest you use my entry, or alter yours to mimic mine (exactly) and enter your keys and location
                              disabled: false,
                              module: 'MMM-NOAA3',
                              position: 'top right',
                                  provider: "darksky",
                                  apiKey: "YOUR apiKey",
                                  airKey: "YOUR airKey", // IF you want Air Quality Index
                                  css: "NOAA5",
                                  userlat: "42.xxx",
                                  userlon: "-72.xxx"
                    Peter Leemon
                    Awesome that got it working thanks heaps can the module also display hourly or daily rainfall as well?
                      @Peter-Leemon
                      I just verified. The module fails if the provider Darksky is a capital. It must be lower case
                        @Peter-Leemon
                        I don’t know. You would have to check the documentation at the repo.
